Topic: REACT 2 Released (Read 1296743 times) previous topic - next topic
0 Members and 8 Guests are viewing this topic.
REACT 2 Released
Reply #1600
When I open EAC via react.exe and press F4, nothing seems to happen.
Any advice would be appreciated.
At the risk of losing any respect, I must report the simplicity of my resolve. I have a multimedia keyboard and the "F Lock" key had deactivated my Function keys.  I stumbled across this today when Ctrl-F2, Alt-F10, Alt-F5, etc. also did nothing.
REACT 2 Released
Reply #1601
It seems strange to me that you have to edit the cfg file to even get the standard cuesheets copied to the destination directory.
Dunno why it wasn't included in other mods.. err, well in THE other mod. Why it isn't in my mod? Time & priority. The Wiki solution as it is, is not suitable for the mod. Especially not for tracks in the image mode. That needs work. I've had this in my ToDo list and I've a pseudo/abstract solution ready which would not use any external apps (GSAR/SED). Unfortunately REACT isn't perfect and needs some work, but since it's freeware, and it's quite stable, I say that it's a helluva good app.
My life situation has changed a bit and I'm really struggling to find time to develop REACT.. but, I haven't deserted it yet.. otherwise I wouldn't have been so active in the AAD XUI topic lately.
EDIT: Sorry for the late reply.
REACT 2 Released
Reply #1602
I was using EAC 0.99pb4 with REACT and the required mod a few month ago (windows xp 32bit) and everything worked fine. Now i had to download the latest version of each component and tried it with windows 7 64bit - i can not get it back working again. My goal is to rip a cd into a single flac file with a cue sheet (with replaygain_albumgain entry in it) and the cover art.
I reached a point where the cue sheet is created (looks very differently to what i want), but maybe it gets rewritten during the process. The extraction does not start, it seems that REACT can not create the neccessary folders: there is an error popping up telling me the specified folder does not exist, which is perfectly correct, but REACT is not able to create it. I granted every user i could imagine full access to the react folder and the extraction base folder. I use a domain user, so the domain user, the domain admin, the local admin, system and everyone have full access to the folders.
Is this some sort of security issue? Is some inheritance feature doing stuff i don't understand? Is it my 64bit win7?
I hope someone can help, i just want to continue ripping my cds as i started.
REACT 2 Released
Reply #1603
First, which mod are you using, and what version? EAC 0.99pb5 is only supported by my latest mod BTW.
Have you read my mod notes about Vista (& Win7)?
Also, what's the (perfectly correct??) error message? From EAC or REACT?
Can you shortly describe (steps) what you do when you use REACT to rip? And what error messages or any oddities you see.
Let's start with these.
REACT 2 Released
Reply #1604
I have b04 of your mod, i hope that's the latest. I'd gladly switch back to what i had a few month ago, but i can't find the 0.99pb4 anymore. For reasons of simplicity i use "c:\eac\" as my root directory, because i don't know if the folder structure of win 7 is 100% supported and because the user folders are mapped to a network drive (i wanted to eliminate possible sources of errors, and "c:\eac\" sounds simple enough).
The dialog i get want's to store a file named the way i want to name the image, the ending is ".eac". The path is as i defined it (artist\cdtitle), and it starts below my root (c:\eac\). The only problem is, that neither EAC nor REACT can create that directory automatically, i have to create it manually. I gave every user that could possible access the folder full access. The user i start can not use REACT, i get the windows dialog asking for admin rights (domain controller admin, in my case). I assume the problem is somewhere connected to win7 and/or the domain user, but i could not figure it out yet. If i had another good plextor drive i'd set up a "ripping station" with windows xp ... The moment i get the dialog there's a cuesheet in my root ("s" type cue), and it is missing the replaygain entries, which is probably normal, because the process of reading the tracks has not started yet.
REACT 2 Released
Reply #1605
I still don't fully understand what you're doing, you didn't describe the steps you take when using REACT to rip.. BUT it seems that you should first solve the problem with user rights. I'll take it that if you start just EAC and try to rip an image, you'd get the same problems..? I quickly looked at EAC forum and there's some problems with Win7 and/or x64 when using EAC.. dunno if related though.
