Topic: Prevent id3v1 tags using converter? (Read 1585 times) previous topic - next topic
  • paulgj
Hello,
I have modified the default MP3 converter command line to specify:
-S --noreplaygain --id3v2-only -V 2 --vbr-new - %d
yet still when I convert say a FLAC file to MP3 I am seeing id3v1 tags in the file (according to Mp3tag).
Is there a way to tell foobar not to include the v1 tags?
Foobar 9.6.9, FLAC 1.2.1b, EAC 0.99 pb 5
Windows 7 Pro 64-bit
  • db1989
  • Global Moderator
Take out the "--id3v2-only" (you may as well switch back to the non-custom encoder) and change the "Preferred Tagging Scheme" option in the advanced preferences (i.e. change to "ID3v2" instead):
  • paulgj
Thank you! that worked like a charm!
