Topic: foo_ui_panels (Read 1319347 times) previous topic - next topic
foo_ui_panels
A UI with the ability to position/show/hide panels through titleformatting.
This is beta and a lot of stuff hasn't been refined/implemented so backups are needed. However, it works well for me (with very limited testing).
You can download it here
Please see the user's guide for setup and frequently asked questions, and the command reference for documentation and help. (thanks to the maintainers).
this is the code for the screenshot:
foo_ui_panels
Crash on start up under Win xp 64 pro :
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00462223h
Access violation, operation: read, address: 00000000h
Call path:
entry=>app_mainloop=>titleformat_object::run
Code bytes (00462223h):
004621E3h:  47 08 EB 02 8B C2 33 DB 80 3C 18 00 74 06 43 83
004621F3h:  FB FF 72 F4 83 7F 0C 00 76 03 8B 57 08 8B 46 08
00462203h:  8B 4E 04 8B 7D 0C 8D 75 0B 56 8D 75 C4 56 53 52
00462213h:  8D 55 D8 C7 45 D8 F4 47 4C 00 89 7D DC 89 45 E0
00462223h:  8B 01 52 FF 50 04 83 4D FC FF 88 45 0F 6A 00 33
00462233h:  DB 8D 45 C8 E8 91 5A FA FF 38 5D 0F 74 05 8A 45
00462243h:  0B EB 0F 8B 07 6A FF 68 24 47 4C 00 8B CF FF 10
00462253h:  32 C0 8B 4D F4 5F 5E 5B 64 89 0D 00 00 00 00 C9
Stack (002DEC88h):
002DEC68h:  00000000 00000000 00000000 00000000
002DEC78h:  00000000 00000000 00000000 00000000
002DEC88h:  02CCDF10 00000005 002DECA4 002DECEB
002DEC98h:  02CCDE50 002DF014 00000000 004C4814
002DECA8h:  02CCDF20 00000001 00000001 00000001
002DECB8h:  004C47F4 002DF014 004DF58C 02CEADD4
002DECC8h:  002DF014 002DECFC 00000014 002DED0C
002DECD8h:  004AEB33 00000001 002DED18 00462F66
002DECE8h:  002DECFC 002DF014 02BE5234 002DED44
002DECF8h:  0000001D 00000000 00000000 004DF58C
002DED08h:  00000013 002DF904 004AB15C 00000001
002DED18h:  002DF910 02B65A45 00000000 002DF014
002DED28h:  004DF58C 6534D473 00000000 000800E8
002DED38h:  02BE5234 002DED24 02BE5234 00000000
002DED48h:  7D9709EE 00000000 00000000 000001EC
002DED58h:  000001D7 000800E8 00000000 00000000
002DED68h:  6601DB0E 00C00000 02CCDE50 00000000
002DED78h:  060108F8 7D9474B6 7D9B0324 00000020
002DED88h:  002DEDC4 7D947C84 7D947C65 02BE5234
002DED98h:  000000C5 0000011C 00000001 00000001
Registers:
EAX: 004DF58C, EBX: 00000005, ECX: 00000000, EDX: 002DECB8
ESI: 002DECA4, EDI: 002DF014, EBP: 002DECE0, ESP: 002DEC88
Crash location: "foobar2000", loaded at 00400000h - 004F3000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7D600000h - 7D6F0000h
kernel32                        loaded at 7D4C0000h - 7D5F0000h
COMCTL32                        loaded at 7DBD0000h - 7DCD3000h
msvcrt                          loaded at 77BA0000h - 77BFA000h
ADVAPI32                        loaded at 77F50000h - 77FEC000h
RPCRT4                          loaded at 7DA20000h - 7DB00000h
GDI32                            loaded at 7D800000h - 7D890000h
USER32                          loaded at 7D930000h - 7DA00000h
SHLWAPI                          loaded at 77DA0000h - 77DF2000h
SHELL32                          loaded at 7C8D0000h - 7D0D3000h
ole32                            loaded at 77670000h - 777A4000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 762B0000h - 762FA000h
LPK                              loaded at 7DBC0000h - 7DBC9000h
USP10                            loaded at 75490000h - 754F1000h
wbload                          loaded at 50000000h - 50008000h
WBLIND                          loaded at 66000000h - 66092000h
WINMM                            loaded at 76AA0000h - 76ACD000h
UXTHEME                          loaded at 7DF50000h - 7DFC0000h
msimg32                          loaded at 76280000h - 76285000h
wbhelp                          loaded at 66600000h - 66617000h
MSCTF                            loaded at 4B8D0000h - 4B921000h
foo_cdda                        loaded at 02290000h - 022C6000h
foo_converter                    loaded at 022F0000h - 02359000h
foo_custominfo                  loaded at 02380000h - 02405000h
foo_cwb_hooks                    loaded at 02430000h - 0245E000h
foo_dsp_std                      loaded at 02480000h - 024C1000h
foo_freedb2                      loaded at 024F0000h - 02530000h
foo_input_monkey                loaded at 02550000h - 02599000h
foo_input_std                    loaded at 025C0000h - 026D4000h
foo_masstag                      loaded at 02700000h - 02750000h
foo_menu_addons                  loaded at 02770000h - 02780000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_playcount                    loaded at 027A0000h - 027C8000h
foo_rgscan                      loaded at 027F0000h - 02838000h
foo_run                          loaded at 02860000h - 0288B000h
foo_uie_albumart                loaded at 028B0000h - 028E7000h
gdiplus                          loaded at 4DD60000h - 4DF07000h
foo_uie_albumlist                loaded at 02920000h - 0295F000h
foo_uie_single_column_playlist  loaded at 02980000h - 029CA000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
foo_uie_tabs                    loaded at 029E0000h - 02A0A000h
foo_uie_trackinfo_mod            loaded at 02A30000h - 02A8A000h
foo_ui_columns                  loaded at 02AA0000h - 02B3B000h
foo_ui_panels                    loaded at 02B60000h - 02BEF000h
foo_unpack                      loaded at 02C10000h - 02C3E000h
foo_utils                        loaded at 02C60000h - 02C99000h
imagehlp                        loaded at 76C10000h - 76C39000h
dbghelp                          loaded at 6D580000h - 6D628000h
VERSION                          loaded at 77B90000h - 77B98000h
Stack dump analysis:
Address: 004C4814h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C47F4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004DF58Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AEB33h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00462F66h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 02BE5234h, location: "foo_ui_panels", loaded at 02B60000h - 02BEF000h
Symbol: "foobar2000_get_interface" (+000368F4h)
Address: 004AB15Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 02B65A45h, location: "foo_ui_panels", loaded at 02B60000h - 02BEF000h
Address: 7D9709EEh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "IsCharAlphaNumericW" (+0000038Bh)
Address: 6601DB0Eh, location: "WBLIND", loaded at 66000000h - 66092000h
Symbol: "GetWindowsDirectoryA" (+0001B6BEh)
Address: 7D9474B6h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "WindowFromDC" (+000001F9h)
Address: 7D9B0324h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DeviceEventWorker" (+0000E508h)
Address: 7D947C84h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DefWindowProcW" (+0000008Ah)
Address: 7D947C65h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 7D947C68h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DefWindowProcW" (+0000006Eh)
Address: 02B662ECh, location: "foo_ui_panels", loaded at 02B60000h - 02BEF000h
Address: 02B6630Ch, location: "foo_ui_panels", loaded at 02B60000h - 02BEF000h
Address: 7D6215AAh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlTryEnterCriticalSection" (+000002E4h)
Address: 7D61F784h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlAllocateHeap" (+00000126h)
Address: 7DA3E54Ch, location: "RPCRT4", loaded at 7DA20000h - 7DB00000h
Symbol: "I_RpcSend" (+0000049Ah)
Address: 7D61F7ACh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlAllocateHeap" (+0000014Eh)
Address: 7D61F740h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlAllocateHeap" (+000000E2h)
Address: 7DA41949h, location: "RPCRT4", loaded at 7DA20000h - 7DB00000h
Symbol: "I_RpcTransConnectionReallocPacket" (+00000847h)
Address: 7DA41917h, location: "RPCRT4", loaded at 7DA20000h - 7DB00000h
Symbol: "I_RpcTransConnectionReallocPacket" (+00000815h)
Address: 7D61F1F0h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlLeaveCriticalSection" (+00000041h)
Address: 7D61F5E8h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlFreeHeap" (+00000145h)
Address: 7D61F4A3h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlFreeHeap" (+00000000h)
Address: 7D61C824h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "NtWaitForSingleObject" (+00000015h)
Address: 7D4D8C46h, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "WaitForSingleObjectEx" (+00000088h)
Address: 7D4D8C6Bh, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "WaitForSingleObjectEx" (+000000ADh)
Address: 7D620304h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlNtStatusToDosError" (+0000002Fh)
Address: 7D620309h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlNtStatusToDosError" (+00000034h)
