Topic: foo_discogs (Read 1397951 times) previous topic - next topic
Re: foo_discogs
Reply #2175
Yeah, I'm unable to tag right now as well.
(FATAL) Error: Network exceptionSecurity error (url: https://api.discogs.com/database/search)
Re: foo_discogs
Reply #2176
Several others have had similar problems in WINE, you might want to search this thread. I think it's all related to Discogs forcing HTTPS and using TLS 1.2. Unfortunately I can't help with any linux WINE problems.
Re: foo_discogs
Reply #2177
First of all, thanks for this great component.
I run Foobar on Windows and I've just installed the latest version of foo_discogs, but I cannot tag, as I'm getting the same message as the guys - (FATAL) Error: Network exceptionSecurity error (url: https://api.discogs.com/database/search) - so it seems it's not the problem with Linux.
Re: foo_discogs
Reply #2178
Are you on Windows XP?
Re: foo_discogs
Reply #2181
I'm getting this:
(FATAL) Error: Error loading release 980209: Network exceptionSecurity error (url: http://api.discogs.com/releases/980209)
[ESCAPE to close]
I'm guessing that it's Discogs having some server issues.
Re: foo_discogs
Reply #2182
And so it was. Everything is working again.
Re: foo_discogs
Reply #2183
Correct you are. Thanks.
Re: foo_discogs
Reply #2185
yesterday there was a problem with the discoGS api, today it works again.
Re: foo_discogs
Reply #2186
Hi zoomorph,
I just tested the Update feature with about 10 Albums at once.
It is possible to walk through the albums with the "next" button, but there is no "prev" button, so if the user presses "skip" or "next", he cannot go back, to the last album to adjust/check something.
Can you please add such a button, so that "browsing" through the albums will be possible?
Also, It would be helpful to name the album anywhere, so users can read what album currently is selected.
Re: foo_discogs
Reply #2187
Hi zoomorph,
the "Abort" Button does not respond, while generating tags.
It only aborts *after* the generating is done, but that could take some minutes.
I presset the button about 50 times, but it did not abort, nor respond. It just generated the tags...
this happens when generating tags for a single album, as well when updating tags for multiple albums.
can you please make the abort button work in some kind of real-time? :-)
Re: foo_discogs
Reply #2188
Hi zoomorph,
we had discussed a bug which would "deactivate" the option to write/update tags, after some time of using the component.
I now maybe figured out, that these greyed-out options could come from pressing the abort-button or the X-button while a generating-/updating-/writting-task is ongoing.
the component maybe cannot close the task it is working correctly and therefore the user cannot open a new task like write-/update-tags again, because the zombie-task is somewhere in the background.
maybe it helps to reproduce, when creating some update-/write-tasks, which take longer (i.e. big compilations, or updating 10 albums at once) to generate and pressing the abort- or X-buttons impatiently, like I did :-)
I can reproduce it this way.
Re: foo_discogs
Reply #2189
Hi zoomorph,
this are my mappings:
when updating tags,
none of them are updated, the tags stay empty (I removed them for testing)
When writing tags normally, those tags are updated/written.
Author:  zoomorph
Version: 2.03
Compiled: May  8 2016
Re: foo_discogs
Reply #2190
Hi zoomorph,
Fixed in next release.
Great catch! Also should be fixed in next release.
Note: if track matching fails and the "prompt if..." option is disabled, those releases are currently silently ignored/skipped. Is that what's happening in this case?
Re: foo_discogs
Reply #2191
Re Album Art download & preference settings when tagging via foo_discogs:
a button "load album art" to load/save the found album art as set up in the preferences.
+1
Conversely to the above, I'd like a way to quickly toggle off saving album art when tagging particular releases.
Paradoxically, also +1! :D
I'd vote for having the preference (to download album art (and a preview / optional chooser [eg double click on album art image preview] if multiple are found, and in case one doesn't want the "first" ) right on the "Match Tracks" AND the "Preview Tags" windows as a little tick box to easily toggle between on/off (and a user pref setting if it should remember the last used, or if on or off should be the default).
