Topic: foo_uie_single_column_playlist (Read 574885 times) previous topic - next topic
Reply #100
terrestrial is it possible to make it so that it can handle more formats, pretty much the ones that the current albumart panel is capable of useing?
yes, eventually.
would be great !
Reply #101
I have in each album folder a folder.png (or. jpg actually) file with the cover, so I'd like to get it with the same command used with album art :
So using the model given above, I've made that line :
$imageabs(6,$add(25,$mul(-14,%tracknumber%)),$left(%path%,$sub($len(%path%),$len(%filename_ext%)))folder.png,)
But it doesn-t work
Anyone have a solution ?
  • FofR
Reply #102
Your image path needs to relative to the foobar directory, I suggest reading the trackinfo panel mod wiki page for details about using images.
Reply #103
ohhh, it's pretty sad. I don't think it's logical to put the covers in the foobar folder, they're better with the rest of the albums... :-(
  • zackorah
Reply #104
to the guy who asked for my code;
ITEM
$if(%tracknumber%,$drawrect(0,0,0,0,brushcolor-255-255-255 pencolor-null),)
$if(%cwb_queueindex%,$drawrect(0,0,0,0,brushcolor-58-110-165 pencolor-null),)
$if(%isplaying%,$drawrect(0,0,0,0,brushcolor-62-128-223 pencolor-null),)
$if(%_selected%,$drawrect(0,0,0,0,brushcolor-62-128-223 pencolor-null),)
$puts(art.width,119)
$puts(art.height,21)
$puts(art.num,$add($div($mul(%list_index%,%_height%),$get(art.height)),1))
$puts(art.offset,-$sub($sub($mul(%list_index%,%_height%),$mul($sub($get(art.num),1),$get(art.height))),%_height%))
$imageabs(0,$get(art.offset),images\column.left.png,)
$imageabs(6,$add(25,$mul(-14,%tracknumber%)),images/%album%.png,)
$imageabs(3,$add(22,$mul(-14,%tracknumber%)),images/overlay.png,)
$alignabs(5,,%_width%,%_height%,,)
$if($stricmp($num(%tracknumber%,2),09),$font(tahoma,8,bold,)$abbr(%artist%,12) - %date%,)
$if($stricmp($num(%tracknumber%,2),10),$font(tahoma,8,bold,62-128-223)$abbr(%album%,16),)
$if($stricmp($num(%tracknumber%,2),11),$font(tahoma,8,bold,)Total Tracks: $font(tahoma,8,,)%totaltracks%,)
$if($stricmp($num(%tracknumber%,2),12),$font(tahoma,8,bold,)Genre: $font(tahoma,8,,)%genre%,)
$font(tahoma,8,,)
$alignabs(125,,%_width%,%_height%,,)
$if(%tracknumber%,
$if(%isplaying%,$font(,,,233-233-233)$imageabs(122,0,images\playing.png,),$font(,,,10-36-106))
%tracknumber%$font(,,,233-233-233).
$if(%isplaying%,$font(,,,233-233-233),$font(,,,0-0-0))
$align(right,middle)
$if(%title%,$trim($left(%title%,$sub($strrchr(%title%,$char(40)),1))),) %length%
$if($strrchr(%title%,$char(40)),
$font(,,,233-233-233) $char(40)
$if(%isplaying%,$font(,,,233-233-233),$font(,,,10-36-106))
$substr(%title%,$add($strrchr(%title%,$char(40)),1),$sub($strrchr(%title%,$char(41)),1))
$font(,,,233-233-233)$char(41)
[%artist% - ]%title%
$alignabs($sub(%_width%,$calcwidth(%cwb_queueindexes%),150),,%_width%,%_height%,,)
$font(,,,233-233-233)Q
$if(%isplaying%,$font(,,,233-233-233),$font(,,,140-186-236)):
$font(,,,233-233-233)$char(91)$if(%isplaying%,$font(,,,233-233-233),$font(,,,140-186-236))%cwb_queueindexes%$char(47)%cwb_queuelength%$font(,,,233-233-233)$char(93)
$align(right,)
GROUP
$if(%tracknumber%,
$drawrect(0,0,0,0,brushcolor-62-128-223 pencolor-null)$padding(4,0)
$imageabs(0,0,images\title.png,)
$font(tahoma,7,,233-233-233)
$align(left,middle)$if(%CDID%,$char(91)$font(,,,140-186-236)%CDID%$font(,,,233-233-233)$char(93),)
$padding(120,0)
$align(left,middle)
$if(%album artist%,
$if($strrchr(%album artist%,$char(12300)),
$font(,,,140-186-236)$char(12300)$font(,,,233-233-233)$substr(%album artist%,2,$sub($len(%album artist%),1))$font(,,,140-186-236)$char(12301)
,%album artist%)
$if($and(%album artist%,%album%),$font(,,,140-186-236) - $font(,,,233-233-233),)
$trim($left(%album%,$sub($strrchr(%album%,$char(40)),1)))
$drawrect(0,0,0,0,brushcolor-130-130-255 pencolor-null)$padding(4,0)
$align(center,)$font(tahoma,7,italic,0-0-0)~ Singles ~
$imageabs(0,0,images\column.left.png,)
With updates every xx seconds, more image types, and ability to include images from other drives then this plugin would be complete, Imo!
