Topic: dBpoweramp Music Converter R12 (Read 82105 times) previous topic - next topic
Illustrate are very pleased to announce Release 12 of Music Converter.
Complete rewrite, new design, every aspect updated & improved. Full Unicode support, Windows 98 to Vista support. Brief overview of changes:
CD Ripper - Secure Ripper, c2 support (reference), AMG meta data with Album art & rating, ultra secure ripping mode (reference).
All Codecs updated to latest versions, all improved.
Multi-CPU encoder support (reference).
New Batch Converter, new scripting engine, new Reference version,
New DSP design allows for live effects.
dBpoweramp
A special thanks to the members of HydrogenAudio who helped with CD Rippers development.
Congratulations spoon!
great, how can i claim my PP upgrade to R12?
Excellent news spoon. This is a welcome addition to the world of secure rippers.
I've announced this on daefeatures too.
daefeatures.co.uk
> PP upgrade to R12?
Will appear on Registered Download Retrieval today.
Fantastic news! I cant say enough good things about this ripper. Now I REALLY want to see the other apps updated and integrated into a music library tool! Keep up the great work spoon. I now have a new default ripper!!!
I too can see this being my default ripper eventually... and it's something which can be recommended to others too short of time to get involved with setting up EAC.
This may be the time for two quick queries which put me off (I haven't used it for a while so these things may have been sorted now anyway).
(1) When I played with the earlier version all my ripped MP3s ended up in a folder in alphabetical order, not track order. As EAC works fine for me - and I'm short of time too -  I didn't get involved in finding the solution to this.
(2) Also, I find it easy to switch Lame versions with EAC - as the new alpha is so good I want to use this, not the version Spoon's undoubtedly excellent prog is bundled with.
Try this string in the naming box:
[IFCOMP][IFVALUE]Various Artists[]Various Artists\[album][IFMULTI] (Disc [disc])[]\[album][IFMULTI] (Disc [disc])[] - [track] - [artist] - [title][][IF!COMP][IFVALUE]album artist,[album artist],[artist][]\[album][IFMULTI] (Disc [disc])[]\[artist] - [album][IFMULTI] (Disc [disc])[] - [track] - [title][]
If you are using logs, then add this:
[rippedtopath][IFCOMP][album][IFMULTI] (Disc [disc])[].txt[][IF!COMP][artist] - [album][IFMULTI] (Disc [disc])[].txt[]
You can use the comand line encoder with dBp to use any available LAME builds.
use [rippedtopath] along with your preferred filename mask to keep logs in the ripped folder.
How good is the the MP3 Encoder by Fraunhofer include with the dbPoweramp Reference version? Is it a recent, licensed full version encoder? How good is the quality - have thy fixed previous encoder bugs?
I like it that dBpoweramp offers both LAME and Fraunhofer encoders in the Reference version...
Also does this new version support adding an Album Art graphic via the new album art tags included in the FLAC 1.1.3 codec?
Cheers, Eli. I'll follow your advice. Thanks again!
Great work! But what happened to AAC Nero Digital codec ????
The Fraunhofer is licensed and is their latest encoder code.
m4a encoder / decoder will appear in beta next week.
Congrats!
I'll definitely be purchasing the reference version in the next couple weeks.
Just a couple of queries after a quick try
The last version had options for delete source track and copy tags from source which seem to have been removed or am I missing something?
I see the tags are copied by default except on the one album I tried the replay gain tags were not.
io
Did pressure from Apple force you to discontinue the AAC/itunes encoder? I miss the ability to use dbpoweramp to make m4a files using the itunes engine. And, congrats! I have been using your product for a long time!
you will make mp3's for compatibility reasons.
Can someone who has successfully configured the r12 command line encoder with LAME.exe share how it's done?
I posted in the dBpoweramp support forum but did not receive a responsive reply.
http://forum.dbpoweramp.com/showthread.php?t=11914
No, will be out next week.
Delete source is now a DSP effect, as will be the ID Tag removal / alteration, this is currently underdevelopment, so a few weeks.
Congratulations i cannot wait for nero aac encoder
I'll definately be buying this when ripping to Cue sheet and Single file is implemented. This is definately a work of art.
What are the recommended CD Ripper settings?
archagon, It's recommended to configure the secure mode options (C2 detection if your version supports it) and probably leave the rest as default.
spoon, Is it / could it be planned to have the option to convert all to uppercase all first characters?
daefeatures.co.uk
It should appear as a DSP effect.
Great!
I remember there have been long threads about the new ripper and various drives. What is the recommend drive working best with that ripper? Overread depending on offset and HTOA would be nice.
Find a drive that's good at DAE. Ergo it will then be good with dBpoweramp. But, as you've said, there have been many threads on this subject recently.
daefeatures.co.uk
