Topic: AutoFLAC (Read 329432 times) previous topic - next topic
AutoFLAC
Reply #300
Oops, mixed something up. It just includes flac.exe...
Ok, so 1.2 is the latest version? I have some strange problem. Somehow AutoFLAC does not create FLAC files, just .wav. I doubled checked all options and paths but can't find the problem (naming schema is correct). I perfectly moves and modifies the .cue file however. Just doesn't compress. What's wrong?
AutoFLAC
Reply #301
Ok, I got my first problem fixed, was a wrong setting in EAC...
Now I have another problem: Is it possible that AutoFLAC does not support naming schemes where the track number and the track title is not separated with a dash (but instead with a single space for example)?
I took a quick look at the source code and line 368 seems to confirm this. Does somebody else have this problem? Is there a workarround or a bug fixed version of AutoFLAC?
AutoFLAC
Reply #302
Ok, changed the script a bit to fit my needs. Here is my source if somebody else needs something similar:
[code]; ----------------------------------------------------------------------------
; AutoFLAC v1.2
; Author:   Jared Breland <jbreland@legroom.net>
; Homepage:   http://www.legroom.net/mysoft
; Language:   AutoIt v3.2.0.1
; License:   GNU General Public License (http://www.gnu.org/copyleft/gpl.html)
; Script Function:
;   Automate ripping and burning of flac files with EAC
; Changes by HiPerFreak:
;  * Fixed bug: EAC puts the log file in the ripping directory with the file
;   name "Artist - Album.log". AutoFLAC handles this correctly now.
;  * Log file is saved with file name "Artist.log" and cue sheet is saved with
;   the file name "Artist.cue" (without "00-" prefix).
;  * Changed parsing logic for track numbers to take the 2 first characters
;   instead of looking for a dash.
;  * Modified CRC check so that only the last status report is evaluated if
;   there are multiple ones in the log file.
;  * All changes I made are marked with "; CHANGE: <description>".
; Setup environment
#include <GUIConstants.au3>
global $name = "AutoFLAC"
global $version = "1.2"
global $title = $name & ' ' & $version
global $eactitle = "Exact Audio Copy"
global $regprefs = "HKCU\Software\" & $name
global $write = 0
global $artist, $year, $album, $genre, $dbtype, $cuefile, $warning, $tcwarning
; Extract options
global $extractmethod = 'all'
global $ripimage = 0
global $createcue = 1
global $embedcue = 0
global $deletecue = 0
; Disc options
global $createlog = 1
global $testandcopy = 0
global $copydata = 1
global $replaygain = 1
global $indiv_replaygain = 1
global $multidisc = 0
global $discnum = 1
;global $checksums = 0
; Rip options
global $outputenc = 'FLAC'
global $cdromdrive = "D:"
global $lowpriority = 0
global $ejectcomplete = 1
global $notifycomplete = 1
global $notifywav = "notify.wav"
; Write options
global $writetemptype = 'album'
global $writetempdir = @tempdir
; Program options
global $eac = regread("HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\EAC.exe", "")
$eac = "c:\test.exe"
$regvalue = regread("HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders", "My Music")
if not @error then
   global $outputdir = $regvalue
else
   global $outputdir = @mydocumentsdir & "\Music"
endif
global $sepscheme = "%I\%A\%C"
global $imgscheme = "%A - %C"
global $flac = "flac.exe"
global $metaflac = "metaflac.exe"
;global $md5sum = "md5sum.exe"
; Validate EAC binary exists
ReadPrefs()
if NOT fileexists($eac) AND NOT SearchPath($eac) then SelectEAC()
; Check for command line arguments
if $cmdline[0] > 0 then
   $write = 1
   if $cmdline[1] = "/write" then
      if $cmdline[0] > 1 then
         $cuefile = $cmdline[2]
      endif
   else
      $cuefile = $cmdline[1]
   endif
; Validate cue file
   if $cuefile <> '' then
   ; Must be a cue file
      if stringtrimleft($cuefile, stringinstr($cuefile, '.', 0, -1)) <> "cue" then
         msgbox(64, $title, "Usage:" & @CRLF & @scriptname & " [/write [album.cue]]")
         exit
      endif
   ; Qualify full path
      if stringmid($cuefile, 2, 1) <> ":" then
         if stringleft($cuefile, 1) == "\" then
            $cuefile = stringleft(@workingdir, 2) & $cuefile
         else
            $cuefile = @workingdir & "\" & $cuefile
         endif
      endif
   ; make sure cue file exists
      if NOT fileexists($cuefile) then
         exit
      endif
   endif
endif
; If /write passed, decompress tracks and load cue sheet for burning
if $write then
; Set write options and set CUE sheet
   WriteSetup()
; Setup paths and file names
   progresson($title, "Preparing files for writing", "Converting cue sheet", -1, -1, 16)
   $cuedir = stringleft($cuefile, stringinstr($cuefile, '\', 0, -1)-1)
   $cueext = stringtrimleft($cuefile, stringinstr($cuefile, '.', 0, -1))
   $cuename = stringtrimright(stringtrimleft($cuefile, stringlen($cuedir)+1), stringlen($cueext)+1)
   if $writetemptype == 'album' then
      $tempdir = $cuedir & "\" & $name
   else
      $tempdir = $writetempdir & "\" & $name
   endif
   dircreate($tempdir)
   $infile = fileopen($cuefile, 0)
   $outfile = fileopen($tempdir & "\" & $cuename & ".wav.cue", 2)
; Create new cue file, save track filenames
   $i = 0
   dim $wavs[$i+1]
   while 1
      $line = filereadline($infile)
      if @error then exitloop
      if stringleft(stringstripws($line, 1), 5) = "FILE " then
         $wavs[$i] = stringmid($line, stringinstr($line, '"') + 1, stringinstr($line, '.', 0, -1) - stringinstr($line, '"')-1)
         $i = $i + 1
         redim $wavs[$i+1]
         $line = stringreplace($line, ".flac", ".wav", 0, 0)
      endif
      if stringinstr($line, "TRACK", 1) AND stringinstr($line, "MODE", 1) then
         exitloop
      endif
      filewriteline($outfile, $line)
   wend
   redim $wavs[$i]
   fileclose($outfile)
   fileclose($infile)
; Verify checksums
;$md5file = $cuename & '.md5'
;if fileexists($cuedir & '\' & $md5file) then
;   progressset(0, "Verifying MD5 checksums")
;   runwait(@comspec & ' /c ' & filegetshortname($md5sum) & ' -c "' & $md5file & '" >"' & $tempdir & '\' & $cuename & '.md5.txt"', $cuedir, @SW_HIDE)
;   $infile = fileopen($tempdir & "\" & $cuename & ".md5.txt", 0)
;   $warning = ''
;   $line = filereadline($infile)
;   do
;      if not stringinstr($line, ": OK", 1) then
;         $warning &= stringleft($line, stringinstr($line, '-')-1) & ', '
;      endif
;   until @error
;   fileclose($infile)
;   if $warning <> '' then
;      $warning = stringtrimright($warning, 2)
;      progressoff()
;      $prompt = msgbox(49, $title, "Warning: The following tracks could not be verified:" & @CRLF & $warning & @CRLF & @CRLF & "Click OK to continue writing this CD, or Cancel to abort.")
