Topic: A good mmpc foobar display config? (Read 64287 times) previous topic - next topic
Reply #75
making some updates to your config, ojdjodododo
will post it once i work out some kinks in the translation to english
Reply #76
Hehe I had the same technicality...
Reply #77
alright, here it goes:
EDIT: Fixed my errors. will post if any more come up
http://stashbox.org/11073/01_30_2007-01_48...s-Oceansize.png
additional info on, timecodes off
http://stashbox.org/11074/01_30_2007-01_48...s-Oceansize.png
addinfo on (not currently displaying), timecodes on
http://stashbox.org/11075/01_30_2007-01_50...s-Oceansize.png
addinfo on (not currently displaying), timecodes off
basically, if addinfo on forces total times to display during the first and last 30 seconds (when the addinfo is displaying)
timecodes on force all time information to display at all times
REQUEST: only display the album title (if you look in the "working" pic, you can see it under the bottom right of the album art) if there is no album art.
anyway, here's the code.
// Global
// CONFIGURATION ///////////////////////////////////////////
// Album Art
// Use $if and $fileexists if more locations need to be checked
$puts(path.albumart,$replace(%path%,$if(%disc%,$directory(%path%,1)\)%filename_ext%,folder.jpg))
// Additional info
// addinfo.show: delete the '1' to disable additional info
// addinfo.time: determines how long addinfo is shown
// timeinfo.show: change the '1' to '0' to disable the time codes displayed on the progress bar
$puts(addinfo.show,1)
$puts(addinfo.time,30)
$puts(timeinfo.show,0)
// Positions
// pos.horizon: y-position of the grey horizon gradient
// pos.shadow: increase to see more reflection of the cd-cover
// pos.artx: if changed, further changes will be necessary for text positioning
// pos.arty: change position of album art relative to horizon line
$puts(pos.horizon,$muldiv(%_height%,4,7))
$puts(pos.shadow,120)
$puts(pos.artx,$sub($div(%_width%,2),278))
$puts(pos.arty,$sub($get(pos.horizon),400))
// Fonts
// font.a, font.b: used by addinfo for a) filling text, b) values
$puts(font.track,$font(Calibri,16,,255-255-255))
$puts(font.album,$font(Calibri,8,,255-255-255))
$puts(font.artist,$font(Calibri,12,,255-255-255))
$puts(font.a,$font(Calibri,12,,150-150-150))
$puts(font.b,$font(Calibri,12,,255-255-255))
$puts(font.c,$font(Calibri,7,,255-255-255))
$puts(font.d,$font(Calibri,7,,225-225-225))
// Progress bar
$puts(bar.height,7)
$puts(bar.color,50-50-50)
// END OF CONFIG ///////////////////////////////////////////
// Background
$drawrect(,,,,brushcolor-0-0-0 pencolor-null)
$imageabs(,$get(pos.horizon),/images/htpc2/horizon.png,)
// PerTrack
// Album Art
$imageabs2(556,516,0,0,556,$add(29,$get(pos.shadow)),$get(pos.artx),$add(460,$get(pos.arty)),/images/htpc2/case.png,ROTATEFLIP-6)
$imageabs2(454,454,0,0,454,$add(-2,$get(pos.shadow)),$add(71,$get(pos.artx)),$add(460,31,$get(pos.arty)),$get(path.albumart),NOKEEPASPECT ROTATEFLIP-6)
$imageabs($get(pos.artx),$add($get(pos.shadow),299,$get(pos.arty)),/images/htpc2/shadow.png,)
$imageabs($get(pos.artx),$get(pos.arty),/images/htpc2/case.png,)
$imageabs2(454,454,0,0,454,454,$add(71,$get(pos.artx)),$add(31,$get(pos.arty)),$get(path.albumart),NOKEEPASPECT)
// PerSecond
// Pause Overlay
$if(%ispaused%,
$drawrect($add(71,$get(pos.artx)),$add(31,$get(pos.arty)),454,454,pencolor-0-0-0 alpha-150)
$alignabs($add(71,$get(pos.artx)),$add(31,$get(pos.arty)),454,454,center,middle)$font(Webdings,72,,255-255-255)';'
$drawrect($add(71,$get(pos.artx)),$add(460,31,$get(pos.arty)),454,$add(-2,$get(pos.shadow)),pencolor-0-0-0 alpha-150)
// Progress Bar
$ifgreater($muldiv(%playback_time_seconds%,%_width%,%length_seconds%),0,
$drawrect(0,$sub(%_height%,$mul($get(bar.height),3)),$muldiv(%playback_time_seconds%,%_width%,%length_seconds%),$get(bar.height),pencolor-null brushcolor-$get(bar.color))
// Trackinfo
$if($and($or($greater($get(addinfo.time),%playback_time_seconds%),$greater($get(addinfo.time),%playback_time_remaining_seconds%)),$get(addinfo.show)),
// Detailed
$alignabs($get(pos.artx),$add($get(pos.arty),493),522,$sub(%_height%,$get(pos.horizon),$get(pos.shadow),140),right,top)
$get(font.album)[%album%]$char(10)
$alignabs($add($sub($get(pos.artx),$div(%_width%,2)),12),$add($get(pos.horizon),$get(pos.shadow),60),556,$sub(%_height%,$get(pos.horizon),$get(pos.shadow),64),center,bottom)
