Topic: foo_uie_bookmarks (Read 258589 times) previous topic - next topic
foo_uie_bookmarks
Reply #150
Great component. Never tried it until now
Only problem is that I often move files around, and it seems to store the bookmarks in a file with static file-locations.
foo_uie_bookmarks
Reply #151
I was stupid, anyway, reporting experience.
I use foo_bookmarks and foo_uie_bookmarks in same time.
This cause some time CUI layout loading failure.
foo_uie_bookmarks
Reply #152
New version 0.3.2 is out. Appearance pref page has been revamped; color system is now more simplified (alpha prefs were removed); support for UI module colors/fonts was added along with the ability to override.
foo_uie_bookmarks
Reply #153
DUI-style icons are available; see 1st post.
foo_uie_bookmarks
Reply #154
Hi all,
How can I limit bookmarking to one playlist only?
Cheers
foo_uie_bookmarks
Reply #155
Help I've been trying to download the latest plugin but I keep getting a corrupted zip file and it won't open.
foo_uie_bookmarks
Reply #156
If you are right clicking and then save as:
Try simple click to get to google sites download link page.
terry
foo_uie_bookmarks
Reply #158
Never mind I got it open with 7zip, the Win XP compression utility can't open this file.
foo_uie_bookmarks
Reply #159
0.3.3
Added new feature: Reset Time. Made changes to some prefs. The format for storing playlist-based options was changed so they will be reset.
foo_uie_bookmarks
Reply #160
From the change log:
+ Made optional the behavior where bookmark time is reset to zero when playback reaches end of track if Time Capture is enabled and Autoremove is disabled (Reset Time)
Thank you very much, tanka, for this new feature. You can't know how much I do appreciate this function!
Robertina.
foo_uie_bookmarks
Reply #161
tanka, with foo_bookmarks 0.3.3 and both "Autoremove" and "Reset Time" unticked in its configuration window:
If I play a bookmarked file by double-clicking the bookmark and playback reaches the end of track, then the bookmark time is reset to the file's length time. E.g. a file's length is 57'22 and it is bookmarked at 22'15, then when the playback has finished the bookmarked time will be reset from 22'15 to 57'22. I expected the bookmarked time to be kept untouched at 22'15 with bookmarks's newest version or did I misunderstand the change log?
foo_uie_bookmarks
Reply #162
That happened due to Time Capture being enabled.
foo_uie_bookmarks
Reply #163
Thank you for your quick reply, tanka. You are right, I had the 'Time Capture'-option ticked, so it was a kind of misconfiguration on my side.
So thank you for the update again.
Robertina.
foo_uie_bookmarks
Reply #164
It somehow doesnt work with the Foo_LIRC plugin  I can select the Bookmark function inside the FooLIRC command list, but the key on my remote will not respond to it.. thats strange because all other remote command seem to work, even the Normal Previous and Delete Current Song, which require an additional plugin.
But thanks for coding this plugin..
I think Foobar should have this bookmarkfunction built-in from scratch
foo_uie_bookmarks
Reply #165
There's something I want which I hope this can achieve.
I have a bunch of playlists, with several 2hour+ files, when I manually play a file in an other playlist it should create a bookmark of the playing time of the file that was previously playing. When starting the first file again it should start playing from the bookmarked time.
This is what I've tried with this plugin:
In the Special tab tick 'On user starting another track in different playlist' (applying it to all playlists).
Which is exactly what I want. BUT this only works if I use the bookmark panel to start playing from that point, NOT when double-clicking the file in the playlist, this plays the file from the beginning.
So how can I make this plugin behave like this when using the default playlist and not the bookmark panel.
If its not possible, I'd like to request this feature
foo_uie_bookmarks
Reply #166
n2k, I think there is no such feature. Have you looked at the playlist attributes componet. Maybe it has such a feature.
foo_uie_bookmarks
Reply #167
I put bookmark panel on panel stack splitter. after, I close foobar2000.
but popup error dialog.
Any ideas?