I'm not an expert with Win7 and user rights, all I can say is that follow the instructions described here: mod notes about Vista (& Win7). I can help with REACT problems after you solve the user rights problem.
I think that there's some HA users who use Win7 and REACT, can you help out here?
REACT 2 Released
Reply #1606
How come Album Art Downloader XUI doesn't start when I press F4? Here is my ini, the settings part:
[Settings]
Version=2.0.akku.b04
ImageExt=wav
ImageNaming=$artist$ - $album$
ImageHotKey={F10}
TracksHotKey={F4}
TracksHotVal=+{F5}
VA=Various Artists
CreateCuesheet=
CoverDownloaderXUI=1
RunCoverDownloader=1
CoverDownloaderXUI=C:\Program Files\AlbumArtDownloader\AlbumArt.exe
CoverDownloaderLocalPath=
OpenAddMetaDataDiag=0
EAC=C:\Program Files\Exact Audio Copy\EAC.exe
Tools=C:\Program Files\REACT2\tools
MinimizeCompressionWindow=1
ProcessPriority=1
Sla_Bks_Col_Qst_Bar_Quo_Ast_Lt_Gt=-|-|-||!|'|#|[|]
Test=0
REACT 2 Released
Reply #1608
Is there a way to pass the lowpass parameter to LAME while using REACT?
Do I add "--lowpass <frequency in Hz>" to the "Additional Command Line Options" in EAC?
REACT 2 Released
Reply #1609
Amending the Opt_LameMP3 setting in REACT.ini file!?
REACT 2 Released
Reply #1610
Hi! And good evening from germany.
Before I do start to ask for help/support, I would like to say "thanks" to those who developed REACT 2.0 + for those who spend their time in this forum to support other people.
Well, I guess I am doing something wrong, but I do not know what; so I'll try to explain what I am doing and whats not working the way I think it should do:
1. Insert Audio CD.
2. Push "F10" for FLAC image and MP3 tracks
=> After appro. 15 sec.: Pop Up:
"Unable to move cuesheet. File does not exist.Canceling will abort the rip."
I can choose (in german language): "wiederholen" or "abbrechen" = "retry" or "abort".
When I choose "retry" the same msg. will appear again, after approx. 25 sec. and so on.
With other words: Nothing started.
If I choose "abort", well, nothing starts.
Some details:
OS: Windows XP Professional
EAC: V0.99 prebeta 5 from 4. Mai 2009
REACT 2.0: v2.0.akku.b03
react.ini
[Settings]
Version=2.0.akku.b03
ImageExt=flac
ImageNaming=$artist$ - [$year$] $album$
ImageHotKey={F10}
TracksHotKey={F4}
TracksHotVal=+{F5}
VA=Various Artists
CreateCuesheet=mg
RunCoverDownloader=0
CoverDownloader=C:\Programme\AlbumArtDownloader\Albumart.exe
EAC=C:\Programme\Exact Audio Copy\EAC.exe
Tools=C:\Programme\Exact Audio Copy\REACT 2.0\tools
ProcessPriority=1
Test=0
[UserTrackFormats]
Flac=0
Wavpack=0
LameMP3=1
NeroAac=0
iTunesAac=0
OggEnc2=0
Tak=0
[UserOutputNames]
OutRoot=F:\01 Musik\00 EAC
ImageDir_Flac=@OutRoot@\FLAC-images\$cdartist$
ImageDir_Wavpack=@OutRoot@\WV-images\$cdartist$
ImageDir_MP3=@OutRoot@\MP3-images\$cdartist$
ImageDir_Tak=@OutRoot@\TAK-images\$cdartist$
TrackDir_Flac=@OutRoot@\FLAC\$cdartist$\$year$.$album$
TrackDir_Wavpack=@OutRoot@\WV\$cdartist$\[$year$] $album$
TrackDir_MP3=@OutRoot@\MP3\$cdartist$\$year$.$album$
TrackDir_AAC=@OutRoot@\AAC\$cdartist$\[$year$] $album$
TrackDir_OGG=@OutRoot@\OGG\$cdartist$\[$year$] $album$
TrackDir_Tak=@OutRoot@\TAK\$cdartist$\[$year$] $album$
TrackName_SA=$track$ - $title$
TrackName_VA=$track$ - $title$ [$artist$]
TrackName_SA_acdir=$n - $~t
TrackName_VA_acdir=$n - $~t [$~a]
[UserSettings]
DebugMode=1
Debug=1
Comment=Created with EAC/@reactversion@, @curdate@
EmbedCover=1
ReplayGain=1
ApplyAlbumGain=1
AdjustAlbumGain_dB=+3.0
AddCuesheetAG=0
UseWaveGainAG=0
Opt_Flac=-5 -f
Opt_Wavpack=-hmy
Opt_LameMP3=-V2 --vbr-new --noreplaygain --nohist
Opt_NeroAac=-lc -q 0.21
Opt_iTunesAac=-d -s 2000
Opt_OggEnc2=-q 3.0
Opt_Tak=-pN -overwrite
Ver_Flac=1.1.3
Ver_Wavpack=4.40
Ver_LameMP3=3.97
Ver_NeroAac=1.0.0.2
Ver_OggEnc2=2.83 Lancer aoTuV b5
Ver_Tak=1.0.1
[DefaultMetaData]
discnumber=1
totaldiscs=1
discname=
What did I wrong?
