Topic: flake test suite addition (Read 2819 times) previous topic - next topic
  • jcoalson
as described here:
http://www.hydrogenaudio.org/forums/index....st&p=463073
note that the scripts require flac 1.1.3 in the path (my cheezy way of converting raw PCM to WAV via FLAC since flake only accepts WAV), and also test_streams which generates a lot of the input files.  I included the source in the tarballs but it is also built when you build flac so that could be used instead.
[ Specified attachment is not available ]
