Topic: WinZIP 11.0 beta using WavPack?! (Read 47309 times) previous topic - next topic
  • DARcode
  • Members (Donating)
From the Maximum Compression home page:
[WinZIP 11.0 beta] now also has a special algorithm to compress .wav files!. Research done by Guillermo Gabrielli shows the audio compressor used for this is WavPack (using Lossless, High compression mode).
Is it true and if so legal?
More info from the guestbook:
posted: 10/20/2006 02:36 PM
>winzip v11.0 beta is out ..
The audio compressor is WAVPACK. The WinZip 11 archives can be decoded with WVUNPACK (Wavpack decoder). According to WVUNPACK -ss (Super Summary) it's using Lossless High compression, but no Extra:
WVUNPACK -ss MWZ.zip
WVUNPACK Hybrid Lossless Audio Decompressor Win32 Version 4.31 2005-12-10
Copyright © 1998 - 2005 Conifer Software. All Rights Reserved.
file name: MWZ.zip
file size: 27780736 bytes
source: 16-bit ints at 44100 Hz
channels: 2 (stereo)
duration: 0:03:53.11
modalities: lossless, high
compression: 32.44%
ave bitrate: 953 kbps
encoder version: 4
Dc
EDIT: Post icon + guestbook part.
  • Last Edit: 23 October, 2006, 03:46:16 PM by DARcode
WavPack 5.1.0 -b384hx6cmv / qaac 2.63 -V 100
  • Fandango
Yes, it's true. I've downloaded the beta and indeed it produces Wavpack files (compression: optimize for maximum compression).
EDIT: WavPack is published under the BSD license, so I'm pretty sure it's legal.
  • Last Edit: 23 October, 2006, 04:09:39 PM by Fandango
  • Bylie
If my memory serves me right didn't wavpack use a BSD license which would suggest that commercial use of the code is not illegal?
BSD and GPL licensing info A snippet  from the original text :
The main differences between the two licenses is that revised BSD licenses are permissive while the GPL is copyleft. The GPL requires the software to always be free, including derivative works, by requiring the software to always be licensed under the GPL. The BSD license only requires acknowledging the original authors, and imposes few restrictions on how the source code may be used. As a result, BSD code can become proprietary software. For instance, parts of Mac OS X and the IP stack in Microsoft Windows are derived from BSD-licensed software.
I guess the only thing they are legally obliged to do is to acknowledge the original authors work (which they're possibly not doing at the moment so, yes, that part would be illegal).
  • Last Edit: 23 October, 2006, 04:14:15 PM by Bylie
  • Fandango
@Bylie: Exactly!
  • db1989
  • Global Moderator
Eh? So it creates files with an extension of .zip, yet which are in WavPack format? Boy, that'll go down well with people who haven't heard of WavPack . . . or am I missing something?
  • ggf31416
The archives use the zip format, but the compressed data which is inside is in Wavpack format. While existing zip programs can browse the "new" zips WVUNPACK can, under some circumstances, skip the ZIP header and decode the wavpack data. However foobar2000 cannot play the files.
  • Last Edit: 23 October, 2006, 06:51:27 PM by ggf31416
  • xmixahlx
sounds like a good idea to me!
  • rjamorim
It is indeed perfectly legal. Are they crediting "Conifer Software" somewhere? That's the only meaningful requirement in the license.
http://www.rarewares.org
  • Fandango
That's not completely true. When the extension is not ZIP but WV, foobar2000 will (try to) skip the PK header, too.
Hehe... now that you mentioned it. It's interesting that WavPack isn't mentioned anywhere on their website or the documentation that comes along with the software... instead we can read stuff like this:
Zip .wav Music Files
A special algorithm will compress .wav files smaller than ever.