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 08B49843h
Access violation, operation: read, address: 00000000h
Call path:
entry=>save config=>cfg file write=>write config=>write config=>write config=>write config=>write config
Code bytes (08B49843h):
08B49803h:  F4 E8 17 74 01 00 B8 D0 97 B4 08 C3 CC 55 8B EC
08B49813h:  83 E4 F8 83 EC 0C 53 56 8B 75 08 8B 06 8B 00 57
08B49823h:  8B D9 8B 4D 0C 51 6A 04 8D 54 24 1C 52 8B CE C7
08B49833h:  44 24 20 0D 00 00 00 FF D0 33 FF 8B FF 8B 4B DC
08B49843h:  8B 14 0F 8B 4D 0C 8B 06 8B 00 51 89 54 24 18 6A
08B49853h:  04 8D 54 24 1C 52 8B CE FF D0 83 C7 04 83 FF 34
08B49863h:  72 DB 33 FF 8B 4B E8 8B 14 0F 8B 4D 0C 8B 06 8B
08B49873h:  00 51 89 54 24 18 6A 04 8D 54 24 1C 52 8B CE FF
Stack (0024F130h):
0024F110h:  00000000 FFFFFD34 000002E4 FFFFFD34
0024F120h:  000002CC 00000019 00000000 0024F50C
0024F130h:  0024F22C 0024F50C 00000000 0C3A9F38
0024F140h:  0024F22C 0000000D 00000000 0C3A9F38
0024F150h:  08C34D61 0024F174 0024F50C 41B0A1FA
0024F160h:  00000000 0024F50C 0024F1E0 0024F22C
0024F170h:  00000064 08C45FF0 0EEC70A0 00000004
0024F180h:  00000004 08C45FF0 0B5ADFB8 00000064
0024F190h:  00000064 0024F50C 0024F1D4 08C3E1D5
0024F1A0h:  00000001 08C35343 00000064 41B0A12A
0024F1B0h:  0024F2E4 0B591D98 00000001 00000001
0024F1C0h:  08C45FF0 0EFA1948 00000094 00000094
0024F1D0h:  0024F1E0 0024F1FC 08C3E28F 00000000
0024F1E0h:  0B592230 08C356E3 0B591D98 41B0A16A
0024F1F0h:  0024F50C 00000000 0000005A 0024F250
0024F200h:  08C3E3E2 00000000 08C34D61 0024F22C
0024F210h:  0024F50C 41B0A282 00000001 0024F50C
0024F220h:  0024F298 0024F2E4 00000064 08C45FF0
0024F230h:  0EE73158 00000121 00000121 08C45FF0
0024F240h:  0B5AE108 00000064 00000064 0024F50C
Registers:
EAX: 00000004, EBX: 0A12EF64, ECX: 00000000, EDX: 0B570000
ESI: 0024F174, EDI: 00000000, EBP: 0024F14C, ESP: 0024F130
Crash location:
Module: foo_bookmarks
Offset: 9843h
Loaded modules:
foobar2000                      loaded at 01160000h - 01345000h
ntdll                            loaded at 77590000h - 77710000h
kernel32                        loaded at 75790000h - 75890000h
KERNELBASE                      loaded at 753B0000h - 753F6000h
COMCTL32                        loaded at 73380000h - 7351E000h
msvcrt                          loaded at 75B60000h - 75C0C000h
GDI32                            loaded at 77090000h - 77120000h
USER32                          loaded at 76230000h - 76330000h
ADVAPI32                        loaded at 75590000h - 75630000h
sechost                          loaded at 76020000h - 76039000h
RPCRT4                          loaded at 76140000h - 76230000h
SspiCli                          loaded at 75100000h - 75160000h
CRYPTBASE                        loaded at 750F0000h - 750FC000h
LPK                              loaded at 75400000h - 7540A000h
USP10                            loaded at 75AA0000h - 75B3D000h
SHLWAPI                          loaded at 75C10000h - 75C67000h
DSOUND                          loaded at 74F50000h - 74FC2000h
ole32                            loaded at 75C70000h - 75DCC000h
WINMM                            loaded at 74F10000h - 74F42000h
POWRPROF                        loaded at 74EE0000h - 74F05000h
SETUPAPI                        loaded at 75210000h - 753AD000h
CFGMGR32                        loaded at 75E60000h - 75E87000h
OLEAUT32                        loaded at 75DD0000h - 75E5F000h
DEVOBJ                          loaded at 75B40000h - 75B52000h
UxTheme                          loaded at 73730000h - 737B0000h
SHELL32                          loaded at 76330000h - 76F79000h
shared                          loaded at 6EED0000h - 6EEFA000h
imagehlp                        loaded at 76110000h - 7613A000h
dbghelp                          loaded at 6DD00000h - 6DDEB000h
COMDLG32                        loaded at 77010000h - 7708B000h
zlib1                            loaded at 5A4C0000h - 5A4D4000h
apphelp                          loaded at 736E0000h - 7372B000h
AcLayers                        loaded at 6FA20000h - 6FAAC000h
USERENV                          loaded at 736C0000h - 736D7000h
profapi                          loaded at 73640000h - 7364B000h
WINSPOOL                        loaded at 74FD0000h - 75021000h
MPR                              loaded at 6FA00000h - 6FA12000h
IMM32                            loaded at 75410000h - 75470000h
MSCTF                            loaded at 76040000h - 7610C000h
RKLauncher                      loaded at 10000000h - 1000F000h
RnmAst                          loaded at 00630000h - 00639000h
VERSION                          loaded at 739B0000h - 739B9000h
