here is the crash dump:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 024B876Ch
Access violation, operation: read, address: 00000088h
Call path:
entry=>initquit::on_quit
Code bytes (024B876Ch):
024B872Ch: 50 68 68 AB 4B 02 FF 74 24 14 8B F1 8B 4C 24 14
024B873Ch: E8 61 BE FF FF 50 8B CE E8 9C ED FF FF 5E C2 10
024B874Ch: 00 C7 01 E4 AE 4B 02 C7 81 88 00 00 00 01 00 00
024B875Ch: 00 83 25 70 E4 4B 02 00 E9 D0 A3 FF FF 56 8B F1
024B876Ch: 83 BE 88 00 00 00 00 75 39 DB 44 24 08 51 51 8B
024B877Ch: 8E 90 00 00 00 DD 1C 24 C7 86 88 00 00 00 01 00
024B878Ch: 00 00 E8 BD AB FF FF DB 44 24 0C 51 51 8B 8E 94
024B879Ch: 00 00 00 DD 1C 24 E8 A9 AB FF FF 83 A6 88 00 00
Stack (0012FA10h):
0012F9F0h: 0000037E C050248C 00000001 C0501000
0012FA00h: C0501694 C06F2000 8221E020 BB87E3E4
0012FA10h: 0012FA80 024B87D1 0000034D 000002E2
0012FA20h: 7FFDE000 77E33021 00000000 00000200
0012FA30h: 0012FA80 00000000 00000002 0012FA60
0012FA40h: 77E59601 000E0000 00000200 0012FA80
0012FA50h: 024B87B2 01D19D4F 00000018 0012FA80
0012FA60h: 0012FACC 77F91BAF 0012FA70 00000028
0012FA70h: 000E0000 00000200 024B87B2 77E32FF1
0012FA80h: 0000034D 000002E2 00000000 00000000
0012FA90h: 0F42529D 00000000 77E33A0B 015406E0
0012FAA0h: 00000002 00000000 00000000 00000000
0012FAB0h: 000002AE 00000000 00000000 00000002
0012FAC0h: 00000000 015406E0 00005280 0012FAEC
0012FAD0h: 77E3B811 0069F010 00000002 00000000
0012FAE0h: 00000000 00000000 020C21A0 0012FB50
0012FAF0h: 02096164 015406E0 00000002 00000000
0012FB00h: 00000000 0012FB3C 0012FB50 00000000
0012FB10h: 020C21A0 02095DBE 77E33F1D 02096D82
0012FB20h: 00000001 0042FE35 0012FC10 77E33F1D
Registers:
EAX: 00000000, EBX: 0069F010, ECX: 00000000, EDX: 0000002D
ESI: 00000000, EDI: 00000000, EBP: 0012FA3C, ESP: 0012FA10
Crash location: "user_input", loaded at 024B0000h - 024C2000h
Loaded modules:
foobar2000 loaded at 00400000h - 004F3000h
ntdll loaded at 77F80000h - 77FFC000h
COMCTL32 loaded at 71710000h - 71794000h
GDI32 loaded at 77F40000h - 77F7C000h
KERNEL32 loaded at 7C570000h - 7C624000h
USER32 loaded at 77E10000h - 77E79000h
ADVAPI32 loaded at 7C2D0000h - 7C335000h
RPCRT4 loaded at 77D30000h - 77D9F000h
SHLWAPI loaded at 70A70000h - 70AD6000h
msvcrt loaded at 78000000h - 78045000h
SHELL32 loaded at 7CF30000h - 7D176000h
ole32 loaded at 7CE20000h - 7CF0F000h
shared loaded at 10000000h - 10029000h
comdlg32 loaded at 76B30000h - 76B6E000h
IMM32 loaded at 75E60000h - 75E7A000h
PPro loaded at 00990000h - 009A9000h
pprotray loaded at 00DC0000h - 00DCC000h
tmhook loaded at 011E0000h - 011ED000h
foo_albumlist loaded at 01200000h - 01247000h
OLEAUT32 loaded at 779B0000h - 77A4B000h
foo_autoplaylist loaded at 01670000h - 016A0000h
foo_cdda loaded at 016B0000h - 016E6000h
foo_common loaded at 01700000h - 0173A000h
foo_converter loaded at 01750000h - 017B9000h
foo_cwb_hooks loaded at 017D0000h - 017FE000h
foo_dbsearch loaded at 01810000h - 0186C000h
foo_dsp_std loaded at 01880000h - 018C1000h
foo_freedb2 loaded at 018E0000h - 01920000h
foo_info_samurize loaded at 01930000h - 01952000h
foo_input_shorten loaded at 01A80000h - 01AAE000h
foo_input_std loaded at 01AC0000h - 01BD4000h
foo_lnk loaded at 01BF0000h - 01C09000h
foo_masstag loaded at 01C20000h - 01C70000h
foo_playlist_manager loaded at 01C80000h - 01CC6000h
foo_pqview loaded at 01CE0000h - 01CFC000h
foo_random loaded at 01D10000h - 01D4F000h
foo_rgscan loaded at 01D60000h - 01DA8000h
foo_RMX loaded at 01DC0000h - 01E53000h
MSVCR80 loaded at 78130000h - 781CB000h
foo_tradersfriend loaded at 01E70000h - 01EAD000h
foo_uie_quicksearch loaded at 01EC0000h - 01F08000h
foo_ui_columns loaded at 01F20000h - 01FBB000h
foo_ui_std loaded at 01FD0000h - 02027000h
foo_utils loaded at 02040000h - 02079000h
foo_vis_samurize2 loaded at 02090000h - 020C0000h
BtBalloon loaded at 02260000h - 02269000h
user_input loaded at 024B0000h - 024C2000h
DSOUND loaded at 51080000h - 510E1000h
WINMM loaded at 77570000h - 775A0000h
VERSION loaded at 77820000h - 77827000h
LZ32 loaded at 759B0000h - 759B6000h
wdmaud loaded at 77560000h - 77568000h
msacm32 loaded at 77400000h - 77408000h
MSACM32 loaded at 77410000h - 77423000h
KsUser loaded at 5EF80000h - 5EF84000h
imagehlp loaded at 77920000h - 77943000h
DBGHELP loaded at 72A00000h - 72A2D000h
Stack dump analysis:
Address: 024B87D1h, location: "user_input", loaded at 024B0000h - 024C2000h
Address: 77E33021h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E59601h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 024B87B2h, location: "user_input", loaded at 024B0000h - 024C2000h
Address: 01D19D4Fh, location: "foo_random", loaded at 01D10000h - 01D4F000h
Address: 77F91BAFh, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77E32FF1h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E33A0Bh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E3B811h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 02096164h, location: "foo_vis_samurize2", loaded at 02090000h - 020C0000h
