Topic: lossless extraction of wma from wmv (Read 5445 times) previous topic - next topic
Hi
Is it possible to extract (losslessly) the audio from a wmv file?
If not, that's the easiest way to rip the audio?
Ax
There's an old-but-still-functional 3rd-party app called AsfTools that allows extraction to wav (might extract losslessly to wma too, though I haven't used it in a long time).
you can use mplayer to dump the audio stream, too
Or ffmpeg, too:)
example :
ffmpeg -i myvideo.wmv -vn -acodec copy myvideo.wma
Or, you can just use Windows Media Stream Editor included with Windows Media Encoder.
all i really want to do is get the audio from the wmv file and create an audio cd with it.  whats the best way to do that.  scratch that, whats the easiest/simpliest way to do that?
1. extract audio to wav using any of the aforementioned methods
2. write wav to audio CD using any burning software (Burrrn, Nero, Infra Recorder, etc.)
The audio quality of the CD will be the same as the audio quality of the wmv.
edit: I spel bad
just drag the wmv to fb2k and convert it to wav?
