Topic: Lame 3.98a9 error encoding (Read 6889 times) previous topic - next topic
I was tring to convert wav's to mp3's with frontah using Lame 3.98a9 and the setting -V 2 --vbr-old and I got this error
"Assertion failed: thr >= 0, file psymodel.c, line 670"
Edit:  tried with -V 2 --vbr-new and got the same results
  • Last Edit: 20 December, 2006, 02:11:00 PM by Fishman0919
  • Junon
There's a link with a working version in another topic about this issue.
Edit: Muahahahahahaha! I was first!
  • Last Edit: 20 December, 2006, 02:31:03 PM by Junon
  • Firon
http://www.hydrogenaudio.org/forums/index....&hl=3.98a9#
Edit: Damn. Beat while I was searching.
  • Last Edit: 20 December, 2006, 02:26:22 PM by Firon
Thx, sorry I'm at work and didn't have much time to search
  • db1989
  • Global Moderator
Rarewares has updated 3.98a9 compiles which may fix this.
  • john33
  • Developer
Nope, they don't!  I could probably 'fix' it by commenting out the offending 'assert', but I'm sure that would not really be the right thing to do. Hopefully, Robert will fix it in the CVS momentarily.
John
  • db1989
  • Global Moderator
Ah, sorry, John! I simply assumed that because I thought that they were re-uploaded after a day.
  • john33
  • Developer
Well, I just tried commenting out the offending 'asserts' and although it completes encoding, '-V 2 --vbr-new' produces what is almost CBR at 319kbps!!  So, clearly something has been broken.
John
  • db1989
  • Global Moderator
Haha, this is a pickle!  Well, let's hope that the good LAME developers figure something out soon.
  • robert
  • Developer
Well, I don't have newer sources than what's in CVS already. John33 are you sure you have latest sources? Did you make a clean rebuild?
  • john33
  • Developer
Yep. Just double checked everything and building via the VC6 IDE and the VC8 IDE, both using ICL9.1 yields the same error message.
John
  • john33
  • Developer
Hmmm, a straight VC8 compile encodes cleanly, but the ICL version fails. I'll look at this more closely tomorrow.
John
  • Enig123
Still the same error with latest CVS code, compiled by MinGW, no extra optimization.
  • robert
  • Developer
10 minutes ago I checked in a bug fix, so you may try again later.
  • Enig123
Alright.
Now it's OK.
BTW, how can I optimize compilation of lame with MinGW as compiler? Should I change Makefile options or do something else, like get a copy of nasm?
  • john33
  • Developer
Thanks a lot Robert, all seems OK now.
The only problem I have now is that Rarewares is down, so I can't upload!!
If anyone is desperate, you can download alpha10 from: http://homepage.ntlworld.com/jfe1205/LAME/ until I can get back to Rarewares.
John
  • halb27
As that will be alpha10 on Rarewares and as I tested the dll based alpha9 version from the link you provided:
Should I expect another behavior so that it's worth testing again? Or is it just a technical bug fix for the assertion error?
lame3995o -Q1
  • robert
  • Developer
It's more of a technical fix, you don't need to test the same samples again.
  • john33
  • Developer
Rarewares is back up and the files are now in their usual place.
John