Just a suggestion/opinion of course...
Cheerio.
c.
ps. nevermind the 'where's the preferences' question, found it [so I removed on edit from above...]. But, I get"(FATAL) Error: Image URLs unavailable - Is OAuth working?" constantly when Fetch/Display image is on.
But, Discogs is known to ban users/services if they are deemed to download/query too much image data regularly...  can anyone confirm it's still working ? I recently did a fresh fooobar & foo_discogs install, and there & then it worked last week. But now at home, w foobar 1.3.9 & foo_discogs 2.0.3 it does not and I only get the error above...
Re: foo_discogs
Reply #2192
Sorry if this has been asked before, but would it be better / possible to add a, or move the configuration subpage to File>Preferences>Tools>?
Re: foo_discogs
Reply #2193
I've been using discogs tagger in Debian under wine for quite a time without problems.
But now I get a error message (can't reproduce it now as I'm at my work).
Also when I try to authorize it again, same problem.
Even when I do it in a VM with windows 10.
cheers r3v0
<3 f00
Re: foo_discogs
Reply #2194
cheers r3v0
I don't know what happened, but it all works again.
cheers r3v0
<3 f00
Re: foo_discogs
Reply #2195
good question, how would I see that?
Now, what happens, is that nothing noteable is happening, when I try to update almost any albums or single files (from an album).
So I guess, its silently skipped.
I show you, what I'm doing:
I have an already (with you component) tagged file:
104. Moby - Alice (General Midi Remix).mp3
where I delete the tags: Artist, Track Title, Album Title and Date for testing.
(In the mappings configuration, I have those tags configures as write+update)
Now I start "Update tags"
[ ] prompt if track matching fails.
Write tags enabled for (o) Update
Result: nothing happens. tags are still empty.
  • prompt if track matching fails.
Result:
A Match Tracks (1/1) window pops up, showing me 5 tracks on the DiscoGS side and the single file on the Files side.
I delete the first 3 tracks and track 5 to match track 4 with my file.
I press Next
Nothing happens
(I expect, that the tags are written, but the tags are still empty)
Note: the Match Tracks (1/1) Window shows "Failed to match track order"
but the tracks are matching:
what about a button, which allows the user to start the track-matching process again? to renew the actual situation on the left/right side?
also it would be useful to activate the track matching not only in the configuration, but also in the match tracks window.
a back button would be useful too (which here goes to the initial "update tags" window)
Re: foo_discogs
Reply #2196
Hi zoomorph,
I'm getting this error:
while getting infos for Johann Sebastian Bach:
FireFox shows that, when entering the URL: https://api.discogs.com/artists/95537/releases
{"pagination": {"per_page": 50, "items": 15347, "page": 1, "urls": {"last": "https://api.discogs.com/artists/95537/releases?per_page=50&page=307", "next": "https://api.discogs.com/artists/95537/releases?per_page=50&page=2"}, "pages": 307}, "releases": [{"status": "Accepted", "thumb": "", "title": "The Brandenburg Concertos (Complete)", "format": "14xShellac, 12\", Album, Ltd, Boo", "label": "Columbia Masterworks, Columbia Masterworks", "role": "Main", "year": 1937, "resource_url": "https://api.discogs.com/releases/5860274", "artist": "Adolf Busch, Busch Chamber Players, Bach*", "type": "release", "id": 5860274}, {"status": "Accepted", "thumb": "", "title": "Brandenburg Concertos Nos. 2 And 3", "format": "3xShellac, 12\", Album, Mono", "label": "World's Greatest Music (2)", "role": "Main", "year": 1938, "resource_url": "https://api.discogs.com/releases/7355769", "artist": "Bach*", "type": "release", "id": 7355769}, {"status": "Accepted", "thumb": "", "title": "Sonata In E Minor For Violin