Hope to get some hints were to look ...
Regards
roloff
REACT 2 Released
Reply #1613
Always try the newest version before reporting problems. There's a 2.0.akku.b04 version (check the full changelog) which has one fix* to the very problematic cuesheet generation part of REACT, hopefully that will fix your problem. (Boy, I hope so.. )
EDIT: Just noticed that you've DebugMode and Debug on in your INI, you can turn them off if you don't have problems.
* "Fixed cuesheet generation again; the indices and gaps detection windows were detected in wrong order. This made REACT error with CD's that had lots of track indices."
Try unchecking  "Retrieve UPC/ISRC code in CUE sheet generation" in EAC.
That's VERY old information, there's NO need to turn off that setting with my mod (2.0.akku.b03 or newer).
REACT 2 Released
Reply #1614
Here the content of the debugging.txt:
2009-10-28 21:55:38  Creating [mg] cuesheet
2009-10-28 21:55:38  Waiting for the Indices Detection 'Analyzing' window to disappear
2009-10-28 21:55:39  Waiting for the Indices Detection 'Analyzing' window to disappear
2009-10-28 21:55:40  Waiting for the Indices Detection 'Analyzing' window to disappear
2009-10-28 21:55:40  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-28 21:55:41  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-28 21:55:42  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-28 21:55:44  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-28 21:55:45  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-28 21:55:46  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-28 21:55:47  Waiting for the UPC/ISRC Detection 'Analyzing' window to disappear
2009-10-28 21:55:48  Waiting for the UPC/ISRC Detection 'Analyzing' window to disappear
2009-10-28 21:55:49  Waiting for the UPC/ISRC Detection 'Analyzing' window to disappear
2009-10-28 21:55:50  Waiting for the UPC/ISRC Detection 'Analyzing' window to disappear
2009-10-28 21:55:51  Waiting for the cuefile to appear
2009-10-28 21:55:52  Waiting for the cuefile to appear
2009-10-28 21:55:53  Waiting for the cuefile to appear
2009-10-28 21:55:54  Waiting for the cuefile to appear
2009-10-28 21:55:55  Waiting for the cuefile to appear
2009-10-28 21:55:56  Waiting for the cuefile to appear
2009-10-28 21:55:56  Unable to move 'F:\01 Musik\00 EAC\Trouble No More.CUE'. File does not exist
2009-10-28 21:55:59  Aborting (cuefile doesn't exist)...
2009-10-28 21:55:59  Tried to delete all other cuefiles from 'F:\01 Musik\00 EAC\' directory
2009-10-28 21:55:59  - END - MoveCuesheet -
Any ideas?
Regards,
Roloff
REACT 2 Released
Reply #1615
Hei! Akkurat
Ymmärrän. Done. :-) Kiitos!
B u t:
... , hopefully that will fix your problem. (Boy, I hope so.. )
No, sorry. Still the same.
