Topic: REACT 2 Released (Read 985758 times) previous topic - next topic
  • wolfsong
REACT 2 Released
Reply #50
The line sets both the BAND and a custom user text field with "album artists" as description to "Various", when and only when the CD is Various Artists. The v2.0 Final adds a key VA in the REACT.ini file (default VA=Various Artists). This will be the value of @cdartist@ for VA albums, otherwise @cdartist@ equals @artist@. I.e. you won't need the "set AlbumArtist" lines in the final release, but for now I believe you will.
If I don't want BAND set do I just remove VA_tag_MP3=--frame TPE2:$q$cdartist$$q? I only want to use this field for classical recordings and would prefer it be blank for nonclassical for query purposes. Thanks.
  • tycho
REACT 2 Released
Reply #51
Correct.
  • mogorp
REACT 2 Released
Reply #52
I have found React 2 to work flawlessly.  I just have a couple of questions.  Just for background, I am encoding flac and Lame tracks.
1. Can you explain the default settings for replay gain int the tracks config.  I am pretty sure that album replay gain is applied.  Is this correct?  Is the gain adjusted +3db and what is the advantage of doing this?
2.  When I looked at my flac files with foobar the cover art was present.  I did not see cover art when playing mp3 files with foobar.  I added a section to copy the cover art to my mp3/artist/album folder (see below).  Is this necessary?  Why was cover art not present orginally?  Thanks for your hard work. This really makes ripping and multiformat encoding much easier.
if %LameMP3%==1 (
pushd "%MP3_TrackDir%"
copy "@eaclog@" "EAClog.txt"
if %add_meta%==1 @tools@\metamp3.exe %MetaMP3_RG% %MetaMP3_cover% *.mp3
if %add_cover%==1 copy "@cover@" "folder.jpg"
popd
  • wolfsong
REACT 2 Released
Reply #53
if %LameMP3%==1 (
popd
foo_uie_albumart does not support embedded album art which is what the default REACT settings provide. What you have now should embed an image and copy folder.jpg to the album's directory.
  • tycho
REACT 2 Released
Reply #54
Yes, on MP3's and M4A's, album gain is *applied*, and adjusted by +3dB to 93dB. I do this because it gives a consistent loudness between the albums. The +3dB is done because it increases the volume of my iPod a little, so I don't have to put the volume near max. Setting volme to (near) max, increases noise and distortions.
  • Last Edit: 28 November, 2006, 01:42:21 AM by tycho
  • wolfsong
REACT 2 Released
Reply #55
I keep running into issues and I think it's some conflicting app but haven't figured out which one. This time around I was ripping Ottmar Liebert's "Poets & Angels". Debug showed that it couldn't create the album directory, apparently because of the ampersand. I don't recall having this probelm before.
Also, with both computers, I'm getting duplicate comments.
Lastly, on the "good" PC
IF @various@==1 SET --user-text $q[album artist]@cdartist@$q
doesn't set the Album Artist field at all.
  • Synthetic Soul
  • Global Moderator
REACT 2 Released
Reply #56
I haven't really been following all this, but the above looks horribly wrong.  I think you are after something like:
IF @various@==1 SET userText=--user-text $q[album artist]@cdartist@$q
FLAC.EXE ... %userText% ...
This will include --user-text $q[album artist]@cdartist@$q in your FLAC command line, only if the album is VA.
I'm on a horse.
  • tycho
REACT 2 Released
Reply #57
Yes, that is part of the problem. However because there are no real quotes (") around the artist name (only $q), the '&' is taken to be DOS command separator, and it is therefore failing. I will try to release the final version without these problems. I've just  added the WaveGain + --scale features that martin H requested, so it should not be too far away.
  • wolfsong
REACT 2 Released
Reply #58
I'm only doing MP3s with image.cfg (to get AG & TG).
Except this is the ALBUM field, not the ARTIST.
I may have found one more quirk. I have an AutoPlaylist to check for tracks missing TG (AG is assumed) and 2 tracks ripped with REACT 2 show up. Both are initials are just initials, S.O.S. and V.F.D.
  • Last Edit: 28 November, 2006, 04:23:43 PM by wolfsong
  • Martin H
REACT 2 Released
Reply #59
[...] I've just  added the WaveGain + --scale features that martin H requested [...]
Thank you very much tycho  I really appreciate it
CU, Martin.
  • Synthetic Soul
  • Global Moderator
REACT 2 Released
Reply #60
OK, sorry, I'm not familiar with the configs yet (no time to rip CDs).
The basic idea is that you use the line:
.. and then add %userText% to whatever command line you are running, where the switch should appear (if relevant).