And Figured Bass", "format": "Shellac, 12\"", "label": "Columbia Masterworks", "role": "Main", "year": 1942, "resource_url": "https://api.discogs.com/releases/3712055", "artist": "Adolf Busch, Artur Balsam* / J. S. Bach*", "type": "release", "id": 3712055}, {"status": "Accepted", "thumb": "", "title": "Matth\u00e4us-Passion", "format": "Shellac, 12\"", "label": "Polydor", "role": "Main", "year": 1945, "resource_url": "https://api.discogs.com/releases/1828838", "artist": "Joh. Seb. Bach*, Bruno Kittelscher Chor, Berliner Philharmoniker", "type": "release", "id": 1828838}, {"status": "Accepted", "thumb": "", "title": "Brandenburg Concertos No. 3 And No. 4", "format": "4xShellac, 12\", Album", "label": "RCA Victor Red Seal", "role": "Main", "year": 1945, "resource_url": "https://api.discogs.com/releases/5124908", "artist": "Bach*, Boston Symphony Orchestra Conducted By Serge Koussevitzky", "type": "release", "id": 5124908}, {"thumb": "", "artist": "J.S. Bach* - Wanda Landowska", "main_release": 3424978, "title": "Goldberg Variations", "role": "Main", "year": 1945, "resource_url": "https://api.discogs.com/masters/552590", "type": "master", "id": 552590}, {"status": "Accepted", "thumb": "", "title": "Suite No. 2 In B Minor For Flute And Strings", "format": "3x12\"", "label": "Columbia Masterworks", "role": "Main", "year": 1947, "resource_url": "https://api.discogs.com/releases/7787771", "artist": "Johann Sebastian Bach, The Pittsburgh Symphony Orchestra, Sebastian Caratelli", "type": "release", "id": 7787771}, {"status": "Accepted", "thumb": "", "title": "Concerto In D Minor For Two Violins And Orchestra \u2027 Concerto No. 2 In E Major For Violin And Orchestra", "format": "LP, Mono", "label": "Columbia Masterworks", "role": "Main", "year": 1948, "resource_url": "https://api.discogs.com/releases/5726486", "artist": "Bach* / Adolf Busch And Frances Magnes And The Busch Chamber Players", "type": "release", "id": 5726486}, {"thumb": "", "artist": "Bach* - Dietrich Fischer-Dieskau, Elfriede Troetschel*, Diana Eutrati*, Friedrich Haertel, Helmut Krebs, Boys Choir Of St. Hedwig's Cathedral*, Orchestra Of The Berlin Radio*, Chorus Of The Berlin Radio*, Fritz Lehmann", "main_release": 3111146, "title": "St. Matthew Passion", "role": "Main", "year": 1949, "resource_url": "https://api.discogs.com/masters/627336", "type": "master", "id": 627336}, {"thumb": "", "artist": "Gustav Mahler \u2027 Johann Sebastian Bach - Carol Brice Contraalto, With Fritz Reiner Conducting The The Pittsburgh Symphony Orchestra", "main_release": 7456522, "title": "Songs Of A Wayfarer \u2027 Sacred Arias", "role": "Main", "year": 1949, "resource_url": "https://api.discogs.com/masters/883343", "type": "master", "id": 883343}, {"thumb": "", "artist": "Johann Sebastian Bach / Karl M\u00fcnchinger, The Stuttgart Chamber Orchestra*", "main_release": 2367926, "title": "Suite No. 3 In D Major", "role": "Main", "year": 1949, "resource_url": "https://api.discogs.com/masters/269210", "type": "master", "id": 269210}, {"status": "Accepted", "thumb": "", "title": "Air / 4. Brandenburgisches Konzert In G-dur", "format": "Shellac, 12\"", "label": "ETERNA", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/1650960", "artist": "Johann Sebastian Bach", "type": "release", "id": 1650960}, {"status": "Accepted", "thumb": "", "title": "4. Brandenburgisches Konzert In G-dur", "format": "Shellac, 12\"", "label": "ETERNA", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/1650965", "artist": "Johann Sebastian Bach", "type": "release", "id": 1650965}, {"status": "Accepted", "thumb": "", "title": "4. Brandenburgisches Konzert In G-dur", "format": "Shellac, 12\"", "label": "ETERNA", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/1650977", "artist": "Johann Sebastian Bach", "type": "release", "id": 