_______________
Additional information: if I do set CreateCuesheet=  (so, no value is set. space is empty) and press F10, than EAC starts, working ... and I do have:
...\FLAC-images\artistname\CUE + FLAC
...\FLAC\artistname\[year] album\*.flac (no CUE)
...\MP3\artistname\[year] album\*.MP3 (no CUE)
En ymmärrä. Why is the CUE in the folder?
Thats all I need, or????
Good night,
Hyvää yötä
Regards
Roloff
REACT 2 Released
Reply #1616
Still "Unable to move cuesheet.." errors?? Can you see the normal EAC "Detecting Pre-Track Gaps", "Detecting Track Indices" and "Detecting UPC/ISRC" (if you have that setting on) windows when you start to rip? Can you post the debugging.txt output for the new b04 version? Also, do you see the "F:\01 Musik\00 EAC\Trouble No More.CUE" (or whatever album you have) file although REACT gives you the error? And finally, does this "Unable to move cuesheet.." error happen with every CD? (don't have to test EVERYTHING )
When ripping in image mode (F10), EAC automatically creates a cuesheet for the image. The process is different when using REACT CreateCuesheet setting to produce cuesheet(s) for the tracks. REACT doesn't have to track the cuesheet generation process with image cuesheets.
The default REACT currently doesn't move cuesheets created with CreateCuesheet setting to the target folder(s). That's a bummer, I know, it's on my Todo list. Fortunately, with a bit of tinkering of the .cfg files, one can get file reference corrected cuesheets to the target folder(s); here's the Wiki guide: Amending Cuesheet File References.
EDIT: Oh, forgot to add that that guide is only for track mode (F4).
Well, it depends.. if you're making/keeping the FLAC images as a backup, then you don't need the cuesheet for the FLAC tracks (no point of saving a cuesheet for lossy Mp3 tracks).
Off topic: do you really need both FLAC image & tracks?
Toivottavasti tämä auttaa. HTH. Suomalainen? Finnish?
REACT 2 Released
Reply #1617
Just for info ... With win7 my React was not working properly.
I had to download and install in my windows\system32\ the file "msvcr71.dll".
This file is required for "acdir" cmd file (that .exe take a cue sheet and split to multiple file ...).
Before that, the result was only log in my destination directory.
REACT 2 Released
Reply #1618
Good morning!
Yes, still unable to move cuesheet..."
Nothing starts. F10 - waiting ... waiting ... (even the CD is not spinning) => Error msg appears.
Yes. Tested a few. Same result for all.
(I am happy that I do not have to test all CDs, very kind of you :-))
2009-10-29 08:28:02  Version: 2.0.akku.b04
2009-10-29 08:28:02  INI version: 2.0.akku.b04
2009-10-29 08:28:02  FileNamingConvention: %D - %C - %N - %T
2009-10-29 08:28:02  VariousFileNamingConvention: %D - %C - %N - %T (%A)
2009-10-29 08:28:05  EAC handle: 0x00090702
2009-10-29 08:28:08  Creating [mg] cuesheet
2009-10-29 08:28:08  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-29 08:28:09  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-29 08:28:10  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-29 08:28:11  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-29 08:28:12  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-29 08:28:13  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-29 08:28:14  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-29 08:28:15  Waiting for the Gap Detection 'Analyzing' window to disappear
2009-10-29 08:28:16  Waiting for the Indices Detection 'Analyzing' window to disappear
2009-10-29 08:28:16  Waiting for the UPC/ISRC Detection 'Analyzing' window to disappear
2009-10-29 08:28:17  Waiting for the UPC/ISRC Detection 'Analyzing' window to disappear
2009-10-29 08:28:18  Waiting for the UPC/ISRC Detection 'Analyzing' window to disappear
2009-10-29 08:28:19  Waiting for the UPC/ISRC Detection 'Analyzing' window to disappear
2009-10-29 08:28:20  Waiting for the cuefile to appear
2009-10-29 08:28:21  Waiting for the cuefile to appear
2009-10-29 08:28:22  Waiting for the cuefile to appear
2009-10-29 08:28:23  Waiting for the cuefile to appear
2009-10-29 08:28:24  Waiting for the cuefile to appear
2009-10-29 08:28:25  Unable to move 'F:\01 Musik\1 überarbeiten\4 selbst gerippt\01 EAC\Little Rock to Leipzig.CUE'. File does not exist
2009-10-29 08:28:26  Aborting (cuefile doesn't exist)...