dragext                          loaded at 00660000h - 00667000h
WindowSizeView                  loaded at 00780000h - 00787000h
CLBCatQ                          loaded at 75180000h - 75203000h
MMDevApi                        loaded at 74E30000h - 74E69000h
PROPSYS                          loaded at 73280000h - 73375000h
dwmapi                          loaded at 730A0000h - 730B3000h
MauHook                          loaded at 00830000h - 00841000h
JoyStickCanceller                loaded at 00860000h - 00868000h
DINPUT8                          loaded at 74CF0000h - 74D20000h
hscrl                            loaded at 00880000h - 00887000h
gdi++                            loaded at 06540000h - 06559000h
freetype                        loaded at 02750000h - 027C6000h
detoured                        loaded at 0F000000h - 0F006000h
ATOK22W                          loaded at 5EC20000h - 5F125000h
MSIMG32                          loaded at 730F0000h - 730F5000h
ATOK22AE                        loaded at 5F4E0000h - 5F55C000h
ATOK22DE                        loaded at 5EAE0000h - 5EB9A000h
ntmarta                          loaded at 73AB0000h - 73AD1000h
WLDAP32                          loaded at 75FD0000h - 76015000h
foo_removefromqueue              loaded at 00A70000h - 00A7A000h
MSVCR80                          loaded at 72D60000h - 72DFB000h
foo_dsp_soundtouch              loaded at 00A90000h - 00AB6000h
foo_uie_trackinfo                loaded at 00C20000h - 00C45000h
foo_uie_lyrics_art              loaded at 03040000h - 030EC000h
gdiplus                          loaded at 71620000h - 717B0000h
foo_vis_vumeter                  loaded at 04AB0000h - 04BCE000h
foo_cmd_playlist                loaded at 00C60000h - 00C69000h
foo_input_tta                    loaded at 010F0000h - 0112F000h
foo_uie_vis_channel_spectrum    loaded at 027D0000h - 0280D000h
foo_midi                        loaded at 04CB0000h - 04E45000h
WS2_32                          loaded at 77150000h - 77185000h
NSI                              loaded at 77560000h - 77566000h
foo_uie_playlists_dropdown      loaded at 02970000h - 029AC000h
foo_wave_seekbar                loaded at 6DE30000h - 6DFFA000h
foo_runcmd                      loaded at 6E920000h - 6E953000h
foo_dsp_echo                    loaded at 02BB0000h - 02BCE000h
foo_dsp_loudspeakereq            loaded at 02CE0000h - 02D0C000h
foo_ui_std                      loaded at 6E800000h - 6E918000h
foo_playlist_attributes          loaded at 02F90000h - 02FE4000h
foo_utils                        loaded at 6E7B0000h - 6E7F4000h
foo_textdisplay                  loaded at 6E620000h - 6E65F000h
foo_random                      loaded at 03100000h - 03139000h
foo_random_pools                loaded at 03150000h - 03188000h
foo_preview_custom              loaded at 031D0000h - 031DE000h
foo_tagbox                      loaded at 04F50000h - 04FC0000h
foo_out_asio                    loaded at 05130000h - 05166000h
foo_scheduler                    loaded at 6E540000h - 6E61E000h
foo_dsp_std                      loaded at 6E4F0000h - 6E538000h
foo_musicbrainz                  loaded at 6E010000h - 6E06C000h
WINHTTP                          loaded at 6DBF0000h - 6DC48000h
webio                            loaded at 6E120000h - 6E16F000h
foo_input_tak                    loaded at 6DBA0000h - 6DBE4000h
tak_deco_lib                    loaded at 04C70000h - 04C90000h
foo_textfile                    loaded at 04FC0000h - 04FE9000h
foo_dsp_bs2b                    loaded at 05170000h - 05197000h
foo_cuefilter                    loaded at 052D0000h - 052F9000h
foo_seek_box                    loaded at 6E4D0000h - 6E4ED000h
foo_exvar                        loaded at 05510000h - 05538000h
foo_freedb2                      loaded at 6C530000h - 6C571000h
foo_input_std                    loaded at 6C3D0000h - 6C524000h
foo_verifier                    loaded at 058A0000h - 058E3000h
foo_gep                          loaded at 06170000h - 0622F000h
foo_ui_columns                  loaded at 069D0000h - 06B5E000h
foo_dsp_winamp                  loaded at 05A40000h - 05A68000h
foo_dsp_vst                      loaded at 05A80000h - 05AA2000h
foo_converter                    loaded at 6C350000h - 6C3CB000h
foo_cuesheet_creator            loaded at 05BE0000h - 05C0C000h
foo_customdb                    loaded at 05E30000h - 05ED5000h
foo_quicksearch                  loaded at 6E440000h - 6E472000h
MSVCP90                          loaded at 6E710000h - 6E79E000h
MSVCR90                          loaded at 6E660000h - 6E703000h
