Topic: Advanced Controls (foo_advancedcontrols) (Read 148101 times) previous topic - next topic
  • niver
Hi, I noticed that the version information in foobar2000 was corrupt in the 9 april dll.
Thanks for the notice. Problem fixed.
  • niver
v0.5.10.0 is now available.
All langages are now integrated in the same library and selectable in component options. The component file is thus slightly bigger (260kb instead of 220kb...) but we have to maintain only one package instead of 20.
Available languages in this version:
  • English
  • Français (French)
  • Deutsch (German)
  • Español (Spanish)
  • Italiano (Italian)
  • 简体字 (Simplified Chinese)
  • Русская (Russian)
  • Cesky (Czech)
  • Dansk (Danish)
  • Eesti keel (Estonian)
  • Ρωμαίικα (Greek)
  • македонски (Macedonian)
  • Magyar (Hungarian)
  • Nederlands (Dutch)
  • Polski (Polish)
  • Português do Brasil (Portuguese)
  • Romana (Romanian)
  • Slovenčina (Slovak)
  • Svenska (Swedish)
  • Türkçe (Turkish)
Release notes:
- Auto-pause on screensaver restarts (stop + play) music streaming instead of pausing (pause + play) it.
- Merged all languages in a single component file.
http://www.niversoft.com/products/fac (official page)
or
http://pelit.koillismaa.fi/plugins/show.php?id=138
  • Yurk Yurk
I have noticed a bug. When I hover the mouse over the controls, an info balloon pops up with the Artist and Title. However, it always shows the artist and title for the previous track, not the current one.
  • niver
Bug confirmed, thanks for the report. We will fix that asap.
  • niver
Hello.
We updated the plugin with the latest foobar2000 SDK and the problem apparently went away. No change in the plugin code.
v0.5.10.2 is now available.
Release notes:
- Updated with the latest Foobar2000 SDK
or
  • drbeachboy
Reply #30
Is this plugin another casualty of the API change of version 0.9.5.3? It doesn't seem to load up at all. It's acting like a "Banned" plugin, although it is not listed as such.
Surf's Up!
"Columnated Ruins Domino"
  • niver
Hello.
On my test systems, it runs well with both v0.9.5.2 and 0.9.5.3 beta 1.
Regards.
  • drbeachboy
I see that the latest version now needs to be in the 'components" folder, instead of the root folder at least with version 0.9.5.3b1.
Surf's Up!
  • niver
Reply #33
The plugin always had to be installed in the components folder. Maybe installing it in foobar root worked in previous version, but this is not supported.
  • drbeachboy
Reply #34
Your zip file path has a blank path for dll & text files, while everything else has path folders. Since the path is blank, the dll & 2 txt files installs into the foobar2000 root directory. You may want to add "component" to the path for those 3 files. Thank you for the prompt help replies.
Surf's Up!
  • niver
Reply #35
All components available on http://foobar2000.org/components/index.html are provided without the "component" path in the zip file. You are expected to unpack these zip files in the component subfolder, I don't see why Advanced Controls should be different?
  • drbeachboy
Reply #36
Whatever!
Surf's Up!
Reply #37
Hello,
A bug which exist since a long time :
Neustradamus
  • niver
Reply #38
This happens when another software inserts its icon at the same time foo_advancedcontrols inserts its two. There is no way to completely prevent that to happen.
When this happens, you can either close and reopen foobar2000, or select "Configuration" / "Reset Tray Icons" in the foo_advancedcontrols right-click menu.
N.
Hello,
Neustradamus
Reply #39
it is bad  You really can't merge icon ?
  • niver
Reply #40
No. Windows explorer supports only 16x16 icons. foo_advancedcontrols uses two icons wide, and the call to display an icon must be done once for each icon. While this doesn't happen often, there is always the possibility of another software inserting its icon at the same time, and Explorer displays the other software's icon between foo_advancedcontrols icons.
Most of the time the two foo_advancedcontrols icons are placed together. If it isn't the case on your system, there might be something else causing that - maybe your taskbar is on two or more rows?
  • r0lZ
Reply #41
Hi!
Thanks for this handy little control panel!
A couple of remarks:
1. Bug: In Preferences, select any foreign language (I selected French) and save.  It is not possible any more to go back to English.  (Selecting another foreign language works.)
2. Not really a bug: When selecting a skin saved on disc, F2K must be restarted for the changes to take effect.
3. When hovering the mouse pointer over an icon, no tooltip is displayed.  Is the "Title" field in Preferences intended to define the content of the tooltip?  It doesn't work for me, no matter what I type in the field.  (The balloon appearing when a new track begins to play works fine.)
4. Suggestion: Add a configurable balloon duration in Preferences.  Currently, it is way too short for me.
5. Question: Is it possible to remove completely the original F2K icon from the tray?  It is now useless.
Merci beaucoup!
  • Last Edit: 18 July, 2008, 07:32:03 AM by r0lZ
  • niver
Reply #42
Hello.
1. Fixed for next release. Stay tuned.
2. I'm not able to reproduce this problem.
3. There is a tooltip. Sometimes tooltips of the taskbar are being displayed _behind_ the taskbar, that's a long-known Explorer bug. When this happens, one of the workarounds is to open the start menu, all programs, right-click on any of them and click "sort by name". Tooltips will then be shown in front.
4. The balloon display is currently fixed at 4 seconds. I'm not sure we want to add a preference field for that. EDIT: You're lucky, the option has been implemented
5. Foobar does not provide us with a way to remove its icon from the tray, but there is perhaps a possible hack. I will see what we can do. EDIT: You're lucky again
N.
Hi!
Merci beaucoup!
  • Last Edit: 22 July, 2008, 01:24:39 AM by niver
  • niver
Reply #43
v0.5.11.0 is now available.
We moved things around in the preferences pane to make some place for two new options (thanks r0lZ and others for the ideas/requests).
The Volume/Seek option has been removed from the preferences as it is already available in the tray icon context menu and the Foobar2000 main menu.
- New option: Hide the Foobar2000 notification icon. The SDK doesn't provide this option to component, we had to find another way. There's no guarantee a future version of Foobar2000 will not break this feature. This feature will work only on Windows XP and further versions.
- New option: Balloon hide delay, default 4 seconds, can be increased up to 10 seconds.
We also updated the the component to use the latest SDK.
or
  • GeSomeone
Reply #44
Thanks for keeping this handy toy up-to-date.
  • niver
Reply #45
v0.5.11.1 is now available.
We have been requested to remove the "Hide Icon" feature as it's possibly against the Foobar2000 SDK terms.
In the latest version of Foobar2000 there is already an option to do so, in the user interface components (colums ui and default ui). Check your Default UI settings.
or
Reply #46
Hi, thanks for a great plug in
For some reason in the FORMAT box  %length% works fine but %playback_time% returns a question mark ?, is this a bug?
  • niver
Reply #47
Try %length%.
%playback_time% is the current playback position and is not available for a static display such as the pop-up balloon.
Reply #48
Try %length%.
As I said %length% is working fine but I wanted to be able to show the elapsed time too to replicate the display on the status bar which I have hidden. That's a shame, no way to show a changing display then?
  • niver
Reply #49
Try %length%.
Sorry, balloons are static.