I guess this relies on tycho's amends to cope with command symbols, like ampersand, outside of quotes.
I'm on a horse.
  • wolfsong
REACT 2 Released
Reply #61
I was hoping I could do something like
SET userText=--user-text $q[album artist]%AlbumArtist%$q
since AlbumArtist is set at the beginning of the config with
if @various@==0 set AlbumArtist=$cdartist$
if @various@==1 set AlbumArtist=Various Artists
but it doesn't seem to work.
  • Synthetic Soul
  • Global Moderator
REACT 2 Released
Reply #62
It should work, unless your variable AlbumArtist contains a command symbol (like "&") as previously discussed.
SET var1=fghij
SET var2=abcde%var1%klmno
ECHO %var2%
... should result in:
abcdefghijklmno
I'm on a horse.
  • wolfsong
REACT 2 Released
Reply #63
SET var1=fghij
ECHO %var2%
abcdefghijklmno
The ampersand problem was in the ALBUM not ARTIST. I tested this with a compilation and it didn't work for me. I'm a bit confused about the variables since cdartist uses @ and AlbumArtist uses % but not where it's being set.
  • Synthetic Soul
  • Global Moderator
REACT 2 Released
Reply #64
The @ parts are REACT's.  They're more tokens, or placeholders, than variables.  Those tokens are replaced by actual values before your config even runs.
The % variables are true DOS variables.  In DOS you use SET myvar=x to set a variable, and %myvar% to retrieve the value of the variable.  You need to use these DOS variables in your config to execute conditionally, whereas the @ REACT tokens will only ever return the value that REACT sets for them.
Without seeing your whole config, and even then perhaps, I can't tell you why your code is not working.  I provided the code above to prove to you that the concept is correct.  If you save the following code as a bat file and double click it you will see it in action:
@ECHO OFF
SET AlbumArtist=Test Artist
ECHO %userText%
ECHO.
PAUSE
With this in mind something else must be adversely affecting your config.
I'm on a horse.
  • wolfsong
REACT 2 Released
Reply #65
@ECHO OFF
ECHO %userText%
ECHO.
PAUSE
This works as expected so I assume it's a config problem. Here's the entire config just in case.
@echo off
chcp 1252
title REACT - "@album@"
REM ================== USER SETTINGS ======================
rem ** To archive a CD as one large "image", you must set
rem ** ImageExt=... in the REACT.ini file (Press Alt-F2).
rem ** This will set the @imageext@ variable. Extensions
rem ** currently supported:  flac, wv, mp3. Set to 'wav'
rem ** for no image archiving (default).
REM ---- Enable/disable additional track formats:
rem ** Splits the wav-image into tracks during encoding, using ACDIR.
rem ** Flac requires flac.exe/metaflac.exe (v1.1.3)
rem ** NeroAac requires NeroAacEnc.exe/NeroAacTag.exe/AacGain.exe.
rem ** OggEnc2 requires OggEnc2.exe/VorbisGain.exe.
set Flac=0
set Wavpack=0
set LameMP3=1
set NeroAac=0
set OggEnc2=0
REM ---- General settings ----
set Debug=0
rem ** I prefer applying album gain 92dB to get a reasonable
rem ** volume for my DAP. The RG tags are still relative
rem ** to 89dB SPL, i.e. album gain will be about -3.0dB.
