Topic: Changing an MP3's sample playback rate (Read 5780 times) previous topic - next topic
I have obtained a MP3 file which specifies a 48000 sample rate. The correct sample rate, however, is obviously 44100. Is there any way I can change this without re-encoding the MP3? I've tried opening the file in a hex editor but can't make anything out besides the comment and mp3DirectCut doesn't appear to have that feature.
Project Leader of DDResampled
What do you mean "the correct sample rate, however, is obviously 44100"?  How do you know the source content wasn't 48 kHz or upsampled to 48 kHz before encoding to MP3?
Because the Flash applet that plays the mp3 on the particular website where this mp3 was obtained does so at a playback rate of 44100. It's pretty easy to tell the difference between an audio file played back at a 48000 sample rate and it played back at a 44100 sample rate.
It's funny that you point that out, though. After some investigation, it seems that the track should indeed be played bak at 48 khz. But I like the 44.1 method better.
The question still stands.
You have to change the 32-Bit sync-code of every frameheader. I don't know of any programm that can do this.
but it would be easy to code.
I don't think so because frame lenghts (the bitrate index)  would be completely off... unless you can pad the frames without trouble that is.
"We cannot win against obsession. They care, we don't. They win."
even if you repackage the data into 44 kHz frames properly it won't work because a decoder treats the data within frames at different sampling rates differently. (For you technical people: The partition of the spectral lines into scalefactor bands depends on the sampling rate)
However you could try to wrap the MP3 into a WAV file and change the WAV file's sampling rate. Depending on your player it might actually use the sampling rate of the Wav-Header -- It used to work with WinAMP, once (a couple of years ago).
Sebastian
I kind of expected this.
I was hoping I wouldn't have to do something like this, but it would work. Thanks!
Does it really matter what rate it is? If it needs downsampling won't the program do that automatically?
I'm not sure where you're going with this.
BTW, SebastianG's idea works, albeit seeking glitches occur, with foobar2000. Unfortunately, WAV files cannot be ReplayGained.