1650977}, {"status": "Accepted", "thumb": "", "title": "Konzert Fur Cembalo Und Streichorchester D-dur", "format": "7\"", "label": "Philips", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/4227911", "artist": "J.S. Bach*", "type": "release", "id": 4227911}, {"status": "Accepted", "thumb": "", "title": "Prades Festival - Vol. 10", "format": "LP, Album, Mono", "label": "Columbia Masterworks", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/4610126", "artist": "Bach* / Pablo Casals, Mieczyslaw Horszowski, John Wummer, Leopold Mannes, Yvonne Lefebure*", "type": "release", "id": 4610126}, {"status": "Accepted", "thumb": "", "title": "Prades Festival - Vol. 3", "format": "LP, Album, Mono", "label": "Columbia Masterworks", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/4655824", "artist": "Bach* / Pablo Casals", "type": "release", "id": 4655824}, {"status": "Accepted", "thumb": "", "title": "Prades Festival - Vol. 4", "format": "LP, Album, Mono", "label": "Columbia Masterworks", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/4655896", "artist": "Bach* / Pablo Casals", "type": "release", "id": 4655896}, {"status": "Accepted", "thumb": "", "title": "Prades Festival - Vol. 7", "format": "LP, Album, Mono", "label": "Columbia Masterworks", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/4655940", "artist": "Bach* / Pablo Casals", "type": "release", "id": 4655940}, {"status": "Accepted", "thumb": "", "title": "Prades Festival - Vol. 9", "format": "LP, Album, Mono", "label": "Columbia Masterworks", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/4772072", "artist": "Bach* / Pablo Casals", "type": "release", "id": 4772072}, {"status": "Accepted", "thumb": "", "title": "Series G: Keyboard Works", "format": "10\"", "label": "Archive Production", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/4932286", "artist": "Johann Sebastian Bach", "type": "release", "id": 4932286}, {"status": "Accepted", "thumb": "", "title": "Stokowski Conducts Bach (Volume I)", "format": "LP", "label": "RCA Victor Red Seal", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/5660482", "artist": "Bach* - Leopold Stokowski", "type": "release", "id": 5660482}, {"status": "Accepted", "thumb": "", "title": "Pr\u00e4ludium Und Fuge G-Dur (BWV 541)", "format": "LP", "label": "Archiv Produktion", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/5991822", "artist": "Johann Sebastian Bach, Helmut Walcha", "type": "release", "id": 5991822}, {"status": "Accepted", "thumb": "", "title": "Suite No. 2 in B Minor for Flute Solo, Strings, and Continuo", "format": "10\", Album, Mono", "label": "London Records", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/7308298", "artist": "Bach* - Andr\u00e9 P\u00e9pin, Doris Rossiaud, Stuttgart Chamber Orchestra*, Karl M\u00fcnchinger", "type": "release", "id": 7308298}, {"status": "Accepted", "thumb": "", "title": "Six Brandenburg Concerti Volume II", "format": "LP", "label": "Columbia", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/7809123", "artist": "J.S. Bach*, Fritz Reiner", "type": "release", "id": 7809123}, {"status": "Accepted", "thumb": "", "title": "Six Brandenburg Concerto Volume I", "format": "LP", "label": "Columbia", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/7809135", "artist": "J.S. Bach*, Fritz Reiner", "type": "release", "id": 7809135}, {"status": "Accepted", "thumb": "", "title": "Organ Music Volume III", "format": "LP, Album, Mono", "label": "Columbia Masterworks", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/8286280", "artist": "Albert Schweitzer, Mendelssohn*, Bach*", "type": "release", "id": 8286280}, {"status": "Accepted", "thumb": "", "title": "IX. Forschungbereich Serie A: Wie schon leuchtet der Morgenstern BWV 1/Christ lag in Todesbanden BWV 4", "format": "LP, Album, Mono", "label": "Archiv