Topic: Converting to FLAC doesn't work (Read 4051 times) previous topic - next topic
I am new to this and now I am trying to convert fromCD to FLAC. I have followed this description as far as I can understand it. The discription is very good  , it's something with me...
http://www.hydrogenaudio.org/forums/index.php?showtopic=30959
What I get out of this is WAV files not flac files. What do I do wrong? Grateful for some good ideas and guidelines...[/quote]
Iam using EAC,
configured Compression options, external compression,
|x| use external program for compression
Parameter: User Define Encoder
file extension: .flac
Program for compression:C:\Programfiler\FLAC\FLAC.exe
Still I get only Wav-files....
Here's a great EAC guide, I found it very helpful when starting out myself:
Essential Ripping Guide for EAC
As for using flac with EAC, check out this Hydrogenaudio Wiki page:
http://wiki.hydrogenaudio.org/index.php?title=EAC_and_Flac
  • Alexxander
Double posting
  • Last Edit: 27 October, 2006, 04:57:00 PM by Alexxander
  • phaedra
Make sure you click on the "MP3" button in EAC ... (not the "WAV" button)
- p
  • Alexxander
http://www.hydrogenaudio.org/forums/index....showtopic=30959
Iam using EAC,
Do you extract/rip to compressed files or uncompressed? When you have an audio CD put in, select a track and pushes command key F6 what files do you get?
NOW I got it  Use comporessed - then it's compressing to FLAC after WAV. Great!
Thanks for good and QUICK help!
But still there are some more questons:
I add these command line options:
-6 -V -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" -T comment="%e" -T "comment=EAC (Secure Mode)" %s
This is the filename I get. And its most of the informaton, but I want the Pink Floyd Catalog (if its not there) automatically to be created. It doesn't.
I also want the Album Catalogue to be created. It doesn't
Pink Floyd - Wish You Were Here [Gold Edition] - 01 - Shine On You Crazy Diamond - Part 1-5.flac
What do I use as command line options to make these to catalogues automatically created?
This is so great forum  And my Squeezebox is incredible
  • probedb
The options for output filenames are actually in EAC....assuming you're not in beginners mode then go to EAC->EAC options, Filename tab...you can then create whatever output filename you like using the options it gives
For example mine is:
%D\%C\%N - %A - %T
which puts each artist in a directory with it's albums underneath it and the tracks underneath that
...and yes Squeezebox + FLAC = awesome
  • Last Edit: 28 October, 2006, 09:18:47 AM by probedb
