Topic: foo_scheduler (Read 337596 times) previous topic - next topic
  • andrew_smolko
foo_scheduler
Reply #475
stilll loving it! but have a little problem...
http://www.hydrogenaudio.org/forums/index....showtopic=95229
I'll try to figure out what's going on, thanks for report!
  • db1989
  • Global Moderator
foo_scheduler
Reply #476
Post #474 was originally a separate thread, which was linked in post #475; I have merged the former into this thread, hence the now-dead link within the latter. Please do not cross-post, particularly when a dedicated thread is already established.
  • Last Edit: 30 May, 2012, 01:22:59 PM by db1989
  • andrew_smolko
foo_scheduler
Reply #477
i can't figure out, where the problem is. my system time is updated with NTPserver hourly.
the only thing left, not been checked, is the CMOS battery.
but if the CMOS would be almost empty, i would recognize this otherwise.
I couldn't reproduce the behavior you've described. Probably something is wrong with windows time correction.
I assume the scenario is the following:
* foo_scheduler inits waitable timer to go off on certain time.
* Your system time is corrected BUT the initiated timer IS NOT (if so then it's windows kernel bug).
* Multiple time corrections lead to 20 seconds delay.
* CMOS battery can be the reason for these multiple corrections.
I can suggest you try to use windows built in scheduler to reproduce the same problem. If it happens then I can't do anything because of the wrong behavior of windows during time correction.
  • Last Edit: 03 June, 2012, 10:59:20 AM by andrew_smolko
foo_scheduler
Reply #478
andrew_smolko
What about the issue I reported above:
It seems that "Playback stop / Starting new track" event doesn't really work. As far as I understand it should happen when one track finishes playing and next track starts playing. I tried to use it for action like "Stop playback after current track and hibernate" - no success.
Is it reproducable? If yes will it be fixed? Thanks!
Magically yours
Raistlin
  • andrew_smolko
foo_scheduler
Reply #479
andrew_smolko
Use "Wait until N tracks played" action. It seems that "Playback stop / Starting new track" event fires only when user clicks next/prev track button.
  • delusion
foo_scheduler
Reply #480
thanksalot andrew for your support!
1. i'll try the windows built-in scheduler
2. i'll try a different ntp-client.
3. i'll go for the cmos
will give you a shout, when i a got solution.
thx for now, you rock!
fg, dls
  • acrox999
foo_scheduler
Reply #481
Thank you very much for this! Been looking for some way to do this.
  • Qtax
foo_scheduler
Reply #482
Scheduler 4.09 crashes foobar2000 v1.1.13:
Illegal operation:
Code: E06D7363h, flags: 00000001h, address: 7C812AFBh
Additional parameters: 19930520h 0012FC3Ch 016CA0BCh
Message: invalid map/set<T> iterator
Call path:
entry=>app_mainloop=>main_thread_callback::callback_run
This happens couple (or more) of times per week on my daily wake up event.
I think the crash happens just as the event is starting, but I'm not completely sure.
The system is running normally (not in sleep or anything) when the event triggers.
Attached are the two latest crash reports in full and the corresponding dump files.
Info:
App: foobar2000 v1.1.13
UI: Default User Interface 0.9.5
foo_scheduler.dll (2012-01-17 11:06:16 UTC)
    Scheduler 4.09
OS: Windows 5.1.2600 Service Pack 3 x86
CPU: Intel(R) Core(TM)2 CPU          6400  @ 2.13GHz, features: MMX SSE SSE2 SSE3
Top of stack:
Stack dump analysis:
Address: 016E17E8h (foo_scheduler+C17E8h)
Address: 7C812AFBh (kernel32+12AFBh), symbol: "RaiseException" (+52h)
Address: 016CA0BCh (foo_scheduler+AA0BCh)
Address: 7C90E920h (ntdll+E920h), symbol: "strchr" (+113h)
Address: 7C9101E0h (ntdll+101E0h), symbol: "RtlAllocateHeap" (+11Ch)
Address: 7C9101DBh (ntdll+101DBh), symbol: "RtlAllocateHeap" (+117h)
Address: 01690A16h (foo_scheduler+70A16h)
Address: 016958A0h (foo_scheduler+758A0h)
Address: 0167A190h (foo_scheduler+5A190h)
Address: 016B44A8h (foo_scheduler+944A8h)
Address: 0163DF99h (foo_scheduler+1DF99h)
Address: 016BA4B8h (foo_scheduler+9A4B8h)
Address: 01642562h (foo_scheduler+22562h)
Address: 0166A147h (foo_scheduler+4A147h)
Address: 016E17E0h (foo_scheduler+C17E0h)
Address: 0056E0E4h (foobar2000+16E0E4h)
Address: 0056B008h (foobar2000+16B008h)
Address: 0047B154h (foobar2000+7B154h)
Address: 016B20AEh (foo_scheduler+920AEh)
Address: 01629339h (foo_scheduler+9339h)
Address: 100027D8h (shared+27D8h), symbol: "uPrintCrashInfo_OnEvent" (+B1h)
Address: 016AC1D0h (foo_scheduler+8C1D0h)
Address: 0045A808h (foobar2000+5A808h)
Address: 7E37B19Ch (USER32+1B19Ch), symbol: "DestroyWindow" (+0h)
Address: 0051547Dh (foobar2000+11547Dh)
Address: 00457DFFh (foobar2000+57DFFh)
Address: 01D12CFCh (foo_jesus+2CFCh)
Address: 0112FEB8h (foo_freedb2+2FEB8h)
Address: 00458853h (foobar2000+58853h)
Address: 4ECDB9F8h (gdiplus+13B9F8h)
Address: 0053A3FCh (foobar2000+13A3FCh)
Address: 00539C60h (foobar2000+139C60h)
Address: 00543FCCh (foobar2000+143FCCh)
Address: 00502D92h (foobar2000+102D92h)
  • Last Edit: 22 June, 2012, 02:29:48 PM by db1989
  • andrew_smolko
foo_scheduler
Reply #483
Try to reproduce this crash with only foo_scheduler installed.