Produktion", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/releases/8366179", "artist": "Johann Sebastian Bach", "type": "release", "id": 8366179}, {"thumb": "", "artist": "Karl M\u00fcnchinger, Stuttgart Chamber Orchestra, The*, Bach*", "main_release": 4204175, "title": "Brandenburg Concertos No. 1 In F Major & No. 5 In D Major", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/masters/541873", "type": "master", "id": 541873}, {"thumb": "", "artist": "Bach* / Pablo Casals, Prades Festival Orchestra", "main_release": 7251293, "title": "Prades Festival - Vol. 2", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/masters/861581", "type": "master", "id": 861581}, {"thumb": "", "artist": "Bach* / Pablo Casals, Prades Festival Orchestra", "main_release": 4411180, "title": "Prades Festival - Vol. 1", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/masters/683280", "type": "master", "id": 683280}, {"thumb": "", "artist": "Bach* - Pablo Casals, Paul Baumgartner / Rudolf Serkin", "main_release": 1212759, "title": "Sonata No. 3 In G Minor For 'Cello And Piano / Chromatic Fantasy And Fugue In D Minor; Italian Concerto In F Major", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/masters/659733", "type": "master", "id": 659733}, {"thumb": "", "artist": "Bach*, Ena Mitchell, Kathleen Ferrier, William Herbert, William Parsons (2) With The Cantata Singers* And The Jacques Orchestra* Conducted By Dr. Reginald Jacques*", "main_release": 5726362, "title": "Cantata No. 11 \"Praise Our God\", No. 67 \"Hold In Affection Jesus Christ\" And \"Jesus, Joy Of Man's Desiring\" From Cantata No. 147", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/masters/848267", "type": "master", "id": 848267}, {"thumb": "", "artist": "Bach* / Pablo Casals", "main_release": 7388208, "title": "Casals Festival At Prades 1950", "role": "Main", "year": 1950, "resource_url": "https://api.discogs.com/masters/875731", "type": "master", "id": 875731}, {"status": "Accepted", "thumb": "", "title": "Air / Dance Of The Sprits", "format": "7\"", "label": "RCA Victor Red Seal", "role": "Main", "year": 1951, "resource_url": "https://api.discogs.com/releases/2428871", "artist": "J. S. Bach* / Gluck*, Arturo Toscanini And The NBC Symphony Orchestra", "type": "release", "id": 2428871}, {"status": "Accepted", "thumb": "", "title": "Concerto For String Quartet And Orchestra / Adagios And Fugues", "format": "LP", "label": "Columbia Masterworks", "role": "Main", "year": 1951, "resource_url": "https://api.discogs.com/releases/4972717", "artist": "Handel* - Sch\u00f6nberg* / Bach* - Mozart* : Manuel Compinsky Quartet, Janssen Symphony Orchestra Of Los Angeles*, Werner Janssen", "type": "release", "id": 4972717}, {"status": "Accepted", "thumb": "", "title": "Bach: The English Suites ", "format": "LP, Mono", "label": "Mercury Classics", "role": "Main", "year": 1951, "resource_url": "https://api.discogs.com/releases/5353982", "artist": "Johann Sebastian Bach, Edith Picht-Axenfeld", "type": "release", "id": 5353982}, {"status": "Accepted", "thumb": "", "title": "Mass In B Minor", "format": "3xLP, Album, Mono", "label": "Westminster Recording Co., Inc., Westminster Recording Co., Inc.", "role": "Main", "year": 1951, "resource_url": "https://api.discogs.com/releases/6151192", "artist": "Johann Sebastian Bach, Hermann Scherchen, Vienna Symphony Orchestra*, Akademie Kammerchor*", "type": "release", "id": 6151192}, {"status": "Accepted", "thumb": "", "title": "Easter Oratorio", "format": "LP, Album", "label": "The Bach Guild", "role": "Main", "year": 1951, "resource_url": "https://api.discogs.com/releases/7469453", "artist": "Johann Sebastian Bach, Vienna Chamber Orchestra*, Akademie Choir And Soloists*", "type": "release", "id": 7469453}, {"thumb": "", "artist": "Bach*, E. Power Biggs", "main_release": 7947724, "title": "Music