;      if $prompt <> 1 then exit
;      progresson($title, "Preparing files for writing", "Verifying MD5 checksums", -1, -1, 16)
;   endif
;endif
; Begin decompression
;$debug = fileopen("c:\autoflac_write.txt", 2); debug
;filewriteline($debug, "$cuedir = " & $cuedir); debug
   for $i = 0 to ubound($wavs) - 1
      progressset(round($i/ubound($wavs), 2)*100, "Converting " & $wavs[$i] & ".wav")
   ;filewriteline($debug, $flac & ' -d -o "' & $tempdir & '\' & $wavs[$i] & '.wav" "' & $cuedir & '\' & $wavs[$i] & '.flac"'); debug
      runwait('"' & $flac & '" -d -o "' & $tempdir & '\' & $wavs[$i] & '.wav" "' & $cuedir & '\' & $wavs[$i] & '.flac"', $cuedir, @SW_HIDE)
   next
;fileclose($debug); debug
   progressoff()
endif
; Run EAC
if $write then
   $pid = runwait('"' & $eac & '" "' & $tempdir & '\' & $cuename & '.wav.cue"')
   dirremove($tempdir, 1)
   exit
else
   if NOT processexists("eac.exe") then run($eac)
endif
if winwait($eactitle, '', 15) then
   winactivate($eactitle)
else
   msgbox(48, $title, "Error: EAC could not be started.")
   exit
endif
; Otherwise, begine extract process
$extract = 1
while $extract
   $extract = ExtractCD()
wend
exit
; main function to extract CD contents
func ExtractCD()
; Prompt to insert disc if necessary
   $album = controlgettext($eactitle, '', 'myedit1')
   if $album == '' then
      $prompt = msgbox(49, $title, "Please insert the CD you'd like to extract and click OK.")
      while $album == ''
      wend
   endif
; If unknown disc is loaded, query FreeDB and prompt to edit
;winactivate($eactitle)
;if stringinstr($album, "Unknown") then
;   send("!g")
;   if winwait("Warning", "All data of the current CD", 1) then
;      winactivate("Warning", "All data of the current CD")
;      send("!y")
;   endif
;   sleep(500)
;   while 1
;      if winexists("Transfer", "CD Identification") then
;         continueloop
;      elseif winexists("Select CD", "Several exact matches") then
;         continueloop
;      else
;         exitloop
;      endif
;   wend
;endif
; Prompt for CD info edit
   ExtractSetup()
;$debug = fileopen("c:\autoflac_rip.txt", 2);debug
; Get CD info
   $artist = SanitizeChars(controlgettext($eactitle, '', 'myedit2'))
   if $artist == "Various" then $artist = "Various Artists"
   $album = SanitizeChars(controlgettext($eactitle, '', 'myedit1'))
   $genre = SanitizeChars(controlgettext($eactitle, '', 'Edit1'))
   $year = SanitizeChars(controlgettext($eactitle, '', 'myedit3'))
   $dbtype = SanitizeChars(controlgettext($eactitle, '', 'mycombo2'))
; CHANGE: Use no prefix instead of "00-".
; ORIGNAL
;   if $multidisc then
;      $metapre = $discnum & "00-"
;      $metapost = " (Disc " & $discnum & ')'
;   else
;      $metapre = "00-"
;      $metapost = ""
;   endif
; ORIGINAL END
; CHANGED
   if $multidisc then
      $metapre = ""
   else
      $metapre = ""
      $metapost = ""
   endif
; CHANGED END
; Setup output naming scheme
;$ripdir = $outputdir & "\" & $genre & "\" & $artist & "\" & $album
   if $ripimage then
      if stringinstr($imgscheme, '\') then
         $ripdir &= '\' & stringleft($imgscheme, stringinstr($imgscheme, '\', 0, -1)-1)
         $imgname = stringtrimleft($imgscheme, stringinstr($imgscheme, '\', 0, -1))
      else
         $imgname = $imgscheme
      endif
      $imgname = VarNameReplace($imgname)
   else
      $ripdir &= '\' & $sepscheme
   endif
   if stringright($ripdir, 1) == '\' then $ripdir = stringtrimright($ripdir, 1)
   $ripdir = VarNameReplace($ripdir)
;filewriteline($debug, "$ripdir = " & $ripdir);debug
;filewriteline($debug, "$metapre = " & $metapre);debug
; Select all tracks
   if $extractmethod == "all" then send("^a")
; Rip complete image if selected
   if $ripimage then
      send("!aic")
      winwait("Save Waveform")
      send('!n' & $outputdir & '\' & $artist & ' - ' & $album & ' (AutoFLAC)' & '!s')
      winwait("Analyzing", "", 10)
      while winexists("Analyzing")
         sleep(500)
      wend
; Otherwise rip to individual tracks
   else
      if $createcue then
         send("!as{DOWN 2}{ENTER}")
            sleep(500)
         wend
      endif
   ; Rip tracks
      opt("WinTitleMatchMode", 2)
      if $testandcopy then
         send("+{F6}")
      else
         send("+{F5}")
      endif
   endif
; Wait for ripping to complete
   winwait("Extracting Audio Data", "", 5)
   if $ripimage then
      local $button = 2
      dircreate($ripdir)
   else
      local $button = 3
   endif
   while controlgettext("Extracting Audio Data", '', 'Button' & $button) == "Cancel"
      if $lowpriority then
         if processexists("flac.exe") then processsetpriority("flac.exe", 0)
      endif
      sleep(500)
   wend
; Check status for erros
   controlclick("Extracting Audio Data", '', 'Button' & $button)
   sleep(200)
   winactivate("Status and Error Messages")
   sleep(200)
   dim $i, $track, $past
   while 1
      controlcommand("Status and Error Messages", '', 'ListBox1', 'SetCurrentSelection', $i)
      $line = controlcommand("Status and Error Messages", '', 'ListBox1', 'GetCurrentSelection')
      if stringleft($line, 5) == "Track" then
         $track = stringtrimleft($line, stringinstr($line, " ", 0, -1))
      endif
      if stringinstr($line, "Suspicious") then
         if $track <> $past then
            $warning &= $track & ", "
            $past = $track
         endif
      endif
      $i = $i + 1
   wend
   controlclick("Status and Error Messages", '', 'Button1')
; Update cue sheet for compressed tracks
   if $createcue then
      if $ripimage then
         $old = fileopen($outputdir & "\" & $artist & " - " & $album & " (AutoFLAC).cue", 0)
         $new = fileopen($ripdir & "\" & $imgname & $metapost & ".cue", 2)
      else
         $old = fileopen($outputdir & "\" & $album & ".cue", 0)
         $new = fileopen($ripdir & "\" & $metapre & $album & ".cue", 2)
      endif
      $line = filereadline($old)
      do
         if stringleft($line, 5) == "TITLE" then
            $line = 'TITLE "' & $album & $metapost & '"'
         elseif stringinstr($line, "FILE ", 1) AND NOT $ripimage then
            $temp = stringtrimleft($line, stringinstr($line, '\', 0, -1))
; CHANGE: Allow naming schemes that do not contain a dash by using a hardcoded track number length of 2 characters.
