Topic: Home stereo display (Read 273964 times) previous topic - next topic
Home stereo display
Reply #200
The font I found actually has those characters.  It is mentioned in this post.
I knew about that font but I have never seen an LCD supporting those accents. I would just prefer the conversion-thing.
Perhaps an option (conversion or not) would be the best thing.
Please,could you provide me with an example track that has those symbols? I need to test it first.
I could give you something. Do you have Skype? I could also send it via email. (374KB)
another small note: you should mention somewhere in the instructions, that a vertical and horizontal padding of 10 is needed for a correct alignment of the boxes behind the letters.
Home stereo display
Reply #201
Email me:russel777@gmail.com
As for the vertiacal padding:i didn't know that it affects the rectangle positioning (b/c it doesn't affect the rest)
I'll add the notice in the first post,thanks.
Favourite artist:CD-R
Favourite album:700MB
Home stereo display
Reply #202
Multichannel support! You made my day...
Home stereo display
Reply #203
Nice update, one thing you might consider adding is a queue length indicator although I have no idea where you would fit it in.
Home stereo display
Reply #204
converting german special characters (ä,ö,ü,ß) to to ae, oe, ue, ss. this way they can be used with the lcd-font. thank you.
Done,will be released soon.
Home stereo display
Reply #205
If you will be doing this, you might want to get other characters with accents.
Home stereo display
Reply #206
Sure,for me it's chineese,if you could provide them to me (together with their spelling) i'll be glad.
Home stereo display
Reply #207
Here are a bunch of them for you:
À,Á,Â,Ã,Ä,Å,Æ,Ç,È,É,Ê,Ë,Ì,Í,Î,Ï,Ñ,Ò,Ó,Ô,Õ,Ö,Ù,Ú,Û,Ü,Œ
I pulled those out of the Character Map in Windows.  I think these are some of the more common ones.  I don't need all of these, but I thought it would be good to cover the bases.  I would assume that you could do upper and lower with needing to copy both here.  If not, let me know.
Home stereo display
Reply #208
Thats all good,but how to spell those?I mean what english letters combinations should i assign to each of those
symbols?
Home stereo display
Reply #209
symbols?
Good point.  Most are straight forward (or should be unless I am wrong):
A,A,A,A,A,A,AE,C,E,E,E,E,I,I,I,I,N,O,O,O,O,O,U,U,U,U,OE
Home stereo display
Reply #210
Home stereo display
Reply #211
I think you should enclose the title/artist display bit in a $lower() function, because the capital M and W letters on the lcdmono2 font "run over" onto the next letter..
example:
Home stereo display
Reply #212
example:
Thanks for the observation,i'll change it.
Home stereo display
Reply #213
Here Is A Little Ditty I made up for a background
Corrected
Home stereo display
Reply #214
Link1
Link2
Jacklewis, I'm so Sorry.
I clicked 2nd Link.
2nd link is delete uploaded file.
Reupload your theme. PLZ.
I'm Korean.
My english is poor. : (
Home stereo display
Reply #216
Russell 777 you are the man Bro. Thank you So much , you are a geneus man with those display they are Off the Hinges they`ll Great.  Give Thanks...  JAHPAL Love`em
Home stereo display
Reply #217
Hi, Russell.  Thanks for new updates.  They're nice.
Unicode (Chi/JP/Kor/Rus) stopped working for me.
But not when the title's latin...
Home stereo display
Reply #218
hey what font are you using for the chi/jp/kor/rus displayed in blue above the home stereo display?
Home stereo display
Reply #220
Yes i know,it's because i had to remove the arial unicode ms font support,but i plan to release an update in which every one could use his own defined font for unicode needs,coming soon.
Home stereo display
Reply #221
--> http://rapidshare.de/files/32160672/1.7_al...essbar.rar.html
my little custom mod, because i dont use last played, so i made it to a progressbar
using V1.7
if any1 has a nice idea, what can be used instead of the rating, post it, i have no good idea (and almost no coding skills :/ )
Home stereo display
Reply #222
VERSION 1.7.1 is out (see the first post)
Added:
-Support for user defined fonts
-Basic transcription support for latin letters with accents.(while using LCD font)
-Adjustable scroll window length
-Slightly changed alignment to achive a more compact and solid look
-Additional theme
Well I know i'm being a pain in the ass with all the updates,but I'm just trying to make it better
and more usable.I promise not to release any updates in the nearest future.Enjoy
Home stereo display
Reply #223
Tahoma has unicode.  And almost everyone has Tahoma...
That's Tahoma.  size 26pt
Home stereo display
Reply #224
I love the stereo track info display, it has changed the way I use foobar2000.
Since you are adding options for various things, I have a couple suggestions that others might like as well and I'd love to see them as configuration variables so I dont have to remake the changes when I update to latest versions.
1 - Option to disable the leading zero on total time and play time.  This can be done
$puts(1,$replace($get(1),0, ))
$puts(8,$replace($get(8),0, ))
2 - Option to display the last played date as the number of days ago, rather than the actual date.  Perhaps the YY_MM_DD variable could be extended to allow you to choose from YY-MM-DD, YY.MM.DD, or xx Days Ago.
$get(active)
$if(%last_played%, $puts(diff,$cwb_datediff(%last_played%,%cwb_systemdate%))
$ifgreater(1,$get(diff),today,$ifgreater(2,$get(diff),yesterday,$get(diff) days)),..........)
There used to be a link to my website here.
