Topic: foo_input_mslive problem (Read 1810 times) previous topic - next topic
I have encountered a problem listening to archived mms streams in a .asx file. I'm using v0.2 of the foo_input_mslive plugin.
Live mms streams play perfect, but with archived streams (streaming through the internet of course), the playback is ended as soon as the current stream is downloaded in the background. So e.g. if the stream is 15 minutes, it can happen that playback is aborted after e.g. 3 minutes because the current stream has finished downloading. After that, the next mms stream in the .asx file is started and the same happens after a few minutes.
Any suggestions?
