foo_audioscrobbler (outdated) crashes on Vista
Reply #3 – 2007-01-25 15:44:26
I'm using Vista Ultimate and foobar is running fine...the key is to use the very latest version of columns_ui and only use components recompiled with the latest version of foobar (0.9.4.2.) Heres my list of components.....some arent fully tested but the important ones like single_column_playlist and trackinfo_mod etc are running perfectlyCore (2006-11-25 13:21:34) foobar2000 core 0.9.4.2 foo_abx.dll (2006-11-25 13:20:22) ABX Comparator 1.3.1 foo_albumlist.dll (2006-11-25 17:49:06) Album List 3.2.0 foo_browser.dll (2006-12-04 09:42:48) Music Browser 1.2.3 [Dec 4 2006 - 09:42:32] foo_cdda.dll (2006-11-25 13:19:46) CD Audio Decoder 2.1.1 foo_converter.dll (2006-11-25 13:20:00) Converter 1.0.1 foo_custominfo.dll (2006-08-25 04:12:16) foo_custominfo 0.1.2 foo_cwb_hooks.dll (2006-12-01 13:47:46) cwbowron's title format hooks 1.1.0beta [Dec 1 2006 - 13:47:34] foo_discogs.dll (2007-01-12 01:53:04) Discogs Tagger 0.92 foo_dsp_continuator.dll (2007-01-22 00:29:30) Continuator 0.4.0 foo_dsp_crossfader.dll (2006-11-28 04:49:30) Crossfader 0.1.6.2 foo_dsp_std.dll (2006-11-25 13:20:12) Standard DSP array 1.0 foo_freedb2.dll (2006-08-29 18:43:04) freedb Tagger 0.5.2a foo_infobox.dll (2006-06-25 11:48:13) Special file info box 2.0.3 foo_input_std.dll (2006-11-25 13:19:14) FLAC Decoder 1.1.0 Standard Input Array 1.0 WMA Decoder 1.1 foo_masstag.dll (2006-11-25 13:18:42) Masstagger 1.6 foo_navigator.dll (2006-11-04 19:56:28) Navigator 0.6 foo_playcount.dll (2006-09-16 17:55:54) Playback Statistics 1.3.2 foo_rgscan.dll (2006-11-25 13:18:18) ReplayGain Scanner 2.0.2 foo_run.dll (2006-06-15 22:08:10) Run services 0.3.2 foo_scheduler.dll (2007-01-09 22:33:46) Scheduler 3.53 foo_sic.dll (2006-07-16 13:45:16) foosic music database 1.0 beta 9 foo_ui_columns.dll (2006-11-22 12:05:24) Columns UI 0.1.3 beta 1v7 foo_ui_std.dll (2006-11-25 13:18:12) Default User Interface 0.9acc foo_uie_albumart.dll (2007-01-15 17:04:44) Album Art Panel 0.2.6 foo_uie_albumlist.dll (2006-11-22 12:57:39) Album list panel 0.2.1 foo_uie_bookmarks.dll (2006-10-19 19:45:18) Bookmarks 0.0.9 foo_uie_console.dll (2006-11-22 12:59:04) Console panel 0.2.1 foo_uie_quicksearch.dll (2007-01-03 14:18:46) Quick Search Toolbar 2.8k foo_uie_single_column_playlist.dll (2007-01-09 15:43:08) Single Column Playlist Display 0.5.4 beta [Jan 9 2007 - 15:42:59] foo_uie_tabs.dll (2006-10-17 22:54:32) Tabbed panel modified 0.2.5 foo_uie_trackinfo_mod.dll (2007-01-05 13:36:20) Track info panel mod 0.8.0 beta [Jan 5 2007 - 13:36:12] foo_unpack.dll (2006-11-25 13:20:32) RAR reader 1.1 ZIP/GZIP reader 1.0 foo_version.dll (2006-07-18 23:20:56) Components versions viewer 0.3 make sure you search the forums for the latest versions forget kernel streaming though.....vista's audio handling is completely different from xp and you can use the inbuilt mixer to isolate foobar sounds if thats your wish. Hope this helps