of Jubilee", "role": "Main", "year": 1951, "resource_url": "https://api.discogs.com/masters/983147", "type": "master", "id": 983147}, {"thumb": "", "artist": "Johann Sebastian Bach, Vienna State Opera Orchestra* And Vienna Chamber Choir* Conducted By Felix Prohaska", "main_release": 5240385, "title": "J.S. Bach: Cantatas No. 140 Wachet Auf/No. 4 Christ Lag In Todesbanden", "role": "Main", "year": 1951, "resource_url": "https://api.discogs.com/masters/639321", "type": "master", "id": 639321}, {"thumb": "", "artist": "J.S. Bach* - Dietrich Fischer-Dieskau, Ristenpart Chamber Orchestra*, The Berlin Motet Singers*, Karl Ristenpart", "main_release": 8211545, "title": "Cantata No. 56 Ich Will Den Kreutzstab Gerne Tragen / Cantata No. 82 Ich Habe Genug", "role": "Main", "year": 1951, "resource_url": "https://api.discogs.com/masters/290737", "type": "master", "id": 290737}, {"thumb": "", "artist": "Johann Sebastian Bach", "main_release": 3268670, "title": "IX. Forschungsbereich \"Das Schaffen Johann Sebastian Bachs\" \u00b7 Serie B : Motteten \u00b7 Jesu, Meine Freude / Der Geist Hilft Unsrer Schwachheit Auf", "role": "Main", "year": 1951, "resource_url": "https://api.discogs.com/masters/547190", "type": "master", "id": 547190}, {"thumb": "", "artist": "J.S. Bach*", "main_release": 4494900, "title": "Magnificat", "role": "Main", "year": 1951, "resource_url": "https://api.discogs.com/masters/547172", "type": "master", "id": 547172}, {"status": "Accepted", "thumb": "", "title": "IX. Forschungsbereich: \"Das Schaffen Johann Sebastian Bachs\", Serie A: \"Kantaten\" \u00b7 \"Wie Sch\u00f6n Leuchtet Der Morgenstern\"", "format": "10\", Album", "label": "Archiv Produktion", "role": "Main", "year": 1952, "resource_url": "https://api.discogs.com/releases/2129828", "artist": "Johann Sebastian Bach - Berliner Philharmoniker - Berliner Motettenchor", "type": "release", "id": 2129828}, {"status": "Accepted", "thumb": "", "title": "Stokowski Music Of Bach", "format": "7\", EP", "label": "RCA Victor Red Seal, RCA Victor Red Seal", "role": "Main", "year": 1952, "resource_url": "https://api.discogs.com/releases/2259228", "artist": "Stokowski*, Bach*", "type": "release", "id": 2259228}, {"status": "Accepted", "thumb": "", "title": "Christians, Engrave Ye This Day! Christmas Cantata (No. 63)", "format": "LP", "label": "Vanguard", "role": "Main", "year": 1952, "resource_url": "https://api.discogs.com/releases/3080117", "artist": "J. S. Bach*, Vienna State Opera Orchestra*, Vienna Chamber Choir*", "type": "release", "id": 3080117}, {"status": "Accepted", "thumb": "", "title": "Brandenburg Concertos: No. 1 In G Major \u2022 No. 6 In B Flat Major", "format": "LP", "label": "Westminster", "role": "Main", "year": 1952, "resource_url": "https://api.discogs.com/releases/4955730", "artist": "Bach*, London Baroque Ensemble Conducted By Karl Haas", "type": "release", "id": 4955730}, {"status": "Accepted", "thumb": "", "title": "Mozart: Concerto No. 25 In C, K. 503 - Bach: Concerto For Three Pianos In C ", "format": "LP, Album", "label": "His Master's Voice", "role": "Main", "year": 1952, "resource_url": "https://api.discogs.com/releases/5806203", "artist": "Mozart*, Bach* - Philharmonia Orchestra, The*", "type": "release", "id": 5806203}, {"status": "Accepted", "thumb": "", "title": "XV Three-Part Inventions", "format": "LP, Mono", "label": "Decca", "role": "Main", "year": 1952, "resource_url": "https://api.discogs.com/releases/6121909", "artist": "J. S. Bach* - Lukas Foss", "type": "release", "id": 6121909}]}
Because the error won't show up all the time or shows up at 3/154 or 50/154 its hard to know, if this is a problem with your component or with the api or both. (Internet connection is stable at this time)
Would it be possible to continue from 49/154 if the process are interrupted at 50/154 ?
