Topic: foo_run 0.3.7 (Read 452694 times) previous topic - next topic
  • The Link
foo_run 0.3.7
Reply #50
... But many of my files have ac3 which sounds better in Winamp than in foobar due to the plugin "Valex's AC3 decoder forWinamp". ...
What do you mean by "better"? Either a decoder is correct or it's not and then it's a bug. If you think about channel mixing options you can use these via various existing dsp components like channel mixer or athsurround in foobar, too.
  • Last Edit: 06 June, 2006, 01:55:32 PM by The Link
  • DruiD_ff
foo_run 0.3.7
Reply #51
I have added "Open with Winamp" and the path "F:\Programme\Audio_Tools\Winamp\winamp.exe".
But this opens Winamp without playing the file.
right string is "F:\Programme\Audio_Tools\Winamp\winamp.exe /a %_path%"
i'm dont have winamp installed, but think its work also for multiply files (you must set simultaneous runs > 1)
  • Last Edit: 06 June, 2006, 02:27:43 PM by DruiD_ff
  • Robbi
foo_run 0.3.7
Reply #52
I cannot explain this it's a feeling, but I will quote something from "Doom9's ForumAudio FAQ"
AC3 Playback Questions
7. Which software do I need to install for AC3 playback?
Download Valex's AC3filter audio filters and install. This filter is highly recommended over any other AC3 capable filter, it's very feature rich and best of all it's open source. Please read over his excellent documentation for a full understanding of all the capabilities of the AC3filter. Valex frequently updates the package so you might check Doom9's news or the AC3filter page often.
When I'm playing the file with foobars decoder the AC3’s volume seems lower during playback.
  • foosion
  • Moderator
foo_run 0.3.7
Reply #53
Are you using ReplayGain in foobar2000?
  • Robbi
foo_run 0.3.7
Reply #54
Yes with ReplayGain it's ok, but I have to do this for each track recorded from radio. It's a little bit unconfortable.
foo_run 0.3.7
Reply #55
does anyone have a script to run the tag & rename "open in tag&rename" context menu item, or any equivalent to open up containing folder in tag & rename?
foo_run 0.3.7
Reply #56
the file is corrupt for me when i download, any thoughts?
  • Cosmo
foo_run 0.3.7
Reply #57
If I Google for an artist with a space in their name, everything after the space is missing  ("Neil Young" becomes "Neil")
WinXP , Firefox 1.5.0.4
+ thanks!
  • Last Edit: 11 June, 2006, 02:57:36 AM by Cosmo
  • gfngfgf
foo_run 0.3.7
Reply #58
Replace "%artist%" with "$replace(%artist%,' ','+')".  Same goes for "%title%" in the "artist+title" preset.
  • roentgen
foo_run 0.3.7
Reply #59
I use this and it works fine
http://www.google.com/search?q=$replace(%artist%", ,+)
I'm slow today (I just woke up )
  • Last Edit: 11 June, 2006, 03:17:13 AM by roentgen
  • mimeryme
foo_run 0.3.7
Reply #60
For the google search, I just enclose the search command with quotation marks and it seems to work just fine.
  • Chaser
foo_run 0.3.7
Reply #61
Would it really be ugly? Since you don't have to add the root entries by default. Rather add them, if the user wishes so.
Ideal situation:
- have the run-menuitem, as it's now (added as standard, if the component is installed)
- have the run:"Item"-menuitems available in the commands list (however not added to the context-menu by standard)
What do you think?
  • Last Edit: 11 June, 2006, 09:07:08 AM by Chaser
foo_run 0.3.7
Reply #62
Any chance of adding a "open in preffered browser" option in the prefference menu ?
You're talking to my guy all wrong... It's the wrong tone. Say it again, and i'll stab you in the face with a soldering iron!
  • roentgen
foo_run 0.3.7
Reply #63
Set your preferred browser as default for opening http and remove 'explorer' from foo_run configuration.
Ex: 'explorer http://google.com' becomes simply 'http://google.com'
foo_run 0.3.7
Reply #64
Thanks for that bit of info roentgen, but i have portablefirefox and foobar2000 on my ipod and i'd like to use portablefirefox instead of ie.
* Sorry found a way to use ff instead of ie
  • Last Edit: 12 June, 2006, 01:17:17 AM by Tomacco_Boy
  • Florian
  • Moderator
foo_run 0.3.7
Reply #65
Ideal situation:
What do you think?
I'm currently not aware of a simple way to implement this, because it seems that creation of submenus via the slash character / is not possible with foobar2000 0.9 anymore.
Mp3tag - universal multi-format tag editor
http://www.mp3tag.de/en/
foo_run 0.3.7
Reply #66
Hey all, I could use some help with this plug-in, basically Im not to sure how to use it.
I have it installed and it shows up under my tools menu, so i can see all the options. I am just not sure how to apply the codes or does it work as a button? any help is appreciated.
thanks in advance
  • Florian
  • Moderator
foo_run 0.3.7
Reply #67
Just released foo_run 0.3.2 which is a maintenance release compiled with the new SDK.
  • Last Edit: 17 June, 2006, 04:51:06 PM by Florian
foo_run 0.3.7
Reply #68
This is the first time I've used this plugin, and I don't know how I ever lived before without it. I'm constantly having to lookup artist and album info from Metal-Archives, within the Firefox searchplugin, but now I can do it an even lazier way! I'm still exploring more settings and options with this great component.