; ORIGNAL
;            $tracknum = stringleft($temp, stringinstr($temp, '-')-1)
; ORIGINAL END
; CHANGED
            $tracknum = stringleft($temp, 2)
; CHANGED END
            $temp = stringleft($temp, stringinstr($temp, '.', 0, -1)-1)
            $trackname = stringtrimleft($temp, stringlen($tracknum)+1)
            if $multidisc then $tracknum = $discnum & $tracknum
; ORIGNAL
;            $line = 'FILE "' & $tracknum & '-' & $trackname & '.flac" WAVE'
; ORIGINAL END
; CHANGED
            $line = 'FILE "' & $tracknum & ' ' & $trackname & '.flac" WAVE'
; CHANGED END
         elseif stringinstr($line, "FILE ", 1) AND $ripimage then
            $line = 'FILE "' & $imgname & $metapost & '.flac" WAVE'
         endif
         filewriteline($new, $line)
      until @error
      fileclose($new)
      fileclose($old)
      if $ripimage then
         filerecycle($outputdir & "\" & $artist & " - " & $album & " (AutoFLAC).cue")
      else
         filerecycle($outputdir & "\" & $album & ".cue")
      endif
   endif
; Process log file
   if $createlog then
; CHANGE: Fixes a bug: Newer versions of EAC store the log file in the rip directory with a different file name.
; ORIGNAL
;      if $ripimage then
;         filemove($outputdir & "\" & $album & ".log", $ripdir & "\" & $imgname & $metapost & ".log", 1)
;      else
;         filemove($outputdir & "\" & $album & ".log", $ripdir & "\" & $metapre & $album & $metapost & ".log", 1)
; ORIGINAL END
; CHANGED
      if $ripimage then
         filemove($ripdir & "\" & $artist & " - " & $album & ".log", $ripdir & "\" & $imgname & $metapost & ".log", 1)
      else
         filemove($ripdir & "\" & $artist & " - " & $album & ".log", $ripdir & "\" & $metapre & $album & $metapost & ".log", 1)
; CHANGED END
; CHANGE: Checks only the last status report If you have multiple reports in one log file.
; ORIGNAL
;      ; Check for Test and Copy errors
;         if $testandcopy then
;            dim $track, $testcrc, $copycrc
;            $infile = fileopen($ripdir & '\' & $metapre & $album & $metapost & '.log', 0)
;            do
;            ; Compare Test and Copy CRCs; flag if mismatch found
;               if stringleft($line, 5) = "Track" then
;                  $track = stringtrimleft($line, stringinstr($line, ' ', 0, -1))
;               endif
;               if stringinstr($line, "Test CRC") then
;                  $testcrc = stringtrimleft($line, stringinstr($line, ' ', 0, -1))
;               endif
;               if stringinstr($line, "Copy CRC") then
;                  $copycrc = stringtrimleft($line, stringinstr($line, ' ', 0, -1))
;                  if $copycrc <> $testcrc then $tcwarning &= $track & ", "
;               endif
;            until @error
;         endif
; ORIGINAL END
; CHANGED
            do
            ; If the beginning of a new status report is encountered, clear previous warnings.
               if stringleft($line, 5) = "-----" then
                  $tcwarning = ""
               endif
               endif
               endif
               endif
            until @error
            fileclose($infile)
         endif
; CHANGED END
      endif
   else
      filerecycle($outputdir & "\" & $album & ".log")
   endif
; Wait for track compression to complete
   while processexists("flac.exe")
      sleep(1000)
         if $lowpriority then processsetpriority("flac.exe", 0)
      else
         sleep(4000)
      endif
   wend
; Move image to correct directory, fix tags, and import cuesheet
   if $ripimage then
      filemove($outputdir & '\' & $artist & ' - ' & $album & ' (AutoFLAC).wav.flac', $ripdir & '\' & $imgname & $metapost & '.flac')
      runwait('"' & $metaflac & '" --remove-tag=TITLE --remove-tag=TRACKNUMBER "' & $ripdir & '\' & $imgname & $metapost & '.flac"', $ripdir, @SW_HIDE)
      if $multidisc then
         runwait('"' & $metaflac & '" --set-tag="DISCNUMBER=' & $discnum & '" "' & $ripdir & '\' & $imgname & $metapost & '.flac"', $ripdir, @SW_HIDE)
      endif
      if $embedcue then
         $infile = fileopen($ripdir & '\' & $imgname & $metapost & '.cue', 0)
         $tag = '"CUESHEET='
         do
            if stringleft($line, 4) <> "REM " then
               $line = stringreplace($line, '"', "'")
               if stringleft($line, 5) = "FILE " then
                  $line = "FILE 'DUMMY' WAVE"
               endif
               $tag &= $line & @CRLF
            endif
         until @error
         fileclose($infile)
         $tag = stringtrimright($tag, 2) & $line & '"'
         runwait('"' & $metaflac & '" --set-tag=' & $tag & ' "' & $ripdir & '\' & $imgname & $metapost & '.flac"', $ripdir, @SW_HIDE)
         runwait('"' & $metaflac & '" --import-cuesheet-from="' & $ripdir & '\' & $imgname & $metapost & '.cue" "' & $ripdir & '\' & $imgname & $metapost & '.flac"', $ripdir, @SW_HIDE)
         if $deletecue then
            filerecycle($ripdir & '\' & $imgname & $metapost & '.cue')
         endif
      endif
   endif
; Update tracknumbers
   if $multidisc AND NOT $ripimage then
      $files = filefindfirstfile($ripdir & "\*.flac")
      $file = filefindnextfile($files)
      do
         if stringlen(stringleft($file, stringinstr($file, '-')-1)) == 2 then
            $tracknum = stringleft($file, stringinstr($file, "-")-1)
            runwait('"' & $metaflac & '" --remove-first-tag=TRACKNUMBER --set-tag=TRACKNUMBER=' & $discnum & $tracknum & ' --set-tag=DISCNUMBER=' & $discnum & ' "' & $ripdir & '\' & $file & '"', $ripdir, @SW_HIDE)
            filemove($ripdir & '\' & $file, $ripdir & '\' & $discnum & $file, 1)
         endif
      until @error
      fileclose($files)
   endif
; Add ReplayGain data
   if $replaygain then
      $list = ''
      do
         if NOT ($multidisc AND $indiv_replaygain) OR (stringisint(stringleft($file, 3)) AND stringleft($file, 1) == $discnum) then
            $list &= '"' & $file & '" '
         endif
      until @error
      fileclose($files)
   ;filewriteline('"' & $metaflac & '" --add-replay-gain ' & $list);debug
   ;fileclose($debug);debug
      $pid = run('"' & $metaflac & '" --add-replay-gain ' & $list, $ripdir, @SW_HIDE)
      if $lowpriority then processsetpriority($pid, 0)
   endif
; Add MD5 checksums
;if $checksums then
;   if $replaygain then processwaitclose('metaflac.exe')
;   runwait(@comspec & ' /c ' & filegetshortname($md5sum) & ' -b *.flac >"' & $metapre & $album & '.md5"', $ripdir, @SW_HIDE)
;endif
; Copy data
   if $copydata then
      local $datatrack = 0
   ; first check - EAC track list
      $items = controllistview($eactitle, '', 'SysListView321', "GetItemCount")
      $firsttrack = controllistview($eactitle, '', 'SysListView321', "GetText", 0, 0)
      if stringleft($firsttrack, 4) = "DATA" then $datatrack = 1
      $lasttrack = controllistview($eactitle, '', 'SysListView321', "GetText", $items - 1, 0)
      if stringleft($lasttrack, 4) = "DATA" then $datatrack = 1
   ; second check - CUE sheet
      if $ripimage then
         $infile = fileopen($ripdir & "\" & $imgname & $metapost & ".cue", 0)
      else
         $infile = fileopen($ripdir & "\" & $metapre & $album & ".cue", 0)
      endif
      do
         if stringinstr($line, "TRACK", 1) AND stringinstr($line, "MODE", 1) then $datatrack = 1
      until @error
      fileclose($infile)
   ; Copy data if available
      if $datatrack then
         $copyfailed = 0
         processclose("eac.exe")
         cdtray($cdromdrive, "open")
         sleep(1000)
         cdtray($cdromdrive, "closed")
         sleep(1000)
         dircreate($ripdir & "\Data" & $metapost)
         dircopy($cdromdrive, $ripdir & "\Data" & $metapost, 1)
         if dirgetsize($cdromdrive) <> dirgetsize($ripdir & "\Data" & $metapost) then $copyfailed = 1
         run($eac)
         winwait($eactitle)
         if $copyfailed then
            msgbox(48, $title, "Error: Not all data files were copied." & @CRLF & "One or more files could not be read from the CD.")