set ReplayGain=1
set ApplyMp3AacAlbumGain=1
set AdjustMp3AacAlbumGain_dB=+0.0
REM ---- Encoder options ----
set Flac_opt=-5 -f
set Wavpack_opt=-hmy
set LameMP3_opt=-V4 --vbr-new --noreplaygain --nohist
rem ** Nero LC-AAC @ ~ 90kbps - great for e.g. iPods:
set NeroAac_opt=-lc -q 0.22
set OggEnc2_opt=-q 3.0
set Flac_ver=1.1.3b2
set LameMP3_ver=3.97
set NeroAac_ver=1.0.0.2
REM ---- Output directories and track names ----
set OutRoot=H:\TAGZ
rem ** Image dirs:
set Flac_ImageDir=%OutRoot%\Flac-Images\%AlbumArtist%
set Wavpack_ImageDir=%OutRoot%\Wavpack-Images\%AlbumArtist%
set MP3_ImageDir=%OutRoot%\MP3-Images\%AlbumArtist%
rem ** Track dirs:
set Flac_TrackDir=%OutRoot%\Flac\%AlbumArtist%\[$year$] $album$
set Wavpack_TrackDir=%OutRoot%\Wavpack\%AlbumArtist%\[$year$] $album$
REM set MP3_TrackDir=%OutRoot%\MP3\%AlbumArtist%\[$year$] $album$
set AAC_TrackDir=%OutRoot%\AAC\%AlbumArtist%\[$year$] $album$
set OGG_TrackDir=%OutRoot%\OGG\%AlbumArtist%\[$year$] $album$
REM set ** MP3_TrackDir
IF @various@==1 GOTO Various
REM CD is not VA
SET MP3_TrackDir=%OutRoot%\$cdartist$\$album$
GOTO Complete
:Various
IF @genre@==Soundtrack GOTO Soundtrack
REM CD is VA but not a soundtrack
SET MP3_TrackDir=%OutRoot%\Various Artists\Collections\$album$
GOTO Complete
:Soundtrack
REM CD is both VA and a soundtrack
SET MP3_TrackDir=%OutRoot%\Various Artists\Soundtracks\$album$
:Complete
rem ** Track names (for ACDIR):
if @various@==0 set TrackName=[$n] $~t
if @various@==1 set TrackName=[$n] $~t ($~a)
REM ============== BEGIN MAIN SCRIPT ==================
if %Debug%==1 echo on
set add_rg=%ReplayGain%
set add_meta=%add_rg%
set add_cover=0
if %ReplayGain%==0 goto end_RG
set Flac_RG=--replay-gain
set MetaFlac_RG=--add-replay-gain
set MetaMp3_RG=--replay-gain
:end_RG
if %ApplyMp3AacAlbumGain%==0 goto end_apply_AG
set AacGain_RG=/a /o /c /d %AdjustMp3AacAlbumGain_dB%
set MetaMP3_RG=--apply-gain album%AdjustMp3AacAlbumGain_dB%
set add_rg=1
set add_meta=1
:end_apply_AG
if not exist "@cover@" goto end_cover
set Flac_cover=--picture="|image/jpeg|||@cover@"
set MetaFlac_cover=--import-picture="|image/jpeg|||@cover@"
set MetaMP3_cover=--pict "{3}@cover@"
set AacTag_cover=-add-cover:front:"@cover@"
set add_cover=1
set add_meta=1
:end_cover
if @various@==0 (
set ArtistField=artist
set MP3ArtistField=TPE1
) else (
set ArtistField=album artist
set MP3ArtistField=TPE2
REM ---- Image ----
if not "@imageext@"=="flac" goto end_flac_image
set dest=%Flac_ImageDir%
if not exist "%dest%" mkdir "%dest%"
@tools@\flac.exe %Flac_opt% %Flac_RG% %Flac_cover% -T "%ArtistField%=@cdartist@" -T "album=@album@" -T "totaltracks=@numtracks@" -T "date=@year@" -T "genre=@genre@" -T "comment=Ripped with EAC/REACT" -T encoded-by="%USERNAME%" --tag-from-file="cuesheet=@cuesheet@" --tag-from-file="eaclog=@eaclog@" "@source@" -o "@image@"
move "@image@" "%dest%"
copy "@cuesheet@" "%dest%"
if %add_cover%==1 copy "@cover@" "%dest%\@basename@.jpg"
:end_flac_image
if not "@imageext@"=="wv" goto end_wavpack_image
set dest=%Wavpack_ImageDir%
@tools@\wavpack.exe %Wavpack_opt% -w "%ArtistField%=@cdartist@" -w "album=@album@" -w "totaltracks=@numtracks@" -w "year=@year@" -w "genre=@genre@" -w "comment=Ripped with EAC/REACT" -w "cuesheet=@@cuesheet@" -w "eaclog=@@eaclog@" "@source@" "@image@"
if %ReplayGain%==1 @tools@\wvgain.exe -a "@image@"
:end_wavpack_image
if not "@imageext@"=="mp3" goto end_mp3_image
set dest=%MP3_ImageDir%
@tools@\lame.exe %LameMP3_opt% "@source@" "@image@"
@tools@\metamp3.exe %MetaMP3_RG% %MetaMP3_cover% --frame %MP3ArtistField%:"@cdartist@" --album "@album@" --track @numtracks@ --year "@year@" --genre "@genre@" --comment "Ripped with EAC/REACT" --frame TENC:"%USERNAME%" --frame TSSE:"LAME %LameMP3_ver% %LameMP3_opt%" "@image@"
:end_mp3_image
REM ---- Tracks ----
if %Flac%==0 goto end_flac_tracks
set dest=%Flac_TrackDir%
if @various@==1 set Flac_VA_tag=-T $qalbum artist=%AlbumArtist%$q
@tools@\acdir.exe --overwrite --output "%dest%\%TrackName%.flac" --pipe "title $n/$N flac $#T & @tools@\flac.exe %Flac_opt% %Flac_VA_tag% -T artist=$#a -T album=$#T -T title=$#t -T tracknumber=$n/$N -T date=$q@year@$q -T genre=$q@genre@$q -T comment=$qRipped with EAC/REACT$q -T encoded-by=$q%USERNAME%$q - -o $#o" "@sourcecuesheet@"
pushd "%dest%"
if %add_meta%==1 @tools@\Glob.exe -v -c @tools@\metaflac.exe %MetaFlac_RG% %MetaFlac_cover% *.flac
if exist "@albumfile@.[*].cue" copy "@albumfile@.[*].cue" .