Address: 7D61CD1Ch, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "NtFsControlFile" (+00000015h)
Address: 7D4D8988h, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "MulDiv" (+00000175h)
Address: 7D61F63Dh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlGetNtGlobalFlags" (+00000038h)
Address: 7D61F5C9h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlFreeHeap" (+00000126h)
Address: 7D61F5E5h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlFreeHeap" (+00000142h)
Address: 7D61F1AFh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlLeaveCriticalSection" (+00000000h)
Address: 02BD44E8h, location: "foo_ui_panels", loaded at 02B60000h - 02BEF000h
Symbol: "foobar2000_get_interface" (+00025BA8h)
Address: 7D6212BDh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlInterlockedPushEntrySList" (+00000010h)
Address: 7D6212A4h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlQueryDepthSList" (+0000001Eh)
Address: 7D6A00F8h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "NlsMbOemCodePageTag" (+00000058h)
Address: 7DA30472h, location: "RPCRT4", loaded at 7DA20000h - 7DB00000h
Address: 7DA30449h, location: "RPCRT4", loaded at 7DA20000h - 7DB00000h
Address: 7D4D90BDh, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "LocalAlloc" (+00000000h)
Address: 7DA3B9E5h, location: "RPCRT4", loaded at 7DA20000h - 7DB00000h
Symbol: "I_RpcTransGetThreadEvent" (+00001080h)
Address: 7DA379B9h, location: "RPCRT4", loaded at 7DA20000h - 7DB00000h
Symbol: "I_RpcFreeBuffer" (+00000010h)
Address: 7D4D9059h, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "LocalFree" (+00000000h)
Address: 7DAC01E9h, location: "RPCRT4", loaded at 7DA20000h - 7DB00000h
Symbol: "NdrClientCall2" (+000001E4h)
Address: 7D628F34h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlLengthSid" (+00000000h)
Address: 77F61908h, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "RegEnumValueW" (+0000042Ah)
Address: 77F6537Eh, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "CopySid" (+000009F9h)
Address: 77F618B8h, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "RegEnumValueW" (+000003DAh)
Address: 7D4D9084h, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "LocalFree" (+0000002Bh)
Address: 7D4D9097h, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "LocalFree" (+0000003Eh)
Address: 7D4D90A0h, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "LocalFree" (+00000047h)
Address: 77F7DAE0h, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "RegSetValueA" (+00000406h)
Address: 77F7DAF6h, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "RegSetValueA" (+0000041Ch)
Address: 77F63048h, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "LsaOpenPolicy" (+000000F1h)
Address: 77F61952h, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "RegEnumValueW" (+00000474h)
Address: 7D61F494h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlGetLastWin32Error" (+00000000h)
Address: 7D61F47Ah, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlSetLastWin32Error" (+00000000h)
Address: 4B8D1D3Ch, location: "MSCTF", loaded at 4B8D0000h - 4B921000h
Address: 4B8DDDF1h, location: "MSCTF", loaded at 4B8D0000h - 4B921000h
Symbol: "TF_CreateLangBarItemMgr" (+00001434h)
Address: 4B8DDE0Ah, location: "MSCTF", loaded at 4B8D0000h - 4B921000h
Symbol: "TF_CreateLangBarItemMgr" (+0000144Dh)
Address: 7D633A8Ch, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlValidAcl" (+0000006Ch)
Address: 77F7DC5Eh, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "RegSetValueA" (+00000584h)
Address: 77F5DD15h, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "ConvertStringSecurityDescriptorToSecurityDescriptorW" (+000009BFh)
Address: 10000000h, location: "shared", loaded at 10000000h - 10029000h
Address: 4B9161A8h, location: "MSCTF", loaded at 4B8D0000h - 4B921000h
Symbol: "TF_GetInputScope" (+0000478Fh)
Address: 77FC23E0h, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "ElfFlushEventLog" (+0000DF59h)
Address: 77F5D59Bh, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "ConvertStringSecurityDescriptorToSecurityDescriptorW" (+00000245h)
Address: 77F5D5A6h, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "ConvertStringSecurityDescriptorToSecurityDescriptorW" (+00000250h)
Address: 7D4D0500h, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Address: 77F5D4E3h, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "ConvertStringSecurityDescriptorToSecurityDescriptorW" (+0000018Dh)
Address: 77F5D4F1h, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "ConvertStringSecurityDescriptorToSecurityDescriptorW" (+0000019Bh)
Address: 77F5D395h, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "ConvertStringSecurityDescriptorToSecurityDescriptorW" (+0000003Fh)
Address: 77F7DCCFh, location: "ADVAPI32", loaded at 77F50000h - 77FEC000h
Symbol: "ConvertStringSecurityDescriptorToSecurityDescriptorA" (+00000067h)
Address: 4B8D3C77h, location: "MSCTF", loaded at 4B8D0000h - 4B921000h
Address: 7D61CEB2h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "NtCreateSection" (+00000012h)
Address: 7D4DA889h, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "CreateFileMappingW" (+00000093h)
Address: 7D4DA8A3h, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "CreateFileMappingW" (+000000ADh)
Address: 7D61CB81h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "NtMapViewOfSection" (+00000012h)
Address: 7D4DA77Ah, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "MapViewOfFileEx" (+0000005Fh)
Address: 7D61F65Eh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7D61CDC1h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "NtOpenEvent" (+00000012h)
Address: 7D50398Bh, location: "kernel32", loaded at 7D4C0000h - 7D5F0000h
Symbol: "OpenEventW" (+0000005Ah)
Address: 7D9494AEh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetClassNameW" (+00000057h)
Address: 7D949544h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DefWindowProcA" (+0000008Dh)
Address: 7D94951Eh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DefWindowProcA" (+00000067h)
Address: 4B8DCFC3h, location: "MSCTF", loaded at 4B8D0000h - 4B921000h
Symbol: "TF_CreateLangBarItemMgr" (+00000606h)
Address: 7D947A69h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+000000E1h)
Address: 7D9479B2h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+0000002Ah)
Address: 7D9479BBh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+00000033h)
Address: 02BCD57Ah, location: "foo_ui_panels", loaded at 02B60000h - 02BEF000h
Symbol: "foobar2000_get_interface" (+0001EC3Ah)
Address: 02B64427h, location: "foo_ui_panels", loaded at 02B60000h - 02BEF000h
Address: 7D9472F8h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "WindowFromDC" (+0000003Bh)
Address: 7D9475E3h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "WindowFromDC" (+00000326h)
Address: 02B643C0h, location: "foo_ui_panels", loaded at 02B60000h - 02BEF000h
Address: 7D947578h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "WindowFromDC" (+000002BBh)
Address: 7D9547E0h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetCursorFrameInfo" (+000000AAh)
Address: 7D947600h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "WindowFromDC" (+00000343h)
Address: 7D947A3Bh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+000000B3h)
Address: 4B911D40h, location: "MSCTF", loaded at 4B8D0000h - 4B921000h
Symbol: "TF_GetInputScope" (+00000327h)
Address: 4B8D54C0h, location: "MSCTF", loaded at 4B8D0000h - 4B921000h
Symbol: "DllGetClassObject" (+00000BE1h)
Address: 7D947A50h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+000000C8h)
Address: 7D947AEEh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+00000166h)
Address: 7D61EA0Eh, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "KiUserCallbackDispatcher" (+0000002Eh)
Address: 7D61E9C0h, location: "ntdll", loaded at 7D600000h - 7D6F0000h
Symbol: "KiUserApcDispatcher" (+00000048h)
Address: 7D9479EAh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "GetWindowLongW" (+00000062h)
Address: 7D953909h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "PrivateExtractIconsW" (+000009BBh)
Address: 7D94918Eh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "WaitMessage" (+00000043h)
Address: 7D94C6ECh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DestroyWindow" (+00000000h)
Address: 7D956BFAh, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "IsDialogMessageW" (+0000009Eh)
Address: 7D947838h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "WindowFromDC" (+0000057Bh)
