Topic: FLAC Checksum off (Read 9198 times) previous topic - next topic
  • FOO_ME
FLAC Checksum off
I'm sorry if this has previously been asked, but I was unable to find anything pertaining to it.
I encoded a WAV into FLAC and calculated the MD5 for each and converted it back.  Both WAV files had the same checksum, but when I did --show-md5sum it gave me a compltely different value, that value didnt match the FLAC or the WAV.
If the result of the --show-md5sum is supposed to be different what is that hash calculated from?
Thanks,
Pete
  • adamjk
FLAC Checksum off
Would you like to give some more informations regarding your software?
  • FOO_ME
FLAC Checksum off
I encoded it originally with the Convert To in foobar and decoded it the same way.  I did it again with Flac front end and got the same results.  The checksum was created with Hash Tab and wxChecksums and both of those came out the same.
  • kjoonlee
FLAC Checksum off
I think it's derived from the raw PCM data, not the full .wav file. Anyway, if the FLAC file's md5sum (visible by using metaflac) stays the same, then there's nothing to worry about.
FLAC Checksum off
http://flac.sourceforge.net/documentation.html says:
"Also included in the STREAMINFO block is the MD5 signature of the unencoded audio data."
So
--show-md5sum (.flac) != md5 (.wav)
but:
--show-md5sum (.flac) == md5 (.raw)
.raw is audio data only.. no headers, no riff chunks..
(.raw = .wav - nonAudioData)
on my machine, flac.exe decodes to .raw via
flac -d --force-raw-format --sign=signed --endian=little <flac-file>
  • Triza
FLAC Checksum off
MD5 checksum calculation is unambiguous, but the layout of the data is NOT. So it matters how the data is layed out. I am referring to the various endianess schemes for example.
Triza
  • FOO_ME
FLAC Checksum off
Thanks for clarifying it, it wasnt making any sense
