Topic: foo_discogs (Read 1489483 times) previous topic - next topic
0 Members and 21 Guests are viewing this topic.
foo_discogs
Reply #925
please help me to let foo_discogs to download artist art to separate folder for example f:/images/artists/ALBUM ARTIST and create folder from %album artist% automatically on art download
i guest it all could be coded in Configuration - ArtistArt directory
That would be difficult as there are different artists with the same name (eg. Kiss (1), Kiss (2), ...).
You could use Biography View for the same purpose. It downloads pictures from last.fm and can be configured to write all files with %artist% as filename.
foo_discogs
Reply #926
there is something weird when i Write Tags:
first time everything is ok - there is atris name in Arists field
but if i need to Write Tags one more time - Artists field is empty (so i need to type manually)
it happends only after Write Tags action by Discogs plugin
is it possible to fiix?
thanks
foo_discogs
Reply #927
since today Discogs doesnt show me Releases list
could anyone confirm that?
foo_discogs
Reply #928
since about an hour or two ago, confirmed. I used it quite a bit earlier today and it was fine. now, not so much.
foo_discogs
Reply #929
but in only works if provide URL directly in "release id or url" window
foo_discogs
Reply #930
Confirmed, not getting any release results after the artist search
foo_discogs
Reply #933
It's the same here. I'm in good hope, this will get fixed soon.
The discogs plugin is excellent to put your music collection in multiple orders just with a few clicks.  Especially friends of electronic music get access to an enormous catalogue of artists and releases.
foo_discogs
Reply #934
I have the same problem today.  It's really disappointing that the "API" is dependent on the layout of the main site, since it seems like the implementation of the new artist pages broke the plugin.
foo_discogs
Reply #935
same here, Ive registered as a new user on hydrogenaudio today
just to show my support to the WONDERFUL Discogs plugin, yeah
foo_discogs
Reply #936
There's a bug from discogs: the response on artists queries is invalid.
I've notified the site so it should be solved soon.
foo_discogs
Reply #937
Let's hope it will be solved soon as the discogs plugin is the best one for finding correct information about artists tracks and release year.
foo_discogs
Reply #938
Y'all know the workaround though, right?
Open up the Discogs dialog, search for your artist. You get the artists list anyway.
Double click on your artist, which opens up the artist page on Discogs.com. Select the release you want (not the master release), copy the Discogs ID (the number at the end of the URL), and paste it into the "Release id or url" field of the dialog (I guess that implies you can copy and paste the whole URL).
Then you're all good to go. Hit Next, check details, tag your files.
foo_discogs
Reply #939
Thanks!  That works great.  Hopefully this is a simple fix that won't take the developer long.
foo_discogs
Reply #940
its not the only thing that got messed up, as fetching artist art isnt possible anymore (artists dont get id in url anymore, only plain name)...
foo_discogs
Reply #941
This is a useful hint but it's only a temporary solution. I hope the plugin will be fixed soon.
foo_discogs
Reply #942
Now it's working perfectly again as before!
foo_discogs
Reply #943
Hello everybody,
i have a quastion:
it is possible that foobar will automatically replace discogs symbols é on e, è on e, à on a, ç on c, ü on u, ö on o, ä on a etc ?
foo_discogs
Reply #944
Would it be possible to add support for barcode field?
foo_discogs
Reply #945
Hi. This plugin is the greatest thing since heated food, however, I have a small problem. I name the downloaded cover art with "%album artist% - %album%" because some of my folders have multiple releases in them - but it seems that the Discogs plugin has a different conversion scheme for forbidden characters than foobar itself. All forbidden characters are converted to _ (underscore) which makes it impossible for the foobar cover view to find the image.
From the File Operations documentation:
    * Beginning in 0.9.6.4, symbols which are invalid in folder and file names such as / \ |: get replaced by a -, * gets replaced by x, " gets replaced with '', and ? < > get replaced by an _.
    * You may want to consider using $ascii() or $ansi() to sanitize the names when applying file operations.
Until this is corrected, I will continue using $replace(%album artist% - %album%,/,-,\,-,|,-,:,-,*,x,",'''',?,_,<,_,>,_).
foo_discogs
Reply #946
Also, foobar crashes when the Discogs component tries saving a cover with a path longer than 255 characters. This is a bug that should be corrected, but actually, Windows allows path up to 260 characters as the "c:\" and the ending null character is not included.
I would suggest that the Discogs component cuts off everything after 259 characters (from before the ".jpg") and that foobar cover display learns to do the same when looking for cover files. (By the way, how to suggest this to the respective developers?)
foo_discogs
Reply #947
May I also suggest that Discogs write album info to those of selected files that are outside the match-list in the component window. Sometimes one wants to add some extra track (maybe a web-only track) to a release that doesn't show up on the track-list from Discogs. So it doesn't match up with a particular track on the list to the left and doesn't get tagged at all.
I would like such a track to get all other info besides title and discogs_original_track_number (and vinyl track) (and artist for compilations). In my opinion it should have the real next tracknumber and have totaltracks the same as the original release to mark the track as extra.
foo_discogs
Reply #948
I would like to see track time along with search results.
(sorry my poor english)
foo_discogs
Reply #949
Dear bubbleguuum, are you aware of crashes from foo_discogs?
My foobar has been occasionally (but often enough that I notice) just crashing for no reason, while doing nothing.
I did the online check thing, and the only component I have that came up is version 1.25 of this component, which has had multiple reports of crashing.
Just letting you know. I certainly haven't had any cases of crashes while actually using the component. I'm on foobar v1.1.1, not one of the betas.