Address: 7D947858h, location: "USER32", loaded at 7D930000h - 7DA00000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 004301ADh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002DD2h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 004C0560h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430CF3h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BC44Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C70FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C70E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E3E80h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
Standard DSP array 1.0  (foo_dsp_std)
CD Audio Decoder 2.1.1  (foo_cdda)
Album Art Panel 0.2.5.1  (foo_uie_albumart)
Converter 1.0.1  (foo_converter)
FLAC Decoder 1.1.0  (foo_input_std)
WMA Decoder 1.1  (foo_input_std)
foo_custominfo 0.1.2  (foo_custominfo)
cwbowron's title format hooks 1.0.13 [Oct  2 2006 - 09:06:52]  (foo_cwb_hooks)
RAR reader 1.1  (foo_unpack)
Track info panel mod 0.7.1 beta [Oct 24 2006 - 22:48:54]  (foo_uie_trackinfo_mod)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Playback Statistics 1.3.1  (foo_playcount)
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
freedb Tagger 0.5.2a  (foo_freedb2)
ZIP/GZIP reader 1.0  (foo_unpack)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Menu Addons 0.2.2  (foo_menu_addons)
foobar2000 core 0.9.4.2  (Core)
Masstagger 1.6  (foo_masstag)
Columns UI 0.1.3 beta 1v5  (foo_ui_columns)
Run services 0.3.2  (foo_run)
PanelsUI 0.1.0 beta [Feb  5 2007 - 23:51:53]  (foo_ui_panels)
Monkey's Audio decoder 2.1.1  (foo_input_monkey)
Playlist tools 0.5.7  (foo_utils)
Single Column Playlist Display 0.5.4 beta [Nov 24 2006 - 21:31:48]  (foo_uie_single_column_playlist)
Favourite artist:CD-R
Favourite album:700MB
foo_ui_panels
crash at start up after choosing panels_ui
os: win xp sp2
thank you for your work
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00461E0Eh
Call path:
Code bytes (00461E0Eh):
00461DCEh:  76 05 8B 41 08 EB 02 8B C2 33 FF 38 1C 38 74 06
00461DDEh:  47 83 FF FF 72 F5 39 59 0C 76 03 8B 51 08 8B 45
00461DEEh:  08 8B 48 08 8B 75 0C 8D 5D FF 53 57 89 4D F8 8B
00461DFEh:  48 04 52 8D 55 F0 C7 45 F0 CC 47 4C 00 89 75 F4
00461E0Eh:  8B 01 52 FF 10 84 C0 75 10 6A FF 88 45 FF 8B 06
00461E1Eh:  68 F8 46 4C 00 8B CE FF 10 8A 45 FF 5F 5E 5B C9
00461E2Eh:  C2 08 00 55 8B EC 53 56 8B 75 0C 8B 06 57 8B F9
00461E3Eh:  8B CE FF 50 10 8B 4F 08 56 FF 75 08 89 45 0C 8B
Stack (0012E68Ch):
0012E66Ch:  00000000 0000000C BC669618 0012F42C
0012E67Ch:  0000903D B860CB60 852EC218 B860CD38
0012E68Ch:  028DFBC0 00000006 0012E6B3 00000000
0012E69Ch:  028E65B8 00000002 004C47CC 0012EA44
0012E6ACh:  004DF594 008E0DF0 0012E6D4 00463681
0012E6BCh:  0012E72C 0012EA44 028E0120 0012EA44
0012E6CCh:  00000002 008E65B8 0012E6F0 00461E52
0012E6DCh:  0012E72C 0012EA44 00000000 028E66A8
0012E6ECh:  00000002 0012E710 00463681 0012E72C
0012E6FCh:  00000000 028E0DF0 0012EA44 00000000
0012E70Ch:  008E66A8 0012E748 00462CDD 0012E72C
0012E71Ch:  0012EA44 01AB5234 0012E774 0000001D
0012E72Ch:  00000000 00000000 004DF594 00000013
0012E73Ch:  0012F334 004AAF01 00000001 0012F340
0012E74Ch:  01A35A45 00000000 0012EA44 004DF594
0012E75Ch:  9E4783EB 00000000 003D009E 01AB5234
0012E76Ch:  21220020 01AB5234 00000000 00000000
0012E77Ch:  00000000 00000000 000001EC 000001D5
0012E78Ch:  003D009E 00000000 00000000 01914714
0012E79Ch:  039DF290 028E0DF0 039DF290 0401303E
Registers:
EAX: 0012E72C, EBX: 0012E6B3, ECX: 00000000, EDX: 0012E6A4
ESI: 0012EA44, EDI: 00000006, EBP: 0012E6B4, ESP: 0012E68C
Loaded modules:
ntdll                            loaded at 7C920000h - 7C9B5000h
kernel32                        loaded at 7C800000h - 7C91D000h
COMCTL32                        loaded at 77180000h - 77283000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77DA0000h - 77E47000h
RPCRT4                          loaded at 77E50000h - 77EE1000h
GDI32                            loaded at 77EF0000h - 77F37000h
USER32                          loaded at 77D10000h - 77D9E000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
SHELL32                          loaded at 7D590000h - 7F005000h
ole32                            loaded at 76990000h - 76AD3000h
comdlg32                        loaded at 76320000h - 76367000h
IMM32                            loaded at 76300000h - 7631D000h
LPK                              loaded at 621F0000h - 621F9000h
USP10                            loaded at 73FA0000h - 7400B000h
uxtheme                          loaded at 5A410000h - 5A447000h
MSCTF                            loaded at 74680000h - 746CB000h
StylerHelper                    loaded at 00AA0000h - 00AAE000h
MFC42                            loaded at 73D30000h - 73E2E000h
MFC42LOC                        loaded at 611C0000h - 611C9000h
msctfime                        loaded at 73640000h - 7366E000h
foo_abx                          loaded at 00B40000h - 00B73000h
foo_albumlist                    loaded at 00BA0000h - 00BE7000h
OLEAUT32                        loaded at 770F0000h - 7717C000h
foo_albumlist_xconfig            loaded at 00C10000h - 00C31000h
VERSION                          loaded at 77BD0000h - 77BD8000h
foo_audioscrobbler              loaded at 00C50000h - 00C87000h
WS2_32                          loaded at 71A10000h - 71A27000h
WS2HELP                          loaded at 71A00000h - 71A08000h
foo_autoplaylist                loaded at 00CF0000h - 00D20000h
foo_cdda                        loaded at 00D40000h - 00D76000h
foo_converter                    loaded at 00DA0000h - 00E09000h
foo_cwb_hooks                    loaded at 00E30000h - 00E5E000h
foo_default_videoplayer          loaded at 00E80000h - 00E8A000h
foo_dockable_panels              loaded at 00EB0000h - 00EE4000h
foo_dsp_std                      loaded at 00F10000h - 00F51000h
foo_freedb2                      loaded at 00F80000h - 00FC0000h
foo_input_monkey                loaded at 00FE0000h - 0102A000h
foo_input_std                    loaded at 01050000h - 01164000h
foo_lyricsdb                    loaded at 01190000h - 011AE000h
WININET                          loaded at 011C0000h - 01289000h
Normaliz                        loaded at 01290000h - 01299000h
iertutil                        loaded at 5DCA0000h - 5DCE5000h
foo_masstag                      loaded at 014B0000h - 01500000h
foo_masstag_addons              loaded at 01520000h - 01529000h
foo_msnalt                      loaded at 01540000h - 01559000h
foo_notitlebar                  loaded at 01580000h - 01588000h
foo_out_asio                    loaded at 015A0000h - 015CE000h
foo_rgscan                      loaded at 015F0000h - 01638000h
foo_uie_albumart                loaded at 01660000h - 01697000h
gdiplus                          loaded at 4AEF0000h - 4B093000h
foo_uie_albumlist                loaded at 016D0000h - 0170D000h
foo_uie_playlists_dropdown      loaded at 01730000h - 0176A000h
foo_uie_quicksearch              loaded at 01790000h - 017D6000h
foo_uie_single_column_playlist  loaded at 01800000h - 0184C000h
foo_uie_tabs                    loaded at 01860000h - 01889000h
foo_uie_trackinfo                loaded at 018B0000h - 018DE000h
foo_uie_trackinfo_mod            loaded at 01900000h - 01956000h
foo_ui_columns                  loaded at 01970000h - 01A07000h
foo_ui_panels                    loaded at 01A30000h - 01ABF000h
foo_ui_std                      loaded at 01AE0000h - 01B37000h
foo_unpack                      loaded at 01B60000h - 01B8E000h
ctagent                          loaded at 01DE0000h - 01DE6000h
mswsock                          loaded at 719B0000h - 719EE000h
DNSAPI                          loaded at 76EF0000h - 76F17000h
rasadhlp                        loaded at 76F90000h - 76F96000h
hnetcfg                          loaded at 605B0000h - 60605000h
wshtcpip                        loaded at 719F0000h - 719F8000h
imagehlp                        loaded at 76C60000h - 76C88000h
DBGHELP                          loaded at 68CC0000h - 68D61000h
Address: 004C47CCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004DF594h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00463681h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00461E52h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00462CDDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01AB5234h, location: "foo_ui_panels", loaded at 01A30000h - 01ABF000h
Address: 004AAF01h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01A35A45h, location: "foo_ui_panels", loaded at 01A30000h - 01ABF000h
Address: 01914714h, location: "foo_uie_trackinfo_mod", loaded at 01900000h - 01956000h
Address: 019077D1h, location: "foo_uie_trackinfo_mod", loaded at 01900000h - 01956000h