         endif
      endif
   endif
; Notify that extraction is complete
   if $notifycomplete then
      if fileexists($notifywav) then
         soundplay($notifywav)
      else
         soundplay(@windowsdir & "\media\" & $notifywav)
      endif
   endif
; Eject the disc
   if $ejectcomplete then
   endif
; Prompt to extract next CD
   if $warning OR $tcwarning then
      dim $message
      if $warning then
         $message = "EAC detected possible errors in track(s): " & $warning & @CRLF & @CRLF
      endif
      if $tcwarning then
         $tcwarning = stringtrimright($tcwarning, 2)
         $message &= "Test and Copy CRCs revealed possible errors in track(s): " & $tcwarning & @CRLF & @CRLF
      endif
      $prompt = msgbox(49, $title, $message & "Click OK to extract another CD, or Cancel to manually validate and repair the errors.")
   else
      $prompt = msgbox(33, $title, "Extraction complete with 0 detected errors." & @CRLF & @CRLF & "Would you like to extract another CD?")
   endif
      return 0
   else
      return 1
   endif
endfunc
; Function to display write options prompt
func WriteSetup()
; Create GUI
   ReadPrefs()
   GUICreate($title, 355, 175)
; AutoFLAC Write options
; CUE sheet selection
   GUICtrlCreateGroup("CUE Sheet Selection", 5, 5, 345, 45)
   local $cuesheet = GUICtrlCreateInput($cuefile, 10, 25, 305, 20)
   GUICtrlSetTip(-1, "The CUE sheet for the album that " & $name & " will burn")
   local $cuebut = GUICtrlCreateButton("...", 320, 25, 25, 20)
; Directory Options
   GUICtrlCreateGroup("Directory Options", 5, 55, 160, 85)
   local $tempalbum = GUICtrlCreateRadio("Use &Album dir for temp files", 10, 75, -1, 20)
   GUICtrlSetTip(-1, "Decompress files to Album dirwhen preparing for writing")
   local $tempspec = GUICtrlCreateRadio("Specify &temporary directory", 10, 95, -1, 20)
   GUICtrlSetTip(-1, "Specify which directory to use for decompressed files")
   local $tempdir = GUICtrlCreateInput($writetempdir, 30, 115, 100, 20)
   local $tempbut = GUICtrlCreateButton("...", 135, 115, 25, 20)
   GUICtrlSetTip(-1, "The directory to use for decompressed files")
   GUICtrlCreateGroup("", -99, -99, 1, 1)
; Binary Options
   GUICtrlCreateGroup("Binary Options", 170, 55, 180, 45)
   GUICtrlCreateLabel("&Flac:", 175, 77, 25, 15, $SS_RIGHT)
   local $flacbin = GUICtrlCreateInput($flac, 205, 75, 110, 20)
   GUICtrlSetTip(-1, "Location of flac.exe")
   local $flacbut = GUICtrlCreateButton("...", 320, 75, 25, 20)
; Buttons
   local $ok = GUICtrlCreateButton("&OK", 85, 150, 80, 20)
   local $cancel = GUICtrlCreateButton("Cancel", 190, 150, 80, 20)
; Set properties
   if $writetemptype = 'specify' then
      GUICtrlSetState($tempspec, $GUI_CHECKED)
   else
      GUICtrlSetState($tempalbum, $GUI_CHECKED)
      GUICtrlSetState($tempdir, $GUI_DISABLE)
      GUICtrlSetState($tempbut, $GUI_DISABLE)
   endif
   GUICtrlSetState($ok, $GUI_DEFBUTTON)
; Display GUI and wait for action
   GUISetState(@SW_SHOW)
   while 1
      $action = GUIGetMsg()
      select
      ; Enable tempdir field if specify directory option selected
         case $action == $tempspec
            GUICtrlSetState($tempdir, $GUI_ENABLE)
            GUICtrlSetState($tempbut, $GUI_ENABLE)
         case $action == $tempalbum
      ; Process flac binary selection
         case $action == $cuebut
            $file = fileopendialog("Select cuesheet", "", "CUE file (*.cue)", 1)
            if not @error then GUICtrlSetData($cuesheet, $file)
            GUICtrlSetState($cuesheet, $GUI_FOCUS)
      ; Process tempdir selection
         case $action == $tempbut
            $dir = fileselectfolder("Select directory", "", 7, GUICtrlRead($basedir))
            if not @error then GUICtrlSetData($tempdir, $dir)
            GUICtrlSetState($tempdir, $GUI_FOCUS)
         case $action == $flacbut
            $file = fileopendialog("Select file", "", "EXE file (*.exe)", 1)
            if not @error then GUICtrlSetData($flacbin, $file)
            GUICtrlSetState($flacbin, $GUI_FOCUS)
      ; Begin processing options
         case $action == $ok
         ; Validate cuesheet extension
            if NOT fileexists(GUICtrlRead($cuesheet)) OR stringright(GUICtrlRead($cuesheet), 3) <> "cue" then
               msgbox(48, $title, "Error: You must select a valid CUE sheet to write.")
