Topic: foo_discogs (Read 771921 times) previous topic - next topic
  • fbuser
foo_discogs
Reply #1175
Wow, only 25 hours after the last one asked this.
  • Anakunda
foo_discogs
Reply #1176
your`e right  thanks for quick link
  • runixer
foo_discogs
Reply #1177
hi, discover 1 minor bug in this great component: Doesn't working multi-value tag "Format". Description says: "Writen as a multi-value tag", but for delimiter in this tag foo_discogs uses ',' instead of ";"
  • somy
foo_discogs
Reply #1178
Thanks for the great plugin!
A quick question, is it possible to embed cover art directly in flac files instead of creating cover.jpg files in album folders?
Or to put it another way, what are the benefits of cover.jpg comparing to embedded cover art in each file?
  • klonuo
foo_discogs
Reply #1179
Don't know if this is reported or known, but there is possibility that [master] name and all release names are different, in which case release query fails because it's not same with [master] name
Example:
Release query "Inside the Cathedral" fails because master is named "Inside Russia"
http://www.discogs.com/Paul-Horn-Inside-Th...l/master/260048
foo_discogs
Reply #1180
I have downloaded the latest version but I keep getting the following error message when trying to use this plugin.
discogs error: release id=3166030: problem connecting to discogs.com
How can I fix it please?
  • somy
foo_discogs
Reply #1181
I have a newbie question, what is the difference betweeen tags with multiple values and single values such as DISCOGS_TRACK_CREDITS_MULTI and DISCOGS_TRACK_CREDITS?
I checked the content of both tags, and they look exactly the same (both use ";" to separate values).
Which tag is recommanded? Thanks!
  • Emerelle
foo_discogs
Reply #1182
@somy:
Multi fields can be displayed as seperate entities (for instance in EsPlaylists groupinfo) using $meta_sep.
I have a question myself now: In the settings dialog there are options to download images for both album and artist. I used $directory_path(%path%) for artist. Now I wonder if there is a way to make foo_discogs write the artists name to the filename? All I get is numbered files.
Similarly, for the album I use the prefix folder (same TF string) but it doesnt seem to be working.
  • somy
foo_discogs
Reply #1183
@somy:
Hi Emerelle,
Thanks for the reply, does it mean that in general "multi" tags are more preferred than single-value tags?
I need to decide which one to use as I don't want duplicate information in my flac files.
  • Emerelle
foo_discogs
Reply #1184
I'm sorry I cannot tell you really. I use it on the style tag, since I have the style displayed in EsPlaylists Groupinfo. There you can use that meta_sep, so all styles are lined up.
It all depends on how you view your media in your layout. In only columns playlists you wont find much use for this feature.
  • thorazine
foo_discogs
Reply #1185
@somy:
I think its not possible, its rather confusing the way it is. Both artist and album art should have the same formatting options.
It would be much better if we could format both files' full path using title formatting, only problem would be handling numbering when downloading all available album art files...
  • Emerelle
foo_discogs
Reply #1186
Thanks thorazine for your input. I also find it kind of confusing, since I am not sure if it takes TF or not. At least the files do get stored in the same folder as the music
Maybe I shouldnt advertise this here, but biography view does store the images with the artist name - more than one become artist_02.jpg, artist_03.jpg and so on. That would be a great feature for this plugin as well!
foo_discogs
Reply #1187
Need my foo_discogs working again!
  • komhst
foo_discogs
Reply #1188
Mine is still working although I received this mail from Discogs:
Hello,
We are writing to you because you have registered for a Discogs API key.
As mentioned here: http://www.discogs.com/help/forums/topic/234138
we will be phasing out the version 1 API and would like all current users to upgrade their clients to use the version 2 API.
API version 1 will be discontinued on Jan 15, 2012. Please make sure to upgrade your clients before then. And let us know if you have any questions.
thanks,
Discogs
  • Last Edit: 13 December, 2011, 07:22:40 AM by komhst
  • bubbleguuum
foo_discogs
Reply #1189
foo_discogs uses the new API  already so it continue to work after Jan 15th.
"problem connecting to discogs.com" errors are intermittent. Just retry later and it should work.
  • Last Edit: 13 December, 2011, 07:34:51 AM by bubbleguuum
  • djfonplaz
foo_discogs
Reply #1190
Hi!
I'd like on the discogs plugin get the information from a compilation.
Now, On Artist, I won't that Various Artist - Album Name, but for each track, the artist name. The same for the Track, I just need the track title.
How can I do it with the plugin? Thank you
  • Emerelle
foo_discogs
Reply #1191
EDIT: Oops, I guess I misunderstood your question. Not sure though, what you are looking for....?
For compilations, album artist is entered as Various Artists and the artists name is in the artist tag, so you got to make sure that in your viewer you are calling %artist% and not %album artist%. I hope that helps
  • Last Edit: 03 January, 2012, 06:07:48 PM by Emerelle
  • djfonplaz
foo_discogs
Reply #1192
Uhm...yeah on the viewer I have both, Album Artist and Artist. But both take the name of the compilation (Various Artists); so for each track in the compilation, I can't get the correct artist name. On the "Edit tag mappings" I have Artist as "DISCOGS_ARTIST", should be correct right? But in fact it doesnt works...I can't get Artist name for each track...
  • tapedeck
foo_discogs
Reply #1193
howdy
i'm getting the 'problem connecting' error again.
discogs error: release id=3345141: problem connecting to discogs.com
i'm assuming this is the same bug that has happened a couple times already where the discogs server changes address, or something like that.
will there be an update to address this soon?
what about making the discogs server (or whatever is causing the problem) a user-editable field as a preference for the plugin?
just an idea.
thanks
edit: this was when putting the release id in manually. when i search, i dont get an error and i get no results. thanks.
  • Last Edit: 15 January, 2012, 09:30:27 PM by tapedeck
  • MDMA
foo_discogs
Reply #1194
Is this not to do with the old API being phased out on the 15th Jan?
  • marc2003
foo_discogs
Reply #1195
no. look a few posts up.
  • laerm
foo_discogs
Reply #1196
Hi all --
Mine stopped working at some point between Tuesday and a week or so before it. (On two different machines, too.) I upgraded one install to the newest version of fb2k but no dice. Literally nothing happens when I hit search. I have v1.26 fix2 of the plugin. No errors come up, nothing shows in the console. Very odd. Any ideas? Thanks.
Micah
edit: I tried clearing the release cache too. Nope.
  • Last Edit: 19 January, 2012, 01:34:08 PM by laerm
  • frogworth
foo_discogs
Reply #1197
Try upgrading to v1.30?
  • laerm
foo_discogs
Reply #1198
Oh, I feel foolish: that worked. I thought discogs had screwed up all releases of the plugin post 1.26...? Serves me right. Sorry for the obvious question; thanks very much!
Micah
  • TGK
foo_discogs
Reply #1199
In what format must be entered plugin foo_discogs data in the following fields : Artist link, Label link, Release link?
The data are recorded, but here in the form:
If they are entered in this form, then they do not make any sense, in a form they just will not open in browser
Is it possible to do so they were recorded in standard URL- WebLinks, for example:
Artist link - http://www.discogs.com/artist/Nikolai
Label link - http://www.discogs.com/label/Sub+Terranean
Release link - http://www.discogs.com/Various-Ravermeiste.../release/129725
Is it possible to make the tag recorded in other fields other than <DISCOGS_ARTIST>, <DISCOGS_ARTIST_LINK>, ie in the field with the other names ?
