Topic: Is sending a playlist to two versions of Foobar possible? (Read 4751 times) previous topic - next topic
before Foobar 0.9 I used to rip most of the internet-radio streams I listened to, using the modified http-reader. As it now seems that ripping streams with 0.9 is not possible anymore -      - I think I have to resort back to using 0.8x. Well, for the ripping, at least.
I already know that it is possible to have two versions of Foobar installed, but would it be possible for the playlists to be sent to both of these versions, ie. if I click an internet-radio link in the browser, 0.9x would start playing back the stream via the soundcard, and 0.8x would at the same time rip the stream (using perhaps some null-output or another soundcard)?
This would enable me to use the more stable and user-friendly version 0.9x for the actual playback but still enable ripping.
Wbr, Tatu
It would also mean downloading the data twice.
David,
compromising some bandwidth would in this case be ok for me.
- Tatu
Diskussion about ripping using Foobar and Streamripper
you can use streamripper to rip
So download
- streamripper win32 console version
put streamripper and the streamripper.exe und die 3 dll in C:\WINDOWS\system32
- download foobar_run and put this in your components folder
Go preferences| tools | run services
Add new service name it stream ripper
path for example:  streamripper %path% -d C:\MP3\ -r 8008  (you can change the path of the mp3)
Install foo_run, and add a run service such as: streamripper %path% -d X:\streamrips\ -r 8008
Then add a stream location: http://localhost:8008/ - if you want to listen to the same stream, but not use double the bandwidth
Useless full-quote of the previous post removed by moderation.
Spirit,
thank you very much for this info, and thank You Cosmo for the ripper!
I had missed this piece of information completely, I thought ripping was still not possible with 0.9x.  I will give the ripper a try on the weekend!
- Tatu
You can also click a stream and than klick right "convert to" but this would mean getting a big file and no playlist so you won't know which songs are in there