               continueloop
            else
               $cuefile = GUICtrlRead($cuesheet)
            endif
         ; Validate tempdir
            if NOT fileexists(GUICtrlRead($tempdir)) then
               msgbox(48, $title, "Error: You must select a valid temporary directory for writing.")
               continueloop
            endif
         ; Validate flac binary
            if NOT fileexists(GUICtrlRead($flacbin)) AND NOT SearchPath(GUICtrlRead($flacbin)) then
               msgbox(48, $title, "Error: You must select the flac binary to use for decoding.")
               continueloop
            endif
         ; Update global variables
            if GUICtrlRead($tempalbum) == $GUI_CHECKED then
            elseif GUICtrlRead($tempspec) == $GUI_CHECKED then
               $writetempdir = GUICtrlRead($tempdir)
            endif
            $flac = GUICtrlRead($flacbin)
         ; Save preferences and begin extraction
            SavePrefs()
            GUIDelete()
            return
      ; Exit if Cancel clicked or window closed
         case $action == $GUI_EVENT_CLOSE OR $action == $cancel
            exit
      endselect
   wend
endfunc
; Function to display extraction method prompt
func ExtractSetup()
   local $options = "You may use the following parameters to customize your output directory and filename."
   $options &= @CRLF & "Anything not included in the following list of options will be treated as static text."
   $options &= @CRLF & @CRLF & "%D/%A" & @TAB & "Album Artist"
   $options &= @CRLF & "%C" & @TAB & "Album Title"
   $options &= @CRLF & "%Y" & @TAB & "Album Year"
   $options &= @CRLF & "%I" & @TAB & "Album Genre"
   $options &= @CRLF & "%B" & @TAB & "FreeDB Category"
; Create GUI
   ReadPrefs()
   GUICreate($title, 445, 370)
   GUICtrlCreateLabel("Please make any changes you would like to the CD information before continuing.", 5, 5, -1, 20)
   GUICtrlCreateLabel("If you would like to extract individual tracks rather than the entire album,", 5, 20, -1, 20)
   GUICtrlCreateLabel("select each individual track in EAC, then select ""Individual Tracks"" below.", 5, 35, -1, 20)
   GUICtrlCreateLabel("Click OK when you are ready to begin extraction.", 5, 55, -1, 20)
; Extract options
   GUICtrlCreateGroup("Extract Options", 5, 80, 125, 145)
   local $sel = GUICtrlCreateRadio("&Individual Tracks", 10, 100, -1, 20)
   GUICtrlSetTip(-1, "Only rip tracks currently selected in EAC")
   local $all = GUICtrlCreateRadio("&All Tracks", 10, 120, -1, 20)
   GUICtrlSetTip(-1, "Rip all tracks from the CD")
   local $image = GUICtrlCreateCheckBox("Rip to &image", 30, 140, -1, 20)
   GUICtrlSetTip(-1, "Rip album to single image file rather than individual tracks")
   local $cue = GUICtrlCreateCheckBox("Create &cue sheet", 10, 160, -1, 20)
   GUICtrlSetTip(-1, "Create a CUE sheet for the CD, which can be used to burn a duplicate backup copy")
   local $store = GUICtrlCreateCheckBox("&Embed in image", 30, 180, 95, 20)
   GUICtrlSetTip(-1, "Embed cue sheet in album image rather than saving separately")
   local $delcue = GUICtrlCreateCheckBox("Delete e&xt cue", 30, 200, -1, 20)
   GUICtrlSetTip(-1, "Delete the external cue sheet after embedding")
; Disc options
   GUICtrlCreateGroup("Disc Options", 145, 80, 130, 165)
   local $log = GUICtrlCreateCheckBox("Write &log file", 150, 100, -1, 20)
   GUICtrlSetTip(-1, "Save EAC's ripping output to a logfile")
   local $test = GUICtrlCreateCheckBox("T&est and Copy", 170, 120, -1, 20)
   GUICtrlSetTip(-1, "Rip using EAC's ""Test and Copy"" mode")
   local $data = GUICtrlCreateCheckBox("Copy &data files", 150, 140, -1, 20)
   GUICtrlSetTip(-1, "If the CD is a multi-session disc with a ""data track""," & @CRLF & "copy all data files after ripping the CD")
   local $gain = GUICtrlCreateCheckBox("Enable &ReplayGain", 150, 160, -1, 20)
   GUICtrlSetTip(-1, "Calculates and stores the Track and Album ReplayGain values")
   local $multi = GUICtrlCreateCheckBox("&Multi-disc set", 150, 180, -1, 20)
   GUICtrlSetTip(-1, "If the CD is part of a multi-disc set, this option will instruct" & @CRLF & $name & " to renumber/retag the ripped files to the format Nxx" & @CRLF & "where N is the Disc number and xx is the track number")
   GUICtrlCreateLabel("Disc", 170, 202, -1, 15)
   local $disc = GUICtrlCreateInput("", 195, 200, 15, 20)
   GUICtrlSetTip(-1, "Specifies the current disc number in a multi-disc set")
   GUICtrlCreateLabel("of the set", 215, 202, -1, 15)
   local $indiv = GUICtrlCreateCheckBox("Indiv Replay&Gain", 170, 220, 103, 20)
   GUICtrlSetTip(-1, "Calculates ReplayGain for each album of a multi-disc set individually")
;local $verify = GUICtrlCreateCheckBox("Write c&hecksums", 280, 100, 110, 20)
;GUICtrlSetTip(-1, "Calculates and stores the MD5 checksums for each track;" & @CRLF & "Can be used to verify track integrity before creating backup copy")
; Rip options
   GUICtrlCreateGroup($name & " Rip Options", 290, 80, 150, 145)
   GUICtrlCreateLabel("Use Encoder: ", 295, 101, -1, 15)
   local $enc = GUICtrlCreateCombo("", 365, 97, 70, 20, $CBS_DROPDOWNLIST)
   GUICtrlSetTip(-1, "Specifies the encoder to be used by AutoFLAC")
   GUICtrlCreateLabel("Use CD-ROM drive:", 295, 123, -1, 15)
   local $cdrom = GUICtrlCreateCombo("", 400, 119, 35, 20, $CBS_DROPDOWNLIST)
   GUICtrlSetTip(-1, "Specifies the CD-ROM drive from which " & $name & "will copy data;" & @CRLF & "This option should match the drive used by EAC")
   local $priority = GUICtrlCreateCheckBox("Low &priority encoding", 295, 140, -1, 20)
   GUICtrlSetTip(-1, "Set flac and metaflac to run with low system priority")
   local $eject = GUICtrlCreateCheckBox("E&ject on complete", 295, 160, -1, 20)
   GUICtrlSetTip(-1, "Ejects the disc after ripping process is complete")
   local $notify = GUICtrlCreateCheckBox("&Notify on complete", 295, 180, -1, 20)
   GUICtrlSetTip(-1, "Plays a WAVE file after ripping process is complete")
   local $wave = GUICtrlCreateInput($notifywav, 315, 200, 90, 20)
