Topic: Review: Best burners for reading/burning audio CDs (Read 405838 times) previous topic - next topic
  • ernstblaauw
Reply #100
Any takers on alexn's question?
To answer this question one needs to have a lot of knowledge about CD / DVD burners. Therefore, I think you can better ask this question to some guys at http://club.cdfreaks.com, which used to be (atm I'm not active over there) a good place to ask such questions.
Moderation: Pruned unnecessary full quotation of the previous post.  We don't need to read everything twice.
  • Last Edit: 28 July, 2009, 11:55:03 AM by greynol
  • funkyblue
Reply #101
It seems there will never be a new decent driver for audio. I would pay $200USD for a simple drive that could do this:
-Overread into lead in/out
-Has accurate C2
-HTOA
-No cache
-Reasonably fast.
But it seems no one is interested in making it.
  • RIV@NVX
Reply #102
Well, according to this page, LITE-ON iHAP 422 8 would qualify (but I'm not sure how frequent this model is, if at all). It would be interesting to see if iHAS/iHAP x24 would also work, since LITE-ON has probably changed chipset in it.
Also, I wonder about Optiarc AD-72xxA/S, since they aren't listed there. Both AD-7200S and AD-7243S have accurate stream, don't cache, and retrieve C2 error information. Not sure how to test HTOA and overread.
  • Mr. Salty
Reply #103
Wow, I've spent more hours than I care to admit over the past few days trying to figure out what the best currently available option is, but unfortunately there is a real lack of concrete information out there nowadays.
I decided to try my luck with a Samsung SH-S223L, at least it appears not to cache and may be able to do HTOA.  It appears no overread but the offset is only 6 so no big deal.  I'll report back once I've actually tried it.
Not having to beat on the tray of my LTD-163 to get it to recognize discs will be a big plus - although I'm sure I'll miss that little "quirk".  I've ripped probably 2000-2500 discs with that drive...
  • Mr. Salty
Reply #104
My first impressions of the Samsung SH-223L are very positive, after some tests I think I'm comfortable making it my new ripping drive.
I'm using EAC 0.99pb5 on Win7.  I've always ripped in secure mode and disabled C2 because I don't trust it.  EAC reports the drive does support C2 but I won't comment on that because I have no experience with it and didn't test it.  Maybe I'll try it with some of my badly scratched discs later.
So, my settings are: Secure mode, Accurate Stream checked, 'Drive caches...' and C2 UNchecked.  Read MMC1, offset +6, gap detection A, Secure.  I make a CUE sheet but rip to individual tracks (APE), MP3 encoding is a separate step.
Anyways, I started off by ripping a couple CDs I had previously ripped with my old drive (LTD-163).  AccurateRip reported all tracks accurate (confidence in the 20s) for one disc, the other disc was just released so it's not in the database.  I also compared WAV files directly and they were all identical with one small exception I'll describe below (I'm not worried about it.)
I'm also happy to report it supports HTOA, I confirmed this with two commercial discs.  I used Action->Copy Selected Track Index Based and got full audio in both cases, which is great.
So, overall I'm very pleased with the DAE performance.  I think I'm pretty anal about accurate rips above all else - so if that's what you're looking for I think you'll be happy with this drive.  As far as I can tell the only thing "missing" is the ability to read into the lead-in/lead-out, but the offset is only 6 so it doesn't really bug me.
  • Mr. Salty
Reply #105
PS: about the WAV miscompare in the post above, the only "difference" was at the very end of the last track of one of the discs:
# ls -l *.wav
-rwxr--r--  1 nobody nobody 168327980 Jan 14 22:28 ltd163.wav*
-rwxr--r--  1 nobody nobody 168327980 Jan 14 22:28 sh223l.wav*
# cmp *.wav
ltd163.wav sh223l.wav differ: byte 168325613, line 1203176
Note the difference is 2367 bytes from the end of the file.  I found that interesting because the offset of the LTD-163 is 594 samples = 2376 bytes - indeed the last 2376 bytes (offset 168325604) of ltd163.wav are filled with zeros as you'd expect.  However, at this point there is still some data in the sh223l.wav file, which continues to the end of the disk (except the last 6 missing samples due to the offset, of course):
# od -x -Ad -j 168325604 -N 32 sh223l.wav
168325604 0000 0000 0000 0000 ffff ffff 0000 0000
168325620 ffff ffff ffff ffff ffff ffff ffff ffff
Prior to that offset, in both files I see an identical random pattern of 0000 and ffff samples, which comprises the last ~369KB (~2.13s) of data on the disc.  Prior to that I see 0001's and fffe's...  So, it just seems like a long fadeout that never quite hits 0, but it's well past anything audible on the disc and obviously not audible itself.  So, I consider the rips identical.
The other disc I ripped didn't have that issue, it went to all 0's long before the end of the last track.
  • Shady88
Reply #106
- Read speed: --
What's this supposed to mean? It means that the ripping speed on the supposed drive is slow, fast or what?
Because since it does a 100% quality rip and it rips it at 4x instead of 16x it doesn't matter, as long as itt obtains the best results
  • Last Edit: 11 April, 2010, 01:00:54 PM by Shady88
  • db1989
  • Global Moderator
Reply #107
- Read speed: --
I wonder if more negative symbols mean that the drive takes longer to rip, and vice-versa with positive symbols.
So, offered several drives that could rip equally accurately, you wouldn't care which was fastest? Well, it's your time.
