Topic: LAME 3.97 released (Read 46084 times) previous topic - next topic
  • Demetris
LAME 3.97 released
Thanks to the LAME developers, to all the testers and issue-reporters, and to those who compile for us!
  • ddrawley
  • Members (Donating)
LAME 3.97 released
Please ignore, my question was already answered.
  • Last Edit: 25 September, 2006, 10:53:39 AM by ddrawley
  • BinaryTB
LAME 3.97 released
I ask this every release, but how long until we stop needing the "lame.exe fixed for decoding through stdout" version?  I mean, I guess the fix has been around for a while, but I don't understand why there is a separate compile every time there is a new version instead of just fixing the regular release version.
  • k.eight.a
LAME 3.97 released
I wonder about the same issue too...
Sorry for my poor English, I'm trying to get better... ;)
"The greatest trick the Devil ever pulled, was convincing the world he didn't exist."
  • krmathis
LAME 3.97 released
LAME 3.97 for Mac OS X (Universal binary).
Feel free to host it on RareWares!
  • john33
LAME 3.97 released
Now at Rarewares, thanks a lot.
John
My compiles and utilities are at http://www.rarewares.org/
  • krmathis
LAME 3.97 released
My pleasure!
  • Martin H
LAME 3.97 released
Reply #32
The fix for decoding MP3s gaplessly ie. modifying the decoder to also remove the trailing padding, and for decoding through stdout has been added to CVS and are included in the latest LAME v3.98 alpha ie. LAME v3.98a6.
  • Last Edit: 25 September, 2006, 06:58:51 PM by Martin H
LAME 3.97 released
Woo hoo, and I was going to reencode all my FLAC files so here's hoping dbpowerAMP gets sorted with 3.97 soon!!
You can replace lame_enc.dll in illustrate/dbpoweramp/compression/lame/ with the new version.  Or you can use the generic cli plugin and use lame.exe.
I'll be getting 3.97 final going with dbpoweramp myself later on.
Thanks to the devs!
Vorbis-q0-lowpass99
lame3.93.1-q5-V9-k-nspsytune
  • Mgz
LAME 3.97 released
Reply #34
those winamp 5.25 guy better make an update quick then
they just add lame 3.97beta something a week ago or so
still LAME 3.96.1 --preset extreme -q 0 -V 0 -m s at least until 2005.
  • spoon
  • Administrator
LAME 3.97 released
Reply #35
The R12 alpha will get 3.97 (non beta) early next week.
  • Maurits
LAME 3.97 released
Reply #36
Thanks krmathis and john33!
By the way, it deserves to be mentioned in the Wiki as well: http://wiki.hydrogenaudio.org/index.php?ti...and_source_code
There is a hidden message in the song at approximately 4:32. If played at half speed, Waters can be heard to say, "That was pretty avant-garde, wasn't it?"
  • probedb
LAME 3.97 released
Reply #37
Excellent, thanks for this I shall give it a go
  • krmathis
LAME 3.97 released
Reply #38
You are most welcome!
By the way, it deserves to be mentioned in the Wiki as well: wiki.hydrogenaudio.org
Then edit the Wiki yourself, and add the information you want in there...
  • DrO
LAME 3.97 released
Reply #39
that's not quite true since the recent lame builds have been in the 5.25betas for most of the ~2month public beta run and the final version is already in internal builds so not something to worry about i think, heh
-daz
  • ZinCh
LAME 3.97 released
Reply #40
thanks for your work!
can you also add *NIX version to rarewares ? (plus freebsd , linux , other compliation ?)
  • Alex B
LAME 3.97 released
Reply #41
Is there any particular reason why lame.exe in the Rarewares 3.97 bundle is now 508 KB. In the 3.97b3 package it was only 263 KB.
I guess it is not compressed similarly, but what is the benefit of the change?
Edit: fixed the size 512 KB -> 508 KB
  • Last Edit: 30 September, 2006, 05:23:00 PM by Alex B
some archived old tests: http://listening-tests.freetzi.com
  • jmartis
LAME 3.97 released
Reply #42
probably a noob question too, but are there any improvements from 3.97b3 > 3.97 final or is 3.97 final basically the same as 3.97b3?
  • DrO
LAME 3.97 released
Reply #43
Alex B: i believe the upx compression was removed since despite using more space on disk, it's better on the system when loaded into memory when it's run (can't find the few posts where it was described off hand)
jmartis: it should be the same as 3.97b3 (think it was mentioned at the start of the thread)
-daz
  • Alex B
LAME 3.97 released
Reply #44
I think I found the answer. It wasn't far away.
Actually, this appears to have been a problem with compressing VC8/ICL9.1 compiles with UPX. It is easily reproducable simply by compressing and decompressing. The compressed version fails, and then decompressing it produces a version that works!!
Looks like I either abandon UPX, or test each time I compress - tedious.
Looks like he abandoned UPX.
  • john33
LAME 3.97 released
Reply #45
Yep!!
John
  • xmixahlx
LAME 3.97 released
Reply #46
fresh lame compiles have been added to RareWares/Debian:
lame, lame-3.97, lame-cvs
later
  • Bourne
  • Banned
LAME 3.97 released
Reply #47
I have just upgraded to foobar 0.9.4 and lame final 3.97. Converting FLAC files to mp3 now returns error code 1. Back to the good ole versions of foobar (0.9.1) and lame (3.97b2).
  • Last Edit: 04 October, 2006, 04:19:47 PM by Bourne
  • Sunhillow
LAME 3.97 released
Reply #48
Better change only 1 parameter at a time, so you can see which change produces the fault
  • Bourne
  • Banned
LAME 3.97 released
Reply #49
the parameters are the foobar2k ones default... and yes, I tried that in the command line...
i suppose it's just broken?
it's a funny thing though... it didn't happen initially... I got to convert about 3 albums from FLAC to MP3.
it's just that 2 days after I upgraded the lame.exe in foobar2k it just couldn't do it anymore...
  • Last Edit: 04 October, 2006, 04:43:52 PM by Bourne