   GUICtrlSetTip(-1, "The WAVE file that should be played after ripping process is complete")
   local $wavebut = GUICtrlCreateButton("...", 410, 200, 25, 20)
; Output Options
   GUICtrlCreateGroup("Output Options", 5, 250, 230, 85)
   GUICtrlCreateLabel("&Base directory:", 10, 272, 75, 15, $SS_RIGHT)
   local $basedir = GUICtrlCreateInput($outputdir, 90, 270, 110, 20)
   GUICtrlSetTip(-1, "All tracks will be ripped to this root directory" & @CRLF & "in the format Base\Genre\Artist\Album\")
   local $basebut = GUICtrlCreateButton("...", 205, 270, 25, 20)
   GUICtrlCreateLabel("Name &scheme:", 10, 292, 75, 15, $SS_RIGHT)
   local $sepschemefield = GUICtrlCreateInput($sepscheme, 90, 290, 110, 20)
   GUICtrlSetTip(-1, "Directory naming scheme for ripped tracks;" & @CRLF & "This must match the naming scheme used by EAC")
   local $sepschemebut = GUICtrlCreateButton("?", 205, 290, 25, 20)
   GUICtrlCreateLabel("Image sc&heme:", 10, 312, 75, 15, $SS_RIGHT)
   local $imgschemefield = GUICtrlCreateInput($imgscheme, 90, 310, 110, 20)
   GUICtrlSetTip(-1, "Directory and file naming scheme for ripped images")
   local $imgschemebut = GUICtrlCreateButton("?", 205, 310, 25, 20)
; Binary Options
   GUICtrlCreateGroup("Binary Options", 240, 250, 200, 65)
   GUICtrlCreateLabel("&Flac:", 245, 272, 45, 15, $SS_RIGHT)
   local $flacbin = GUICtrlCreateInput($flac, 295, 270, 110, 20)
   local $flacbut = GUICtrlCreateButton("...", 410, 270, 25, 20)
   GUICtrlCreateLabel("Me&taflac:", 245, 292, 45, 15, $SS_RIGHT)
   local $metaflacbin = GUICtrlCreateInput($metaflac, 295, 290, 110, 20)
   GUICtrlSetTip(-1, "Location of metaflac.exe")
   local $metaflacbut = GUICtrlCreateButton("...", 410, 290, 25, 20)
;GUICtrlCreateLabel("MD5sum binary:", 10, 292, 80, 15, $SS_RIGHT)
;local $md5bin = GUICtrlCreateInput($md5sum, 95, 290, 100, 20)
;GUICtrlSetTip(-1, "Location of md5sum.exe")
;local $md5but = GUICtrlCreateButton("...", 200, 290, 25, 20)
; Buttons
   local $ok = GUICtrlCreateButton("&OK", 130, 345, 80, 20)
   local $cancel = GUICtrlCreateButton("Cancel", 235, 345, 80, 20)
; Set properties
   if $extractmethod == 'all' then
      GUICtrlSetState($all, $GUI_CHECKED)
   elseif $extractmethod == 'sel' then
      GUICtrlSetState($sel, $GUI_CHECKED)
      GUICtrlSetState($image, $GUI_DISABLE)
      GUICtrlSetState($cue, $GUI_DISABLE)
      GUICtrlSetState($store, $GUI_DISABLE)
      GUICtrlSetState($delcue, $GUI_DISABLE)
   endif
   if $ripimage then
      GUICtrlSetState($image, $GUI_CHECKED)
   else
   endif
   if $createcue then
      GUICtrlSetState($cue, $GUI_CHECKED)
   else
   endif
   if $embedcue then
      GUICtrlSetState($store, $GUI_CHECKED)
      if $deletecue then GUICtrlSetState($delcue, $GUI_CHECKED)
   else
   endif
   GUICtrlSetData($enc, 'FLAC', $outputenc)
   if $createlog then
      GUICtrlSetState($log, $GUI_CHECKED)
      GUICtrlSetState($test, $GUI_ENABLE)
   else
      GUICtrlSetState($log, $GUI_UNCHECKED)
      GUICtrlSetState($test, $GUI_DISABLE)
   endif
   if $testandcopy then GUICtrlSetState($test, $GUI_CHECKED)
   if $replaygain then GUICtrlSetState($gain, $GUI_CHECKED)
   if $copydata then GUICtrlSetState($data, $GUI_CHECKED)
   if $multidisc then
      GUICtrlSetState($multi, $GUI_CHECKED)
      GUICtrlSetData($disc, $discnum)
   else
      GUICtrlSetState($disc, $GUI_DISABLE)
      GUICtrlSetState($indiv, $GUI_DISABLE)
   endif
   if $indiv_replaygain then GUICtrlSetState($indiv, $GUI_CHECKED)
;if $checksums then GUICtrlSetState($verify, $GUI_CHECKED)
   if stringinstr(GetCDROMs(), $cdromdrive, 0) then
      GUICtrlSetData($cdrom, GetCDROMs(), $cdromdrive)
   else
      GUICtrlSetData($cdrom, GetCDROMs(), stringleft(GetCDROMs(), stringinstr(GetCDROMs(), '|')-1))
   endif
   if $lowpriority then GUICtrlSetState($priority, $GUI_CHECKED)
   if $ejectcomplete then GUICtrlSetState($eject, $GUI_CHECKED)
      GUICtrlSetState($notify, $GUI_CHECKED)
   else
      GUICtrlSetState($wave, $GUI_DISABLE)
      GUICtrlSetState($wavebut, $GUI_DISABLE)
   endif
   while 1
      select
      ; Enable/Disable cue sheet creation depending on track selection
         case $action == $all
            GUICtrlSetState($image, $GUI_ENABLE)
            GUICtrlSetState($cue, $GUI_ENABLE)
            if GUICtrlRead($cue) == $GUI_CHECKED AND GUICtrlRead($image) == $GUI_CHECKED then
               GUICtrlSetState($store, $GUI_ENABLE)
               if GUICtrlRead($store) == $GUI_CHECKED then GUICtrlSetState($delcue, $GUI_ENABLE)
            endif
         case $action == $sel
            GUICtrlSetState($cue, $GUI_UNCHECKED)
      ; Enable/Disable embedded cue options
         case $action == $cue OR $action == $image OR $action == $store
               else
               endif
            else
            endif
      ; Enable Test and Copy if createlog is checked
         case $action == $log
            if GUICtrlRead($log) == $GUI_CHECKED then
            else
            endif
      ; Enable Disc field if Multi-disc option checked
         case $action == $multi OR $action == $gain
            if GUICtrlRead($multi) == $GUI_CHECKED then
               GUICtrlSetState($disc, $GUI_ENABLE)
               GUICtrlSetState($disc, $GUI_FOCUS)
               if GUICtrlRead($gain) == $GUI_CHECKED then
                  GUICtrlSetState($indiv, $GUI_ENABLE)
               else
               endif
            else
            endif
      ; Enable Wave field if notify option checked
         case $action == $notify
            if GUICtrlRead($notify) == $GUI_CHECKED then
               GUICtrlSetState($wave, $GUI_ENABLE)
               GUICtrlSetState($wavebut, $GUI_ENABLE)
            else
            endif
      ; Process output dir selection
         case $action == $basebut
            if not @error then GUICtrlSetData($basedir, $dir)
            GUICtrlSetState($basedir, $GUI_FOCUS)
      ; Process directory naming scheme selection
         case $action == $sepschemebut
            local $message = "The ""Output scheme"" field sets the directory structure for ripped tracks."