Also the MS help files that come along with the Packer don't acknowledge WavPack or its creator at all. You can check for yourself. Just in case they silently add the Acknowledgement, the MD5 of the installer is: D0AE7158522F12E20953F1C88D1A9CCC (wz110beta.exe - Build 7291)
IMHO, that's hardly legal. It doesn't matter if it's not yet final, even a beta release is a release. David Bryant should contact them, so it can be fixed. I don't think it's a big deal when they agree to include his name. But nevertheless, the total absence of "Wavpack" or "Bryant" in all documentation and also the way of introducing the new audio compression feature leaves me with a very special feeling that they wanted to sell the new "special algorithm" that "compress[es] .wav files smaller than ever" as their very own creation.
  • Last Edit: 23 October, 2006, 09:00:09 PM by Fandango
  • bryant
  • Developer (Donating)
Thanks for the heads-up on this, it's very interesting to say the least!
The BSD license obviously allows them to use the code if they include the copyright notice somewhere in their distribution. However, also according to the license, they're not supposed to use my name (or perhaps even the name "WavPack") to endorse or promote their product without my permission. Of course, if it turns out to be a "buggy" implemention of WavPack, I'd rather not have everyone knowing where it came from!
Anyway, they're obviously not trying to be sneaky because they made no effort to hide the fact that it's WavPack. I'll shoot off an e-mail and see what's up...
David
  • shadowking
Awesome stuff..
  • Liisachan
They also say:
When you select our Best Compression Method, we use a new compression algorithm for lossless compression of .wav files. A must-have for music lovers who don't want to compromise the file integrity or sound quality.
It's a good idea, but the above explanation is slightly insincere, as true music lovers don't and shouldn't use ZIP this way to compress standalone .wav. "A must-have for music lovers who don't want to compromise the file integrity or sound quality" is, obviously, not WinZip but WavPack or other lossless compressors.
Imho this new approach of WinZip would work best for game lovers when they compress some kind of a game ISO image, so called mix-mode, which consists of track1.iso+track2.wav+track3.wav+...
  • Liisachan
And, if 7-ZIP, WinRAR, etc. are going to try to be compatible with WinZip, the WavPack algo might be spread internally on many different apps all over the world.
  • Borisz
Which begs the question: does Winzip actually search for pcm algorythms when using the wavpack compression, or will it only use wavpack when it encounters a wav file? Because if it actually compresses based on code and not file header/extension, it could be a powerful tool for zipping bin/cue images with audio tracks (raw pcm).
  • Fandango
Well, that's missing at the moment.
Ah, so this explains the fact that Wavpack wasn't mentioned anywhere. In fact they neither said it was yours nor it was theirs. Then I take back all my allegations I made before concerning selling it as their own.  Because that's probably not going to happen...
  Haha, I can understand that. And I guess it's what the abovementioned BSD license term is about...
On the other hand, if they do it right... maybe this will be good publicity!
  • ggf31416
I renamed a wav file to iso and Winzip used PPMd instead of Wavpack for compress it, so it's based on extensions.
  • Fandango
Which leads me to the question... have you tried the opposite? The result might be interesting.
  • ggf31416
  • rjamorim
The only correct course of action for Corel (owners of WinZIP) would be giving credits somewhere (about box?) to "Conifer Software".
  • db1989
  • Global Moderator
^ Well, there's the first evidence of a mention . . .
Still, I don't like the way that they have called it a "new" algorithm and other spiel; it's not all that new at all.
  • bryant
WinZIP contacted me early today before I was even able to send off an e-mail. They have no plans to ignore the license and wanted to get my permission to credit me publicly. So, all is fine.
Now I just need to test their implementation.
  • DARcode
That's great! Then fantastic pubblicity it is!
  • Firon
THat's pretty cool, having WavPack be more widespread is always a good thing.
It's also good that they e-mailed you about it.
  • db1989
  • Global Moderator
Congratulations, David!
  • Synthetic Soul
  • Global Moderator
Indeed.  A nice bit of well-deserved publicity for WavPack hopefully.  Congratulations David.
I'm on a horse.
