It crashed foobar, if I do the following:
- update a playlist with foo_playlist_bind
- press pageup or pagedown (which are linked to "jump to prev/next directory")
*CRASH*
I edit and add info to this posting if I know more.
EDIT: It seems to happen if no track is marked. Probably your plugin does not handle this. If I mark a track with mouse or up/down arrows, everything is fine.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01286316h
Access violation, operation: read, address: 00000000h
Call path:
entry=>app_mainloop
Code bytes (01286316h):
012862D6h: 07 29 01 89 44 24 4C 89 5C 24 50 89 5C 24 54 89
012862E6h: 5C 24 58 89 5C 24 5C 89 44 24 38 89 5C 24 3C 89
012862F6h: 5C 24 40 89 5C 24 44 89 5C 24 48 89 5C 24 14 8B
01286306h: 75 0C 3B F3 C6 84 24 48 02 00 00 03 75 60 8B 0F
01286316h: 8B 01 8B 50 0C FF D2 8B 10 8B C8 8B 02 FF D0 8D
01286326h: 4C 24 24 51 8B C8 E8 8F 2F 00 00 C6 84 24 48 02
01286336h: 00 00 04 39 58 10 76 05 8B 40 04 EB 05 B8 D8 05
01286346h: 29 01 8B 54 24 4C 6A FF 50 8B 42 08 8D 4C 24 54
Stack (0012F494h):
0012F474h: 778B7E64 77881678 FFFFFFFF 00E1D49C
0012F484h: 77E9F715 00070000 00000000 000DAC38
0012F494h: 1E4B1FAF FFFFFFFF 00000004 00000000
0012F4A4h: 00000088 00000000 00130000 004DF180
0012F4B4h: 778CB618 00000000 00000000 001A4040
0012F4C4h: 008B0688 0012F56C 012907D8 00000000
0012F4D4h: 00000000 00000000 00000000 012907D8
0012F4E4h: 00000000 00000000 00000000 00000000
0012F4F4h: 054B0260 04A70000 0012F518 778CD981
0012F504h: 000003C5 054B21D8 04A70000 054B0260
0012F514h: 054B0268 04A70000 04A70000 04A70178
0012F524h: 778CBA2B 04A70608 778CB9B1 0012F6B0
0012F534h: 0012F5A0 00000001 00000000 00000040
0012F544h: 6569565B 614C2F77 74756F79 6F4E205D
0012F554h: 6F626574 00806B6F 00000000 00000000
0012F564h: 00000000 00000000 0012F59C 054915F0
0012F574h: 778B2C8A 04A70000 054915E8 054915F0
0012F584h: 0012F578 04A70688 0012F630 778B7E64
0012F594h: 77883158 FFFFFFFF 0012F640 778CB7C2
0012F5A4h: 04A70778 054915F0 00000000 054915F0
Registers:
EAX: 012907D8, EBX: 00000000, ECX: 00000000, EDX: 00133048
ESI: 00000000, EDI: 0012F70C, EBP: 0012F6E0, ESP: 0012F494
Crash location: "foo_menu_addons", loaded at 01280000h - 0129E000h
Loaded modules:
foobar2000 loaded at 00400000h - 004F3000h
ntdll loaded at 77880000h - 77902000h
COMCTL32 loaded at 71710000h - 71794000h
GDI32 loaded at 77F40000h - 77F7F000h
KERNEL32 loaded at 77E70000h - 77F30000h
USER32 loaded at 77E00000h - 77E69000h
ADVAPI32 loaded at 79350000h - 793B5000h
RPCRT4 loaded at 77D20000h - 77D98000h
SHLWAPI loaded at 70BD0000h - 70C35000h
msvcrt loaded at 78000000h - 78045000h
SHELL32 loaded at 7CF90000h - 7D1EC000h
ole32 loaded at 7CE80000h - 7CF81000h
shared loaded at 10000000h - 10029000h
comdlg32 loaded at 76B00000h - 76B3F000h
foo_abx loaded at 008C0000h - 008F3000h
foo_autoplaylist loaded at 00910000h - 00940000h
foo_cdda loaded at 00950000h - 00986000h
foo_cmd_playlist loaded at 009A0000h - 009B8000h
foo_common loaded at 009D0000h - 00A0A000h
foo_converter loaded at 00A20000h - 00A89000h
foo_cwb_hooks loaded at 00AA0000h - 00ACE000h
foo_dsp_continuator loaded at 00AE0000h - 00B12000h
OLEAUT32 loaded at 779A0000h - 77A3B000h
foo_dsp_delta loaded at 00F40000h - 00F5E000h
foo_dsp_std loaded at 00F70000h - 00FB1000h
foo_dsp_vlevel loaded at 00FD0000h - 00FF4000h
foo_freedb2 loaded at 01010000h - 01050000h
foo_fullscreen loaded at 01060000h - 0107B000h
foo_input_monkey loaded at 01090000h - 010D9000h
foo_input_std loaded at 010F0000h - 01204000h
foo_masstag loaded at 01220000h - 01270000h
foo_menu_addons loaded at 01280000h - 0129E000h
MSVCR80 loaded at 78130000h - 781CB000h
foo_playlist_bind loaded at 012B0000h - 012D5000h
foo_playlist_manager loaded at 012F0000h - 01336000h
foo_pqview loaded at 01350000h - 0136C000h
foo_random loaded at 01380000h - 013BF000h
foo_rgscan loaded at 013D0000h - 01418000h
foo_runcmd loaded at 01430000h - 0145F000h
foo_sic loaded at 01470000h - 014C7000h
WS2_32 loaded at 74FA0000h - 74FB4000h
WS2HELP loaded at 74F90000h - 74F98000h
foo_uie_bookmarks loaded at 015E0000h - 01626000h
foo_uie_explorer loaded at 01640000h - 0167C000h
foo_uie_queuemanager loaded at 01690000h - 016C9000h
msvcm80 loaded at 7C4C0000h - 7C53D000h
mscoree loaded at 79000000h - 79045000h
mscorwks loaded at 79E70000h - 7A3D1000h
mscorlib.ni loaded at 03A40000h - 04528000h
mscorjit loaded at 79060000h - 790B3000h
rsaenh loaded at 7CA00000h - 7CA23000h
USERENV loaded at 791A0000h - 79205000h
CRYPT32 loaded at 799D0000h - 79A5C000h
MSASN1 loaded at 77400000h - 77411000h
System.ni loaded at 7A440000h - 7ABFE000h
System.Drawing.ni loaded at 7ADE0000h - 7AF74000h
Gdiplus loaded at 70D00000h - 70E91000h
foo_uie_quicksearch loaded at 048A0000h - 048E8000h
foo_uie_tabs loaded at 04900000h - 04926000h
foo_uie_trackinfo loaded at 04940000h - 0496F000h
foo_uie_trackinfo_mod loaded at 04980000h - 049CE000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