            $message &= @CRLF & "This directory structure will be created below the ""Output base"", and is"
            $message &= @CRLF & "modelled after EAC's variable naming scheme.  Unlike EAC, however,"
            $message &= @CRLF & "you should only specify the directory structure, excluding file names."
            $message &= @CRLF & @CRLF & "The default scheme is ""%I\%A\%C"", which translates to ""Genre\Artist\Album."""
            $message &= @CRLF & @CRLF & "Note: This MUST match EAC's naming scheme, minus the filename portion."
            $message &= @CRLF & @CRLF & $options
            msgbox(64, $title, $message)
            GUICtrlSetState($sepschemefield, $GUI_FOCUS)
      ; Process image naming scheme selection
         case $action == $imgschemebut
            local $message = "The ""Image scheme"" field is used instead of ""Output scheme"" when ripping to an image."
            $message &= @CRLF & "The same options are available, but this field requires that the filename be set as well."
            $message &= @CRLF & @CRLF & "The default image scheme is ""%A - %C"", which translates to ""Artist - Album."""
            GUICtrlSetState($imgschemefield, $GUI_FOCUS)
      ; Process metaflac binary selection
         case $action == $metaflacbut
            if not @error then GUICtrlSetData($metaflacbin, $file)
            GUICtrlSetState($metaflacbin, $GUI_FOCUS)
      ; Process md5sum binary selection
      ;case $action == $md5but
      ;   $file = fileopendialog("Select file", "", "EXE file (*.exe)", 1)
      ;   if not @error then GUICtrlSetData($md5bin, $file)
      ; Process wave file selection
         case $action == $wavebut
            $file = fileopendialog("Select file", @windowsdir & "\media", "Wave file (*.wav)", 1)
            if not @error then GUICtrlSetData($wave, $file)
            GUICtrlSetState($wave, $GUI_FOCUS)
         case $action == $ok
         ; Validate output dir
            if NOT fileexists(GUICtrlRead($basedir)) then
               msgbox(48, $title, "Error: You must select a valid output base directory.")
               continueloop
            endif
               msgbox(48, $title, "Error: You must select the flac binary to use for encoding.")
               continueloop
            endif
         ; Validate metaflac binary
            if NOT fileexists(GUICtrlRead($metaflacbin)) AND NOT SearchPath(GUICtrlRead($metaflacbin)) then
               msgbox(48, $title, "Error: You must select the metaflac binary to use for encoding.")
               continueloop
            endif
         ; Validate md5sum binary
         ;if NOT fileexists(GUICtrlRead($md5bin)) AND NOT SearchPath(GUICtrlRead($md5bin)) then
         ;   msgbox(48, $title, "Error: You must select the md5sum binary to use for encoding.")
         ;   GUICtrlSetState($md5bin, $GUI_FOCUS)
         ;   continueloop
         ;endif
         ; Validate wave file
            if GUICtrlRead($notify) == $GUI_CHECKED AND NOT fileexists(GUICtrlRead($wave)) AND NOT fileexists(@windowsdir & "\media\" & GUICtrlRead($wave)) then
               msgbox(48, $title, "Error: You must select the wave file to use for notification.")
               continueloop
            endif
         ; Validate disc input
            if GUICtrlRead($multi) == $GUI_CHECKED AND NOT stringisint(GUICtrlRead($disc)) then
               msgbox(48, $title, "Error: You must enter the disc number.")
               continueloop
            endif
            $outputdir = GUICtrlRead($basedir)
            $sepscheme = GUICtrlRead($sepschemefield)
            $imgscheme = GUICtrlRead($imgschemefield)
            $metaflac = GUICtrlRead($metaflacbin)
         ;$md5sum = GUICtrlRead($md5bin)
            $cdromdrive = GUICtrlRead($cdrom)
            if GUICtrlRead($priority) == $GUI_CHECKED then
               $lowpriority = 1
            else
               $lowpriority = 0
            endif
            if GUICtrlRead($eject) == $GUI_CHECKED then
               $ejectcomplete = 1
            else
               $ejectcomplete = 0
            endif
               $notifycomplete = 1
               $notifywav = GUICtrlRead($wave)
            else
               $notifycomplete = 0
            endif
               $createlog = 1
            else
               $createlog = 0
            endif
            if GUICtrlRead($test) == $GUI_CHECKED then
               $testandcopy = 1
            else
               $testandcopy = 0
            endif
               $replaygain = 1
            else
               $replaygain = 0
            endif
            if GUICtrlRead($data) == $GUI_CHECKED then
               $copydata = 1
            else
               $copydata = 0
            endif
               $multidisc = 1
               $discnum = GUICtrlRead($disc)
               if GUICtrlRead($indiv) == $GUI_CHECKED then
               else
                  $indiv_replaygain = 0
               endif
            else
               $multidisc = 0
            endif
         ;if GUICtrlRead($verify) == $GUI_CHECKED then
         ;   $checksums = 1
         ;else
         ;   $checksums = 0
         ;endif
            if GUICtrlRead($all) == $GUI_CHECKED then
            else
               $extractmethod = 'sel'
            endif
            if GUICtrlRead($image) == $GUI_CHECKED AND $extractmethod == 'all' then
               $ripimage = 1
            else
               $ripimage = 0
            endif
            if GUICtrlRead($cue) == $GUI_CHECKED AND $extractmethod == 'all' then
               $createcue = 1
            else
               $createcue = 0
            endif
            if GUICtrlRead($store) == $GUI_CHECKED AND $ripimage AND $createcue then
               $embedcue = 1
            else
               $embedcue = 0
            endif
            if GUICtrlRead($delcue) == $GUI_CHECKED AND $ripimage AND $createcue then
               $deletecue = 1
            else
               $deletecue = 0
            endif
            SavePrefs()
            GUIDelete()
            return
            exit
      endselect
   wend
endfunc
; Function to read AutoFLAC preferences
func ReadPrefs()
   $value = regread($regprefs, "extractmethod")
   if $value <> '' then $extractmethod = $value
   $value = regread($regprefs, "ripimage")
   if $value <> '' then $ripimage = int($value)
   $value = regread($regprefs, "createcue")
   if $value <> '' then $createcue = int($value)
   $value = regread($regprefs, "embedcue")
   if $value <> '' then $embedcue = int($value)
   $value = regread($regprefs, "deletecue")
   if $value <> '' then $deletecue = int($value)
   $value = regread($regprefs, "createlog")
   if $value <> '' then $createlog = int($value)
   $value = regread($regprefs, "testandcopy")
   if $value <> '' then $testandcopy = int($value)
   $value = regread($regprefs, "replaygain")
   if $value <> '' then $replaygain = int($value)
   $value = regread($regprefs, "indiv_replaygain")
   if $value <> '' then $indiv_replaygain = int($value)
   $value = regread($regprefs, "copydata")
   if $value <> '' then $copydata = int($value)
;$value = regread($regprefs, "checksums")
;if $value <> '' then $checksums = int($value)
   $value = regread($regprefs, "outputdir")
   if $value <> '' then $outputdir = $value
   $value = regread($regprefs, "sepscheme")
   if $value <> '' then $sepscheme = $value
   $value = regread($regprefs, "imgscheme")
   if $
AutoFLAC
Reply #303
I've been using Autoflac for ripping for some time, but have just started to use it for writing, and I'm having the same problem I've seen earlier in this forum. I drop a cue sheet file onto the Autoflac icon, follow the prompts, and it indicates that it is writing the WAV files. However, this finishes almost instantaneously, so in fact the WAV files are not created, though the temporary directory and modified cue sheet are. EAC is started, but gives the error "Error in CUE sheet! File does not exixt in line 7", because of course it does not exist.
