Topic: the new psytell aac encoder v1.6 still crashes on me (Read 4497 times) previous topic - next topic
i just downloadet the new psytell v1.6 aac encoder and it still crashes on the same tracks...
however only when using -streaming if i use -normal it works fine but gives me to big files  (above 160kbits)
i ten tried using -br 128 -vr -c18500 and it still crashes. so somethings tells me it got somethign to due with the "small" vbr mode
Sven Bent - Denmark
I tried the setting you used, but had no problems (only 3 clips tested).
hum, is the file name is without space ?? try with a smaller file name
Hummmm... maybe I should add "BETA" to its status in my page, and upload again
good old 1.5?
the error must lie in v1.5 hence i re-econde cd which i had no problems with v1.5
but now when i encode with 1.6 it crashes on 6 of the songs....
yes plese uplaod v1.5 again i need that :-)
but the errro also does only occur when using -streaming.
if i use -normal it works fine..which even more show that the fault must lie in the encoder......
i can compress the wa.vs with winrar and upload somwhere for testing purpose
Sven Bent - Denmark
the aacenc 1.6 is working again for me..for some wierd reason.
even thougt i have tried with to different version of 1.6 (crc32 chekc revealed differences in exe file) and it woudle crashes..te latest i got from http://www.inf.ufpr.br/~rja00/  suddenly worket fine....is ther a third v1.6  of psytell AAC encoder?
Sven Bent - Denmark
You should take a look at the build date of the files in my page.
Version numbers seem to only reflect algorithm improvements, no bug fixes.
Regards;
Roberto.
