Topic: FLAC 1.1.3 beta1 available (Read 122776 times) previous topic - next topic
  • jcoalson
Reply #100
yeah, this is only for the windows binary, I couldn't get MSVC6 to accept dashes in /D arguments in the .dsp file, even with quoting.  the 1.1.3 final will not have this problem since there will be no beta suffix or dashes.
Egor, thanks for the file, will check it out tomorrow.
Josh
  • Madman2003
Reply #101
I wanted to warn a smaller project, but i cannot seem to find any api documentation of 1.1.3 (the website has the old stuff and can't find anything in cvs).
So were can api documentation be found?
  • jcoalson
Reply #102
yes, unfortunately the API docs are built from sources at release time and not checked in.  the easiest way would be to check out CVS head anonymously:
http://sourceforge.net/cvs/?group_id=13478
...and run Doxygen.  or just read the raw porting guide in include/FLAC/all.h:
http://flac.cvs.sourceforge.net/*checkout*...lude/FLAC/all.h
Josh
  • JWolf
Reply #103
One small problem with version info. I use flac.exe –version and metaflac.exe –show-vendor-tag in a windows batch script to determine if a .flac file needs to be updated to a newer version. The problem is the output is no longer consistent.
flac.exe –version = flac 1.1.3beta2
metaflac.exe --show-vendor-tag = reference libFLAC 1.1.3-beta2 20061016
The “-“ seems to be the problem. Can you make the change in the final version so my script will work again?
Would you mind posting your batch file please? I would love to know which of my FLAC files need updating and let the batch file go through them all and update just the ones that need updating.
Reply #104
That function is part of a larger script I use for multi-format flac conversion. You can download my current 1.1.2 compatable package from: http://www.revnull.com/download.php?file=!convert.zip
Just unzip the !convert directory into the root of your flac file directory. Run the flac-util.cmd script and follow the prompts.
  • Jose Hidalgo
  • Banned
Reply #105
Hi everybody,
I was just wondering if the LYRICS tab request (see previous topic pages) has been taken into consideration (maybe it already has). IMHO it should be quite easy to implement (I guess it's just an empty space of a given size, isn't it ?).
Josh ? Any news on that matter ?
Thanks again  /  Jose
  • Egor
Reply #106
Hi, support for LYRICS tag has already been added. You can add lyrics text to your flac files like that:
flac.exe --tag-from-file=LYRICS=lyrics.txt (while encoding),
metaflac.exe --set-tag-from-file="LYRICS=lyrics.txt"
If you want to add an empty LYRICS tag, then use following options:
flac.exe --tag=LYRICS="" (while encoding)
metaflac.exe --set-tag="LYRICS="
  • JWolf
Reply #107
Thank you!
  • jcoalson
Reply #108
Foobar2000 [a href='index.php?showtopic=49191']generates[/a] multichannel WAV files, which are not compatible with flac.exe 1.1.3 and Windows Media Encoder. I've sent you a sample to the address at sf.net.
ok, these look like the WAV files flac used to generate too, they are 6ch WAVEFORMATEX which are technically not allowed but common.
the way I am handling this in flac-1.1.3 is an undocumented option '--channel-map=none' to let flac assume the channels are in WAVEFORMATEXTENSIBLE's order.  note that you still have to feed flac a multichannel file that uses one of the legal channel assignments (http://flac.cvs.sourceforge.net/*checkout*...ml#frame_header) if you want to make sure the decoded WAV later has the right channels in the right order with the right channel mask.
Josh
  • Jose Hidalgo
  • Banned
Reply #109
Thanks Egor for your valuable information. Now all we need is music software support for FLAC 1.1.3 including the new "picture" and "LYRICS" tags.
FLAC 1.1.3 is going to ROCK !
Oh BTW, what's the point in adding an empty LYRICS tag ? I don't understand.
  • Egor
Reply #110
An empty LYRICS tag is kinda LYRICS tab you've asked about  :
  • Jose Hidalgo
  • Banned
Reply #111
Ooh, sorry, I meant "tag" not "tab" !
My question was just about the use of an EMPTY lyrics tag. As far as I know we are not compelled to tell FLAC to define empty tags for all the other tags (title, album, genre, etc, etc.). They are default-defined (and empty of course until they are filled), and I guess it will be the same for the picture and LYRICS tags.
So I don't see the use in defining an empty lyrics tag, except for deleting the lyrics you don't want anymore of course. Is that what you meant ?