For the earlier report of this problem, the fix seemed to be to install the 1.2 version of Autoflac. Though I figured that's what I was already using, I downloaded and installed again (did not de-install first), and Autoflac wrote the CD exactly as expected! Problem solved, I figured, and went on to write more CD's. Unfortunately, the same error was now back, and has been since. Given the sequence of events, I thought maybe some temporary file was deleted during the installation, and this allowed things to work until it was written again (after writing the first CD), but I couldn't find anything along those lines.
Any ideas on this?
AutoFLAC
Reply #304
The only time I've received an error like that is when the file names in the cue don't match the actual files.  In other words, the CUE tells AutoFlac to convert a file that doesn't exist.
AutoFLAC
Reply #305
I failed to mention, most likely there is a path statement in the cue file that doesn't match the path on your computer.  For example, if the cue says something like this:
FILE "c:\EAC\01 - You're Gonna Miss Me.wav" WAVE
...and your files are not in C:\EAC\ but another folder, they will not me converted.  If the cue file was built by AutoFlac, then there is something wrong with your naming schemes.  You probably didn't set up the default save folder correctly in either the AutoFlac or EAC options.
You must edit each line to replace FILE "c:\EAC\ with FILE ", removing c:\EAC\for each track, or if its an image rip, then you'll only need to edit it once.
AutoFLAC
Reply #306
It works fine with v0.99.  I've been using it for a couple of months now.  I may have stated earlier that it does not, but that was incorrect.
hi
installed autoflac so i could click on cue sheets that come with flac files and get straight to the EAC write page.
however, when i use it in write mode, it 'prepares files for writing' but then stops at that, EAC doesn't start up.
Also, the regular mode of AutoFLAC won't work at all - I get a thousand windows come up and have to log off and back on again!!! Aaarghhh!
Where have I got it all wrong?
could it be something to do with where I've got the EAC/AutoFLAC/FLAC folders? or there versions not liking each other?
I'm running Vista 32.
any help much appreciated.
AutoFLAC
Reply #307
Hi! I'm new at the forum, and my english is not quite good, but I'll try my best, hehehe
I'm a music lover -so into 90's music- but also loving classical music and jazz. I recently discovered that the FLAC format is, among the universe of music formats, one of the best (if not the best!).
So started to buy, and download from internet some players and rippers, and I found this Exact Audio Copy program which is now my favorite since I discovered how to rip my CDs into the FLAC format, and so enjoy them in my PC and laptops.
When I found out about this Autoflac script I decided to try it, because I read in the page where I got it (http://www.legroom.net/software/autoflac), that I could create from a CD, the separate FLAC files and in addition a CUE file with information so I can make an exact copy of the CD by using a burning program like, say, NERO. (Well this is what I understood, at the end of the page when it says "Individual FLAC tracks VS Single FLAC Images, it also says: "As a result, AutoFLAC only supports ripping to individual tracks")
Well, this is my question: ¿Am I right?, hehehehe I mean: AutoFLAC really does this? Can I create the indicidual tracks along with a CUE image?. Or Am I confusing the CUE sheet with an image file?
I do anything that AutoFLAC is allowed to do, it's really amazing, but these are my little problems:
- When I go to the Extract Options and check the box [Rip to image] it doesn't do anything, it says: "script paused"
- When I disable the box [Rip to image], but enable [Create cue sheet], it works but it doesn't create the cue sheet!
I have read almost all the questions and answers in this forum, and I've fixed, changed, corrected every parameter and/or variable and still isn't working when I check the image box.
Hope you can help me! Thanks to everyone for their questions and their advices, it helped a lot!
AutoFLAC
Reply #308
Yes, you can create individual tracks plus use a CUE sheet to re-create the original disc in case it's ever lost or damages.  This is how I use AutoFLAC.
Unfortunately, AutoFLAC hasn't been updated for a while.  I started work on version 2.0 last year, but that got sidetracked by some other projects and I haven't returned to it yet.  It has some issues with current versions of EAC, although the problem you've described is new to me.  As a workaround, you can manually create a CUE sheet by clicking Action, Create CUE Sheet, Multiple WAV Files With Gaps... (Noncompliant).  This is exactly what AutoFLAC does to create the CUE sheet, though you'll also need to do some cleanup such as update the file paths and extensions in the CUE sheet.
This is inconvenient to be sure, and takes away much of the convenience of using a frontend like AutoFLAC, but unfortunately I can't offer much advice beyond that at this time.  If someone else has encountered this problem before maybe they can suggest something, but I've been using an updated/beta version of AutoFLAC for some time now so it'd be difficult to troubleshoot the 1.2 release.  The only other suggestion I can make is to try using EAC 0.95, since that's what AutoFLAC 1.2 was developed against.  You can also try some of the other EAC/FLAC frontends available through this board - there were quite a few available at the time I wrote AutoFLAC, but I'm not sure how up-to-date any of them are at this time either.
For what it's worth, the 2.0 update is still coming at some point, and I think everyone will be quite pleased with the new features and reliability updates, but it's still likely a ways off.  I'm hoping to at least get to the point where I can release a beta for people to start using, since it already works much better than 1.2 with recent versions of EAC and FLAC.
AutoFLAC
Reply #309
REACT? My short guide. If you use 64bit OS, copy "CHCP.com" file from your OS "system32" folder to "SysWOW64" folder before using REACT.
AutoFLAC
Reply #310
Ok. thanx for your help. I coud create the CUE file! thanks a lot!
I didn't tell you why I needed the CUE file, well, this is it: I have some friends in Australia and Europe, which are venezuelan (like me), but they wanted to hear some music from local artists. They can't find this artists' cds or music on internet (because these musicians are not international, pretty much local or native), and some of these music are very instrumental, so I decided to help them by sending the music and cds, but I wanted to do it right, without loss or low quality, using FLAC format.
Well, As I said before, I'm trying to do my best with English, hope you understand me, hehehehe. I'm Looking forward to try the new version of AUTOFLAC. Thanx a Lot Again! You made some "farway friends" of mine very pleased by making them hear their beloved home music. Bye