foo_stop_on_error                loaded at 6E4B0000h - 6E4CC000h
foo_uie_albumart                loaded at 05D80000h - 05DBD000h
foo_stop_on_current              loaded at 6DE10000h - 6DE29000h
foo_dsp_mm                      loaded at 060F0000h - 06131000h
foo_uie_console                  loaded at 05C40000h - 05C5A000h
foo_rgscan                      loaded at 6C300000h - 6C34D000h
foo_bubble_coverflow            loaded at 06320000h - 06371000h
OPENGL32                        loaded at 6C230000h - 6C2F8000h
GLU32                            loaded at 6CC10000h - 6CC32000h
DDRAW                            loaded at 6C580000h - 6C667000h
DCIMAN32                        loaded at 6FDF0000h - 6FDF6000h
foo_truephase_fft                loaded at 06140000h - 0615F000h
foo_out_wasapi                  loaded at 06240000h - 06266000h
foo_7taskbar                    loaded at 6CA60000h - 6CA9A000h
foo_uie_textbox                  loaded at 062A0000h - 062CE000h
foo_playcount                    loaded at 6C1F0000h - 6C22B000h
foo_navigator                    loaded at 06380000h - 063B4000h
foo_uie_ptb                      loaded at 06410000h - 06435000h
foo_talktome                    loaded at 6C1C0000h - 6C1EA000h
foo_uie_explorer                loaded at 06470000h - 064AD000h
WindowsCodecs                    loaded at 6FE30000h - 6FF2B000h
EhStorShell                      loaded at 6F330000h - 6F361000h
ntshrui                          loaded at 6F250000h - 6F2BF000h
srvcli                          loaded at 73AF0000h - 73B09000h
cscapi                          loaded at 6F3A0000h - 6F3AB000h
slc                              loaded at 6F390000h - 6F39A000h
foo_chronflow                    loaded at 07000000h - 07061000h
foo_uie_albumlist                loaded at 070D0000h - 07113000h
foo_uie_quicksearch              loaded at 07120000h - 07166000h
foo_chacon                      loaded at 6C190000h - 6C1B4000h
foo_uie_wsh_panel_mod            loaded at 6C0E0000h - 6C187000h
foo_fileops                      loaded at 6C090000h - 6C0D6000h
foo_albumlist                    loaded at 6C030000h - 6C08D000h
foo_dsp_freeverb                loaded at 06EB0000h - 06ECE000h
foo_dsp_fsurround                loaded at 07080000h - 070B1000h
libfftw3f-3                      loaded at 63740000h - 6380B000h
foo_bpm                          loaded at 6C000000h - 6C02D000h
libfftw                          loaded at 6BE70000h - 6BFF6000h
foo_dbsearch                    loaded at 07770000h - 077E0000h
foo_dsp_tube                    loaded at 07310000h - 07336000h
foo_dop                          loaded at 083F0000h - 08598000h
QUARTZ                          loaded at 6BB80000h - 6BCF7000h
foo_dsp_crossfader              loaded at 077F0000h - 07822000h
foo_playlists_sort              loaded at 73910000h - 73920000h
foo_queuecontents                loaded at 086A0000h - 0875D000h
foo_uie_elplaylist              loaded at 6BE00000h - 6BE70000h
foo_run                          loaded at 080C0000h - 0811F000h
foo_uie_lyrics2                  loaded at 08950000h - 08A3E000h
WININET                          loaded at 75630000h - 75724000h
Normaliz                        loaded at 75A90000h - 75A93000h
urlmon                          loaded at 75E90000h - 75FC5000h
CRYPT32                          loaded at 75470000h - 7558C000h
MSASN1                          loaded at 75170000h - 7517C000h
iertutil                        loaded at 75890000h - 75A89000h
foo_rg_trn                      loaded at 6BDD0000h - 6BDF4000h
foo_cdda                        loaded at 6BD80000h - 6BDCE000h
foo_quicktag                    loaded at 07AD0000h - 07B04000h
foo_dsp_resampler                loaded at 07F70000h - 07FAA000h
foo_masstag                      loaded at 08140000h - 08194000h
foo_uie_dragpanel                loaded at 07950000h - 07975000h
foo_uie_lyrics_panel            loaded at 08370000h - 083D4000h
foo_discogs                      loaded at 6BD10000h - 6BD71000h
foo_uie_library_tree            loaded at 08760000h - 087A2000h
foo_uie_vis_peakmeter_spectrum  loaded at 088F0000h - 0892F000h
foo_dsp_yac                      loaded at 6DDF0000h - 6DE01000h
foo_menu_addons                  loaded at 08200000h - 08230000h
foo_bookmarks                    loaded at 08B40000h - 08BB3000h
foo_uie_panel_splitter          loaded at 08C00000h - 08C59000h
foo_uie_graphical_browser        loaded at 6BAE0000h - 6BB74000h
foo_stopaftercuralbum            loaded at 08BC0000h - 08BDF000h
foo_autoupdate                  loaded at 6BA90000h - 6BADC000h