Address: 7C9305C8h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C930551h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C93056Dh, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 78134B6Eh, location: "MSVCR80", loaded at 78130000h - 781CB000h
Symbol: "free" (+00000000h)
Address: 7C92EE18h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "strchr" (+00000117h)
Address: 7C930570h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 78134C3Bh, location: "MSVCR80", loaded at 78130000h - 781CB000h
Symbol: "free" (+000000CDh)
Address: 78134C5Ah, location: "MSVCR80", loaded at 78130000h - 781CB000h
Symbol: "free" (+000000ECh)
Address: 7C930732h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C931538h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C931596h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9306EBh, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Address: 7C9305D4h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Address: 7C930738h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 01AA44E8h, location: "foo_ui_panels", loaded at 01A30000h - 01ABF000h
Address: 7C9306ABh, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C809A09h, location: "kernel32", loaded at 7C800000h - 7C91D000h
Symbol: "lstrlenW" (+00000000h)
Address: 5A4174ECh, location: "uxtheme", loaded at 5A410000h - 5A447000h
Symbol: "GetThemeSysColor" (+00000332h)
Address: 77D194BEh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 77D1B42Dh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+000000F1h)
Address: 77D1B3F9h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 77D18BD9h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 77D70088h, location: "USER32", loaded at 77D10000h - 77D9E000h
Address: 77D1B3CCh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+00000090h)
Address: 77D1B3A7h, location: "USER32", loaded at 77D10000h - 77D9E000h
Address: 77D40467h, location: "USER32", loaded at 77D10000h - 77D9E000h
Address: 77D1B3B0h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 01A362ECh, location: "foo_ui_panels", loaded at 01A30000h - 01ABF000h
Address: 01A3630Ch, location: "foo_ui_panels", loaded at 01A30000h - 01ABF000h
Address: 77EFF45Fh, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GetCharWidthW" (+0000015Ch)
Address: 77EFF3CEh, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GetCharWidthW" (+000000CBh)
Address: 77EFE24Fh, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GetCharABCWidthsW" (+0000006Dh)
Address: 77F1D74Ah, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GetCharABCWidthsI" (+0000001Bh)
Address: 73FB5DCEh, location: "USP10", loaded at 73FA0000h - 7400B000h
Symbol: "ScriptApplyDigitSubstitution" (+0000114Ch)
Address: 7C931414h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "wcsncpy" (+00000985h)
Address: 74684636h, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "DllGetClassObject" (+000002ABh)
Address: 74690455h, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_DllDetachInOther" (+00001625h)
Address: 77D1EB3Eh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "CallNextHookEx" (+0000003Bh)
Address: 746909A4h, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_UninitSystem" (+0000053Bh)
Address: 746909A9h, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_UninitSystem" (+00000540h)
Address: 746BE548h, location: "MSCTF", loaded at 74680000h - 746CB000h
Address: 746909B0h, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_UninitSystem" (+00000547h)
Address: 77D318F4h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "UnhookWinEvent" (+00000077h)
Address: 77D1EA9Eh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "EnableMenuItem" (+0000006Fh)
Address: 77D1EAADh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "EnableMenuItem" (+0000007Eh)
Address: 77D31699h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetOpenClipboardWindow" (+00000037h)
Address: 746908B6h, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_UninitSystem" (+0000044Dh)
Address: 77D318A2h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "UnhookWinEvent" (+00000025h)
Address: 77D3E185h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "User32InitializeImmEntryTable" (+00000E18h)
Address: 77D3E162h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "User32InitializeImmEntryTable" (+00000DF5h)
Address: 00C11365h, location: "foo_albumlist_xconfig", loaded at 00C10000h - 00C31000h
Address: 00C11375h, location: "foo_albumlist_xconfig", loaded at 00C10000h - 00C31000h
Address: 77D188D1h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77D188DAh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 77D18B26h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 01A9D57Ah, location: "foo_ui_panels", loaded at 01A30000h - 01ABF000h
Address: 01A34427h, location: "foo_ui_panels", loaded at 01A30000h - 01ABF000h
Address: 00EB478Ah, location: "foo_dockable_panels", loaded at 00EB0000h - 00EE4000h
Address: 00EB4750h, location: "foo_dockable_panels", loaded at 00EB0000h - 00EE4000h
Address: 77D18734h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D18816h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D18830h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetDC" (+00000169h)
Address: 77D1B4C0h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 77D1B4D0h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D1B50Ch, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C92EAE3h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 77D1B473h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D194D2h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowLongA" (+00000075h)
Address: 77D1B530h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DefWindowProcW" (+000001F4h)
Address: 7469E8FEh, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_CreateCicLoadMutex" (+00007E9Bh)
Address: 77D189F0h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D196C7h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "DispatchMessageA" (+0000000Fh)
Address: 7469EEDEh, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_CreateCicLoadMutex" (+0000847Bh)
Address: 7469F7F8h, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_CheckThreadInputIdle" (+00000703h)
Address: 77D2EF54h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetQueueStatus" (+00000000h)
Address: 7469F8B8h, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_CheckThreadInputIdle" (+000007C3h)
Address: 7469E951h, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_CreateCicLoadMutex" (+00007EEEh)
Address: 7469FDFDh, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_CheckThreadInputIdle" (+00000D08h)
Address: 011C005Dh, location: "WININET", loaded at 011C0000h - 01289000h
Address: 0043492Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00AA5B20h, location: "StylerHelper", loaded at 00AA0000h - 00AAE000h
Symbol: "whiteHook" (+000000B0h)
Address: 77D6AB8Eh, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "GetRawInputDeviceInfoA" (+000000C1h)
Address: 7468F687h, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_DllDetachInOther" (+00000857h)
Address: 77D1D4E4h, location: "USER32", loaded at 77D10000h - 77D9E000h
Symbol: "SetPropW" (+000000BBh)
Version info:
foobar2000 v0.9.4
UNICODE
Additional info:
cwbowron's title format hooks 1.0.14 [Nov  1 2006 - 10:20:44]  (foo_cwb_hooks)
Quick Search Toolbar 2.8k  (foo_uie_quicksearch)
Album List 3.2.0  (foo_albumlist)
Track info panel 0.8  (foo_uie_trackinfo)
Hide Main Title Bar 1.0.0 [May 26 2006 - 09:32:33]  (foo_notitlebar)
Default video player 0.1.2  (foo_default_videoplayer)
foobar2000 core v0.9.4  (Core)
Default User Interface 0.9acc  (foo_ui_std)
Album Art Panel 0.2.5  (foo_uie_albumart)
Album list panel 0.2.1  (foo_uie_albumlist)
Album List XtraConfig 0.1.2  (foo_albumlist_xconfig)
Dockable Panels 1.0.5 [Dec  4 2006 - 09:04:00]  (foo_dockable_panels)
FLAC decoder 1.1.0  (foo_input_std)
ABX Comparator 1.3.1  (foo_abx)
Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]  (foo_uie_trackinfo_mod)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Masstagger Addons 0.2.1  (foo_masstag_addons)
MSN Now Playing (alt) 2.4  (foo_msnalt)
foo_lyricsdb 0.0.7 beta 4  (foo_lyricsdb)
ASIO support 1.2.4  (foo_out_asio)
Single Column Playlist Display 0.5.4 beta [Jan  9 2007 - 15:42:59]  (foo_uie_single_column_playlist)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
Playlists Dropdown 0.5.7.5  (foo_uie_playlists_dropdown)
Tabbed panel modified 0.2.4  (foo_uie_tabs)
Audioscrobbler 1.3.4  (foo_audioscrobbler)
Dark, black, are my remembrances.
        All around me is dark.
        Dark, like, my soul.
        My soul is sad, she's bleeding.
