Topic: foo_discogs (Read 762181 times) previous topic - next topic
  • wojtek
foo_discogs
Reply #1150
Release dialog is opened on the same display on which foobar is - not the one on which we put the "Find release" dialog -- it would be more convenient is the Release dialog followed "Find release" one (i.e. foobar2000 is playing on the side monitor, we want to tag an album while wanting to get better view of the search data so we place the dialog on the main monitor and after the search we have to repeat the steps for the Release dialog because it's opened on the side display.
http://foobar2000.pl/ :: unofficial polish forum
  • fuffi
foo_discogs
Reply #1151
hi bubbleguuum,
i'd like to suggest for a later version, that we (the users of your fine extension) could better seperate the releases shown.
if you take a look at the screenshot, you can't say what is the ALBUM, or the SINGLE of the shown Master of Avalon.
Just add anything so we can see what release/master we are clicking :-)
thanks
  • Tilo
foo_discogs
Reply #1152
Hi guys,
First, I want to thank bubbleguuum for this great plugin.
I've been using it for a while and only recently I have no results when fetching the artist list. I reinstalled a new version of foobar and latest foo_discogs but still no results.
I made sure to try with artists listed in the database but so far no success.
Could it be coming from my network or am I simply missing something?
Thanks for your help.
  • zaede
foo_discogs
Reply #1153
Hi guys,
Since a long time same problem. Didn`t find solution
foobar2000 best player ever
  • bubbleguuum
  • Developer
foo_discogs
Reply #1154
Hi guys,
Untick the "Exact matches" checkbox found in the "Find Release" dialog (see screenshot 2 posts above this one).
That should help
  • Last Edit: 04 November, 2011, 05:52:53 AM by bubbleguuum
  • zaede
foo_discogs
Reply #1155
That should help
Artists always be found but never the releases !
  • bubbleguuum
  • Developer
foo_discogs
Reply #1156
That should help
Clear the "Filter" text field in the dialog ?
  • fuffi
foo_discogs
Reply #1157
i can confirm this (at least, replace 'always' with 'sometimes').
i don't have an incident right now, but it seems, that sometimes the plugin swallow up some releases.
i remember being confused when using the websearch with the same pattern as the plugin, the websearch of dg shows more results.
i'll try to remember using the api via the web if this is possible? so i (we all) could test if the plugin shows the same as the api shows.
as far as i understand, the websearch is a bit different from the api?
  • Last Edit: 04 November, 2011, 07:52:14 AM by fuffi
  • zaede
foo_discogs
Reply #1158
No way. It`s strange !
If i wright the release number in " Release id  or url" and than Next it works.
http://www.hydrogenaudio.org/forums/index....st&p=771425
  • Last Edit: 04 November, 2011, 07:52:56 AM by zaede
  • Tilo
foo_discogs
Reply #1159
Did more testing but even with "exact matches" and "filters" turned off I can't get any artist list.
Searching by "Release id or url" send me the following "discogs error: release id=3198961: problem connecting to discogs.com"
I have no problem connecting the discogs site though. Enabling a proxy leads to the same error.
  • Zarty
foo_discogs
Reply #1160
Just tried discogs out for the first time on a sample of tracks.  About 1 in 5 worked.  I was getting this error most of the time...
Very promising though.  Hope I can get it to work for me!
Zarty
  • Emerelle
foo_discogs
Reply #1161
Hmm, did you get that error after you selected one of the results? Cause thats one of the things to watch out for, it returns an error if you just hit enter without selecting one of the releases from the right pane.
I love discogs plugin and couldnt live without it. Fortunately, it works fine with most of my tracks.
  • Zarty
foo_discogs
Reply #1162
Doh!  Ok, user error.  Now all I need it to do is work on more than one track at a time. :-)
Zarty
  • Emerelle
foo_discogs
Reply #1163
Haha, happened to me the first 100 times I tried that plugin!  Im glad you got it sorted.
I am still kind of baffled that so many people have problems with this plugin (not seeing releases etc). I never had that happen, also no crashes.
  • Zarty
foo_discogs
Reply #1164
The other thing that when wrong initially was that although I had got to the point where the correct album was displayed, I didn't select the correct track in the right way.  As a result, the wrong track details were written to the file.  I'm not sure what happened exactly but selecting the correct track and moving it to the top of the track list always works so that's what I do now.
Zarty
  • Emerelle
foo_discogs
Reply #1165
Yes, that is one of the things you have to fiddle around with using this addon: the track lists must be totally identical on both sides (release title list and your file list) _incuding_ all gaps/empty lines. Otherwise the wrong info goes into the files. That's one of the things I hope will get improved maybe in future release
  • ledge
foo_discogs
Reply #1166
How else do you expect it to know what tags to put to what file? Of course the files on either side must match.
You might want to try unticking "Automatically match discogs tracks to local tracks, based on track length where available" in the preferences. I found this cocked things often enough for me that it wasn't worth using. As long as your tracks are in the correct album order to start with you should be fine.
  • Emerelle
foo_discogs
Reply #1167
Sorry you got me entirely wrong: that was no complaint. Im fine with it. And I have that unticked, nevertheless files need to be exactly on the same level - what I hope for is a better handling of gaps once you remove files from the list.
  • fuffi
foo_discogs
Reply #1168
i also completley do not understand the intention of having blank lines when deleting a file on the right side.
deleting a track on the left side does not leave a blank line, the rest of the listed tracks (under the deleted one) will just go one level up (as expected), why does the behaviour differ, when deleting a file from the list on the right side?
maybe we can sum the benefits here, so i can see how i could use that feature.
  • Emerelle
foo_discogs
Reply #1169
Exactly this is what was "bugging" me just a little bit: the blank lines on the right side, thats what I was hoping for to get fixed some time. And it is just a pitfall for new users when they update their files and dont know that the wrong info will be written when the files are not on exactly the same level (including blank lines). And I have no idea what this behaviour might be good for, I just got used to it
  • Last Edit: 20 November, 2011, 08:10:07 AM by Emerelle
  • Torava
foo_discogs
Reply #1170
What's wrong with track order? This happens too often.
  • Last Edit: 26 November, 2011, 06:56:58 AM by Torava
  • frogworth
foo_discogs
Reply #1171
The answer's on this very page. Untick "Automatically match discogs tracks to local tracks, based on track length where available" in the preferences.
  • fuffi
foo_discogs
Reply #1172
(i suggested it already) it would be useful to have the configuration setting *inside* the release-window to switch it on/off in realtime. maybe with realtime sorting, so the user could see how the tracks change on his click.
don't know, but i think this might could prevent some of this "allready asked" questions.
foo_discogs
Reply #1173
Thanks for this great component!
Could you please add an option to remove all existing tags, like the freedb component has?
  • Last Edit: 26 November, 2011, 12:25:51 PM by Lucky Luciano
  • Anakunda
foo_discogs
Reply #1174
Hello, I find one annoying thing on Discogs tagger, sometimes I get the record for queried album with tracklist in shuffled order, I don't know if that's a bug or a feature, but in case of the latter I don't understand the sense of getting tracklist in shuffled order. It's not due to wrong track order at Discogs as the track numbers do match. How can I make Discogs plugin to sort tracks by tracknumber always?? Thanks