foo_uie_tagger_mod              loaded at 08EE0000h - 08F21000h
foo_dbsearch_api_demo            loaded at 08C60000h - 08C81000h
foo_vis_shpeck                  loaded at 6BA40000h - 6BA81000h
foo_stop_after_queue            loaded at 6BA20000h - 6BA38000h
foo_dsp_eqsplit                  loaded at 6B9C0000h - 6BA12000h
foo_input_monkey                loaded at 09130000h - 09178000h
foo_uie_esplaylist              loaded at 6B960000h - 6B9BB000h
foo_covers2                      loaded at 6B930000h - 6B957000h
foo_uie_biography                loaded at 6B610000h - 6B667000h
foo_ui_hacks                    loaded at 090E0000h - 09115000h
foo_playlist_tree_mod            loaded at 09410000h - 09489000h
foo_podcatcher                  loaded at 09980000h - 09A03000h
WtsApi32                        loaded at 73950000h - 7395D000h
Hook                            loaded at 08FA0000h - 08FAD000h
SXS                              loaded at 6CFE0000h - 6D03F000h
jscript                          loaded at 6B550000h - 6B602000h
CRYPTSP                          loaded at 736A0000h - 736B6000h
rsaenh                          loaded at 73970000h - 739AB000h
RpcRtRemote                      loaded at 73960000h - 7396E000h
mscms                            loaded at 6DC50000h - 6DCC9000h
icm32                            loaded at 6B4E0000h - 6B518000h
atioglxx                        loaded at 69030000h - 69CB6000h
atiadlxy                        loaded at 04450000h - 04481000h
WINTRUST                        loaded at 77120000h - 7714D000h
wshom                            loaded at 6B900000h - 6B921000h
ScrRun                          loaded at 6B830000h - 6B85A000h
explorerframe                    loaded at 74B70000h - 74CDF000h
DUser                            loaded at 74B40000h - 74B6F000h
DUI70                            loaded at 74A80000h - 74B32000h
drprov                          loaded at 6CD40000h - 6CD48000h
WINSTA                          loaded at 73920000h - 73949000h
ntlanman                        loaded at 6CD20000h - 6CD34000h
davclnt                          loaded at 6CD00000h - 6CD16000h
DAVHLPR                          loaded at 6CCF0000h - 6CCF8000h
wkscli                          loaded at 6CCE0000h - 6CCEF000h
netutils                        loaded at 6CD50000h - 6CD59000h
mswsock                          loaded at 73240000h - 7327C000h
wshtcpip                        loaded at 730D0000h - 730D5000h
wship6                          loaded at 73A40000h - 73A46000h
DNSAPI                          loaded at 731F0000h - 73234000h
IPHLPAPI                        loaded at 731A0000h - 731BC000h
WINNSI                          loaded at 73190000h - 73197000h
dhcpcsvc6                        loaded at 73180000h - 7318D000h
dhcpcsvc                        loaded at 73150000h - 73162000h
rasadhlp                        loaded at 73100000h - 73106000h
fwpuclnt                        loaded at 73110000h - 73148000h
CTASIO                          loaded at 09B70000h - 09B7F000h
ctosuser                        loaded at 09B90000h - 09BA6000h
Stack dump analysis:
Address: 08C34D61h (foo_uie_panel_splitter+34D61h), symbol: "foobar2000_get_interface" (+21F51h)
Address: 08C45FF0h (foo_uie_panel_splitter+45FF0h), symbol: "foobar2000_get_interface" (+331E0h)
Address: 08C3E1D5h (foo_uie_panel_splitter+3E1D5h), symbol: "foobar2000_get_interface" (+2B3C5h)
Address: 08C35343h (foo_uie_panel_splitter+35343h), symbol: "foobar2000_get_interface" (+22533h)
Address: 08C3E28Fh (foo_uie_panel_splitter+3E28Fh), symbol: "foobar2000_get_interface" (+2B47Fh)
Address: 08C356E3h (foo_uie_panel_splitter+356E3h), symbol: "foobar2000_get_interface" (+228D3h)
Address: 08C3E3E2h (foo_uie_panel_splitter+3E3E2h), symbol: "foobar2000_get_interface" (+2B5D2h)
Address: 06AF69C0h (foo_ui_columns+1269C0h), symbol: "foobar2000_get_interface" (+70FB0h)
Address: 06A4230Ah (foo_ui_columns+7230Ah)
Address: 06AF7498h (foo_ui_columns+127498h), symbol: "foobar2000_get_interface" (+71A88h)
Address: 06ACF278h (foo_ui_columns+FF278h), symbol: "foobar2000_get_interface" (+49868h)
Address: 06A88376h (foo_ui_columns+B8376h), symbol: "foobar2000_get_interface" (+2966h)
Address: 06AD1E50h (foo_ui_columns+101E50h), symbol: "foobar2000_get_interface" (+4C440h)
Address: 06ABCFA0h (foo_ui_columns+ECFA0h), symbol: "foobar2000_get_interface" (+37590h)
Address: 06A41395h (foo_ui_columns+71395h)
Address: 06A0B4B7h (foo_ui_columns+3B4B7h)
Address: 06AF7600h (foo_ui_columns+127600h), symbol: "foobar2000_get_interface" (+71BF0h)
Address: 01167C65h (foobar2000+7C65h)
