Topic: Startup time : up to 0:33.678257 (Read 3382 times) previous topic - next topic
I have a long startup time, i don't know why. when close and re-open first time, startup time was 0:11.088974, when re-close and re-open second time, startup time reduce to 0:02.391993
[-] Media libary contain 5200 songs, most mp3. don't contain any compressed archives.
[-] 2 normal playlist, 10 autoplaylist, 1 player queue.
[-] Main window :
[-] Technical information :
CPU: Intel® Pentium® M processor 1.86GHz [x86 Family 6 Model 13 Stepping 8] [DEP enabled]
Operating System: Microsoft Windows XP [version: 5.1.2600 Service Pack 2]
Installed RAM: 503 MBytes
Free disk space on foobar2000 partition: 214 MBytes
foobar2000 path: C:\Program Files\foobar2000.beta\
Core version: foobar2000 v0.9.3 beta 2
Build time: 22:11:28 on 17 July 2006
[-] Components (45 active) :
foo_albumlist.dll v[b]3.2.0[/b] [17 July 2006] - Album List
foo_audioscrobbler.dll v[b]1.3.4[/b] [15 June 2006] - Audioscrobbler
foo_cdda.dll v[b]2.1.1[/b] [17 July 2006] - CD Audio Decoder
foo_channel_mixer.dll v[b]0.9.4[/b] [12 April 2006] - Channel Mixer
foo_common.dll v[b]0.1[/b] [11 March 2006] - Common services
foo_converter.dll v[b]1.0.1[/b] [17 July 2006] - Converter
foo_custominfo.dll v[b]0.1.0[/b] [16 July 2006] - foo_custominfo
foo_dbsearch.dll v[b]1.3.1 beta 11[/b] [13 March 2006] - Database search
foo_dsp_continuator.dll v[b]0.4.0[/b] [11 April 2006] - Continuator
foo_dsp_std.dll v[b]1.0[/b] [17 July 2006] - Standard DSP array
foo_freedb2.dll v[b]v0.5.1[/b] [14 March 2006] - freedb tagger
foo_infobox.dll v[b]2.0.3[/b] [25 June 2006] - Special file info box
foo_input_monkey.dll v[b]2.1[/b] [27 June 2006] - Monkey's Audio decoder
foo_input_shorten.dll v[b]0.4.2a[/b] [11 March 2006] - Shorten decoder
foo_input_std.dll v[b]1.1.0[/b] [17 July 2006] - FLAC decoder
foo_input_std.dll v[b]1.0[/b] [17 July 2006] - Standard Input Array
foo_lnk.dll v[b]1.1[/b] [11 March 2006] - Shell link resolver
foo_masstag.dll v[b]1.6[/b] [17 July 2006] - Masstagger
foo_navigator.dll v[b]0.2[/b] [13 June 2006] - Navigator
foo_osd.dll v[b]1.52[/b] [23 March 2006] - On-Screen Display
foo_out_ks.dll v[b]1.2.1[/b] [21 March 2006] - Kernel Streaming Output
foo_playcount.dll v[b]1.2[/b] [17 July 2006] - Playback Statistics
foo_playlist_manager.dll v[b]1.0[/b] [13 March 2006] - Playlist Manager
foo_prettypop.dll v[b]1.2.3[/b] [17 June 2006] - Pretty Popup
foo_preview.dll v[b]1.1[/b] [06 June 2006] - Preview
foo_random.dll v[b]1.2.3[/b] [13 March 2006] - Randomized playlist entry
foo_rgscan.dll v[b]2.0.2[/b] [17 July 2006] - ReplayGain Scanner
foo_sendtodevice.dll v[b]1.0.4 [May 17 2006 - 13:21:17][/b] [17 May 2006] - Send to Device
foo_skip.dll v[b]0.2[/b] [06 July 2006] - foo_skip
foo_tradersfriend.dll v[b]0.6.1[/b] [13 March 2006] - Live show tagger
foo_ui_columns.dll v[b]0.1.3 beta 1v5[/b] [29 April 2006] - Columns UI
foo_ui_std.dll v[b]0.9acc[/b] [17 July 2006] - Default User Interface
foo_uie_albumart.dll v[b]0.175[/b] [27 May 2006] - Album Art Panel
foo_uie_albumlist.dll v[b]0.2.1 beta 4[/b] [28 April 2006] - Album list panel
foo_uie_console.dll v[b]0.2[/b] [28 April 2006] - Console panel
foo_uie_playlists_dropdown.dll v[b]0.5.7.5[/b] [09 June 2006] - Playlists Dropdown
foo_uie_quicksearch.dll v[b]2.6[/b] [04 June 2006] - Quick Search Toolbar
foo_uie_tabs.dll v[b]0.2.1[/b] [07 July 2006] - Tabbed panel modifyed
foo_uie_trackinfo.dll v[b]0.8[/b] [03 May 2006] - Track info panel
foo_uie_vis_projectm.dll v[b]0.4 (SSE2)[/b] [24 May 2006] - projectM visualization (Panel)
foo_unpack.dll v[b]1.1[/b] [17 July 2006] - RAR reader
foo_unpack.dll v[b]1.0[/b] [17 July 2006] - ZIP/GZIP reader
foo_unpack_lha.dll v[b]1.0[/b] [29 May 2006] - LHA unpacker
foo_utils.dll v[b]0.5.7[/b] [27 April 2006] - Playlist tools
foo_version.dll v[b]0.3[/b] [18 July 2006] - Components versions viewer
-> foo_uie_vis_projectm : is not activeted, and there is no visable panel.
-> foo_dsp_continuator : is activated, in Ovelap mode.
What would i do to reduce it....
You have a lot of components installed. I would begin by deleting all those you aren't using, which from that screenshot seems to be quite a few.
Hey. Many people have had problems with foo_ui_trackinfo. the foobar wiki provides the solution
Track Info Panel (foo_ui_trackinfo)
    * set Scroll Steps to 1
    * set Scroll end delay (ms) to 50000 (this is the max)
foo_custominfo has been put on the Potentially Dangerous Plugins list so deleting it may be an idea. I had a lot of problems caused by this personally
My Name is Sean and I'm here to leech off your genius.
I remove a few unneeded component, and change foo_trackinfo config as u sugeaste...
Startup time : 0:04.977937
