Topic: command line usage of EAC? (Read 3695 times) previous topic - next topic
  • psm
Is it possible to use EAC (or a competing product but I like EAC) via command line only?  I don't mean config of LAME settings via command line but actually calling EAC and ripping tracks from CD to mp3 from command line.  With my HTPC frontend i'd like it to be as simple as insert CD, press "Copy" or whatever on the remote, and EAC is auto-launched, looks up track info on freedb and auto-picks the best title match, and then rips/encodes the files to hard disk, i.e. do exactly what EAC does except without having to have any user interaction.  I've been looking for a list of command line switches for EAC but haven't had much luck.  The encoding doesn't have to be anything special, it's not that that i'm concerned with/having trouble with, but rather getting EAC to work from the command line.  Even better would be a guide to command line use of EAC, but if someone can provide a link to the command line switches that would be more than enough to help alot.
  • HotshotGG
It's called the wiki: (edit: sorry I just re-read the post ignore).
http://wiki.hydrogenaudio.org/index.php?title=EAC_and_Lame
or you can use CDex 1.60, which is much easier for the average Joe IMO. If folks around here didn't need that comfort of that bit-perfect rip we wouldn't be in this situation.
I don't think it's possible to use EAC standalone command-line based.  It is with cdparanoia though. It's kind of like "half-assing" it if you ask me, but that's my opinion.  Half-GUI half-command line.
  • Last Edit: 04 June, 2006, 02:53:05 AM by HotshotGG
budding I.T professional
  • Never_Again
  • Members (Donating)
It is not. What you want is cdda2wav.
  • bhoar
Actually, it is possible, REACT has shown the way:  use AutoIT to automate EAC.  That's what I'm going to be working on this summer for another project.
-brendan
Hacking CD Robots & Autoloaders: http://hyperdiscs.pbwiki.com/
  • psm
'or you can use CDex 1.60, which is much easier for the average Joe IMO.'
Sounds great but are there command line switches for CDex either?  That's actually what I started with but got sick of it for lack of documentation on command line stuff.  Quick check shows the sourceforge forum continues to be down for CDex.
Oh and incidentally running winXP, not linux; cdda2wav doesn't appear to have been ported to it.  Thanks for the replies though.
  • M
... Oh and incidentally running winXP, not linux; cdda2wav doesn't appear to have been ported to it.  Thanks for the replies though.
Sure it has. You were probably searching for it by name, but cdda2wav is actually a part of Jörg Schilling's CDRTools suite. Current win32 compiles are available here.
    - M.
  • psm
Aha.  Thanks M but I spent the afternoon learning on AutoIT and that seems to be capable of everything I need.  Thanks for all the help.
  • Never_Again
bhoar sez:
>automate EAC.
That's scripting a GUI app, not command line usage. But since the OP found what he wanted, this is beyond the point. =)
  • bhoar
bhoar sez:
>automate EAC.
It can be used for CLI use on the console, if you modify the app type flag or use a wrapper, both of which are discussed in the AutoIT forums.  Just FYI.
-brendan