And show your foo_scheduler configuration please.
  • Qtax
foo_scheduler
Reply #484
It's very random, and I can't seem to reproduce it using a menu trigger, has only happened when using the timed schedule (yet).
In the (about) 3 months since this occurred the first time (4th of April) it has only happened 10 times (number of crash reports with this error).
So it's not so easy to reproduce.
Before that it worked without issue for 2-3 months.
Around the time before/when this happened first time I haven't installed any new plugins, nor changed the schedule actions (iirc).
But I could have updated foobar2000 around that time, to some then current beta.
Time and dates of the crash reports if it's of any interest.
They always occur at the time the action is scheduled to trigger.
2012-04-04  07:00
2012-04-19  15:00
2012-04-20  09:30
2012-06-04  07:30
2012-06-08  08:00
2012-06-10  12:30
2012-06-11  07:30
2012-06-13  07:30
2012-06-14  08:00
2012-06-22  08:30
Also whats the best way to show my scheduler config?
  • Last Edit: 22 June, 2012, 04:44:42 PM by Qtax
  • andrew_smolko
foo_scheduler
Reply #485
Send me this file in private message:
c:\Documents and Settings\<UserName>\Application Data\foobar2000\configuration\foo_scheduler.dll.cfg
  • Dirki
foo_scheduler
Reply #486
It seems, as if the scheduler, which let my computer hibernate each day at a special time, affects the computer when it is started the next time. So e.g. the scheduler lets the computer hibernate each day at 5 p.m. When it is already turned off or hibernating at 5 p.m. and when you turn it on the next time, it will go to hibernate or turn it off after starting. How could you – if it is like that - avoid it without changing „Event list“, „Action list“ of the scheduler?
Win 7, Win Vista, newest stable foobar & EAC & Cue-Tools
  • db1989
  • Global Moderator
foo_scheduler
Reply #487
Re the above, which was merged in, please note this from the rules of the Support subforum (prominently advertised):
This forum "Support - (fb2k)" is for issues with the main application itself and official (bundled) components only.
  • Dirki
foo_scheduler
Reply #488
Very sorry about that, db1989,
I didn't realize that the scheduler is a component.
And many thanks for your hints, sorry again.
  • andrew_smolko
foo_scheduler
Reply #489
If the actual time when an event fires, differs from the scheduled event time, the action list won't start executing. So if you hibernate your computer manually before 5 p.m. and then turn it on e.g. at 5:05, it won't hibernate again.
  • Dirki
foo_scheduler
Reply #490
Many thanks.
Sorry, I do not quite understand:
If the actual time when an event fires, differs from the scheduled event time...
Would this work:
  • andrew_smolko
foo_scheduler
Reply #491
Yes, it will.
  • Dirki
foo_scheduler
Reply #492
Thank you, Andrew.
  • Dirki
foo_scheduler
Reply #493
How can I avoid, that missed actions (e.g. hibernating) will be executed after starting the computer next time?
After shutting down the computer by the scheduler and starting again, there is a message displayed, whether foobar shall be started in normal mode or another mode. How could you avoid this message?
  • Last Edit: 02 July, 2012, 08:58:23 AM by Dirki
  • andrew_smolko
foo_scheduler
Reply #494
4.10 release with small fixes.
  • Dirki
foo_scheduler
Reply #495
Thank you very much, Andrew.
And now, I guess, that message and executing missed actions will not be occur anymore.
Many thanks again.
  • andrew_smolko
foo_scheduler
Reply #496
Well, I've just improved debugging support, I didn't fix exactly your problem. But when this happens again, send me crash reports and dumps. That will help me fix it faster.
  • Dirki
foo_scheduler
Reply #497
Great. How could I get these reports and dumps to let you have them later?
  • sentriz
foo_scheduler
Reply #498
Mine worked well (at Night), but the music didn't start in the morning..
http://files.senankelly.net/screenshots/9xj9kP4q.jpg < Screenshot of config.
  • Andreasvb
foo_scheduler
Reply #499
By morning you mean 12:10 at night?
  • Last Edit: 20 August, 2012, 09:00:45 AM by Andreasvb
