Topic: foo_discogs (Read 1399481 times) previous topic - next topic
0 Members and 8 Guests are viewing this topic.
foo_discogs
Reply #975
I have had the same issue a couple of times. I can live with doing it by hand - I just love this component so much  However, maybe you could come with a suggestion as to how this could be implemented? How should the info be written to the file?
foo_discogs
Reply #976
For a "multi tracks" track, you could consider adding the data for each field separated with either :
- ";" if this is a field that support multiple values.
- " / " if it doesn't.
That way, you keep the all the info of these tracks. It seems to me that it's just a simple concatenation job with a bit of fiddling in the advanced options for the multiple values support fields, but I'm not the one coding the plugin.
This situation happens quite often when you want to tag electro mixes, and I'm sure I'm not the one who would benefit from the support of these tracks.
foo_discogs
Reply #977
Is there an overview somewhere which fields DO support multiple values?
foo_discogs
Reply #978
Yes, look at :
tools > advanced > display > Properties dialog
there you'll be able to edit which fields are multi values, multi lines and so on.
foo_discogs
Reply #980
What about the download of album covers ?
foo_discogs
Reply #981
Any time i try to tag something i don't find never the cover on the discogs db, why??
One year ago i remember that my discogs was more capable to find albumart. :/
foo_discogs
Reply #982
check your discogs configuration options (I've had it get reset on me before): right click menu, tagging, discogs, configuration, album/artist art tab
foo_discogs
Reply #983
Oh gosh!! I'm a stupid!!! How i can forgot this option?!?!?
Thanks!!!!
foo_discogs
Reply #984
Anybody else not getting a response at the moment? I'm stuck on "Connecting to discogs". The site itself is working.
foo_discogs
Reply #985
i get this error message
discogs error: release id=186355: problem connecting to discogs.com
foo_discogs
Reply #986
not working today
foo_discogs
Reply #987
Today not working! Please fix it! I can't live without this plugin
foo_discogs
Reply #989
Not working here either.
Be patient, this has happened before, and the dev is usually responsive.
foo_discogs
Reply #991
bubbleguuum is king!
foo_discogs
Reply #993
bubbleguuum drinks awsomeness for breakfast
foo_discogs
Reply #995
Super, bubbleguuumm! The discogs plugin is absolutely basic for me.
foo_discogs
Reply #996
yeah!!
Just wanted to reiterate what everyone else is saying. foo_discogs is a cornerstone of my own foobar2000 experience, and the speed at which breakage is dealt with never fails to surprise me (especially considering the state of disrepair of foo_vorbisstream  )
With that, let's return to our regularly scheduled discussion of the component instead of celebration of the fix, shall we?
foo_discogs
Reply #997
I'd really like to have your input on what I posted earlier bubblegum (Post #976 & #978). Even a "not interested" would suffice
Thanks for the update.
foo_discogs
Reply #998
Not interested because this is a corner case not that easy to handle (and I'm not making significant change to the plugin at this point). In particular the way subtracks are identified for a track is *not* standardized in the returned data. In your example the submitter used 1.1...1.2...  but he could have used anything else.
So if it was to be done, the UI would have to provide a way  to manually indicate which subtracks form a single track.
foo_discogs
Reply #999
Fair enough, it's not really a deal breaker anyway but it does happen quite often in electro releases.