$get(font.c)'0:00'
$alignabs($sub($add($get(pos.artx),$div(%_width%,2)),12),$add($get(pos.horizon),$get(pos.shadow),60),556,$sub(%_height%,$get(pos.horizon),$get(pos.shadow),64),center,bottom)
[%length%]
$alignabs(80,$add($get(pos.horizon),$get(pos.shadow)),$sub(%_width%,160),$sub(%_height%,$get(pos.horizon),$get(pos.shadow),64),center,bottom)
$get(font.track)$if2(%title%,%filename%)$char(10)
$get(font.artist)[%artist%]
$char(10)$font(Arial,10,,0-0-0) $char(10)
$if(%last_played%,$get(font.a)Played $get(font.b)%play_counter%$get(font.a) time'('s')'', 'last on $get(font.b)$substr(%last_played%,9,10) $select($substr(%last_played%,6,7),January,February,March,April,May,June,July,August,September,October,November,December) $substr(%last_played%,1,4)$get(font.a).$char(10))
$if(%playback_time_seconds%,$get(font.a) $if(%album%,From the album $get(font.b)%album%$get(font.a)))$if(%date%,', 'published in $get(font.b)%date%$get(font.a) )$if(%publisher%,by $get(font.b)%publisher%$get(font.a))
// Default
$alignabs($get(pos.artx),$add($get(pos.horizon),$get(pos.shadow)),556,$sub(%_height%,$get(pos.horizon),$get(pos.shadow),64),center,bottom)
//time codes
$if($greater($get(timeinfo.show),0),$alignabs($add($sub($get(pos.artx),$div(%_width%,2)),12),$add($get(pos.horizon),$get(pos.shadow),60),556,$sub(%_height%,$get(pos.horizon),$get(pos.shadow),64),center,bottom)
$get(font.c)'0:00'
[%length%]
$alignabs($add($sub($get(pos.artx),$div(%_width%,2)),$muldiv(%playback_time_seconds%,%_width%,%length_seconds%),-11),$add($get(pos.horizon),$get(pos.shadow),51),556,$sub(%_height%,$get(pos.horizon),$get(pos.shadow),64),center,bottom)
$get(font.d)[%playback_time% ]
$alignabs($add($sub($get(pos.artx),$div(%_width%,2)),$muldiv(%playback_time_seconds%,%_width%,%length_seconds%),13),$add($get(pos.horizon),$get(pos.shadow),51),556,$sub(%_height%,$get(pos.horizon),$get(pos.shadow),64),center,bottom)
$get(font.c)[ -%playback_time_remaining%],)
Reply #78
in the above code, how do i place text relative to the progress bar?
both just on the far left (static), the far right (static), and moving along with the progress bar
EDIT: figured it out, and added it to the above code.
Reply #79
My new config; a mix of stuff by ojdo and FofR, with a tiny bit added by myself  :
Both clickable.
First the default layout:
And extra info, first and last 30 seconds of a track:
So thanks again ojdo (and of course FofR).
Les mots d'amour...
Reply #80
for those who like pictures.
Reply #81
ummm....
http://stashbox.org/10804/01_27_2007-13_59...ian-Circles.png
why does that not work at all?
I'm still having the same problem as the image you posted here.  In other words, I'm getting the album image reflected at the bottom, but it's not faded, and I'm not getting the horizon image.  Can you tell me what you did to fix the problem you had?  Or can anyone else tell me what I might have that's conflicting, or have done wrong?  I pasted the code directly.
I installed custominfo but that didn't fix it.
I'm using Foobar 0.9.4 and trackinfomod .0.8.0
The path to those images on my computer is C:\Program Files\foobar2000\images\htpc2\
Thanks for any help, I'm not too great at messing with this kind of coding.
Reply #82
theres your problem
put the images in c:\documents and settings\YOURNAME\application data\foobar2000\images\htpc2
Reply #84
slight updates:
made album art smaller
added background image
Reply #85
My edit
move cd
http://www.youtube.com/watch?v=iHL5DM4NaO4
Reply #88
and movie
It's ok , now ?
Reply #89
thanks for the ideas here.  very cool.  just thought i'd post my slightly modified version, possibly useful to others like myself with slow machines. no different visually, but i optimized it for my slow via chipset.  went from over 30-35% cpu usage during playback down to 10-15%.  i basically just took out all of the "addinfo" timing stuff... all info displays for the whole track.  also took out the case image.
and two questions...
first, the line that gives the playback stats updates in the middle of playing.  is there a way i could just have that update at the beginning of each track, and not in real time as the tag/database information changes?
second, could somebody help me with the syntax for displaying a default "no cover" image?  i.e. i have a "default.gif" in the components folder that should display when no folder.jpg is found in the album's folder.