Address: 01186FD6h (foobar2000+26FD6h)
Address: 06AF4000h (foo_ui_columns+124000h), symbol: "foobar2000_get_interface" (+6E5F0h)
Address: 069EA02Dh (foo_ui_columns+1A02Dh)
Address: 06ABCFD0h (foo_ui_columns+ECFD0h), symbol: "foobar2000_get_interface" (+375C0h)
Address: 06A8817Fh (foo_ui_columns+B817Fh), symbol: "foobar2000_get_interface" (+276Fh)
Address: 06AD75BCh (foo_ui_columns+1075BCh), symbol: "foobar2000_get_interface" (+51BACh)
Address: 06AB6718h (foo_ui_columns+E6718h), symbol: "foobar2000_get_interface" (+30D08h)
Address: 06A8597Eh (foo_ui_columns+B597Eh)
Address: 01193373h (foobar2000+33373h)
Address: 012CAB0Ch (foobar2000+16AB0Ch)
Address: 012CA94Ch (foobar2000+16A94Ch)
Address: 012CA5E4h (foobar2000+16A5E4h)
Address: 012AC9F9h (foobar2000+14C9F9h)
Address: 011936ADh (foobar2000+336ADh)
Address: 6E8CF840h (foo_ui_std+CF840h), symbol: "foobar2000_get_interface" (+21220h)
Address: 011C45A5h (foobar2000+645A5h)
Address: 012AE291h (foobar2000+14E291h)
Address: 0118C4E7h (foobar2000+2C4E7h)
Address: 6EED2826h (shared+2826h), symbol: "uCallStackTracker::~uCallStackTracker" (+0h)
Address: 012FD38Ch (foobar2000+19D38Ch)
Address: 012A6049h (foobar2000+146049h)
Address: 011CB61Ch (foobar2000+6B61Ch)
Address: 0066001Eh (dragext+1Eh)
Address: 012C6204h (foobar2000+166204h)
Address: 77600300h (ntdll+70300h), symbol: "LdrUnregisterDllNotification" (+1F8h)
Address: 012D8194h (foobar2000+178194h)
Address: 776003DDh (ntdll+703DDh), symbol: "WinSqmSetIfMaxDWORD" (+31h)
Address: 775BE1CCh (ntdll+2E1CCh), symbol: "RtlInitUnicodeString" (+164h)
Address: 775BDF32h (ntdll+2DF32h), symbol: "RtlAllocateHeap" (+ACh)
Address: 0118EDC0h (foobar2000+2EDC0h)
Address: 01293F74h (foobar2000+133F74h)
Address: 0129A666h (foobar2000+13A666h)
Address: 01297A90h (foobar2000+137A90h)
Address: 01298325h (foobar2000+138325h)
Address: 012B5243h (foobar2000+155243h)
Address: 6EED27D8h (shared+27D8h), symbol: "uPrintCrashInfo_OnEvent" (+B1h)
Address: 012CE17Ch (foobar2000+16E17Ch)
Address: 6EED281Eh (shared+281Eh), symbol: "uCallStackTracker::uCallStackTracker" (+31h)
Address: 011CB7BDh (foobar2000+6B7BDh)
Address: 01160000h (foobar2000+0h)
Address: 0129DA4Dh (foobar2000+13DA4Dh)
Address: 013021C8h (foobar2000+1A21C8h)
Address: 0129729Fh (foobar2000+13729Fh)
Address: 01294246h (foobar2000+134246h)
Address: 01294240h (foobar2000+134240h)
Address: 012C01A8h (foobar2000+1601A8h)
Address: 012C01ACh (foobar2000+1601ACh)
Address: 012BDE61h (foobar2000+15DE61h)
Address: 012B581Dh (foobar2000+15581Dh)
Address: 012950E2h (foobar2000+1350E2h)
Address: 0129BD0Fh (foobar2000+13BD0Fh)
Address: 757A3677h (kernel32+13677h), symbol: "BaseThreadInitThunk" (+12h)
Address: 775C9D42h (ntdll+39D42h), symbol: "RtlInitializeExceptionChain" (+63h)
Address: 757C9775h (kernel32+39775h), symbol: "UnhandledExceptionFilter" (+0h)
Address: 775C9D15h (ntdll+39D15h), symbol: "RtlInitializeExceptionChain" (+36h)
Address: 01295135h (foobar2000+135135h)
Address: 6E757220h (MSVCP90+47220h), symbol: "LPoly" (+DE14h)
Address: 10000000h (RKLauncher+0h)
Environment:
App: foobar2000 v1.1
OS: Windows 6.1.7600 x64
CPU: AMD Phenom™ II X4 955 Processor, features: 3DNow!ex MMX SSE SSE2 SSE3
Audio: Speaker (Creative SB X-Fi); SPDIF Out (Creative SB X-Fi); digital audio (HDMI) (Creative SB X-Fi)
UI: Columns UI 0.3.8.7
Components:
Core (2010-08-21 11:42:56 UTC)
    foobar2000 core 1.1
foo_7taskbar.dll (2009-10-31 12:13:05 UTC)
    Seven Taskbar 1.3.0
foo_albumlist.dll (2010-08-21 11:41:12 UTC)
    Album List 4.5
foo_autoupdate.dll (2010-04-19 16:21:14 UTC)
    Automatic Updater 1
foo_bookmarks.dll (2010-08-10 10:10:18 UTC)
    Bookmarks 0.3.3.4
foo_bpm.dll (2010-01-12 14:36:55 UTC)
    BPM Analyser 0.2.4
foo_bubble_coverflow.dll (2010-02-02 15:13:36 UTC)
    Cover Flow 0.31
foo_cdda.dll (2010-08-21 11:41:04 UTC)
    CD Audio Decoder 3.0
foo_chacon.dll (2010-04-06 17:03:40 UTC)
    Chacon 3
foo_chronflow.dll (2008-04-13 15:16:00 UTC)
    Chronial's Coverflow 0.3.0
foo_cmd_playlist.dll (2007-03-17 15:00:00 UTC)
    Playlist Command Line Tools 0.0.2
foo_converter.dll (2010-08-21 11:40:42 UTC)
    Converter 1.5
foo_covers2.dll (2010-01-20 01:33:20 UTC)
    Locate Covers 0.06
foo_cuefilter.dll (2009-04-28 06:09:44 UTC)
    CUE Playlist Filter 0.1.7.0
foo_cuesheet_creator.dll (2007-03-10 02:58:28 UTC)
    Cuesheet Creator 0.4.6
foo_customdb.dll (2010-03-04 03:10:54 UTC)
    Custom Database 0.1.0_beta1
foo_dbsearch.dll (2007-01-25 12:58:48 UTC)
    Database Search 1.4
foo_dbsearch_api_demo.dll (2007-01-22 04:01:38 UTC)
    Database Search Toolbar Demo 1.0
foo_discogs.dll (2010-08-23 13:34:41 UTC)