foo_ui_panels
Illegal operation:
Call path:
Stack (0012EB94h):
0012EB74h:  00000000 00000000 0000000C BC681300
0012EB84h:  0012FA98 00009FB5 ED4B1B64 ED4B1D38
0012EB94h:  026F93B0 00000006 0012EBBB 00000000
0012EBA4h:  026FA3A0 00000002 004C47CC 0012EF4C
0012EBB4h:  004DF594 0089EE00 0012EBDC 00463681
0012EBC4h:  0012EC34 0012EF4C 026FC130 0012EF4C
0012EBD4h:  00000003 006FA3A0 0012EBF8 00461E52
0012EBE4h:  0012EC34 0012EF4C 00000000 026FA070
0012EBF4h:  00000003 0012EC18 00463681 0012EC34
0012EC04h:  00000000 0289EE00 0012EF4C 00000000
0012EC14h:  006FA070 0012EC50 00462CDD 0012EC34
0012EC24h:  0012EF4C 02195234 0012EC7C 0000001D
0012EC34h:  00000000 00000000 004DF594 00000013
0012EC44h:  0012F83C 004AAF01 00000001 0012F848
0012EC54h:  02115A45 00000000 0012EF4C 004DF594
0012EC64h:  79C056FB 00000000 00080504 02195234
0012EC74h:  00740075 02195234 00000000 0070004F
0012EC84h:  00000000 00000000 000001EC 000001D9
0012EC94h:  00080504 00000000 00000000 006C006C
0012ECA4h:  00000000 0289EE00 7C9153F5 B5010A9D
Registers:
EAX: 0012EC34, EBX: 0012EBBB, ECX: 00000000, EDX: 0012EBAC
ESI: 0012EF4C, EDI: 00000006, EBP: 0012EBBC, ESP: 0012EB94
Loaded modules:
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F4000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 77D40000h - 77DD0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
comdlg32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
wbsys                            loaded at 66500000h - 6650A000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
MSCTF                            loaded at 74720000h - 7476B000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_albumlist_autoupdate        loaded at 00C60000h - 00C77000h
foo_uie_albumlist                loaded at 00CA0000h - 00CDF000h
foo_ui_columns                  loaded at 00D00000h - 00D97000h
foo_abx                          loaded at 00DC0000h - 00DF3000h
foo_albumlist                    loaded at 00E20000h - 00E67000h
OLEAUT32                        loaded at 77120000h - 771AC000h
foo_autoplaylist                loaded at 00E90000h - 00EC0000h
foo_cdda                        loaded at 00EE0000h - 00F16000h
foo_cmd_playlist                loaded at 00F40000h - 00F58000h
foo_common                      loaded at 00F80000h - 00FBA000h
foo_converter                    loaded at 00FE0000h - 01049000h
foo_cwb_hooks                    loaded at 01070000h - 0109E000h
foo_dbsearch                    loaded at 010C0000h - 0111C000h
foo_discogs                      loaded at 01140000h - 011B2000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
WINMM                            loaded at 76B40000h - 76B6D000h
foo_dockable_panels              loaded at 01260000h - 01294000h
foo_dop                          loaded at 012C0000h - 01315000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_dsp_std                      loaded at 01340000h - 01381000h
foo_dsp_tube                    loaded at 013B0000h - 013D6000h
foo_freedb2                      loaded at 013F0000h - 01430000h
foo_fullscreen                  loaded at 01450000h - 01468000h
foo_input_shorten                loaded at 01490000h - 014BE000h
foo_input_std                    loaded at 014E0000h - 015F4000h
foo_lnk                          loaded at 01620000h - 01639000h
foo_lyricsdb                    loaded at 01660000h - 0167E000h
WININET                          loaded at 771B0000h - 77270000h
Normaliz                        loaded at 71660000h - 71669000h
iertutil                        loaded at 5DCA0000h - 5DCE0000h
foo_masstag                      loaded at 018B0000h - 01900000h
foo_msnalt                      loaded at 01920000h - 0193A000h
foo_notitlebar                  loaded at 01960000h - 01968000h
foo_osd                          loaded at 01980000h - 019B5000h
foo_playcount                    loaded at 019E0000h - 019F4000h
foo_playlist_bind                loaded at 01A10000h - 01A35000h
foo_playlist_manager            loaded at 01A50000h - 01A96000h
foo_playlist_tree                loaded at 01AC0000h - 01B2B000h
foo_pqview                      loaded at 01B50000h - 01B6C000h
foo_random                      loaded at 01B90000h - 01BCF000h
foo_rgscan                      loaded at 01BF0000h - 01C38000h
foo_run                          loaded at 01C60000h - 01C8B000h
foo_sic                          loaded at 01CB0000h - 01D07000h
foo_snap                        loaded at 01E30000h - 01E46000h
foo_tradersfriend                loaded at 01E70000h - 01EAD000h
foo_uie_albumart                loaded at 01ED0000h - 01F07000h
foo_uie_quicksearch              loaded at 01F30000h - 01F78000h
foo_uie_single_column_playlist  loaded at 01FA0000h - 01FEC000h
foo_uie_tabs                    loaded at 02000000h - 02029000h
foo_uie_trackinfo                loaded at 02050000h - 0207E000h
foo_uie_trackinfo_mod            loaded at 020A0000h - 020F7000h
foo_ui_panels                    loaded at 02110000h - 0219F000h
foo_ui_std                      loaded at 021C0000h - 02217000h
foo_unpack                      loaded at 02240000h - 0226E000h
foo_utils                        loaded at 02290000h - 022C9000h
foo_whatsnew                    loaded at 022F0000h - 02320000h
foo_dsp_dolbyhp                  loaded at 02340000h - 02361000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_uie_lyrics                  loaded at 02380000h - 023DE000h
DolbyHph                        loaded at 03120000h - 03215000h
mslbui                          loaded at 605D0000h - 605D9000h
imagehlp                        loaded at 76C90000h - 76CB8000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Address: 02195234h, location: "foo_ui_panels", loaded at 02110000h - 0219F000h
Address: 02115A45h, location: "foo_ui_panels", loaded at 02110000h - 0219F000h
Address: 7C9153F5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFindActivationContextSectionString" (+000000DCh)
Address: 7C97C220h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 020A0018h, location: "foo_uie_trackinfo_mod", loaded at 020A0000h - 020F7000h
Address: 7C915707h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlHashUnicodeString" (+000002A2h)
Address: 7C915A00h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDosApplyFileIsolationRedirection_Ustr" (+0000025Dh)
Address: 7C915A65h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDosApplyFileIsolationRedirection_Ustr" (+000002C2h)
Address: 7C97C2C0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C916999h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlMultiAppendUnicodeStringBuffer" (+0000027Eh)
Address: 7C9169A5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlMultiAppendUnicodeStringBuffer" (+0000028Ah)
Address: 7C90EFE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+000002E2h)
Address: 7C90EF43h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000242h)
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 605D6024h, location: "mslbui", loaded at 605D0000h - 605D9000h
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 605D0000h, location: "mslbui", loaded at 605D0000h - 605D9000h
Address: 7C91691Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlMultiAppendUnicodeStringBuffer" (+00000202h)
Address: 7C916924h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlMultiAppendUnicodeStringBuffer" (+00000209h)
Address: 7C91D369h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "LdrQueryImageFileExecutionOptions" (+00000012h)
Address: 7C91D496h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "LdrQueryImageFileExecutionOptions" (+0000013Fh)
Address: 7C91D4B0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "LdrQueryImageFileExecutionOptions" (+00000159h)
Address: 74720278h, location: "MSCTF", loaded at 74720000h - 7476B000h
Address: 021844E8h, location: "foo_ui_panels", loaded at 02110000h - 0219F000h
Address: 7C910895h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlImageDirectoryEntryToData" (+0000003Fh)
Address: 605D02F2h, location: "mslbui", loaded at 605D0000h - 605D9000h
Address: 7C911B09h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLogStackBackTrace" (+00000025h)
Address: 7C919B3Fh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "towlower" (+000003D3h)
Address: 7C919AEBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "towlower" (+0000037Fh)
Address: 7C91A16Ah, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDoesFileExists_U" (+000000BAh)
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 7C9119E6h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDeleteCriticalSection" (+0000015Ch)
Address: 7C911A24h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDeleteCriticalSection" (+0000019Ah)
Address: 7C97C080h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9119FAh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDeleteCriticalSection" (+00000170h)
Address: 7C911B10h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLogStackBackTrace" (+0000002Ch)
Address: 7C911AD6h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlInitializeCriticalSectionAndSpinCount" (+000000ACh)
Address: 7C97C0A0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 77C2C3CEh, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "free" (+000001B3h)
Address: 7C90E10Eh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "NtQueryPerformanceCounter" (+0000000Ch)
Address: 7C80A43Bh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "QueryPerformanceCounter" (+00000014h)
Address: 605D23C9h, location: "mslbui", loaded at 605D0000h - 605D9000h
Address: 605D242Eh, location: "mslbui", loaded at 605D0000h - 605D9000h
Address: 605D3BFFh, location: "mslbui", loaded at 605D0000h - 605D9000h
Address: 605D3BADh, location: "mslbui", loaded at 605D0000h - 605D9000h
Address: 7C9011A7h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "LdrInitializeThunk" (+00000029h)
Address: 7C91CC06h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "LdrFindResourceDirectory_U" (+000002D1h)
