Topic: Titleformatting $if3? (Read 4291 times) previous topic - next topic
I'm adding some code to Track Info Mod to indicate the presence of embedded lyrics or TXT or LRC files. So far I have:
$if($or(%lyric%,%lyrics%), Embedded,)
$if($cwb_fileexists($replace(%_path%,%_filename_ext%,)%album artist% - %title%.txt), TXT,)
$if($cwb_fileexists($replace(%_path%,%_filename_ext%,)%album artist% - %title%.lrc), LRC,)
$rgb(255,0,0) NONE$char(10)
This code works fine but what I'd like to display is basicaly
Lyrics: (Embedded) (TXT) (LRC) NONE
where none is displayed when the first 3 fail. Seemingly $if3 is the way to go but when I use the above code it results in false. Here's what I have.
$if3($if($or(%lyric%,%lyrics%), Embedded),$if($cwb_fileexists($replace(%_path%,%_filename_ext%,)%album artist% - %title%.txt), TXT),$if($cwb_fileexists($replace(%_path%,%_filename_ext%,)%album artist% - %title%.lrc), LRC),$rgb(255,0,0) NONE)
Any ideas? Thanks.
Any ideas? Thanks.
How about...
$if($or(%lyric%,%lyrics%), Embedded,$if($cwb_fileexists($replace(%_path%,%_filename_ext%,)%album artist% - %title%.txt), TXT,$if($cwb_fileexists($replace(%_path%,%_filename_ext%,)%album artist% - %title%.lrc), LRC,$rgb(255,0,0) NONE$char(10))))
Now, I have by all means never touched a single line of tagz code, but as far as I understand, this setup will evaluate the next IF clause until a positive is found, or the last ELSE is issued (the NONE thingy)
Pusk is the new Start.
How about...
I don't think you can have that many arguements in an $if statement. I tested it and it didn't work BTW but thanks for trying.
I didn't count brackets, but it seems to be constructed properly.
Try it without the $rgb function that you've placed just before the NONE.
How about...
Please, I hope that the number of arguments is not the reason why my example didn't work, as each of the if statements were only supposed to see two arguments - The if, and the else. If tagz cant handle stacking, it really should.
Well it can but the $if function has a specific format that only accepts so many arguements but funtions like $if3 handles more and works differently.
Yeah, I read the documentation. I think there is a slight chance we are misunderstanding each other.
What I did amounts to basically this:
if(something)
dothis();
else
  if(somethingelse)
    dothat();
  else
    if(somethingthird)
      donothing();
This should be possible within any programming or scripting language, even though it is very ugly and just plain utterly wrong. One should use if-elseif instead of stacking if statements, but from what I've seen in tagz scripts, I'm thinking tagz doesnt have if-elseif.
I think you want something like this:
$rgb(255,0,0)
$if($or(%lyric%,%lyrics%),Embedded,
$if($cwb_fileexists($replace(%_path%,%_filename_ext%,)%album artist% - %title%.txt),TXT,
$if($cwb_fileexists($replace(%_path%,%_filename_ext%,)%album artist% - %title%.lrc),LRC,
NONE
$char(10)
It's not pretty, but it should work.
</signature>
$rgb(255,0,0)
NONE
$char(10)
Beautifully, although I only wanted NONE to be in red (easily changed)! Thanks Insolent.