popd
:end_flac_tracks
if %Wavpack%==0 goto end_wavpack_tracks
set dest=%Wavpack_TrackDir%
if @various@==1 set Wavpack_VA_tag=-w $qalbum artist=%AlbumArtist%$q
@tools@\acdir.exe --overwrite --output "%dest%\%TrackName%.wv" --pipe "@tools@\wavpack.exe %Wavpack_opt% %Wavpack_VA_tag% -w artist=$#a -w album=$#T -w title=$#t -w track=$n/$N -w year=$q@year@$q -w genre=$q@genre@$q -w comment=$qRipped with EAC/REACT$q - $#o" "@sourcecuesheet@"
pushd "%dest%"
if %ReplayGain%==1 @tools@\wvgain.exe -a *.wv
popd
:end_wavpack_tracks
if %LameMP3%==0 goto end_mp3_tracks
set dest=%MP3_TrackDir%
REM if @various@==1 set MP3_VA_tag=--frame TPE2:$q%AlbumArtist%$q
@tools@\acdir.exe --overwrite --output "%dest%\%TrackName%.mp3" --pipe "title $n/$N mp3 $#T & @tools@\lame.exe %LameMP3_opt% - $#o & @tools@\metamp3.exe %MP3_VA_tag% --artist $#a --album $#T --title $#t --track $n/$N --year $q@year@$q --genre $q@genre@$q --comment $qRipped with EAC/REACT$q --frame TENC:$q%USERNAME%$q --frame TSSE:$qLAME %LameMP3_ver% %LameMP3_opt%$q $#o" "@sourcecuesheet@"
pushd "%dest%"
if %add_meta%==1 @tools@\metamp3.exe %MetaMP3_RG% *.mp3
REM copy "@eaclog@" "EAClog.txt"
popd
:end_mp3_tracks
if %NeroAac%==0 goto end_aac_tracks
set dest=%AAC_TrackDir%
@tools@\acdir.exe --overwrite --output "%dest%\%TrackName%.m4a" --pipe "title $n/$N aac $#T & @tools@\neroAacEnc.exe %NeroAac_opt% -if - -of $#o & @tools@\neroAacTag.exe $#o -meta:artist=$#a -meta:album=$#T -meta:title=$#t -meta:track=$n -meta:totaltracks=$N -meta:year=$q@year@$q -meta:genre=$q@genre@$q -meta:comment=$qRipped with EAC/REACT$q" "@sourcecuesheet@"
pushd "%dest%"
if %add_cover%==1 for %%i in (*.m4a) do @tools@\neroAacTag.exe "%%i" %AacTag_cover%
if %add_rg%==1 @tools@\aacgain.exe %AacGain_RG% *.m4a > gainlog.txt
REM if %add_cover%==1 copy "@cover@" "folder.jpg"
popd
:end_aac_tracks
if %OggEnc2%==0 goto end_ogg_tracks
set dest=%OGG_TrackDir%
@tools@\acdir.exe --overwrite --output "%dest%\%TrackName%.ogg" --pipe "title $n/$N ogg $#T & @tools@\oggenc2.exe %OggEnc2_opt% -c artist=$#a -c album=$#T -c title=$#t -c tracknumber=$n/$N -c date=$q@year@$q -c genre=$q@genre@$q -c comment=$qRipped with EAC/REACT$q -c encoded-by=$q%USERNAME%$q - -o $#o" "@sourcecuesheet@"
pushd "%dest%"
if %ReplayGain%==1 @tools@\vorbisgain.exe -a *.ogg
popd
:end_ogg_tracks
REM ================ END MAIN SCRIPT ===================
if %Debug%==1 (
pause
REM exit
rem ** Cleanup
del "@source@"
del "@eaclog@"
del "@cuesheet@"
del "@albumfile@.[*].cue"
del "@cover@"
rem ** Delete this .bat file:
del %0
I just had a thought. Does --user-text need to be added to?
