Topic: Can the software uncompress the files with song titles as the filename (Read 1788 times) previous topic - next topic
  • Pickngrin
I have limited experience with FLAC, but have downloaded some live shows in this format.  Using the FLAC Frontend, the files are decompressed with filenames along the lines of artist-date-disc x-trackx.  Is it possible to have the program rename the files with the actual song titles (eg, based on info in the tags)?
  • Laemtao
I'm not sure about the FLAC Frontend, but fb2k has a nice file renamer that can rename based on tags.
  • Pickngrin
Thanks.  I didn't know what fb2k was (I'm new to this forum) until I just Googled and downloaded it.  Is the renamer built-in or is it a plug-in?
  • SamHain86
It is a built in ability. Here is a sample/simple way you to rename the files:
\%genre%\%album artist%\%album%\['['%track%'] ']%title%
So if you have the first track of an album called Introduction by Pearl Jam, it would rename the file "[01] Introduction.flac" and move it into the folder "\Rock\Pearl Jam\Live Album\"
Those [] indicate that if the item within it exists, it will put it there. For instance if that didn't have a track number, then it would have named the file: Introduction.flac
Others here have far more sophisticated naming scripts. I am new to this stuff and know nothing of programming.
  • Last Edit: 19 February, 2007, 09:44:07 PM by SamHain86
OP can't edit initial post when a solution is determined  :'-(