  • Shady88
Reply #108
Yup, i thought that too but i just needed a confirmation
The important thing is that my backups comes perfect ripped as they appear on the cd after the rip, it might take more time to rip them surely with a slower drive, but at least i obtain perfect rips
Hey, i've got a few old drives that i'd be glad to test as soon as i get my pc fixed (i'm writing from a "temporary" pc), can somebody me drive me through the simplest way to test their effective capacities?
That's what i got:
Vuego 685A (or Vuego JVP685-D, i'm not sure)
LG GCE-8527B
TOP-G BCD F561D
AOPEN CD-952E/TKU
LG CRD-8520B
  • Cutter
Reply #109
Thanks for your test results Mr. Salty.
Does anyone know if the Lite-On iHAS524 is able to do HTOA?
  • Last Edit: 13 April, 2010, 05:06:58 PM by Cutter
  • funkyblue
Reply #110
It does not. I have tried it. No new drives are as good as Plextor's unfortunatly. I've yet to find a decent one that reads into leadin/out/ has decent C2 and HTOA.
  • Cutter
Reply #111
Thanks funkyblue.
  • mous00
Reply #112
Hmmm, I just found a new never installed BenQ DW1640 in storage. Are these good drives to rip from?
  • greynol
  • Global Moderator
Reply #113
I've heard excellent things about the Plextor PX-230, which I think is just a rebadge of the DW1640, so I'm thinking the answer to your question is yes.  I don't have one myself, however.
Reply #114
Seeing as the last post was from September, can someone post a recent list??
I've been looking for a Plextor cd drive but can't find one anywhere..lol
I've got 3 or 4 Lite-On drives, a couple of Matsumi and a Sony..All either cd drive/burner or dvd drive/burner. I've been ripping secure rips with EAC and quite enjoy it..lol
I've got 2 drive bay and would like to utillize that..Possible??
  • Kitlope
Reply #115
Thanks for the info on the Samsung SH-S223L Mr. Salty. I know this thread is a little old and perhaps you'll poke your head around here once again but did you ever find out if it supports Caching & C2 Errors? I picked up this drive on your recommendation and am quite happy with it but am a bit of a n00b with this stuff. I just follow the HA wiki to set it up properly.
As others have said, I really wish someone would come out with a "audiophile" drive that meets the needs of picky rippers. My Plextor 716SA has pretty much died, bought a used one off ebay and it's pretty much dead too. Bastards.
Kit
  • Mr. Salty
Reply #116
I'm still very happy with the drive, I might pick up another one or two in case mine dies, so I don't have to evaluate a new crop of drives.
You want it to *not* cache audio data, which AFAICT (and according to EAC) is the case.
As far as C2, I haven't looked into it, based on what I've read here I don't think I'd trust C2 to work properly on *any* drive.
todd.
  • Last Edit: 22 October, 2011, 12:40:30 PM by greynol
  • derty2
Reply #117
I'm getting beautiful reads and writes of audio CD's using a TEAC DV-W28S-R External USB Optical Disc Drive.
I use it only for audio CD tasks, and it's the nicest drive I have ever used for such tasks. EAC and ImgBurn work great with it.
  • Andavari
Reply #118
In EAC I have C2 enabled for both my drives, and coupled with AccurateRip and EAC's own Secure Mode I haven't had any issues.
  • norlane
Reply #119
Can some one advise me on a good brand of
DVD burner for reading/burning audio CDs
if i was to go out and buy one tommorrow
thankx.
Using for EAC works
  • Last Edit: 16 August, 2012, 08:40:30 PM by norlane
  • soundping
Reply #120
thankx.
Using for EAC works
ASUS BW-12B1ST is a very good drive.
http://www.asus.com/Optical_Storage/Intern...#specifications
  • Last Edit: 17 August, 2012, 01:00:57 PM by soundping
I like bacon and .OPUS   :-)
  • norlane
Reply #121
Awsome thankx for the advice
  • beneix
Reply #122
thankx.
Using for EAC works
I'm also looking - but would prefer an external drive.  I know I can build one using an internal one, but if I can I'd like to avoid that.
Are there any decent external drives that the experts on this forum would endorse for EAC use?  That's priority no 1.  No 2 would be good burning ability and no 3 speed.
Reply #123
I am also looking for an external USB drive for ripping audio CDs to FLAC via EAC.
All suggestions are very welcome. Are there any known drives which give good results?
Re: Review: Best burners for reading/burning audio CDs
Reply #124
Posted by Treetrunks - 22 April, 2013, 01:47:20 PM
A USB drive is usually just a SATA drive with a USB<-> SATA media converter.  You can buy prepackaged USB drives or make your own with an enclosure which often includes the USB<-> SATA converter.
I have had a high performance ripping PC with 4 DVD-ROMs that EAC will run concurrently. There does not seem to be an obvious speed loss due to running 4 drives at a time.  The 4 drives run off of their own low cost 4 drive PCI-E SATA controller card.  The net result is much faster ripping, if you keep the beast fed.
One consequence of having 4 drives operating concurrently is that there are about 4 times as many single-drive failures. The failures are often soft failures, where  the failing drive just gets pickier about the condition of the media that it rips error-free.
The last time I checked my drives out I had a number of CDs on hand from estate sales that tended to cause little tummy aches. I also had a number of different brand new drives. At the time I had 4 different brand drives in use including Asus, LG, Optiarc, and Samsung. Testing with damaged and dirty discs showed the Samsung/TSSTCorp  SH 224 (various submodels) to be far and away the most capable, often giving error free rips where other drives stumbled and even locked up.