Address: 77D48CC3h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "KillTimer" (+00000081h)
Address: 77D50A2Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CopyImage" (+00000236h)
Address: 7C91C8E4h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "snwprintf" (+00000643h)
Address: 605D4D90h, location: "mslbui", loaded at 605D0000h - 605D9000h
Address: 7C910D5Ch, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+000002CDh)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C90D958h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "ZwEnumerateKey" (+0000000Ch)
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C917CB7h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000002BAh)
Address: 7C917BB0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 74725835h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "DllGetClassObject" (+000014AAh)
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C90D79Fh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "NtCreateSection" (+0000000Ch)
Address: 7C809437h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "CreateFileMappingW" (+000000A9h)
Address: 7C80B920h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "MapViewOfFile" (+0000001Bh)
Address: 7C80995Ah, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Address: 7C910F46h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+000004B7h)
Address: 7C910E91h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000402h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C80996Dh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Address: 747215C0h, location: "MSCTF", loaded at 74720000h - 7476B000h
Address: 7474284Bh, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_CheckThreadInputIdle" (+00003756h)
Address: 7C90DCDFh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "ZwOpenEvent" (+0000000Ch)
Address: 7C8131AAh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "OpenEventW" (+0000006Ah)
Address: 7C81325Ah, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "OpenEventA" (+0000004Eh)
Address: 7C90D592h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "NtClose" (+0000000Ch)
Address: 7C809B8Bh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "CloseHandle" (+00000044h)
Address: 747215D9h, location: "MSCTF", loaded at 74720000h - 7476B000h
Address: 7473F6A5h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_CheckThreadInputIdle" (+000005B0h)
Address: 7473C949h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_CreateCicLoadMutex" (+00005EE6h)
Address: 7473C95Eh, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_CreateCicLoadMutex" (+00005EFBh)
Address: 7473C96Bh, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_CreateCicLoadMutex" (+00005F08h)
Address: 7D1C98FBh, location: "SHELL32", loaded at 7C9C0000h - 7D1D5000h
Address: 7C80261Ah, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "WaitForSingleObjectEx" (+000000DAh)
Address: 7C8025F0h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "WaitForSingleObjectEx" (+000000B0h)
Address: 7C8025F8h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "WaitForSingleObjectEx" (+000000B8h)
Address: 7C802532h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "WaitForSingleObject" (+00000012h)
Address: 7C90E2F1h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "NtReleaseMutant" (+0000000Ch)
Address: 7C8024B7h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "ReleaseMutex" (+00000010h)
Address: 77D48B26h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D488D1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D488DAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 0217D57Ah, location: "foo_ui_panels", loaded at 02110000h - 0219F000h
Address: 02114427h, location: "foo_ui_panels", loaded at 02110000h - 0219F000h
Address: 021143C0h, location: "foo_ui_panels", loaded at 02110000h - 0219F000h
Address: 77D48734h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D48816h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D4D559h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcA" (+0000006Bh)
Address: 77D70467h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D48830h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D4C63Fh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsWindowUnicode" (+000000A1h)
Address: 77D4C665h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallWindowProcW" (+0000001Bh)
Address: 01E31A33h, location: "foo_snap", loaded at 01E30000h - 01E46000h
Address: 0126478Ah, location: "foo_dockable_panels", loaded at 01260000h - 01294000h
Address: 01264750h, location: "foo_dockable_panels", loaded at 01260000h - 01294000h
Address: 77D4B4C0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D4EA9Eh, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D4B4D0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D4B50Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D4EBF3h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+000000F0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 77D4B473h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D494D2h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D4B530h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D4DAEAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D5E04Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsDialogMessageW" (+0000008Eh)
Address: 77D489F0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D48A10h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 0042FED3h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0510h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430A19h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C07D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4
UNICODE
Additional info:
foosic music database 1.0 beta 10  (foo_sic)
Playlist Manager 1.0  (foo_playlist_manager)
Live show tagger 0.6.1  (foo_tradersfriend)
Tube Sound 0.7  (foo_dsp_tube)
Columns UI 0.1.3 beta 1v6 TEST  (foo_ui_columns)
Discogs Tagger 0.91  (foo_discogs)
Fullscreen 0.3.1  (foo_fullscreen)
Feature Watcher 1.0.1  (foo_whatsnew)
On-Screen Display 1.52  (foo_osd)
Randomized playlist entry 1.2.3  (foo_random)
Dolby Headphone Wrapper 1.1  (foo_dsp_dolbyhp)
Playlist Bind 3.1  (foo_playlist_bind)
Main window snapping 0.1  (foo_snap)
Play Count 1.9.2  (foo_playcount)
Playlist Tree Panel 2.2.4 [Nov 17 2006 - 16:34:17]  (foo_playlist_tree)
Shorten decoder 0.4.2a  (foo_input_shorten)
iPod manager 0.3.7 TEST  (foo_dop)
Playlist Commandline Tools 0.0.1  (foo_cmd_playlist)
Albumlist autoupdate 0.1  (foo_albumlist_autoupdate)
Quick Search Toolbar 2.8f  (foo_uie_quicksearch)
freedb tagger v0.5.1  (foo_freedb2)
MSN Now Playing (alt) 2.4.2  (foo_msnalt)
Shell link resolver 1.1  (foo_lnk)
Track info panel mod 0.8.0 beta [Dec  6 2006 - 14:21:24]  (foo_uie_trackinfo_mod)
Database search 1.3.1 beta 11  (foo_dbsearch)
Common services 0.1  (foo_common)
Lyric Show Panels 0.3.0.0  (foo_uie_lyrics)
But I have a feeling this will be pretty revolutionary!
Thanks terrestrial
foo_ui_panels
Crash under Vista Ultimate
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0046206Bh
Call path:
Code bytes (0046206Bh):
0046202Bh:  76 05 8B 41 08 EB 02 8B C2 33 FF 38 1C 38 74 06
0046203Bh:  47 83 FF FF 72 F5 39 59 0C 76 03 8B 51 08 8B 45
0046204Bh:  08 8B 48 08 8B 75 0C 8D 5D FF 53 57 89 4D F8 8B
0046205Bh:  48 04 52 8D 55 F0 C7 45 F0 F4 47 4C 00 89 75 F4
0046206Bh:  8B 01 52 FF 10 84 C0 75 10 6A FF 88 45 FF 8B 06
0046207Bh:  68 20 47 4C 00 8B CE FF 10 8A 45 FF 5F 5E 5B C9
0046208Bh:  C2 08 00 55 8B EC 53 56 8B 75 0C 8B 06 57 8B F9
0046209Bh:  8B CE FF 50 10 8B 4F 08 56 FF 75 08 89 45 0C 8B
Stack (0012EC88h):
0012EC68h:  00000000 00000000 00000000 00000000
0012EC78h:  00000000 00000000 00000000 00000000
0012EC88h:  041187C0 00000006 0012ECAF 00000001
0012EC98h:  040CFA30 00000005 004C47F4 0012F004
0012ECA8h:  004DF58C 00FFFFFF 0012ECD0 004638DC
0012ECB8h:  0012ECEC 0012F004 04118AA0 0012F004
0012ECC8h:  00000000 000CFA30 0012ED08 00462F66
0012ECD8h:  0012ECEC 0012F004 028E5234 0012ED34
0012ECE8h:  0000001D 00000000 00000000 004DF58C
0012ECF8h:  00000013 0012F8F4 004AB15C 00000001
0012ED08h:  0012F904 02865A45 00000000 0012F004
0012ED18h:  004DF58C D3350571 00000000 000C034C
0012ED28h:  028E5234 0012ED44 028E5234 00000000
0012ED38h:  00000000 00000000 00000000 000001E4
0012ED48h:  000001D0 000C034C 00000000 00000000
0012ED58h:  0012F210 D3648687 04118AA0 000C0000
0012ED68h:  A901157D 10107C2B 00000000 00000000
0012ED78h:  00000000 00000000 00000000 00000000
0012ED88h:  00000000 00000000 00000000 00000000
0012ED98h:  00000000 00000000 00000000 00000000
Registers:
EAX: 0012ECEC, EBX: 0012ECAF, ECX: 00000000, EDX: 0012ECA0
ESI: 0012F004, EDI: 00000006, EBP: 0012ECB0, ESP: 0012EC88
Loaded modules:
ntdll                            loaded at 76E00000h - 76F1E000h
kernel32                        loaded at 76D20000h - 76DF8000h
COMCTL32                        loaded at 74460000h - 745F4000h
msvcrt                          loaded at 756F0000h - 7579A000h
ADVAPI32                        loaded at 769A0000h - 76A5F000h
RPCRT4                          loaded at 76420000h - 764E3000h
GDI32                            loaded at 76F40000h - 76F8B000h
USER32                          loaded at 76BF0000h - 76C8E000h
SHLWAPI                          loaded at 76530000h - 76585000h
SHELL32                          loaded at 75820000h - 762EE000h
ole32                            loaded at 76850000h - 76994000h
comdlg32                        loaded at 757A0000h - 75814000h
IMM32                            loaded at 76F20000h - 76F3E000h
MSCTF                            loaded at 766B0000h - 76777000h
LPK                              loaded at 76F90000h - 76F99000h
USP10                            loaded at 765E0000h - 7665D000h
uxtheme                          loaded at 74760000h - 7479F000h
lgscroll                        loaded at 10100000h - 1011B000h
NTMARTA                          loaded at 74A30000h - 74A51000h
