Hello,
I have a small issue I am unable to resolve. All of my tracks are getting encoded properly - both FLAC & V0 in track mode. RG is applied and cues & m3u are created. The problem I am having is getting the EAC log file moved to the proper directory. Most of the time it works just fine, other times the log file sits in the working directory after post processing has run. I am truly puzzled why it works sometimes and not others.
INI:
[Settings]
Version=2.0.ssb16
ImageExt=wav
ImageNaming=$artist$ - $album$
ImageHotKey={F10}
TracksHotKey={F4}
TracksHotVal=+{F6}
VA=Various
CreateAllCuesheets=1
RunCoverDownloader=0
CoverDownloader=C:\Program Files\AlbumArtDownloader\AlbumArt.exe
CoverDownloaderXUI=0
EAC=C:\Program Files\Exact Audio Copy\EAC.exe
Tools=C:\Program Files\REACT2\tools
MinimizeCompressionWindow=0
ProcessPriority=1
Sla_Bks_Col_Qst_Bar_Quo_Ast_Lt_Gt=-|-|-||!|'|#|[|]
Test=1
[UserTrackFormats]
Flac=1
Wavpack=0
LameMP3=1
NeroAac=0
iTunesAac=0
OggEnc2=0
[UserOutputNames]
OutRoot=D:\Rips-Audio
ImageDir_Flac=@OutRoot@\$cdartist$ - $album$ (FLAC)
ImageDir_Wavpack=@OutRoot@\WV-images\$cdartist$
ImageDir_MP3=@OutRoot@\$cdartist$ - $album$ (V0)
TrackDir_Flac=@OutRoot@\$cdartist$ - $album$ (FLAC)
TrackDir_Wavpack=@OutRoot@\WV\$cdartist$\[$year$] $album$
TrackDir_MP3=@OutRoot@\$cdartist$ - $album$ (V0)
TrackDir_AAC=@OutRoot@\AAC\$cdartist$\[$year$] $album$
TrackDir_OGG=@OutRoot@\OGG\$cdartist$\[$year$] $album$
TrackName_SA=$track$ - $title$
TrackName_VA=$track$ - $artist$ - $title$
TrackName_SA_acdir=$n - $~t
TrackName_VA_acdir=$n - $~t [$~a]
[UserSettings]
Debug=0
Comment=
EmbedCover=0
ReplayGain=1
ApplyAlbumGain=1
AdjustAlbumGain_dB=+0
AddCuesheetAG=0
UseWaveGainAG=0
Opt_Flac=-8 -f
Opt_Wavpack=-hmy
Opt_LameMP3=-V0 --vbr-new --noreplaygain --nohist
Opt_NeroAac=-lc -q 0.21
Opt_iTunesAac=-d -s 2000
Opt_OggEnc2=-q 3.0
Ver_Flac=1.1.3
Ver_Wavpack=4.40
Ver_LameMP3=3.97
Ver_NeroAac=1.0.0.2
Ver_OggEnc2=2.83 Lancer aoTuV b5
[DefaultMetaData]
discnumber=1
totaldiscs=1
discname=
Track Config:
@ECHO OFF
REM CHCP 1252
TITLE @track@/@numtracks@ - "@album@"
REM Copyright © Tycho, 2006
REM
REM ** Create compressed audio tracks from ripped .wav tracks.
REM **
REM ** You may consider using image mode (F10)
REM ** as it supports creating tracks via acdir.exe,
REM ** and post-processing will always work (see below).
REM **
REM ** Flac requires flac.exe/metaflac.exe (v1.1.3)
REM ** NeroAac requires NeroAacEnc.exe/NeroAacTag.exe/AacGain.exe.
REM ** OggEnc2 requires OggEnc2.exe/VorbisGain.exe.
REM **
REM ** I prefer applying album gain 92dB to get a reasonable
REM ** volume for my DAP. The RG tags are still relative
REM ** to 89dB SPL, i.e. album gain will be about -3.0dB.
