Topic: foo_ui_panels (Read 1124908 times) previous topic - next topic
foo_ui_panels
Reply #375
I recognized a strange effect
I posted in this topic a code for "now playing" notes and becuase of missing unicode support the notes were shown as ??? and also in SCPL
Now I recognized that the notes were shown although in code there were just  "???".
I am still using 0.4.2
Some else has this strange effect?
A question about plugin apdating too:
How can I backup my layout in case there are problems to import this into 0.6.1 ?
When will there be unicode support?
Or is this already available?
Request: Better support for Egoh spectrum analyser.
It isn't possible to configure it
foo_ui_panels
Reply #376
The safest way to do this (and to get help via copy and paste into this forum) is to use $char() after a font statement that contains the referenced $char().
Safest way to backup a config is still to copy and paste code to a text file.  That's how I do it just to be sure nothing gets blown away.  There was a change to how PanelsUI stores the layout from v0.4 to v0.5+, so copy and paste is a GREAT idea.
foo_ui_panels
Reply #377
at unicode Support. I found out some $char seem to work but not everything. I thought it was because terrestrial said that he added no unicode support.
Thanks for your answer.For me it is horrible to loose all the code and the work behind it.
So know I will copy and paste
foo_ui_panels
Reply #378
Feature request: Window title adjustments. Currently, it's set to either follow cursor or follow playback, but that's a little annoying for me.
foo_ui_panels
Reply #379
Occasionally, when shutting down Windows Vista with foobar open, panels_UI seems to create a default.pui and will try to load that on startup. However, when it does this, foobar won't actually open. It will be running in task manager but it will be nowhere to be found on the desktop or system tray.
This only seems to happen on my Vista box at work. It may have something to do with Vista, but it may also have something to do with me running foobar on my second monitor. Maybe it isn't related to either of those. Anyhow, here is the default.pui file it is creating in case it helps in the diagnosis:
default.pui
foo_ui_panels
Reply #380
I'm sure you know better than I about actual unicode support.  However I've never had a problem with $char() not working as long as the $char() I was referencing actually existed in the font I was using.
To be safe, set a font with $font() then use $char().  Check the Windows Character Map to be sure what you want to use exists in the specified font and the unicode number is correct.
foo_ui_panels
Reply #381
I have a request, I have found that as I build up the themes available for my configuration the panels code begins to get cluttered with the likes of
"if theme 1... set these variables (30 or so)
if theme 2... set another 30
This makes managing and customising the code difficult.
I would love to be able to say, "if theme 1 load variables from "theme1.txt" which is just a text file formatted for panelsUI and imported directly in. Then in the actual code all I would need it one $select function to switch between all the themes - nicely separating variables and design.
foo_ui_panels
Reply #382
@FofR
That's a nice idea.  I think future support will also be added to call different .pui files from buttons.  That will also be a nice one-click layout change.  Easy to keep code separated as well.
foo_ui_panels
Reply #383
to further awesomeness this idea, the textfiles could become objects:
example:
$getpvar(layoutShakey.fontsize)
where setting fontsize is stored in a textfile named layoutShakey
elevatorladylevitateme
foo_ui_panels
Reply #384
how do I get a good looking carriage return with this component?
$crlf() adds an ugly block.
foo_ui_panels
Reply #385
@FofR
Thanks for the config you posted. But, I don't understand how to use it. You use pvars to $put() into other variables. I don't understand the rationale for this, or how to initialize the pvars in the first place, since, according to the wiki pvars can only be set in button. Thanks.
