Topic: Track Info Panel with ability to change font (Read 733147 times) previous topic - next topic
Reply #475
Not much you can do there. I just used $alignabs for it, But thats rather 'dirty' as you need to specify your own 'box' for the text. That, and the fact mine had all kinds of random pixel values
Reply #476
is it possible to use this to display a picture or one of many pngs in a music folder??
edit: can you use wildcards in the folder adress, so you can use foobars titleformatting then?
Reply #477
@terrstrial
I'm not sure if I am doing something wrong, but $get variables do not seem to work inside the $button2 function.
$puts(fonthover,$font(tahoma,8,nocleartype underline,255-0-0))
$button2(117,14,0,0,$calcwidth(See Review),18,'$font(tahoma,8,nocleartype underline,88-116-163)See Review','$get(fonthover)See Review',Album Review,)
Reply #478
@terrstrial
He said that the $button2 display parts are like seperate trackinfo panels, so I'm guessing that it won't work.
You could either put the $puts into the $button2 code, or just replace the $get with the actual code, which will work, but will probably defeat the point of having the $puts/$get in the first place..
Reply #479
@spex04
You're right. I missed that post. Thanks.
all the code has to be self contained inside the button. it doesn't carry through outside the button. think of it as a separate trackinfo panel.
Reply #480
Right now I'm using this code:
$alignabs(50,32,$sub($div(%_width%,2),283),15,,)
$font(,,,255-255-255)%track%. %title%
How can i make "%track%. %title%" scroll horizontally?
What I'm doing is confining the text in a certain area that is flexible depending on how wide the panel is, and if the text is too wide for that area i want to to clip it down and scroll.
Reply #481
i need some help folks :/
i am all new to this coding etc. so show some mercy pls
this is my current code:
$if(%_isplaying%,
$imageabs2(,,,,,,$sub(%_width%,75),$sub($div(%_height%,2),38),'C:\programme\foobar2000\images\arrows.png',)
$imageabs2(474,90,,,,,0,-13,'C:\Programme\foobar2000\components\Untitled-1.png',)
$padding(4,2)
$align(left,bottom)$font(Swis721 Cn BT D-Type,10,bold glow-91-100-111 glowblur-10,203-206-211)
$font(Swis721 Cn BT D-Type,10,bold glow-91-100-111 glowblur-10,203-206-211)$get(head)Length: $font(Swis721 Cn BT D-Type,10,bold  glow-129-138-150 glowblur-10,255-255-255)$get(info)$if(%_isplaying%,%_time_elapsed%$get(anno)$if(%_length%, / %_length%,)$if(%_time_elapsed%, / $muldiv(%_time_elapsed_seconds%,100,%_length_seconds%)'%')$if(%_length%, / -%_time_remaining%),%_length%)$char(10)
$font(Swis721 Cn BT D-Type,10,bold glow-91-100-111 glowblur-10,203-206-211)$get(head)Quality: $font(Swis721 Cn BT D-Type,10,bold  glow-129-138-150 glowblur-10,255-255-255)$if(%__codec%, $get(info)%__codec%) $get(info)
$if2(%__bitrate_dynamic%,%__bitrate%) $get(anno)Kb/s $if($stricmp(%__codec%,mp3),$if($stricmp(%__extrainfo%,vbr),VBR,CBR))
$char(10)
$if(%__lame_version%,$get(head)Encoder: $font(Swis721 Cn BT D-Type,10,bold  glow-129-138-150 glowblur-10,255-255-255)$get(info)$left(%__lame_version%,4) $right(%__lame_version%,4) [$upper(%__lame_profile%)]$char(10),)