  • Last Edit: 17 November, 2006, 09:11:16 AM by Jose Hidalgo
  • jcoalson
Reply #112
that's right
for that you can use 'metaflac --remove-tag=LYRICS'
another update: 1.1.3 is in final testing now so it should be ready witihin a week or so.  updated comparison here:
http://flac.sourceforge.net/comparison.html
Josh
  • Jose Hidalgo
  • Banned
Reply #113
Thanks Josh, that's great news !
No offense intended of course, but as far as I know the information on WavPack given at http://flac.sourceforge.net/comparison.html is a bit outdated isn't it ? Here ( http://wiki.hydrogenaudio.org/index.php?ti...less_comparison ) it seems that WavPack has both streaming capabilities and hardware support. Am I wrong ? (I am not used to WavPack).
  • Last Edit: 17 November, 2006, 11:30:04 AM by Jose Hidalgo
  • jcoalson
Reply #114
yeah, that part does need some maintenance but I fixed some of the glaring stuff.
  • Jebus
Reply #115
Sort of off-topic, but the developers page at http://flac.cvs.sourceforge.net/*checkout*.../api/index.html doesn't seem to exist.
  • Egor
Reply #116
You can find the documentation in the latest source tarball (e.g., flac-1.1.3-beta2.tar.gz). See also the quote below:
  • Maurits
Reply #117
the beta seems fine.  I'm still writing patches for various projects that are affected by API changes to make the transition easier.  should be a couple more weeks.
Josh
Have you been in contact with the developers behind taglib? It is a popular open source metadata lib and getting things like lyrics and image support in there means that probably very soon a lot of open source players will support it.
They are working on releasing 1.5 (stable) soon but getting it in now would still be on time judging from the dev-list.
  • Last Edit: 19 November, 2006, 01:26:38 PM by Maurits
There is a hidden message in the song at approximately 4:32. If played at half speed, Waters can be heard to say, "That was pretty avant-garde, wasn't it?"
  • fairway
Reply #118
Are there any news regarding the final testing? (...another update: 1.1.3 is in final testing now so it should be ready witihin a week or so...)
  • fairway
Reply #119
Hi all,
I just checked the download site again and flac 1.1.3 is now out and ready to download!
  • Jose Hidalgo
  • Banned
Reply #120
Thanks fairway.
However I don't see any mention of the LYRICS tag in the changelog : http://flac.sourceforge.net/changelog.html.
And the windows installer link ( http://cyberial.com/flacinstaller.asp ) still points to FLAC 1.1.2a : it seems that only the "tools only" link ( http://sourceforge.net/project/showfiles.p...ackage_id=12675 ) has been updated.
  • Last Edit: 28 November, 2006, 05:16:17 PM by Jose Hidalgo
  • arpeggio
Reply #121
You will find the Windows binaries over here:
http://sourceforge.net/project/showfiles.p...lease_id=467249
  • Last Edit: 28 November, 2006, 05:43:36 PM by arpeggio
  • Jose Hidalgo
  • Banned
Reply #122
Same links as the last one I gave up here (same binaries in fact)...  Thanks anyway !
  • goodnews
  • Banned
Reply #123
Thanks fairway.
Yes, I agree with you, a reference in the FLAC 1.1.3 Docs and CHANGELOG would be nice to let people know that the "LYRICS" tag is the approved tag name for embedding LYRICS in a FLAC file. Josh has posted here that he thinks we should use the LYRICS name for the Tag, plus many others here in this thread have agreed to standadize the tag name on "LYRICS". We need authors to know this so they start supporting an optional LYRICS tag/info along with the new ALBUM ART that the new FLAC version is supporting.
Also a new validated news thread for the FLAC 1.1.3 press release should be started as this thread is for the FLAC 1.1.3 beta, plus it's getting quite long.  Just my opinion...
  • Last Edit: 29 November, 2006, 12:38:52 AM by goodnews
  • jcoalson
Reply #124
I am waiting on the windows installer from Mike (since that is what most people use) before doing the official announcement, to avoid confusion.  but you can get binaries and source for 1.1.3 on sourceforge.
the LYRICS tag is strictly a user issue.  neither FLAC nor Vorbis specify tagging policy, and the only real recommendations are here.  the LYRICS tag as described in this thread is intuitive so I don't see any problem with adoption.
Josh