foo_ui_panels
Reply #386
How the hell do i make an image dynamic so itll stay on the center no matter how i resize the window? i can do this on panels, but i cant figure out how to make an image dynamic :S
foo_ui_panels
Reply #387
If you want to center
- horizontally: the left position of your image should be
$div($sub(%_width%,your_image_width),2)
- vertically: the top position of your image should be
$div($sub(%_height%,your_image_height),2)
As far as I remember, it can be added in any section (background, per track or per second)
foo_ui_panels
Reply #388
I have a little problem with PVAR and i was wondering if it came from my code. I have a button in my panelUI config which aim is to change my SCPL layout:
$button2($sub(%_width%,90),$sub(%_height%,30),0,0,26,22,'$imageabs2(,,0,44,26,22,0,0,'images/ayofe/ViewButtons.tiff',)','$imageabs2(,,0,44,26,22,0,0,'images/ayofe/ViewButtons.tiff',)',PVAR:SET:scp.display.mode:0,)
I put a test in my group display in SCP to see this change:
$select($add($getpvar(scp.display.mode),1),!noheader,%album%,%album%)
My problem is that SCP doesnt see the change.
It works between Track Display and PanelUI but not in this case.
Does anyone managed to make something like that work?
foo_ui_panels
Reply #389
I'm not sure if anyone has mentioned this yet but I have had a lot of success making panels work on glass by setting their background to $rgb(0,0,0). I even made a track display panel work by using the following line:
$drawrect(0,0,0,0,brushcolor-0-0-0)
It's not perfect though, foreground colors get distorted when used on glass but it sure makes for some interesting effects.
foo_ui_panels
Reply #390
I've tried PanelsUI and found that album art inside playlist is easily ruined if one of the tracks is missing. Like, if you don't have the first few tracks album art will have its top part cut (corresponding to the rows for tracks that 'should' be there).
I gather that there have been a limitation of that sort in ColumsUI (that is, it cannot look ahead and see how much tracks you have, only blindly assigning 1 row for 1 track, so missing tracks = missing rows for anything it tries to display alogside the tracklist).
So, is that problem still not solved?
use %totaltrack% and an if statement eg if %totaltracks% greater than 4 show album art
No, you've probably misunderstood me. It is not short tracklists that cause the problem, it is the fragmented ones that do. Missing tracks - missing image parts.
foo_ui_panels
Reply #391
Then use %_itemindex% instead of %tracknumber%
foo_ui_panels
Reply #392
I tried a while ago to do the same thing but it doesn't work.
foo_ui_panels
Reply #393
How can you then ensure that the art shows at the start of the group? EDIT: A tutorial on how to do this would be nice on fooblog.
@jonpb: Please post Config questions in the correct place or in the comments on the blog.
I use $setpvar to set the PVAR. I put these into $puts commands as it offered a quick way of moving variables out of one panel and into another and helped me create a global configuration section.
foo_ui_panels
Reply #394
I think $char(10) should work for you.
@carmenm
The SCPL layout is only drawn once when foobar is opened, or for new tracks when they are added (I know this is true for the 'Group Header' anyway).  The only way to redraw this, that I've found, is to restart foobar.  So changing by button at this point I don't think will work.
EDIT:  or SCPL is not aware of PVAR changes yet.  Perhaps this has only been implemented between Panels main config and Track Display?
@Yotsuya
I believe Terrestrial mentioned a while back, that on top of glass colors equate to transparency.  Black is transparent and white is opaque.  Anything else is going to be some strange looking partially transparent color.  That's why it was mentioned to use black as background and white as foreground for the spectrum analyser, for example.
foo_ui_panels
Reply #396
Is there a way to toggle between "Now Playing" and "Follow Cursor" other than the right-click menu? Either a button command or a pvar, perhaps?
Terrestrial, thanks for this plugin so far - I can see some really interesting things happening with this one.
-Nate
foo_ui_panels
Reply #397
Sadly, i dont get it
Could you make an example?
foo_ui_panels
Reply #398
Basically, you want the middle of your image in the middle of the panel. e.g. For a 200 pixel picture on a 1024x pixel panel you want the 100 pixel mark to be at 512 pixels across. We can only define the starting point from the left edge of the image, which is of course 100 pixels further left. So we choose to set the image corner at 412 pixels across.
Now the maths:
panel width - image width: 1024-200 = 824
divide this by 2: 824 / 2 = 412
foo_ui_panels
Reply #399
Now the maths:
Ok, but i dont get where/how to put the string above... =\