WLDAP32                          loaded at 76590000h - 765D9000h
WS2_32                          loaded at 756C0000h - 756ED000h
NSI                              loaded at 76FA0000h - 76FA6000h
PSAPI                            loaded at 756B0000h - 756B7000h
SAMLIB                          loaded at 75170000h - 75181000h
foo_abx                          loaded at 002D0000h - 00304000h
foo_albumlist                    loaded at 01010000h - 01057000h
OLEAUT32                        loaded at 76FB0000h - 7703C000h
foo_amipwrapper                  loaded at 010C0000h - 010EC000h
foo_browser                      loaded at 01100000h - 0113A000h
foo_cdda                        loaded at 01320000h - 01356000h
foo_converter                    loaded at 013D0000h - 01439000h
foo_custominfo                  loaded at 01540000h - 015C5000h
foo_cwb_hacks                    loaded at 01390000h - 013AA000h
foo_cwb_hooks                    loaded at 01440000h - 01475000h
foo_discogs                      loaded at 014B0000h - 01522000h
gdiplus                          loaded at 73F10000h - 740BA000h
WINMM                            loaded at 741F0000h - 74223000h
OLEACC                          loaded at 741B0000h - 741E8000h
foo_dsp_continuator              loaded at 01680000h - 016B2000h
foo_dsp_crossfader              loaded at 015F0000h - 015FD000h
MSVCR80                          loaded at 728B0000h - 7294B000h
foo_dsp_std                      loaded at 016C0000h - 01701000h
foo_freedb2                      loaded at 01740000h - 01780000h
foo_fullscreen                  loaded at 01710000h - 01728000h
foo_infobox                      loaded at 01780000h - 017C0000h
foo_input_std                    loaded at 01940000h - 01A54000h
foo_lyricsdb                    loaded at 017E0000h - 017FE000h
MSVCP80                          loaded at 6FEC0000h - 6FF47000h
WININET                          loaded at 76780000h - 7684F000h
Normaliz                        loaded at 76520000h - 76523000h
iertutil                        loaded at 76660000h - 766A5000h
foo_masstag                      loaded at 01880000h - 018D0000h
foo_msnalt                      loaded at 01850000h - 0186A000h
foo_navigator                    loaded at 01A60000h - 01A91000h
foo_out_ks                      loaded at 01AF0000h - 01B1A000h
SETUPAPI                        loaded at 76A60000h - 76BE8000h
foo_playcount                    loaded at 01B20000h - 01B48000h
foo_rgscan                      loaded at 01B50000h - 01B98000h
foo_run                          loaded at 01BB0000h - 01BDB000h
foo_scheduler                    loaded at 01BE0000h - 01C4F000h
POWRPROF                        loaded at 74A10000h - 74A2A000h
foo_sic                          loaded at 01CC0000h - 01D10000h
foo_uie_albumart                loaded at 01D10000h - 01D4C000h
foo_uie_albumlist                loaded at 01D50000h - 01D8D000h
foo_uie_bookmarks                loaded at 01DF0000h - 01E38000h
foo_uie_console                  loaded at 01D90000h - 01DAB000h
foo_uie_lyrics_panel            loaded at 01EA0000h - 01F08000h
foo_uie_quicksearch              loaded at 01F40000h - 01F86000h
foo_uie_single_column_playlist  loaded at 02600000h - 0264C000h
foo_uie_tabs                    loaded at 01E60000h - 01E8A000h
foo_uie_trackinfo_mod            loaded at 02650000h - 026A6000h
foo_ui_columns                  loaded at 027C0000h - 02857000h
foo_ui_panels                    loaded at 02860000h - 028EF000h
foo_ui_std                      loaded at 028F0000h - 02947000h
foo_unpack                      loaded at 026B0000h - 026DE000h
foo_version                      loaded at 02710000h - 02736000h
dbghelp                          loaded at 6F520000h - 6F5FC000h
CLBCatQ                          loaded at 76C90000h - 76D14000h
amip                            loaded at 06290000h - 0643D000h
mswsock                          loaded at 74D20000h - 74D5B000h
wshtcpip                        loaded at 749F0000h - 749F6000h
imagehlp                        loaded at 764F0000h - 76519000h
Address: 004638DCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 028E5234h, location: "foo_ui_panels", loaded at 02860000h - 028EF000h
Address: 02865A45h, location: "foo_ui_panels", loaded at 02860000h - 028EF000h
Address: 10107C2Bh, location: "lgscroll", loaded at 10100000h - 1011B000h
Symbol: "UninstallScrollHooks" (+0000131Bh)
Address: 76BF8AA3h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "CallNextHookEx" (+0000003Dh)
Address: 10107C0Ah, location: "lgscroll", loaded at 10100000h - 1011B000h
Symbol: "UninstallScrollHooks" (+000012FAh)
Address: 7689709Bh, location: "ole32", loaded at 76850000h - 76994000h
Symbol: "CoRegisterInitializeSpy" (+00001E43h)
Address: 768AFF60h, location: "ole32", loaded at 76850000h - 76994000h
Symbol: "OleRun" (+00000112h)
Address: 768A9AFFh, location: "ole32", loaded at 76850000h - 76994000h
Symbol: "CoInitializeEx" (+000012A2h)
Address: 768972F2h, location: "ole32", loaded at 76850000h - 76994000h
Symbol: "CoRegisterInitializeSpy" (+0000209Ah)
Address: 76897E1Eh, location: "ole32", loaded at 76850000h - 76994000h
Symbol: "CoRegisterInitializeSpy" (+00002BC6h)
Address: 76897B11h, location: "ole32", loaded at 76850000h - 76994000h
Symbol: "CoRegisterInitializeSpy" (+000028B9h)
Address: 768974CCh, location: "ole32", loaded at 76850000h - 76994000h
Symbol: "CoRegisterInitializeSpy" (+00002274h)
Address: 768ADD73h, location: "ole32", loaded at 76850000h - 76994000h
Symbol: "CoTaskMemAlloc" (+0000080Ah)
Address: 768953A8h, location: "ole32", loaded at 76850000h - 76994000h
Symbol: "CoRegisterInitializeSpy" (+00000150h)
Address: 76895BE4h, location: "ole32", loaded at 76850000h - 76994000h
Symbol: "CoRegisterInitializeSpy" (+0000098Ch)
Address: 76895BD4h, location: "ole32", loaded at 76850000h - 76994000h
Symbol: "CoRegisterInitializeSpy" (+0000097Ch)
Address: 76C11D60h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetMessageW" (+000003BEh)
Address: 74761F61h, location: "uxtheme", loaded at 74760000h - 7479F000h
Address: 028D44E8h, location: "foo_ui_panels", loaded at 02860000h - 028EF000h
Address: 76D63C87h, location: "kernel32", loaded at 76D20000h - 76DF8000h
Symbol: "LocalAlloc" (+00000166h)
Address: 76D63C2Dh, location: "kernel32", loaded at 76D20000h - 76DF8000h
Symbol: "LocalAlloc" (+0000010Ch)
Address: 76D63C52h, location: "kernel32", loaded at 76D20000h - 76DF8000h
Symbol: "LocalAlloc" (+00000131h)
Address: 76C1320Bh, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetClassLongW" (+000000C5h)
Address: 76C1250Eh, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetWindowLongW" (+00000000h)
Address: 76C1334Eh, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "SetPropW" (+0000004Eh)
Address: 76C1332Ah, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "SetPropW" (+0000002Ah)
Address: 74761ADBh, location: "uxtheme", loaded at 74760000h - 7479F000h
Address: 74761AA1h, location: "uxtheme", loaded at 74760000h - 7479F000h
Address: 76C11E2Ch, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "DefWindowProcW" (+0000009Ch)
Address: 76C11DFBh, location: "USER32", loaded at 76BF0000h - 76C8E000h
Address: 76C12937h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "IsWindow" (+0000003Dh)
Address: 76C128FAh, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "IsWindow" (+00000000h)
Address: 76C576B4h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "AlignRects" (+00001926h)
Address: 76C11D87h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetMessageW" (+000003E5h)
Address: 76C12FA9h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "PtInRect" (+00000056h)
Address: 76C5AB20h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "AlignRects" (+00004D92h)
Address: 766B8DF6h, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "TF_IsThreadWithFlags" (+00001F96h)
Address: 76C11B41h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetMessageW" (+0000019Fh)
Address: 76C11AFFh, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetMessageW" (+0000015Dh)
Address: 1011062Bh, location: "lgscroll", loaded at 10100000h - 1011B000h
Symbol: "InstallScrollHooks" (+000087ABh)
Address: 76C11A10h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetMessageW" (+0000006Eh)
Address: 76C11A91h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetMessageW" (+000000EFh)
Address: 76E60E6Eh, location: "ntdll", loaded at 76E00000h - 76F1E000h
Address: 76BF981Eh, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "DefDlgProcA" (+000000C6h)
Address: 76C11C0Eh, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetMessageW" (+0000026Ch)
Address: 76C547BBh, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetRawInputDeviceInfoA" (+00000127h)
Address: 10107870h, location: "lgscroll", loaded at 10100000h - 1011B000h
Symbol: "UninstallScrollHooks" (+00000F60h)
Address: 76C13656h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "OffsetRect" (+0000004Dh)
Address: 76C13666h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "OffsetRect" (+0000005Dh)
Address: 76E60E20h, location: "ntdll", loaded at 76E00000h - 76F1E000h
Address: 76C5475Bh, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetRawInputDeviceInfoA" (+000000C7h)
Address: 76C083ACh, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetThreadDesktop" (+0000071Ah)
Address: 76C08340h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetThreadDesktop" (+000006AEh)
Address: 766B4673h, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "TF_GetAppCompatFlags" (+00000045h)
Address: 766B0000h, location: "MSCTF", loaded at 766B0000h - 76777000h
Address: 766C3D90h, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "TF_CreateLangBarItemMgr" (+00002859h)
Address: 76E623C1h, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlTryEnterCriticalSection" (+00000ADBh)
Address: 76E62447h, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlTryEnterCriticalSection" (+00000B61h)