    Discogs Tagger 1.25
foo_dop.dll (2010-02-20 19:51:18 UTC)
    iPod manager 0.6.6.7
foo_dsp_bs2b.dll (2009-06-08 03:30:06 UTC)
    bs2b 3.1.0
foo_dsp_crossfader.dll (2010-01-13 12:46:10 UTC)
    Gapless Crossfader 1.3.4.1
foo_dsp_echo.dll (2010-06-05 10:07:36 UTC)
    Echo DSP 1.0
foo_dsp_eqsplit.dll (2008-07-12 17:49:10 UTC)
    Split equalizer v0.0.1
foo_dsp_freeverb.dll (2010-01-25 02:37:54 UTC)
    Freeverb 0.3
foo_dsp_fsurround.dll (2010-02-16 13:43:38 UTC)
    FreeSurround 0.3.5
foo_dsp_loudspeakereq.dll (2009-07-01 23:52:58 UTC)
    Loudspeaker Equalizer 1.0.1
foo_dsp_mm.dll (2008-06-06 05:29:10 UTC)
    Matrix Mixer 0.3
foo_dsp_resampler.dll (2009-07-28 18:01:58 UTC)
    SoX Resampler 0.5.4.1
foo_dsp_soundtouch.dll (2010-01-14 12:08:06 UTC)
    SoundTouch DSP 1.1
foo_dsp_std.dll (2010-08-21 11:41:12 UTC)
    Standard DSP Array 1.0
foo_dsp_tube.dll (2007-02-06 23:17:55 UTC)
    Tube Sound 0.8
foo_dsp_vst.dll (2007-05-17 09:39:34 UTC)
    VST bridge 0.60 Beta
foo_dsp_winamp.dll (2010-01-23 00:39:18 UTC)
    Winamp DSP Bridge 1.4.7
foo_dsp_yac.dll (2010-08-05 08:17:52 UTC)
    Yet Another Convolver 1.0
foo_exvar.dll (2008-06-13 22:42:55 UTC)
    Extended Variables 0.3.1
foo_fileops.dll (2010-08-21 11:39:48 UTC)
    File Operations 2.1.3
foo_freedb2.dll (2010-08-21 11:40:00 UTC)
    freedb Tagger 0.6.2
foo_gep.dll (2010-08-23 13:34:41 UTC)
    Game Emu Player 1.102
foo_input_monkey.dll (2009-05-01 05:40:52 UTC)
    Monkey's Audio Decoder 2.1.4
foo_input_std.dll (2010-08-21 11:40:42 UTC)
    Standard Input Array 1.0
foo_input_tak.dll (2010-01-09 10:11:58 UTC)
    TAK Decoder 0.4.4
foo_input_tta.dll (2010-01-15 16:00:00 UTC)
    TTA Audio Decoder 2.4.4
foo_masstag.dll (2009-09-18 01:01:36 UTC)
    Masstagger 1.8.4
foo_menu_addons.dll (2010-01-16 02:18:34 UTC)
    Menu Addons 1.4.2
foo_midi.dll (2010-08-23 13:34:41 UTC)
    MIDI synthesizer host 1.108
foo_musicbrainz.dll (2009-04-10 20:27:28 UTC)
    MusicBrainz Tagger 0.2
foo_navigator.dll (2010-02-20 01:13:12 UTC)
    Navigator 0.64
foo_out_asio.dll (2009-03-22 06:15:46 UTC)
    ASIO support 1.2.7
foo_out_wasapi.dll (2009-05-19 13:45:18 UTC)
    WASAPI output support 2.1
foo_playcount.dll (2010-08-24 12:05:51 UTC)
    Playback Statistics 3.0
foo_playlist_attributes.dll (2010-05-23 19:22:21 UTC)
    Playlist Attributes 0.3.0
foo_playlist_tree_mod.dll (2010-01-09 14:15:56 UTC)
    Playlist Tree Mod Panel 3.0.6.3 NoScheme [Jan  9 2010 - 15:15:40]
foo_playlists_sort.dll (2009-06-13 07:57:32 UTC)
    Playlist Sorter 0.1.9
foo_podcatcher.dll (2010-03-01 12:47:58 UTC)
    Podcatcher 0.1.6c (beta)
foo_preview_custom.dll (2009-09-09 11:21:29 UTC)
    Preview Custom 1.0.1
foo_queuecontents.dll (2010-05-20 01:18:58 UTC)
    Queue Contents Editor 0.3.9
foo_quicksearch.dll (2010-05-14 10:08:00 UTC)
    Quick Search Toolbar 1.9
foo_quicktag.dll (2009-12-23 12:36:24 UTC)
    Quick Tagger 1.0.2
foo_random.dll (2009-06-30 14:06:58 UTC)
    Randomized Playlist Entry 1.3.0
foo_random_pools.dll (2010-04-05 08:00:43 UTC)
    Random Pools 0.0.2.1
foo_removefromqueue.dll (2007-07-14 05:30:00 UTC)
    Remove from Queue 1
foo_rg_trn.dll (2010-01-13 23:01:01 UTC)
    ReplayGain override 0.1.3
foo_rgscan.dll (2010-08-21 11:40:44 UTC)
    ReplayGain Scanner 2.0.9
foo_run.dll (2009-06-07 06:15:18 UTC)
    Run services 0.3.7
foo_runcmd.dll (2010-01-07 10:32:34 UTC)
    Run Command 1.1
foo_scheduler.dll (2010-07-18 12:37:36 UTC)
    Scheduler 4.05
foo_seek_box.dll (2010-04-21 06:03:30 UTC)
    Seek box 0.0.3
foo_stop_after_queue.dll (2009-06-19 09:49:42 UTC)
    Stop After Queue 0.1
foo_stop_on_current.dll (2009-06-17 20:54:52 UTC)
    Stop on Current 0.4
foo_stop_on_error.dll (2010-01-14 09:28:26 UTC)
    Stop on Error 0.3
foo_stopaftercuralbum.dll (2009-06-01 00:50:42 UTC)
    foo_stopaftercuralbum 0.2
foo_tagbox.dll (2010-08-12 04:58:10 UTC)
    TagBox 0.172
foo_talktome.dll (2010-07-20 12:40:37 UTC)
    TalkToMe 0.6
foo_textdisplay.dll (2008-07-08 10:45:26 UTC)
    Text Display UI Element 1.0 RC 3
foo_textfile.dll (2009-03-08 05:15:58 UTC)
    Textfile 0.0.3
foo_truephase_fft.dll (2010-02-16 11:04:33 UTC)
    True Phase 1.1
foo_ui_columns.dll (2010-06-17 20:49:12 UTC)
    Columns UI 0.3.8.7
foo_ui_hacks.dll (2010-08-23 16:51:44 UTC)
    UI Hacks 2010-08-23
foo_ui_std.dll (2010-08-21 11:41:10 UTC)
    Default User Interface 0.9.5
foo_uie_albumart.dll (2007-12-15 15:22:24 UTC)
    Album Art Panel 0.2.7.1
foo_uie_albumlist.dll (2009-06-13 22:49:19 UTC)
    Album list panel 0.3.5
foo_uie_biography.dll (2010-06-27 12:50:10 UTC)
    Biography View 0.4.2.2
foo_uie_console.dll (2009-08-29 16:06:24 UTC)
