Topic: Advanced Controls (foo_advancedcontrols) (Read 148095 times) previous topic - next topic
  • Kresnik
Reply #75
Thanks, it works fine now.
  • Forfit
Reply #76
Why the size is duplicate from 256kb to 528kb whit only fix?
  • niver
Reply #77
Because the new binary includes debug symbols which will allow me to fix problems much more quickly if other bugs are reported.
This increase of size does not change the efficiency of the component.
  • Forfit
Reply #78
The volume bar has become less precise and more difficult to manage now for me.
Win Xp Pro sp3 italian.
When you finish the fix you can remove the debug symbols?
  • Last Edit: 17 May, 2009, 02:09:38 AM by Forfit
  • niver
Reply #79
Please explain what you mean - there shouldn't be a difference with previous versions.
The volume/time bar has only 32 pixels wide anyway, it's a bit hard to be precise, isn't it?
Are the 256 extra bytes really that annoying? Debug symbols are just extra informations in the binary to link a section of compiled code with the human-readable code it comes from. When these symbols are combined with the program database created by the compiler (a file I have here), it's possible for me to pinpoint exactly where a crash happens when a proper report is sent to me. I would prefer keeping these debug symbols on.
  • Yirkha
  • Moderator
Reply #80
/DEBUG enables PDB generation but also disables some linker optimizations by default, try forcing unreferenced code elimination (/OPT:REF) in linker settings.
  • niver
Reply #81
Right, thanks. The /OPT:REF setting is usually forced on in my projects but I forgot it in this one.
The new dll is (almost) back to its original size.
  • Forfit
Reply #82
i view double:
excuse me i have renamed the old component.
In this mode first bar control song progress and second volume.
Now i not have the previous problem.
  • Last Edit: 17 May, 2009, 12:49:13 PM by Forfit
  • Yirkha
  • Moderator
Reply #83
niver,
your component blocks going to sleep mode when foobar2000 is playing or when it's paused. Please stop doing that, people are complaining and making false accusations about the core. Or at least confess why and write a disclaimer about it.
  • Last Edit: 21 May, 2009, 10:36:49 AM by Yirkha
  • niver
Reply #84
niver,
Right... I implemented this feature for me but the code got mistakenly copied in the public component. Sorry, I'll fix this immediately.
  • Peter
  • Administrator
Reply #85
How about spelling "foobar2000" correctly in your component's version string?
  • niver
Reply #86
niver,
Done. v0.5.12.3 is available and will not block the sleep mode anymore
However, if someone liked this feature, I could make it an option.
  • niver
Reply #87
That has been fixed too in the latest version, thanks.
  • Forfit
Reply #88
Here the video to explain, my english is poor. The cursor not follow the mouse.
Win Xp Pro Sp3.
  • Last Edit: 22 May, 2009, 08:56:03 AM by Forfit
Reply #89
Same Problem here on Xp SP3 but with the pause/stop/forward/backward buttons.
  • niver
Reply #90
Win Xp Pro Sp3.
Can you confirm you have the latest version (0.5.12.3)?
0.5.12.0 had such a problem, but it's supposed to be fixed now - I can't reproduce it here.
  • Forfit
Reply #91
Yes, confirmed the last versione: 0, 5, 12, 3
No problem with 0, 5, 11, 5
  • Last Edit: 23 May, 2009, 01:30:24 PM by Forfit
  • niver
Reply #92
Ok. I compared the code of 0.5.11.5 and 0.5.12.3 and found what could cause you this problem.
v0.5.12.4 is now available, could you please try it and confirm whether or not the problem is fixed?
Thank you.
  • Forfit
Reply #93
Thank you.
Now it is Ok for me. Ty.
Reply #94
For me too. Thank you buddy.
  • GeSomeone
Reply #95
So that was it (I was wondering too) ... thank for fixing and Yirkha for pointing in the right direction.
  • GeoffX
Reply #96
Thanks for the v0.5.12.4 fix, I'm not sure how I'd cope without Foobar2000 and Advanced controls...
The page http://fb2k.org/section.php?section=8 is out of date, it lists the previous version of Advanced Controls. It's only through reading this thread that I discovered the update.
  • niver
Reply #97
Fixed, thanks.
  • tenzip
Reply #98
Thank you very much for this component, particularly the pause on screensaver functionality.
You can see a thread I started looking for this functionality here:  http://www.hydrogenaudio.org/forums/index....showtopic=74079  Your foo_advancedcontrols seems to fit my needs quite well.
Again, thank you for your time and effort.
  • (O)fer_cz
Reply #99
plz update for win 7 !!! this component is for me must have