Address: 02095DBEh, location: "foo_vis_samurize2", loaded at 02090000h - 020C0000h
Address: 77E33F1Dh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 02096D82h, location: "foo_vis_samurize2", loaded at 02090000h - 020C0000h
Address: 0042FE35h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 020B694Ch, location: "foo_vis_samurize2", loaded at 02090000h - 020C0000h
Address: 0042FDF7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A683Bh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430D85h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BC44Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C70FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77FCA907h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C70E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77FB2C0Ch, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77FCB301h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77FCB4BEh, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77FCB618h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77FCACEAh, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 0044005Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004F0048h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00470042h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0042004Fh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049004Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 1000375Bh, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uGetCallStackPath" (+0000095Bh)
Address: 004E41E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4230h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77FB7E64h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77F81650h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 00491D18h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040CA96h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004480F4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77FCD168h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 00497FFDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0570h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004AF5D4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430EFAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0928h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049729Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004935BCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004935B6h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49E4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B34A0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4228h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496FE0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF9C8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496154h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C2EE774h, location: "ADVAPI32", loaded at 7C2D0000h - 7C335000h
Address: 7C5989A5h, location: "KERNEL32", loaded at 7C570000h - 7C624000h
Address: 7C5C216Ch, location: "KERNEL32", loaded at 7C570000h - 7C624000h
Address: 7C572B18h, location: "KERNEL32", loaded at 7C570000h - 7C624000h
Address: 004961BDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 02000000h, location: "foo_ui_std", loaded at 01FD0000h - 02027000h
Address: 01AD0003h, location: "foo_input_std", loaded at 01AC0000h - 01BD4000h
Address: 004C0004h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
Default User Interface 0.9acc (foo_ui_std)
Playlist tools 0.5.7 (foo_utils)
RMX Automation - Media Edition v1.4 (20070101) (foo_RMX)
ReplayGain Scanner 2.0.2 (foo_rgscan)
Converter 1.0.1 (foo_converter)
CD Audio Decoder 2.1.1 (foo_cdda)
Live show tagger 0.6.1 (foo_tradersfriend)
Shorten decoder 0.4.2a (foo_input_shorten)
Randomized playlist entry 1.2.3 (foo_random)
WMA Decoder 1.1 (foo_input_std)
Quick Search Toolbar 2.8i (foo_uie_quicksearch)
Samurize Visualization Server (AMPI) 1.64 (foo_vis_samurize2)
Database search 1.3.1 beta 11 (foo_dbsearch)
Standard DSP array 1.0 (foo_dsp_std)
Columns UI 0.1.3 beta 1v5 (foo_ui_columns)
Common services 0.1 (foo_common)
Samurize Info Server (AMPI) 1.64 (foo_info_samurize)
Album List 3.2.0 (foo_albumlist)
Standard Input Array 1.0 (foo_input_std)
freedb tagger v0.5.1 (foo_freedb2)
cwbowron's title format hooks 1.0.13 [Oct 2 2006 - 09:06:52] (foo_cwb_hooks)
Shell link resolver 1.1 (foo_lnk)
foobar2000 core 0.9.4.2 (Core)
Masstagger 1.6 (foo_masstag)
FLAC Decoder 1.1.0 (foo_input_std)
Autoplaylist Manager 1.0 (foo_autoplaylist)
Playlist Manager 1.0 (foo_playlist_manager)
all i can say is that i suspected foobar2k to be the cause of my recent sluggish system (jumpy mouse and all) as the jumpyness of the mouse went away when i shut foobar2k down.
started it back up and it came back.
so i tried to shut it down again and got this crash.
