Topic: Track Info Panel with ability to change font (Read 733512 times) previous topic - next topic
Reply #1025
Thank you wraithdu that gave a good idea how to do it. Is it possible to add transition time between images?
And another thing.. How do I bind buttons to current playlist selection instead of now playing item?
Reply #1026
I don't believe it's possible to transition between art exactly, at least not a blending effect.  You could do something with cropping to make the image appear as a horizontal/vertical/diagonal wipe.  But I don't know how to get timing in smaller increments than seconds, so the wipe would be very choppy and ugly IMO.
I'm not sure what you mean by this?  Buttons are assigned commands, that is all.  If a command affects the selection or now playing item, that is the nature of the command.
Reply #1027
I'm trying to link rating buttons to current playlist selection. If I use the code below it rates currently playing song instead. In the normal buttons panel you can select the item group a specific command affects.
$button(300,10,0,0,22,22,images\orchid\buttons\1.png,images\orchid\buttons\1a.png,rating1,)
"rating1" is a masstagger script that changes %rating%=1
Reply #1028
I see exactly what you are saying now.  Unfortunately I don't have an answer for you.  Maybe the actual command is altered/appended in some way to affect the selection vs now playing item.  If it is though, it is not shown how it is changed.  This might just be a function of the button panel though, and would have to be something added to Track Display button coding by terrestrial to enable this functionality, ie something in the OPTIONS section of the button code.
What happens if you stop playback (so there is no now playing item), then select some songs, then try your button?
Reply #1029
I'm having problem with some code I have here:
//REPLAY GAIN//
$puts(rpg,
$if(%__replaygain_track_gain%,   TGain: $rgb(77,122,172)$cut(%__replaygain_track_gain%,5)' dB',$rgb(78,78,78)       '['$button2(300,1,0,0,150,16,'$font(tahoma,8,underline,61-131-182)No TGain','$font(tahoma,8,underline italics,120-145-209)No TGain',Scan Per-file Track Gain,)']'))
$alignabs(400,1,95,16,,)
$get(rpg)
//REPLAY GAIN//
What it's supposed to do is display the replaygain info, which it does when the file HAS some. But if it DOESN'T have any, its supposed to display a [ bracket, then a button I click (text) that will scan the file, then a closing ] bracket.
I'm not sure what I screwed up here in the code . A little help?
Reply #1030
Hi, I've got a problem.
I was planning to change the old foo_uie_trackinfo to this one but i encountered a problem (i simple one i hope)
Basicly the problem is that [%playback_time% / ]%length% or similar don't work:
All the time its 00:00/XX:XX
I hope someone could point me where the problem is
Reply #1031
[a href="http://xs.to/xs.php?h=xs412&d=07074&f=foo_prob.jpg" target="_blank"].
Reply #1032
Thank you. Works perfectly now
Reply #1033
Could anyone tell me if there is a command to switch a panel between 'follow cursor' and 'now playing' modes?  I want to switch to 'now playing' when playing and 'follow cursor' when stopped.
Reply #1034
I've seen this on the forum and it works good, but when I add the last part ($char(10)[%playback_time% / ] %length%) I'm getting an
"No track
when I dont play anything, the No track is fine, but how do I delete the "?"
// PerSecond
$char(10)$char(10)$if(%_trackinfo_notrack%,No track,Artist: %artist%
$char(10)Title: %title%
$char(10)Album: %album%)
Reply #1035
"No track
// PerSecond
add [ and ] around %length%. [ and ] make the "tagz" only show up if the "tag" is there. So the last line would read: $char(10)[%playback_time% / ] [%length%]
(NOTE: Still need help with my problem meantioned above people ...)
Reply #1036
sorry I can't help you but maybe someone knows this:
I want to add the source in the info panel
So I already have:
Artist:
Album:
etc...
But now I want to add the source of the folder like:
Source: D:\music\John - Happy Song.mp3
I use now [%path%] but this only shows D:\My
instand of D:\My music\folder\John - Happy Song.mp3
Reply #1037
Has anyone had any luck associating .trackinfo files to an external editor? When I click the Edit button it always uses Notepad. I'm a little bit unsure about this anyway since I don't know where these .trackinfo files would be. Are the just created in the TEMP directory?
Reply #1038
So I already have:
Artist:
Album:
etc...
Hmm, not sure.  It works just fine for me, and I have spaces in my directory structure as well.  Post the rest of your code.  Perhaps there's a problem somewhere else that is causing the text to be cut off.
Reply #1039
I tried this code and now it works fine.
so I think you are right, the code was wrong
// PerSecond
$char(10)Artist: %artist%
$char(10)Date: %date%
$char(10)Length: %Playback_time% / %length%
$char(10)Bitrate: %bitrate%kbps
Reply #1040
@terrstrial
Is there a way to use mouse wheel for scroll like the classic trackinfo?
no, the display code (and syntax) are not really designed for scrolling.
Is this still the case with the latest version? I'm trying to create a tagging panel and have a fairly lengthy list.
Reply #1041
How do I get the bitrate at //PerTrack and %Playback_time% / %length% //PerSecond in the following order:
- Artist (//PerTrack)
- Title (//PerTrack)
- Album (//PerTrack)
- Date (//PerTrack)
- Lenght //PerSecond
- Bitrate (//PerTrack)
I use now
// PerSecond
But when I change // PerTrack everyting is going wrong.