foo_ui_columns loaded at 049D0000h - 04A67000h
foo_ui_std loaded at 04A80000h - 04AD7000h
foo_unpack loaded at 04AF0000h - 04B1E000h
foo_utils loaded at 04B30000h - 04B69000h
CLBCATQ loaded at 784A0000h - 78530000h
cscui loaded at 77840000h - 7787F000h
CSCDLL loaded at 77090000h - 770B3000h
MPR loaded at 782F0000h - 78301000h
ntlanman loaded at 750D0000h - 750DC000h
NETAPI32 loaded at 7CE20000h - 7CE73000h
DNSAPI loaded at 77970000h - 77994000h
WSOCK32 loaded at 74FC0000h - 74FC9000h
NETRAP loaded at 75130000h - 75136000h
NTDSAPI loaded at 77BE0000h - 77BF1000h
WLDAP32 loaded at 77940000h - 7796C000h
SECUR32 loaded at 79430000h - 7943F000h
SAMLIB loaded at 750C0000h - 750D0000h
NETUI0 loaded at 75180000h - 75195000h
NETUI1 loaded at 75140000h - 75178000h
System.Windows.Forms.ni loaded at 7AFD0000h - 7BC56000h
keyboard loaded at 067A0000h - 067B0000h
imagehlp loaded at 77910000h - 77933000h
DBGHELP loaded at 72970000h - 7299D000h
Stack dump analysis:
Address: 004DF180h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 778CB618h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 012907D8h, location: "foo_menu_addons", loaded at 01280000h - 0129E000h
Address: 778CD981h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CBA2Bh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CB9B1h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778B2C8Ah, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778B7E64h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77883158h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CB7C2h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 049E05B6h, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 004BE0C4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 00403929h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00416922h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040A6AAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040A6B7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A6162h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 012821BDh, location: "foo_menu_addons", loaded at 01280000h - 0129E000h
Address: 0128E138h, location: "foo_menu_addons", loaded at 01280000h - 0129E000h
Address: 01286C30h, location: "foo_menu_addons", loaded at 01280000h - 0129E000h
Address: 01296A44h, location: "foo_menu_addons", loaded at 01280000h - 0129E000h
Address: 0040A63Fh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01291808h, location: "foo_menu_addons", loaded at 01280000h - 0129E000h
Address: 0128DFD9h, location: "foo_menu_addons", loaded at 01280000h - 0129E000h
Address: 01283961h, location: "foo_menu_addons", loaded at 01280000h - 0129E000h
Address: 0128EB30h, location: "foo_menu_addons", loaded at 01280000h - 0129E000h
Address: 01286116h, location: "foo_menu_addons", loaded at 01280000h - 0129E000h
Address: 0128EE98h, location: "foo_menu_addons", loaded at 01280000h - 0129E000h
Address: 0048081Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A72B8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0042B285h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040BC48h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77881678h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 004286A3h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BFF04h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004DE76Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004287E9h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004287D1h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 049DAF11h, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 04A43374h, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 04A32B98h, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 049DB0F5h, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 049DB036h, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 049DB047h, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 04A42FDCh, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 04A43414h, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 04A4340Ch, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 04A33090h, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 049E967Dh, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 04A2EF5Ah, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 049EC5C9h, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 77E2C159h, location: "USER32", loaded at 77E00000h - 77E69000h
Address: 0495B424h, location: "foo_uie_trackinfo", loaded at 04940000h - 0496F000h
Address: 04A2F342h, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 77E317D6h, location: "USER32", loaded at 77E00000h - 77E69000h
Address: 77E317A7h, location: "USER32", loaded at 77E00000h - 77E69000h
Address: 049D6828h, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 77E22FC0h, location: "USER32", loaded at 77E00000h - 77E69000h