    Console panel 0.4
foo_uie_dragpanel.dll (2009-05-01 17:37:56 UTC)
    Drag Panel 0.0.8
foo_uie_elplaylist.dll (2010-02-19 16:57:06 UTC)
    ELPlaylist 0.6.7.0(beta)
foo_uie_esplaylist.dll (2010-08-15 13:21:32 UTC)
    EsPlaylist 0.1.1.1
foo_uie_explorer.dll (2010-02-22 13:51:29 UTC)
    Explorer Tree 2.04.8
foo_uie_graphical_browser.dll (2008-12-11 14:10:27 UTC)
    Graphical Browser rev015
foo_uie_library_tree.dll (2010-03-22 08:51:34 UTC)
    Library Tree 0.3.4.4
foo_uie_lyrics2.dll (2010-04-12 11:19:24 UTC)
    Lyric Show Panel 2 0.4.6.15
foo_uie_lyrics_art.dll (2008-06-11 17:28:31 UTC)
    Lyrics Art Panel 0.058
foo_uie_lyrics_panel.dll (2007-08-17 14:56:36 UTC)
    Lyrics panel 0.35
foo_uie_panel_splitter.dll (2009-12-09 15:16:12 UTC)
    Panel Stack Splitter 0.3.8.3(alpha)
foo_uie_playlists_dropdown.dll (2009-09-23 15:44:46 UTC)
    Playlists Dropdown 0.7.6
foo_uie_ptb.dll (2008-02-16 07:45:33 UTC)
    Playback Toolbars 0.2
foo_uie_quicksearch.dll (2007-05-18 04:31:10 UTC)
    Quick Search Toolbar 2.8l
foo_uie_tagger_mod.dll (2009-09-20 21:49:42 UTC)
    Tagger Mod Panel Window 1.1.0.6 [Sep 20 2009 - 23:33:24]
foo_uie_textbox.dll (2008-04-02 01:08:10 UTC)
    Textbox 0.0.5a
foo_uie_trackinfo.dll (2008-11-01 04:24:02 UTC)
    Track info panel 0.8
foo_uie_vis_channel_spectrum.dll (2008-12-07 09:40:37 UTC)
    Channel Spectrum panel 0.17.2
foo_uie_vis_peakmeter_spectrum.dll (2008-04-19 11:18:50 UTC)
    Peakmeter Spectrum Visualisation 0.2.0.0 beta
foo_uie_wsh_panel_mod.dll (2010-06-19 10:52:06 UTC)
    WSH Panel Mod 1.3.6
foo_utils.dll (2008-12-07 13:13:11 UTC)
    Playlist Tools 0.6.2 beta 6
foo_verifier.dll (2009-10-05 02:39:20 UTC)
    File Integrity Verifier 1.1
foo_vis_shpeck.dll (2009-09-28 02:32:16 UTC)
    Shpeck - Winamp vis plugins wrapper 0.3.7
foo_vis_vumeter.dll (2010-06-07 18:52:04 UTC)
    VU Meter 2010-06-07
foo_wave_seekbar.dll (2010-04-24 15:35:42 UTC)
    Waveform seekbar 0.2.12
Recent events:
Times: a2 - a3: 0msec
Times: a3 - a4: 3msec
Times: a4 - a5: 0msec
Synch: 5 msec (in mainthread!)
Shutting down...
foo_uie_bookmarks
Reply #168
it's not working for me. I installed it in 2 ways, the first is simply going to Preferences --> Components and choose "Bookmarks" and Install.
Didn't get any errors at all and i can see "Bookmarks" under Tools (in Preferences). Also, in Context Menu (still in Preferences), i can see the "Bookmark", "Bookmark +" and "Bookmark + (flush)" option.
I could also configure the keyboard shortcuts to them fine.
But how do i use it?? When i right click on a song or on the trackbar or right click ANYWHERE, the context menu doesn't show the bookmark option, i can't figure out how to use this.
All i want is to create bookmarks of a certain point of a song, i often listen to techno or hardcore trance and the climatic/chorus part that gets build up is the point that i want to bookmark so i can let it start playing from there.
Anyway so the 2nd way i did (uninstalling it first) is simply download the plugin from page 1 and put it in the correct folders........and same thing, it showed up fine but it doesn't show in the context menu when i right click. I have no idea how to use it....
foo_uie_bookmarks
Reply #169
Bookmarks cannot be created if the DUI element or CUI panel has not been added to the layout.
foo_uie_bookmarks
Reply #170
Too slow and I deleted as my info may be in error
terry
foo_uie_bookmarks
Reply #171
i can't find that option at all, i'm in layout editing mode and also checked the quick setup option and don't see either of them....
EDIT:
NVM i just added a new splitter and can now add bookmarks ui.
foo_uie_bookmarks
Reply #172
The foobar wiki has documentation on how to configure foobar.
Assuming you have foo_uie_bookmarks component installed, and you are in layout edit mode:
right click on any panel and you will have a context menu to replace the panel
bookmarks will be under the UTILITY heading.
Of course if you are wanting to add bookmarks without removing an existing panel, you will need to replace the existing panel with a splitter and then add the current panel back and add bookmarks to the other panel area created by the splitter [as per docs]
terry
foo_uie_bookmarks
Reply #173
I use panel stack splitter.
foo_bookmark is useful.
I add bookmark panel on panel stack splitter, it will cause crash.
Then, I use following structure.
panel stack splitter->horizontal splitter->bookmark
It work fine. but I think this is bad.
please fix it.
foo_uie_bookmarks
Reply #174
It is a panel stack splitter issue, deduced from a crash report sent by another user.
