Topic: Replaygain problem (Read 2018 times) previous topic - next topic
Replaygain problem
I'm having a problem with an MPC file.
When I use replaygain v0.84 like this:
"replaygain.exe --auto FileName.mpc" it says it can't decode the file..
In WinAMP the properties say that the tag is APE2, so the file shouldn't be corrupted.. or could it be ?
Replaygain problem
Make sure you have a copy of mppdec.exe in your path.
Replaygain problem
Lightning-fast response ! The path was indeed the problem, thanks !