2009-10-29 08:28:26  Tried to delete all other cuefiles from 'F:\01 Musik\1 überarbeiten\4 selbst gerippt\01 EAC\' directory
2009-10-29 08:28:26  - END - MoveCuesheet -
I'll keep the FLAC images as a backup, so its fine as it is.
No, I changed it.
German. Found just some finnish words. Thanks a lot for your help so far.
REACT 2 Released
Reply #1619
Roloff, did you abort/interrupt EAC while it was ripping a disc? Try going back to the directory set to '@OutRoot' in your REACT.ini file (and sub-folders), and delete all files related to incomplete rips that you find there. It might also help taking a look at "My Document -> My Music -> EAC" and its sub-folders. Of course, all this applies to Windows XP.  I don't know how the Windows 7 file system is organized.
It is possible that REACT2 expects a specific CUESheet file name, but EAC renamed your current CUESheet to something else since an old one already existed there. You may have to get rid of the files that are confusing REACT2. Try this and tell us if it works.
REACT 2 Released
Reply #1620
Rohangc, thanks, here my result:
No. F10 ... wait ... wait... EAC did not even start doing anything visual ... msg appears => I pressed "Abort".
If I press "retry" the debugging.txt will be longer ... But EAC will not start doing someting visual to me.
Msg. appears again and again until I press "abort".
I deleted all files in '@OutRoot@'. I deleted all files in "My Document -> My Music -> EAC" and its sub-folders.
Nothing changed. Msg. still apears.
What else can I do?
REACT 2 Released
Reply #1621
That's weird. You wrote that you got image+cue when not using CreateCuesheet, perfectly normal, but you should see the EAC "detecting" windows then. Weird.
What happens if you select "Action -> Create CUE Sheet -> Multiple WAV Files With Gaps...  (Noncompliant)" menu item?
Could it be that you're in a beginner mode ("EAC Options -> Tools -> Activate beginner mode...") and that menu is not available? That would explain why EAC does nothing.. not even spinning the CD.
REACT does "left behind" cleaning before creating the cuesheets (+it cleans old log files & processing
  • .tmp files), so cleaning out your rip folder(s) is not necessary. In fact, REACT even detects "locked" cuesheet files that can't be cleaned/deleted and aborts & notifies the user.
REACT 2 Released
Reply #1622
Before I changed the "beginner mode":
If I didn't use CreateCuesheet i would have seen the EAC "detecting" window.
If I did use the CreateCuesheet I wouldn't have seen any window / action on the screen.
I will get a CUEsheet.
Yes, I was. Now I am not. And now its working. Thats the solution: Because I was in "beginner mode"?? I thought beginner mode means I cannot see all menu details!?!?!?
Thanks a lot. If that was the reason, "problem" solved!
Kaikki hyvin! Hyvää yötä.
Kiitos paljon,
roloff
REACT 2 Released
Reply #1623
Good to hear that the problem was solved.
Yes*, +EAC warns that some settings are turned to default when activating the beginner mode. I advice you to configure REACT again (Ctrl+F2) just in case. Remember that the EAC "Use this directory" setting will be changed to default user "My Music" directory when you configure REACT. You can change the setting after configuring (not needed though).
* but it seems that this also removes/disables shortcuts (if any available) for the hidden items. Also, when creating a "mg" cuesheet, REACT needs to have an "access" to the "Multiple WAV Files With Gaps... (Noncompliant)" menu item (doesn't have a shortcut in expert mode). Funny that this issue hasn't come up earlier. Next version of my mod will set the expert mode on when configuring.
REACT 2 Released
Reply #1624
Hello Akkurat, seems that I have a similiar issue with your mod. Everything works fine, except the creating of the cuesheets does not work. I am using the "CreateCuesheet=mg" version in the ini-file but there is no cuesheet saved in the FLAC-folder after the compression is done.  After pressing F4 the Album Art starts and Detecting of gaps works but the cue sheets are not saved. I am in Expert Mode. What is wrong with my configuration? Thanks for your help!
