Topic: SV8 wishes (Read 9052 times) previous topic - next topic
  • r2d
SV8 wishes
Hello,
SV8 is on it's way. One target of the first SV8 release is lossless conversion from SV7 files, so there will be limited changes in the compression engine.
You can see the current SV8 schedule of conditions ( http://trac.musepack.net/trac/wiki/SV8ScheduleOfConditions ) in the Musepack Trac Wiki. I'm waiting for your wishes / comments / improvement suggestions on this stream.
  • j7n
SV8 wishes
Independent frames or at least groups of frames, optional or recreatable file header. So that Musepack streams could be cut and played back like MPEG Layer-3. It is important for a lossy format to enable at least basic lossless transformations.
  • Fandango
SV8 wishes
Most of all I'm hoping for an active development...
  • dariju
SV8 wishes
r2d,
are you an mpc developer? Could you tell us if there is someone working on it at the moment?
  • r2d
SV8 wishes
r2d,
Yes, I am since september. See http://trac.musepack.net/trac/timeline
Frames are grouped in blocks. You can cut at block boundaries and an optional edition block allow to skip samples at the begining and the end of the stream. See http://trac.musepack.net/trac/wiki/SV8ScheduleOfConditions.
  • jido
SV8 wishes
Mac (PPC) encoder, decoder and translator support. Mac playback.
Keep improving sound quality.
SV8 wishes
I can see it now
Change log for MPC SV8:
*Updated version number of encoder to SV8 to reflect encoder version
[span style=\'font-size:8pt;line-height:100%\']"We will restore chaos"-Bush on Iraq[/span]
  • yong
SV8 wishes
You could try ffmpeg or mplayer, to playback mpc or decoding on mac
  • Lefungus
SV8 wishes
I fixed compilation for sparc64 recently in mppenc 1.16+svn, so the encoder will work with any mac (ppc or x86). The decoder has been compatible since the beginning.
What do you mean by 'translator' btw ?
What would be nice is a quicktime plugin, which will happen only with a mac developer :|
Btw, there is already a rough version of sv8 in svn, it compiles, it decodes with xmms/winamp, it has new huffman code (~+2% compression), new bitstream (which also allow mp4/mkv/nut/whatever). That's why r2d is trying to get useful feedback while the new code is still in progress, so people have a chance to interact.
It's a 'Jump to Conclusions Mat'. You see, you have this mat, with different CONCLUSIONS written on it that you could JUMP TO.
  • Enig123
SV8 wishes
I'd glad to see if SV8 can improve quality of classical music. There's some defect been discovered via listening test by Guruboolez, which really should be given enough respect for developers IMHO.
  • seanyseansean
  • Members (Donating)
SV8 wishes
Can we keep out the off-topic complaining? I use mpc because it's had a pretty stable format (althought with intra-frame dependencies) for years. I don't need to use unofficial builds, it's fast, and just works. You might find codecs with better scores in some of the metrics, but mpc is competitive *to me* in pretty much all of them. So why change?
r2d - thanks for the updates. Do you have any idea of how much the filesize will increase for files transcoded from sv7? And when you say the quality will increase after sv8 - does this mean there will be bitstream format changes both in the decoder and encoder later?
  • r2d
SV8 wishes
The file size should decrease when transcoding from sv7 to sv8 (even if a seek table has been added) by ~2%.
Yes, if results are good enough to justify it.
  • GeSomeone
SV8 wishes
I remember there was this "overloading" (of scalefactor?) thing that was more or less "solved" with --xlevel.
This was one of the things that was supposed to be definitively fixed in SV8
  • r2d
SV8 wishes
It's fixed, just no yet removed the --xlevel switch
  • GeSomeone
SV8 wishes
Another thing, that I think was once suggested for SV8, is more a Stream header/info thing.
Store (somewhere) the encoding quality setting numerical including the decimals. So instead of the old "Standard" "Xtreme" "Insane", the value of --quality e.g. 5.48.
  • Last Edit: 09 January, 2007, 12:42:58 PM by GeSomeone