Reply #1042
Are you looking for something like this?
// PerTrack
$alignabs(0,0,50,15,,)Artist:
$alignabs(0,15,50,15,,)Title:
$alignabs(0,30,50,15,,)Album:
$alignabs(0,45,50,15,,)Date:
$alignabs(0,60,50,15,,)Length:
$alignabs(0,75,50,15,,)Bitrate:
$alignabs(60,0,$sub(%_width%,60),15,,)%artist%
$alignabs(60,15,$sub(%_width%,60),15,,)%title%
$alignabs(60,30,$sub(%_width%,60),15,,)%album%
$alignabs(60,45,$sub(%_width%,60),15,,)%date%
$alignabs(60,75,$sub(%_width%,60),15,,)%bitrate%kbps
// PerSecond
$alignabs(60,60,$sub(%_width%,60),15,,)%Playback_time% / %length%
The cursor position seems to get reset when changing from PerTrack to PerSecond so I personally avoid using $char(10) and instead use $alignabs() for greater reliability and flexibility.
Also you might want to further develop the way you display bitrate because with the approach you are using, variable and adaptive bitrates will be misrepresented. I'd suggest either moving that line to PerSecond as well or add additional logic to show VBR, ABR, or something else instead of the normal bitrate.
Reply #1043
Yes I like that, but one thing is going wrong I just want this:
- Artist ARTIST
- Title TITLE
- Album ALBUM
- Date DATE
- Lenght LENGHT
- Bitrate BITRATE
instead of this:
- Artist............ARTIST
- Title.............TITLE
- Album..........ALBUM
- Date............DATE
- Lenght..........LENGHT
- Bitrate..........BITRATE
I'm totally noob but I see it's the (60,0,$sub(%_width%,60),15,,) doing this.
When I change 60 to 40 it's a little better, but is there a better option for this? so it's just
Abum: Album name
only 1 single space.
Reply #1044
If you prefer that type of formatting, try this instead:
// PerTrack
$alignabs(0,0,%_width%,15,,)Artist: %artist%
$alignabs(0,15,%_width%,15,,)Title: %title%
$alignabs(0,30,%_width%,15,,)Album: %album%
$alignabs(0,45,%_width%,15,,)Date: %date%
$alignabs(0,75,%_width%,15,,)Bitrate: %bitrate%kbps
// PerSecond
$alignabs(0,60,%_width%,15,,)Length: %Playback_time% / %length%
It's the same basic approach. By using $alignabs() for each line you can split up your text into whatever update interval you want and not wory about the text positioning being reset on the refresh. I prefer to handle the labels separately so you can do stuff like right alignment on the labels.. $alignabs(0,0,50,15,right,)Label: but the above code should do what you ask.
Reply #1045
Since trackinfo isn't scrollable I was wondering if I can split text into two or more side by side columns, if a specific height is exceeded? I'd use this for showing long lyrics which don't fit on the panel.
Edit: I figured how to split it with $len() but I'd prefer by the height of area. Thought I could use $calcheight() but seems like it returns the size of font instead. So is there any function for calculating the height of a multiline string? Below is an example how I did it so far
$ifgreater($len(%lyrics%),1000,
$alignabs(0,65,$div(%_width%,2),$sub(%_height%,80),center,middle)
$left(%lyrics%,$div($len(%lyrics%),2))
$alignabs(0,65,$muldiv(%_width%,3,2),$sub(%_height%,80),center,middle)
$right(%lyrics%,$add($div($len(%lyrics%),2),1)),
$alignabs(0,65,%_width%,$sub(%_height%,80),center,middle)%lyrics%)
Reply #1046
I want two buttons for control playback's order.
With default order:
$button(,,,,,,,,default,)
and work very well, but with shuffle (tracks) (or another shuffle mode) non:
$button(,,,,,,,,Shuffle(tracks),)
I try with Playback/Order/Shuffle (tracks), Shuffle, Shuffle tracks... and nothing... and try with this:
#  Playback/Order/Shuffle
# Playback/Order/Shuffle album
# Playback/Order/Shuffle album 2
# Playback/Order/Shuffle tag set
how put: http://wiki.hydrogenaudio.org/index.php?ti...text_Menu_Items
BUT NOTHING...
any sugerence?
THANKS!
(sorry for my english)
Reply #1047
// PerTrack
// PerSecond
Thank you, can you help me with one little thing?
With the $char(10) code I used
when I listened to nothing.
Is there anyway to do this with the $alignabs code?
When no track is playing:
No track
When Pause:
Artist: ARTIST
Title: TITLE
Album: ALBUM
Date: DATE
Lenght: LENGHT
Bitrate: BITRATE
Status: Pause
Reply #1048
[removed]
Reply #1049
When no track is playing: No track
When Pause: ...
// PerTrack
$alignabs(0,0,%_width%,15,,)No track,
// PerSecond
Or if you don't want to show the trackinfos while paused use something like this
// PerTrack
$if(%ispaused%,
$alignabs(0,0,%_width%,15,,)Paused,
// PerSecond