Address: 76E61D37h, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlTryEnterCriticalSection" (+00000451h)
Address: 76E62033h, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlTryEnterCriticalSection" (+0000074Dh)
Address: 76E405CCh, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlReleaseActivationContext" (+0000025Fh)
Address: 76E6214Ch, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlTryEnterCriticalSection" (+00000866h)
Address: 76895834h, location: "ole32", loaded at 76850000h - 76994000h
Symbol: "CoRegisterInitializeSpy" (+000005DCh)
Address: 76E08BF2h, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "EtwLogTraceEvent" (+000000FBh)
Address: 76E405ACh, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlReleaseActivationContext" (+0000023Fh)
Address: 76E61C21h, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlTryEnterCriticalSection" (+0000033Bh)
Address: 76E42BB1h, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlReAllocateHeap" (+000001C4h)
Address: 76E688D8h, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlImageNtHeaderEx" (+0000009Dh)
Address: 766B00F0h, location: "MSCTF", loaded at 766B0000h - 76777000h
Address: 76E6240Bh, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlTryEnterCriticalSection" (+00000B25h)
Address: 76E40BD4h, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "wcslen" (+000000A7h)
Address: 76E688FBh, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlImageNtHeader" (+0000001Bh)
Address: 76C08483h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetThreadDesktop" (+000007F1h)
Address: 76E62054h, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlTryEnterCriticalSection" (+0000076Eh)
Address: 766B2829h, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "TF_Notify" (+00000470h)
Address: 767310B8h, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "TF_SetShowFloatingStatus" (+000204E2h)
Address: 766B6DD2h, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "CtfImeInquireExW" (+0000137Bh)
Address: 766B6DE3h, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "CtfImeInquireExW" (+0000138Ch)
Address: 766B6D77h, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "CtfImeInquireExW" (+00001320h)
Address: 766B6D8Eh, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "CtfImeInquireExW" (+00001337h)
Address: 00490064h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004D0049h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 76E61843h, location: "ntdll", loaded at 76E00000h - 76F1E000h
Symbol: "RtlAllocateHeap" (+00000216h)
Address: 766B2BB8h, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "TF_Notify" (+000007FFh)
Address: 766B8ACDh, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "TF_IsThreadWithFlags" (+00001C6Dh)
Address: 766B8810h, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "TF_IsThreadWithFlags" (+000019B0h)
Address: 766B8820h, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "TF_IsThreadWithFlags" (+000019C0h)
Address: 766B725Dh, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "TF_IsThreadWithFlags" (+000003FDh)
Address: 766B7265h, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "TF_IsThreadWithFlags" (+00000405h)
Address: 766B745Bh, location: "MSCTF", loaded at 766B0000h - 76777000h
Symbol: "TF_IsThreadWithFlags" (+000005FBh)
Address: 76C124AFh, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "SetWindowLongW" (+00000065h)
Address: 76C12539h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Address: 76C12545h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetWindowLongW" (+00000037h)
Address: 028CD57Ah, location: "foo_ui_panels", loaded at 02860000h - 028EF000h
Address: 02864427h, location: "foo_ui_panels", loaded at 02860000h - 028EF000h
Address: 013914C4h, location: "foo_cwb_hacks", loaded at 01390000h - 013AA000h
Address: 76C11AE8h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetMessageW" (+00000146h)
Address: 01391460h, location: "foo_cwb_hacks", loaded at 01390000h - 013AA000h
Address: 76C11C03h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetMessageW" (+00000261h)
Address: 76C0AC38h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetSysColor" (+00000048h)
Address: 76C0AC4Ah, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetSysColor" (+0000005Ah)
Address: 76C11BB8h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "GetMessageW" (+00000216h)
Address: 76C0C1AEh, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "BeginPaint" (+00000020h)
Address: 76C0C1C1h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Symbol: "BeginPaint" (+00000033h)
Address: 76C08C26h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Address: 76C12A98h, location: "USER32", loaded at 76BF0000h - 76C8E000h
Address: 01C08C26h, location: "foo_scheduler", loaded at 01BE0000h - 01C4F000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
Kernel Streaming Output 1.2.2  (foo_out_ks)
Navigator 0.6  (foo_navigator)
Scheduler 3.53  (foo_scheduler)
cwbowron's title format hooks 1.1.0beta [Dec  1 2006 - 13:47:34]  (foo_cwb_hooks)
Continuator 0.4.0  (foo_dsp_continuator)
Special file info box 2.0.3  (foo_infobox)
Discogs Tagger 0.92  (foo_discogs)
Lyrics panel 0.34.1  (foo_uie_lyrics_panel)
foosic music database 1.0 beta 9  (foo_sic)
Music Browser 1.2.3 [Dec  4 2006 - 09:42:32]  (foo_browser)
Crossfader 0.1.6.2  (foo_dsp_crossfader)
Album Art Panel 0.2.6  (foo_uie_albumart)
AMIP Wrapper 0.90  (foo_amipwrapper)
Components versions viewer 0.3  (foo_version)
Bookmarks 0.0.9  (foo_uie_bookmarks)
Console panel 0.2.1  (foo_uie_console)
Playback Statistics 1.3.2  (foo_playcount)
cwbowron's hacks 1.0.1 [Jun 16 2006 - 08:35:38]  (foo_cwb_hacks)
My Name is Sean and I'm here to leech off your genius.
foo_ui_panels
same  for me
foo_ui_panels
wait
as in, a trackinfomod panel that can have any other panel inside it?
if this works.....
foo_ui_panels
oops... should be fixed now. please try redownloading
foo_ui_panels
it works.... some more details about it?
foo_ui_panels
does it do what i asked about?
foo_ui_panels
alright, explain to me how this works?
when i start up foobar, it gives me the new option of UI Panels... and then i have a layout where all there is is a SCPL and nothnig else.
what?
foo_ui_panels
Works just fine... using WinXP Pro.
This opens up some amazing possibilities.
Some Questions:
What happens with the config of a panel if it is not displayed? Is it deleted? Useful if some panels need to pop up when a certain condition is met.
Is there a way to permanently save variables? E.g. when a button is pressed and this should somehow cause the layout to change.
Could minimization to the system tray be added like in columnsUI? And maybe the possibility to change the title of the window.
What happens when two panels overlap?
Is it possible to implement a list of panels? Its kind of annoying to switch between this plugin and columnsUI on a regular basis.
foo_ui_panels
I'm trying it out now, looks like this is going to be huge (in terms of popularity, not my foobar window.)
we was young an' full of beans
foo_ui_panels
At the pace you're going, I figured you were going to tire of columns terrestrial!
elevatorladylevitateme
foo_ui_panels
i still dont understand how to use this at all.
how can i code this like a trackinfomod deal when the only thing that shows up is SCPL?
foo_ui_panels
Some Questions:
nope, the panel settings will be stored and restored the next time it's displayed (as long as the ID matches). The individual panel settings are stored in the PanelsUI subfolder.
not quite sure what you mean? you should be able to use regular variables to do this... eg $set(var,val)
yep.
it uses the "Main window title" from the foobar preferences (only when playing a song, however).
one hides the other
yep.. the settings dialog is very crude at the moment  But you can see the list of panels thru the foobar preferences dialog.
try right-clicking the title bar, which should give you the settings popup.
foo_ui_panels
right clicking a title bar collapses a window
foo_ui_panels
So how do I access the main foobar preferences from this UI?
- All I see is the titlebar, a trackinfomod panel, and a scpl panel
- Ctrl+P does not open the foobar preferences
- I tried adding this line to the main layout code but all I got was a strange black box:
$panel(Menu,Menu,0,0,%_width%,50,)
The gears are spinning in my head with all sorts of fun to have with this plugin but I guess I'll have to wait a bit for it to mature a little.
foo_ui_panels
To Yousuva
You must change ui_panels on firsr start.
Then close foobar and start it again.
Right click mouse - select Setting  of ui_panel.
foo_ui_panels
amazing component... but is possible to add, i.e., other  components like  ui_tab or the spectrum? or the album list panel? it gives me graphic glithces to the volume bar....
foo_ui_panels
Some issues:
The background color is always black.
Inserting a menu panel seems to have odd effects... it's there, but completely black, nevertheless still usable.
Inserting a Album Art panel results in 10 seconds loading time and not displaying a Album Art panel.
Changing the panel type and using the same ID crashes foobar.
foo_ui_panels
Would it still be possible to add Columns Playlist panel?
foo_ui_panels
This is a cool component and all though a lot of stuff is missing.
* Panel backgrounds (solid color or custom images perhaps?)
* A way to get to Foobar properties.
* Panel list. So one knows what's available.
* What are the panel options?
* Volume. Could you add the same volume control as in Columns UI?
keep up the good work.
foo_ui_panels
fixed the other issues, still looking into this one.
yep, works fine.
it actually turns out you can use a custom background on *some* panels.
there are none yet
yep.
I've uploaded a new version which fixes the background glitches, adds shortcut processing (so you can get to the preferences), and fixes a couple of bugs.
There is also a more usable default layout. To get to it delete you "PanelsUI" folder, and the default will be loaded.