Now, it starts over from 1/154, which is...quite time consuming :-)
Re: foo_discogs
Reply #2197
It's probably as much a foobar syntax $replace/IF question as it is a foo_discogs one...
I'd love to have a discogs tagging & additional file-rename syntax of these 2, i.e. IF:
DISCOGS_CREDIT_REMIXED_BY - append to %title%
as well as:
DISCOGS_TRACK_CREDITS - IF "Remix" append to %title% (-Remix)
To be able to have the remix info from discogs directly in %title% as well as the fileName... and I can probably get a working $replace syntax going for the rename part after poking it for a while (haven't found anything for the check IF-DISCOGS_CREDIT_REMIXED_BY-exists check... if anyone has any pointers ?  ), but I'm not so sure how to do this with foo_discogs mapping...?
Cheers.
c.
Re: foo_discogs
Reply #2198
I'm not quite sure, I understand what you want to achieve, so I try to repeat:
After tagging your tracks with the component, you want the DISCOGS_CREDIT_REMIXED_BY-info for each song in the Title-Tag to be able to write them to your disk, like i.e. "01. My Artists - SuperDuperTrack (Remixed by MixMasterMorris).mp3" ?
If your answer is no, ignore this:
It will not be always automaticly working, because, i.e. this release has the remix information in the Title already (and no further remix-infos for the tracks) while this release has both of the infos and this release has the info, but a different remix info (too lazy for more examples...).
If this is no problem, you can try this code to add a tag called DISCOGS_CREDIT_REMIXED_BY to your files after taggin with the fine component:
[$puts(ROLE,Remix)$flatten($multi_if($any($multi_strcmp($sextend(%<<TRACK_CREDITS_SHORT_ROLES>>%,%<<RELEASE_CREDITS_SHORT_ROLES>>%),$get(ROLE))),$multi_if($put(aj,$sextend(%<<TRACK_CREDITS_ARTISTS_JOIN>>%,%<<RELEASE_CREDITS_ARTISTS_JOIN>>%)),$joinnames($put(an,$sextend(%<<TRACK_CREDITS_ARTISTS_NAME>>%,%<<RELEASE_CREDITS_ARTISTS_NAME>>%)),$get(aj)),$get(an)),))]
Later then, you can save it with this code for the File Name Pattern, from the File Operation Setup-Window:
$trim([%discnumber%][%tracknumber%. ][%artist% - ]%title%[' ('%DISCOGS_CREDIT_REMIXED_BY%')'])
Have a try...
The File Operation Setup-Window:
The Edit tag mappings-Window:
Re: foo_discogs
Reply #2199
I am just updated to the newest version with the new tag mapping dialogue.
I was looking for support for my standard function for assigning album artists.
If album artist (%<RELEASE_ARTISTS_NAME>%) matches artist (%<ARTISTS_NAME>%) then leave album artist empty, but only if true for the entire release.
In other words:  I just want to have an empty album artist in case it matches the artist for the entire release.
Is this doable?