thanks
// Global
// Album Art
// Positions
$puts(pos.artx,$sub($div(%_width%,2),290))
// Fonts
$puts(font.track,$font(Calibri,24,,255-255-255))
$puts(font.artist,$font(Calibri,18,,255-255-255))
// Progress bar
$puts(bar.height,7)
// Background
// PerTrack
// Album Art
$imageabs2(454,454,0,0,454,$add(-2,$get(pos.shadow)),$add(54,$get(pos.artx)),$add(454,31,$get(pos.arty)),$get(path.albumart),NOKEEPASPECT ROTATEFLIP-6)
$imageabs2(454,454,0,0,454,454,$add(54,$get(pos.artx)),$add(31,$get(pos.arty)),$get(path.albumart),NOKEEPASPECT)
// PerSecond
// Pause Overlay
$if(%ispaused%,
$drawrect($add(54,$get(pos.artx)),$add(31,$get(pos.arty)),454,454,pencolor-0-0-0 alpha-150)
$alignabs($add(54,$get(pos.artx)),$add(31,$get(pos.arty)),454,454,center,middle)$font(Webdings,72,,255-255-255)';'
$drawrect($add(54,$get(pos.artx)),$add(454,31,$get(pos.arty)),454,$add(-2,$get(pos.shadow)),pencolor-0-0-0 alpha-150)
// Progress Bar
// Default
$if(%last_played%,$get(font.a)played $get(font.b)%play_count%$get(font.a) times', 'last on $get(font.b)$substr(%last_played%,9,10) $select($substr(%last_played%,6,7),january,february,march,april,may,june,july,august,september,october,november,december) $substr(%last_played%,1,4)$get(font.a)$char(10))
$get(font.a) $if(%album%,from the album $get(font.b)%album%$get(font.a))$if(%date%,', 'published in $get(font.b)%date%)
Reply #90
at this point in the code:
// PerTrack
// Album Art
change it to
// PerTrack
// Album Art
$if($fileexists($replace(%path%,%filename_ext%,folder.jpg)),
$imageabs2(454,454,0,0,454,$add(-2,$get(pos.shadow)),$add(54,$get(pos.artx)),$add(454,31,$get(pos.arty)),PUTTHEFILEPATHHERE,NOKEEPASPECT ROTATEFLIP-6)
$imageabs2(454,454,0,0,454,454,$add(54,$get(pos.artx)),$add(31,$get(pos.arty)),PUTTHEFILEPATHHERE,NOKEEPASPECT)
where i've written PUTTHEFILEPATHHERE, put the... well... file path. for your alternate "no cover" image.
i have it as just
// PerTrack
// Album Art
so nothing shows up when there's no album image.
Reply #91
drake- thanks, that worked like a charm.
Reply #92
And... quicker than expected I finished version 2 of my fullscreen layout (version 1). This time it is much better coded and highly configurable. Credits go to FofR for inspiration and Cyex for his beautiful cd cover.
Preview
[a href=\"http://www.galsch.de/files/open/screenshots/2007-01-27--fb2k-htpc2-1.png\" target=\"_blank\"] Thanks. I love this, but I am having one problem.
I do not get the reflection of the CD case.
[a href=\"http://img263.imageshack.us/my.php?image=minenz6.png\" target=\"_blank\"]
foobar2000 + EAC + Burrrn = Happiness
Reply #93
Both clickable.
[a href="http://tinypic.com/4fudr1y.png" target="_blank"] ) but also, leokennis, can you share your background
Reply #94
.....I modified the code from your first codebox to change the language to English, to remove the progress bar, remove the "last played" etc. stats, and to show all the additional info the whole time), but even if I copy/paste your first codebox exactly I still don't get the cd case reflection, as can be seen here:
Can anyone figure out what is going wrong?
thanks in advance for any help.
Please don't fullquote, it makes the thread very difficult to read. The most probable reason for the cd case reflection not displaying is an outdated (old) version of trackinfo_mod. The reflection uses the ROTATEFLIP-option which is the only difference between the both pictures (cd case and its reflection). Download the latest version of the plugin and try again.
And a request from my side: Can you point me to the direction where you found these "neon" icons? I'm looking for dock icons in this style but only found some for a few applications. Thanks!
HTH
ojdo
Reply #95
Both clickable.
Can't find any reason it shouldn't work...try commenting out all the other images except the CD case and its reflection...
For my background: contact FofR, or else wait untill monday and I'll post it when I'm at my PC again
Les mots d'amour...
Reply #96
I am using 0.8.0 beta [Jan 5 2007], and I get the ROTATEFLIP on the album art just not the CD case.
.....damn it is frustrating.
Anyway...the buttons can be found here.
Reply #97
[a href="http://img375.imageshack.us/my.php?image=fb2kup6.jpg" target="_blank"] (a bit from everything and some from myself)
Reply #98
Well, after hours (literally) of trying each image line and everything working fine except the ROTATEFLIP on the case, I completly uninstalled foobar and reinstalled it and now my code works fine.
Go figure.
Reply #99
[pic]
my config  (a bit from everything and some from myself)
Very nice! My next config probably will have artist photos again.
Glad to hear that. Thanks for the link to the neon icons!