$if(%__flac_vendor%,$get(head)Encoder: $font(Swis721 Cn BT D-Type,10,bold  glow-129-138-150 glowblur-10,255-255-255)$get(info)$if($stricmp(%__flac_vendor%,reference libFLAC 1.1.2 20050205),FLAC 1.1.2 -8)$char(10),)
$if(%__mpc_profile%,$get(head)MPC Profile: $font(Swis721 Cn BT D-Type,10,bold  glow-129-138-150 glowblur-10,255-255-255)$get(info)%__mpc_profile%$char(10),)
$font(Swis721 Cn BT D-Type,10,bold glow-91-100-111 glowblur-10,203-206-211)$get(head)Compression: $font(Swis721 Cn BT D-Type,10,bold  glow-129-138-150 glowblur-10,255-255-255)$get(info)$div(1411,%__bitrate%).$substr($muldiv(1411,100,%__bitrate%),2,3):1 '('$get(info)$muldiv(%__bitrate%,100,1411)$get(anno)'% of original quality)'$char(10)
$font(Swis721 Cn BT D-Type,10,bold glow-91-100-111 glowblur-10,203-206-211)$get(head)Channel Mode: $font(Swis721 Cn BT D-Type,10,bold  glow-129-138-150 glowblur-10,255-255-255)$get(info)$if($stricmp($codec(),MP3),$get(space2)$caps(%__mp3_stereo_mode%),
$if(%__channels%,$ifgreater(%__channels%,1,Stereo,Mono),'?'))$char(10)
$if(%__bitspersample%,$font(Swis721 Cn BT D-Type,10,bold glow-91-100-111 glowblur-10,203-206-211)$get(head)Bitdepth: $get(info)%__bitspersample% bits/sample$char(10),)
$if(%__samplerate%,$font(Swis721 Cn BT D-Type,10,bold glow-91-100-111 glowblur-10,203-206-211)$get(head)Samplerate: $font(Swis721 Cn BT D-Type,10,bold  glow-129-138-150 glowblur-10,255-255-255)$get(info)$div(%__samplerate%,1000).$substr(%__samplerate%,3,3) KHz $char(10))
$if(%_filesize%,$font(Swis721 Cn BT D-Type,10,bold glow-91-100-111 glowblur-10,203-206-211)$get(head)Filesize: $font(Swis721 Cn BT D-Type,10,bold  glow-129-138-150 glowblur-10,255-255-255)$get(info)
$div(%_filesize%,1048576).$left($num($muldiv($mod(%_filesize%,1048576),100,1048576),2),2) $get(anno)'MB'$char(10),)
$align(right,bottom)
$font(calibri,8,bold glow-129-138-150 glowblur-10,255-255-255)
$upper(%title%)
$font(calibri,8,bold glow-91-100-111 glowblur-10,129-138-150)
$font(calibri,8,bold glow-91-100-111 glowblur-10,203-206-211)
$upper(%artist%)
$imageabs2(66,66,,,,,$sub($div(%_width%,2),33),$sub($div(%_height%,2),38),'C:\programme\foobar2000\images\arrows.png',))
//////////TRACKINFO MOD PROGRESS BAR
$padding(0,0)
$drawrect(,,,10,brushcolor-null pencolor-222-225-228)
$puts(progress,$muldiv(%playback_time_seconds%,$sub(%_width%,10),%length_seconds%))
$ifgreater($get(progress),0,
$padding(2,2)$drawrect(,,$get(progress),6,brushcolor-190-197-203 pencolor-null),)
/////////////PLAYLIST DROPDOOOWN
%index%/%total% %title%
$hsl(140,25,121)
$if(%isactive%,' (active'$if(%isplaying%,', playing')')',$if(%isplaying%,' (playing)'))
$tab(2)[ '('%lock%')']
$hsl(140,25,121)' ('
%size% tracks @ %length%')'
and this is what it looks like:
as you can see, i was trying to add that image on top and it just doesnt look right. i'd like that image to be width dynamic and also show up when im not playing music.
any help is appreciated!
thx in advance.
- creative x-fi extreme music
- sennheiser 650hd
- F U B A R++
Reply #482
alskdjflkasjflkjsalkdflksadjflkjsadlkfj
thx in advance.