  • Last Edit: 01 December, 2006, 11:16:19 AM by wolfsong
  • Synthetic Soul
  • Global Moderator
REACT 2 Released
Reply #66
Yes.
Also, on an unrelated note, on line 89 I think it should be:
if @various@==1 set TrackName=[$n] $~t ^($~a^)
... but I may be wrong.
I have still yet to actually use REACT 2, so I can't really advise on configs.
I'm on a horse.
  • wolfsong
REACT 2 Released
Reply #67
Yes.
Well adding it by itself doesn't work. In fact most of the tags are now blank. I guess it is expecting some sort of arguement like
which seemingly makes the previous line:
unnecessary but I'm not really sure if that is correct or the syntax is right.
This part works fine actually.
  • Synthetic Soul
  • Global Moderator
REACT 2 Released
Reply #68
I'm sorry, I should have been more clear: you need to add %userText% to the command line.
@tools@\acdir.exe --overwrite --output "%dest%\%TrackName%.mp3" --pipe "title $n/$N mp3 $#T & @tools@\lame.exe %LameMP3_opt% - $#o & @tools@\metamp3.exe %MP3_VA_tag% %userText% --artist $#a --album $#T --title $#t --track $n/$N --year $q@year@$q --genre $q@genre@$q --comment $qRipped with EAC/REACT$q --frame TENC:$q%USERNAME%$q --frame TSSE:$qLAME %LameMP3_ver% %LameMP3_opt%$q $#o" "@sourcecuesheet@"
Yes, on thinking about it, I think I had to do that previously as I had the line already in brackets.  Sorry for confusing the issue.
  • Last Edit: 01 December, 2006, 02:54:01 PM by Synthetic Soul
I'm on a horse.
  • wolfsong
REACT 2 Released
Reply #69
YEAH! That worked. Thanks SS.
  • Dondo
REACT 2 Released
Reply #70
Thanks Tycho for creating REACT. I'm finding it very useful! And thanks to Synthetic Soul for the tech help. What an improvement for Various Artist albums! Excellent.
I tried the previous version for the first time about a month ago, and worked my way through the forum threads until I had a basic understanding - and a good Test & Copy Flac tracks routine.
Now, with REACTv2, I've added AAC tracks to my Test & Copy Flac tracks. It's all working well, except for one minor thing - I'd like to save CRC values in the FLAC tags, but I'm not getting the code right.
    if @various@==1 set Flac_VA_tag=-T "album artist=%AlbumArtist%"
    @tools@\flac.exe %Flac_opt% %Flac_VA_tag% -T artist="@artist@" -T album="@album@" -T tracknumber="@track@/@numtracks@" -T title="@title@" -T date="@year@" -T genre="@genre@" -T comment="Ripped with EAC/REACT" -T CRC="%CRC%" "@source@" -o "%dest%\%TrackName%.flac"
:end_flac_tracks
I've probably missed something major.
  • Last Edit: 01 December, 2006, 06:48:57 PM by Dondo
  • Synthetic Soul
  • Global Moderator
REACT 2 Released
Reply #71
No problem.  This is actually what I was referring to in post #57 when I suggested:
... but I mistakingly used FLAC.EXE in the example assuming --user-text to be a FLAC switch, and not a METAMP3 switch.  Ah well, we got there in the end.
:end_flac_tracks
I think you want -T CRC="@crc@" and not -T CRC="%CRC%", unless you have set a DOS variable previously in your config.
Thanks for the thanks.
I'm on a horse.
  • Dondo
REACT 2 Released
Reply #72
I was afraid it was something simple like that! It's working perfectly now, Thanks again.
I was having something odd happen last night - I would start ripping a CD by hitting F4 - EAC would begin checking for gaps, and the coverart downloader would start. Then EAC would just stop after finishing saving the cue sheets - no copying tracks.
I've rebooted and have not been able to re-produce the problem (not that I'm complaining!).
Has anybody else had this trouble?
REACT 2 Released
Reply #73
I've installed REACT 2 several times on Windows Vista Ultimate (final, not beta or RC) and I never get a REACT.ini file.  The other files seem to be there.  Hitting Alt-F2 gets me a "Cannot find the C:\Program Files\REACT2\React.ini file would you like to create it?" dialog.  I assume I can just get a copy from somebody else or create my own if somebody can post or PM me the text of the file, right?
  • wolfsong
REACT 2 Released
Reply #74
Are you starting EAC or REACT? When you run REACT it creates the INI file for you. You should always start with REACT going forward.