REM ============== Begin Main Script ==================
IF @Debug@==1 ECHO ON
SET TrackDir_Flac="@TrackDir_Flac@"
SET TrackDir_Wavpack="@TrackDir_Wavpack@"
SET TrackDir_MP3="@TrackDir_MP3@"
SET TrackDir_AAC="@TrackDir_AAC@"
SET TrackDir_OGG="@TrackDir_OGG@"
IF @various@==0 SET TrackName=@TrackName_SA@
IF @various@==1 SET TrackName=@TrackName_VA@
SET have_cover=0
SET embed_cover=0
IF EXIST "@cover@" (
SET have_cover=1
SET embed_cover=@EmbedCover@
REM ---- Track ----
IF NOT @Flac@==1 GOTO end_flac_tracks
IF NOT EXIST %TrackDir_Flac% MKDIR %TrackDir_Flac%
PUSHD %TrackDir_Flac%
IF @various@==1 SET VA_tag=-T "album artist=@VA@"
IF %embed_cover%==1 SET Cover_tag=--picture="|image/jpeg|||@cover@"
ECHO ON
@tools@\flac.exe @Opt_Flac@ %Cover_tag% %VA_tag% -T artist="@artist@" -T album="@album@" -T tracknumber="@track@/@numtracks@" -T title="@title@" -T date="@year@" -T genre="@genre@" "@source@" -o "%TrackName%.flac"
SET trackCueFile="$cdartist$ - $album$.cue"
IF NOT EXIST %trackCueFile% (
COPY "@albumfile@.[mg].cue" %trackCueFile%
ECHO CHCP 1252 ^| PROMPT>>update-cuesheet.bat
ECHO @tools@\GSAR.EXE "-s@basename@.wav" "-r%TrackName%.flac" -o %trackCueFile%>>update-cuesheet.bat
@tools@\tag.exe --playlist --onlyfiles --sort track --plname "$artist$ - $album$.m3u" *.flac
@ECHO OFF
POPD
:end_flac_tracks
IF NOT @LameMP3@==1 GOTO end_lame_tracks
IF NOT EXIST %TrackDir_MP3% MKDIR %TrackDir_MP3%
PUSHD %TrackDir_MP3%
IF @various@==1 SET VA_tag=--user-text "[album artist]@VA@" --frame "TPE2:@VA@"
IF %embed_cover%==1 SET Cover_tag=--pict "{3}@cover@"
ECHO ON
@tools@\lame.exe @Opt_LameMP3@ "@source@" "%TrackName%.mp3"
@tools@\metamp3.exe %Cover_tag% %VA_tag% --artist "@artist@" --album "@album@" --track @track@/@numtracks@ --title "@title@" --year "@year@" --genre "@genre@" "%TrackName%.mp3"
ECHO @tools@\GSAR.EXE "-s@basename@.wav""" WAVE" "-r%TrackName%.mp3""" MP3" -o %trackCueFile%>>update-cuesheet.bat
@tools@\tag.exe --playlist --onlyfiles --sort track --plname "$artist$ - $album$.m3u" *.mp3
@ECHO OFF
POPD
:end_lame_tracks
REM ** Delete the source .wav
DEL "@source@"
REM ---- Post-processing ----
rem ** Scan and compute ReplayGain and add cover picture for supported formats.
rem ** NB: The following will only work if at least the last track is selected,
rem ** and it is a regular audio track.
REM ** Compression threads workaround. Ensures that all compression threads are closed before starting post-processing.
:checkTmp
IF NOT EXIST processing[*].tmp GOTO allProcsClear
ECHO.
ECHO Waiting for all other processes to clear... If program hangs here and there are no other tracks being encoded, delete all processing[#].tmp files in your "@sourcedir@" directory.
ECHO.
REM ** Pause for 10000 milliseconds
PING 1.1.1.1 -n 1 -w 10000 >NUL
GOTO checkTmp
:allProcsClear
IF NOT @track@==@numtracks@ GOTO end_post_process
SET add_rg=@ReplayGain@
SET aac_enc=@NeroAac@
IF @iTunesAac@==1 SET aac_enc=1
IF NOT @ReplayGain@==1 GOTO end_RG
SET RG_MetaFlac=--add-replay-gain
SET RG_MetaMP3=--replay-gain
:end_RG
IF NOT @ApplyAlbumGain@==1 GOTO end_apply_AG
SET RG_MetaMP3=--apply-gain album@AdjustAlbumGain_dB@
SET RG_AacGain=/a /o /c /d @AdjustAlbumGain_dB@
SET add_rg=1
:end_apply_AG
REM ** Audio Formats:
IF @Flac@==1 (
IF %add_rg%==1 @tools@\Glob.exe -v -c @tools@\metaflac.exe %RG_MetaFlac% *.flac
IF %add_rg%==1 @tools@\Glob.exe -v -c @tools@\metamp3.exe --remove [mp3gain_*]TXXX *.flac
@tools@\GSAR.EXE -s%% -r%%%% -o update-cuesheet.bat
CALL update-cuesheet.bat
DEL update-cuesheet.bat
COPY /Y "@eaclog@" "$cdartist$ - $album$.log"
POPD
IF @LameMP3@==1 (
IF %add_rg%==1 @tools@\metamp3.exe %RG_MetaMP3% *.mp3
IF %add_rg%==1 @tools@\metamp3.exe --remove [mp3gain_*]TXXX *.mp3
POPD
REM ** Cleanup
DEL "@eaclog@"
DEL "@albumfile@.[*].cue"
DEL "@cover@"
:end_post_process
REM ================ End Main Script ===================
IF @Debug@==1 (
PAUSE
EXIT
REM ** Delete this .bat file:
DEL %0