I'm not the best with code but I'm learning........(i think) but looking at yours I'd say for starters the
$if(%_isplaying%,
string being right before your images could be why they dont show when your not playing anything
also the image does not stretch across the entire panel so you can try this
$imageabs2(,,,,,,0,0,'C:\Programme\foobar2000\components\Untitled-1.png',)
becuase the plugin wants even ratios anyways ie (100,100,,,,,)
Reply #483
I'm having trouble getting images to work and I can't figure out why. I'm using this line:
$imageabs(0,0,'C:\Program Files\foobar2000\images\cloudbw.png',)
and the file is definately there, but I'm still just getting black.
(I'm having the same problem with the single column playlist plugin)
Anything obvious I could be missing?
Reply #485
@terrstrial
Is there a way to use mouse wheel for scroll like the classic trackinfo?
I want to show lyrics with background image.
Reply #486
try this:
$imageabs2(,,,,,,,,'C:\Program Files\foobar2000\images\cloudbw.png',)
pd: i have the same problem with 'width dynamic image'
a stretch or resize image code will be nice.
Reply #487
"a stretch or resize image code will be nice."
There is a resize, but it seems to only be able to 'squeeze' the image and not stretch it.
Reply #488
@terrstrial
no, the display code (and syntax) are not really designed for scrolling.
I've uploaded a new version which fixes a bug which could cause a crash when using a button. Also a new button command: "TAG:SET:tag:value" which sets tag values without having to use scripts.
example:
$button2(0,0,0,0,20,10,'$font(tahoma,11,,0-0-0)Rating1','$font(tahoma,11,bold,0-0-0)Rating1',TAG:SET:Rating:1,)
Reply #489
So I guess you didn't find out about the reported display glitches? How can I help?
BTW, would you please edit the first post and add a version info if you offer a new version? Then we can see there, when the post was edited and which version it is. Now we have to search and read your postings within the thread.
Reply #490
Thank you terrestrial
Favourite artist:CD-R
Favourite album:700MB
Reply #491
Thanks for the update terrestrial!
Question:
How do i know which main menu entries are supported for buttons?!
I am trying to set up my own volume-control, but "Set volume to XYdB" does not work.
Entries like e.g. "Seek ahead by 10 seconds" or "About" work (but do not really help me setting up a volume-control  ).
I looked them up on the Commandline Guide.
Reply #492
New command seems to work very well - no crashes when clicking around on tag-related buttons anymore
Reply #493
2 LXtreme
In latest fb2k versions the volume commands are restricted to volume up\down\mute only,however you can define the volume steps in advanced options window.That's the reason why it doesn't work from $button command.
Reply #494
display glitch in trackinfo? if you're referring to the display glitch in single column playlist, I haven't had a chance to look further into it yet...
will try to remember for next time.
it shouldn't crash using scripts anymore either
Reply #495
is there any way i can check if "stop after current" is turned on?
Reply #497
That is awesome addition. Thank you
Reply #498
thanx russell777! didn't know that. is there a ressource where all availible commands are listed?
(well, i could use foo_run or the buttons to have a look at them, but isn't there a web-ressource....would be easier for a lazy guy like me  )
didn't know about that feature either, so thanks for the hint....now my volume-up and down buttons are more helpful....
and with foo_runs "simultanious runs"-option it might be even possible to create some kind of klickable volume-bar.
(i thought someone allready made something like this with pics included, but i can't find the thread/post anymore)
Reply #499
Would you be able to implement standard windows controls into this somehow, like:
$button_check(xpos,ypos,text,offcriteria,oncriteria,offaction,onaction,disabledcriteria)
$button_radio(xpos,ypos,text,groupname,oncriteria)
I know this could be done with some fancy coding, but it would be nice to have real skinned windows controls with easily set options. You could do stuff like have panels of checkboxes for genres, styles, etc and maybe even dropdown lists, real windows-style progress bars, buttons, etc. Also, you could create custom context menus for certain areas of the panel, so for example you could right click on genre and a menu would popup with a list of genres.
$menu(xstart,ystart,xend,yend,menuitem1,action1,menuitem2,action2,etc...)