EDIT: Took out two comments that shouldn't have been in the code
EDIT2: oh and draggable sorting
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Converted [ code ] to [ codebox ] to preserve forum layout.[/size]
  • Last Edit: 05 September, 2006, 04:15:37 AM by foosion
Reply #105
That is really amazing!
It seems rather limitating though.. But, when the improvements you speak about will be here, it will be just great!
Reply #106
your layout si quite awsome can you share these images also?
and your lineheight and group by parameters?
... when i come home from work i would like to try to use your layout and im looking really forward to it  thanks for you work
  • Last Edit: 05 September, 2006, 08:53:26 AM by cartman(2vd)
  • zackorah
Reply #107
http://zack.leafo.net/foobar
Everything for my new layout is on there; I deleted the images (overwritten) for my older one, sorry :s
  • BlindSeer
Reply #108
Nice component. It would be very useful to have a setting wherein tracks that are not part of a group would not be given a header. Thanks.
I use $if(%singletrack%,,%album%%disc%) for Group by and tagged the files with "SINGLETRACK=1"
When I try this, it produces a header for every single track preceded by non-single tracks. I would prefer no header at all.
  • Fitret
Reply #109
I'm trying to use this and I'm having one slight issue.  You appear to be pulling album art from your App Data folder, but I have all of my album art stored in the folder that the songs are stored in (and it's also stored in the tags, I think).  Anyways, I tried changing the one line to:
$imageabs(6,$add(25,$mul(-14,%tracknumber%)),$replace(%path%,%filename_ext%,'folder.jpg'),)
but it's not loading the image.  I also tried folder.png, no luck.  I printed out the result of the $replace() statement, and the path is correct.  Any ideas as to why this wouldn't be working?
  • zackorah
Reply #110
it HAS to be png, files can't come from another drive other than foobar too, and try..
$imageabs(6,$add(25,$mul(-14,%tracknumber%)),$replace(../../%path%,%filename_ext%,'folder.png'),)
Read back a few in the topic, someone did something like this.
  • Fitret
Reply #111
I knew the png thing, which is why I tried it out, but I didn't know about the hard drive thing.  My foobar is on a different drive than my MP3s, and I plan on keeping it that way.  I'm assuming that (hopefully soon) the plugin will be updated to load art from other hard drives?
  • Last Edit: 05 September, 2006, 05:52:17 PM by Fitret
  • zackorah
Reply #112
Yeah, that is how it is for me, seperate 200gb hard drive for music. Thus the reason I just batch converted my art to png, and batch resized to 100x100 and renamed to album and put into the app dir .
EDIT: infact, terrerstrial do you plan to release the source code?
  • Last Edit: 05 September, 2006, 07:41:12 PM by zackorah
  • vonmeth
Reply #113
Edit: Someone already answered the question I was going to answer.
  • Last Edit: 05 September, 2006, 08:13:51 PM by vonmeth
  • Fitret
Reply #114
I also have a seperate 200gb drive for music.  Maybe I should do this... did you do it in photoshop?  I know how to resize and change to png in batch mode, but not how to rename the file based on the directory structure. (All of my music is Artist\Album\music.mp3)
  • tool++
Reply #115
How would I do this?
All my art is in F:\music\Artist\[Year]Album\folder.png/jpg
Whereas foobar is in D:\fb2k
hi
  • lextune
Reply #116
First off, amazing work man.
Second. Is it possible to select multiple tracks for tagging and/or converting purposes?
foobar2000 + EAC + Burrrn = Happiness
  • acedriver
Reply #117
yes, you can.
  • lextune
Reply #118
Can someone enlighten me?
  • FofR
Reply #119
ctrl+click the items?
  • acedriver
Reply #120
ctrl+click and shift+click
  • lextune
Reply #121
Hmmm....yeah, thanks, but how about with just the mouse, (like the regular Columns UI) I don't want to have to ctrl+click 20 times if I can avoid it.
  • tool++
Reply #122
Shift Click start, then shift click end of where you want to select.
Will select all between those points.
hi
  • lextune
Reply #123
EDIT: Shift+click at least narrows it down to 2 clicks.
Thanks again.
2ND EDIT: Thanks tool, just realized that.
  • Last Edit: 06 September, 2006, 09:15:17 AM by lextune
Reply #124
Hoping someone can help me out here. What part do i change to get a black selection bar instead of white?
 $if($strcmp($mod(%_playlist_number%,2),1),
$drawrect(,,,,brushcolor-45-45-45 pencolor-null))
$padding(2,0)
$font(Calibri MOD2,8,,$if(%isplaying%,85-217-255,170-170-170))
[  %tracknumber%  ]$replace(%title%,'(',$font(,,bold italic,204-204-204)'(')
Cheers