For those interested searching on Metal-Archives I've just been playing around with these strings:
Artist:
http://www.metal-archives.com/search.php?string=$replace(%artist%, ,+)&type=band&sourceid=Mozilla-search
Album:
http://www.metal-archives.com/advanced.php?band_name=&band_status=&genre=&themes=&origin=0&location=&release_name=$replace(%album%, ,+)&exact_release=0&release_type=&label=&release_year=
Thanks again!
  • lss
foo_run 0.3.7
Reply #69
i like foo_run.dll and have writen a script to delete files on playing
 Usage:
   1. save the code below to foobar2000\scripts\delete_playing_file.vbs
       2. configure Run sevices (foo_run.dll), add Delete Playing File:
       3. assign a hotkey to this script, such as Ctrl + Del
   4. play music now, and use Ctrl + Del to delete ugly songs ^i^
' delete_playing_file.vbs
' version: 0.2.2
' update: 2006.6.15
'   -- Scripted by lifesinger
' Usage:
' 1. place this script in foobar2000\scripts
'  3. assign a hotkey to this script, such as Ctrl + Del
' 4. play music now, and use Ctrl + Del to delete ugly songs ^i^
' Home: [url=http://lifesinger.3322.org/]http://lifesinger.3322.org/[/url]
Option Explicit
Const beQuiet = False ' If you are annoyed with any confirmation, please change False to True
'Get commandline arguments, if none, show tips and quit
Dim objArgs, filepath
Set objArgs = WScript.Arguments
If objArgs.Count <> 1 Then
msgbox "delete_playing_file.vbs: delete song on playing. " & _
vbNewLine & vbNewLine & _
  "   -- by lifesinger. Jun 16th, 2006 " & _
  "Usage: delete_playing_file.vbs <file_path> " & _
vbNewLine, 64, "About"
Wscript.Quit
Else
filepath = objArgs(0)
End If
'**** DON'T EDIT BELOW ****
'-------------------------== CODE BEGIN ==----------------------------
Dim ScriptPath, fso, oShell, file_ext
ScriptPath = Left(WScript.ScriptFullName, (Len(WScript.ScriptFullName) - Len(WScript.ScriptName)))
Set oShell = CreateObject("WScript.Shell")
Set fso = CreateObject("Scripting.FileSystemObject")
If (fso.FileExists(filepath)) Then
file_ext  = LCase(Right(filepath, 3))
If file_ext = "cue" Then
oShell.Run Chr(34) & ScriptPath & "..\foobar2000.exe" & Chr(34) & "/command:Remove", 0, True  ' Remove from playlist
WScript.Sleep 100
oShell.Run Chr(34) & ScriptPath & "..\foobar2000.exe" & Chr(34) & " /next", 0, True ' play next song
Else
WScript.Sleep 100
'del file
delete_file filepath
'remove dead items
oShell.Run Chr(34) & ScriptPath & "..\foobar2000.exe" & Chr(34) & " /command:" & Chr(34) & "Remove dead items"& Chr(34), 0, True
End If
Else
If Not beQuiet Then
MsgBox filepath & " is not existed." & _
vbNewLine & _
"Run Services(foo_run.dll) maybe is configured improperly. " & _
vbnewline & _
"Please check it -_-", 48, "error"
End If
End If
Set oShell = Nothing
Set fso = Nothing
WScript.Quit
'-------------------------== CODE END ==----------------------------
Sub delete_file(filespec)
On Error Resume Next
Err.Clear
Dim r
r = vbNo
If Not beQuiet Then
r = MsgBox("This will delete 1 file:" & vbNewLine & vbNewLine & filespec & vbNewLine & vbNewLine & "Continue ?", vbYesNo + vbQuestion, "Warning")
End If
If r = vbYes Then
fso.DeleteFile filespec, True
Else
WScript.Quit
End If
If Err.Number <> 0 Then
' maybe filespec is the last file in the playlist
' so first stop it, and try delete again
oShell.Run Chr(34) & ScriptPath & "..\foobar2000.exe" & Chr(34) & " /stop", 0, True  ' stop
WScript.Sleep 100
Err.Clear
If Not beQuiet Then
MsgBox "Delete " & filespec & " failed." & vbNewLine & "I don't know why :(", 48, "error"
End If
End If
End If
On Error Goto 0
End Sub
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: added codebox[/size]
  • Last Edit: 17 June, 2006, 04:50:15 PM by Florian
  • RogerG
foo_run 0.3.7
Reply #70
Hi, I have a feature request:
Could you make it possible to pass the paths (or all variables) of several selected tracks as parameters to one single command!?
Best Regards!
  • Last Edit: 17 June, 2006, 10:25:46 PM by RogerG
  • Fifoxtasy
foo_run 0.3.7
Reply #71
cool plugin
is it possible to execute two or more commands in one foo_run service?
(e.g. executing a program and adding the files to a playlist with one click?)
  • saratoga
foo_run 0.3.7
Reply #72
You can use a batch file.  Basically, open a text file, type the commands you want to run, one per line.  Finally, save as file.cmd.  foo_run seems to work fine with them.
  • Fifoxtasy
foo_run 0.3.7
Reply #73
i tried that but couldn't achieve what i wanted...
i want to copy files from my external hard drive to my internal hd AND add the files to a specific playlist in foobar.
i made a batch file but couldn't figure out the right way to tell foobar with commandline to add a folder to a specific playlist. i checked the wiki for the commandline parameters, tried several different ways, but didn't succeed.  can anybody help me, please?
  • RogerG
foo_run 0.3.7
Reply #74
have you tried Playlist Bind (foo_playlist_bind)     "Synchronize playlist with contents of specified directory(es). "?