Address: 77E3158Fh, location: "USER32", loaded at 77E00000h - 77E69000h
Address: 77E31DC9h, location: "USER32", loaded at 77E00000h - 77E69000h
Address: 049D66B0h, location: "foo_ui_columns", loaded at 049D0000h - 04A67000h
Address: 77E23F1Dh, location: "USER32", loaded at 77E00000h - 77E69000h
Address: 77E229EBh, location: "USER32", loaded at 77E00000h - 77E69000h
Address: 77E337BDh, location: "USER32", loaded at 77E00000h - 77E69000h
Address: 77E31DF8h, location: "USER32", loaded at 77E00000h - 77E69000h
Address: 77E31E7Eh, location: "USER32", loaded at 77E00000h - 77E69000h
Address: 0042FED3h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002DD2h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 004C0510h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430A19h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01020102h, location: "foo_freedb2", loaded at 01010000h - 01050000h
Address: 01020100h, location: "foo_freedb2", loaded at 01010000h - 01050000h
Address: 004C07D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C767Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C7660h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 778B2C0Ch, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77883148h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CB0FFh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CB4BEh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CACEAh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CB301h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 004E41C0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 1000363Bh, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uGetCallStackPath" (+0000083Bh)
Address: 10000000h, location: "shared", loaded at 10000000h - 10029000h
Address: 004E41F0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4240h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77881650h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 00493B9Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00428FEFh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00447E95h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 778CD168h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 0049695Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0520h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF314h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430C20h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E09B0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004969E4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00491EDCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00491ED6h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49F0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B3B30h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4238h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496CE0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF708h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496144h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77E98989h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 77EC1F54h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 77E72B18h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 004961ADh, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4
UNICODE
Additional info:
Fullscreen 0.3.1 (foo_fullscreen)
Continuator 0.4.0 (foo_dsp_continuator)
Track info panel mod 0.6 beta [Sep 27 2006 - 20:37:46] (foo_uie_trackinfo_mod)
FLAC decoder 1.1.0 (foo_input_std)
Standard Input Array 1.0 (foo_input_std)
foobar2000 core v0.9.4 (Core)
Randomized playlist entry 1.2.3 (foo_random)
Standard DSP array 1.0 (foo_dsp_std)
LPCM <--> delta-PCM converter 0.1.1 (foo_dsp_delta)
WMA Decoder 1.1 (foo_input_std)
Tabbed panel modifyed 0.2.1 (foo_uie_tabs)
Queue manager panel 0.2.1 (foo_uie_queuemanager)
Masstagger 1.6 (foo_masstag)
Playlist tools 0.5.7 (foo_utils)
Run Command 1.0 beta 1 (foo_runcmd)
Explorer Tree 1.04.6b (foo_uie_explorer)
Bookmarks 0.0.5.2 (foo_uie_bookmarks)
ReplayGain Scanner 2.0.2 (foo_rgscan)
Playlist Manager 1.0 (foo_playlist_manager)
cwbowron's title format hooks 1.0.12 [Sep 29 2006 - 08:22:23] (foo_cwb_hooks)
ZIP/GZIP reader 1.0 (foo_unpack)
Quick Search Toolbar 2.8h (foo_uie_quicksearch)
Monkey's Audio decoder 2.1.1 (foo_input_monkey)
RAR reader 1.1 (foo_unpack)
Columns UI 0.1.3 beta 1v6 TEST (foo_ui_columns)
foosic music database 1.0 beta 11 (foo_sic)
Menu Addons 0.3.4 (foo_menu_addons)
Common services 0.1 (foo_common)
VLevel 20060324.0 (foo_dsp_vlevel)
CD Audio Decoder 2.1.1 (foo_cdda)
Track info panel 0.82 (foo_uie_trackinfo)
Autoplaylist Manager 1.0 (foo_autoplaylist)
Playlist Bind 2.2 (foo_playlist_bind)
Default User Interface 0.9acc (foo_ui_std)
ABX Comparator 1.3.1 (foo_abx)
freedb Tagger 0.5.2a (foo_freedb2)
Converter 1.0.1 (foo_converter)
Playlist Commandline Tools 0.0.1 (foo_cmd_playlist)
