Topic: iPod manager (Read 2286376 times) previous topic - next topic
0 Members and 10 Guests are viewing this topic.
[seemingly abandonware] iPod manager
Reply #2376
I'm using one of the new 16GB Ipod Nanos and am having troubling sending files to it. When I select "send to iPod," foobar converts the files from FLAC to MP3, but then I get a "Item not found" error when it attempts to transfer them to the iPod. Is there something I'm doing wrong?
Reply #2377
I've put up 0.6.5.6, let me know if it fixes it
Maybe wrong encoder settings? Compare them to the help page, or post them here.
Reply #2378
Hmm, I doublechecked my encoder settings, and they match the ones on the wiki perfectly. Also, I just tried transferring an  mp3 file and an mp4 video onto the Nano with foobar and received the same error message, which is actually "Object not Found," instead of "Item not found" like I mistakenly reported before.
I just got the Nano today, so this is my first time transferring anything onto it. Do I need to have iTunes installed for foodop to work? I have not installed it yet, and would rather not install it at all if I don't have to.
Reply #2379
Not really. I can get all the info whether the phone is locked or not at first plug in. Right after any command is run in foo_dop then info (except capacity) is gone.
OK. I don't know why it happens then but it seems harmless, it's probably one of those things I won't be able to fix without the device in hand..
Oh. You will need the iPod driver, it is part of Apple Mobile Device Support. You can just extract the iTunes installer until you find it, but if you do that you will have to install it manually. Alternatively just extract Apple Mobile Device Support and install that.
You will also need to create the "iPod_Control\iTunes\iTunes Library.itlp" folder, it isn't created by the component at the moment so that might be what it is complaining about.
Reply #2380
All right, it works great now. Thanks for the assistance!
Reply #2381
Definatly harmless
Reply #2384
I'm using foo_dop 0.6.5.6 (iPod nano 5G),
I wannna use sort order tag in the iPod database:
%titlesortorder%
%albumsortorder%
%albumartistsortorder%
%composersortorder%
%titlesortorder%
Please support it.
Reply #2385
Almost perfect. artist names are shown.
When playing track, arts were displayed.
However, album arts were not displayed.(like cover flow)
After the launch of iTunes, some files are changed.(Library.itdb etc...)
And, cover flow displayed.
I uploaded
adgjmp.dip.jp/up/iPod_Control_1.7z (before)
adgjmp.dip.jp/up/iPod_Control_2.7z (after itunes)
Reply #2386
I agree with what Ise is seeing, sorry hadn't had a chance to try out the new version musicmusic. Coverflow displays every song under an alphabet letter named "?" and without art. The music -> artist list displays them alphabetically but without cover art. However when I shuffle songs, they all display properly. Keep up the good work.
Reply #2387
Hey
Can this component embed artwork in the mp3 tags?  That are already on the ipod?  I have a iPod Touch 2nd Gen 3.0 firmware.  Thanks
Reply #2388
Please support it.
Yes it is planned at some point...
I uploaded
Thanks for the backups.
Please try version 0.6.5.7 - should hopefully help with those issues...
In case of any problems like this, dual backups like those are very helpful.. Thanks
If it's still the same with the new version, are the album fields showing correctly in 'File/iPod/Manage contents'? If so, does opening / closing iTunes make a difference?
Reply #2389
musicmusic, the last update you released fixed all of the artwork problems on my Nano 5G. Thanks for your tireless efforts!
Reply #2390
can fb2k work with  3.1 now???
i  can add muice to iphone by my tool, but i can not find the music from the artist page.
the sqlite bd change some tables.
Reply #2391
Good  Welcome
Next problem is play counts - they are using a new format for the Play Counts file. So any iPod_Control\iTunes folder backups with the Play Counts file with some plays etc. in it (and any OTGPlaylist files also) would help in adding support for those.
Note: iTunes and foo_dop remove the Play Counts file after updating the database, so you would need to have a look before using either of those. If you did various activities on the iPod (plays, skips, bookmarks, ratings..) that would also help.
Reply #2392
I'm using ipod nano 5G.
adgjmp.dip.jp/up/itunes1.7z
adgjmp.dip.jp/up/itunes2.7z (after play,skip,change rating...)
I hope that it useful.
Reply #2394
Aha great, seems to all make sense, thanks  So there should be support for reading back play counts in one of the next builds..
Reply #2395
It's one thing that you wrote this awesome component, but the prompt support when apple goes and changes everything up is incredible, thanks again. I don't use play counts so I'm pretty much back where I was and my ipod is working flawlessly.
Reply #2396
I'm experiencing kind of a weird bug.  I'm using foo_dop 0.6.5.7 with a non-jailbroken iPhone 3GS running OS 3.1.  I'm trying to add 3 Tiësto CDs.  I like to view my music by genre, and I have the genre for all my Tiësto CDs as "Electronic."  Under Electronic, all my other electronic music shows up, but Tiësto doesn't.  However, when I look under artists and songs, I see all my Tiësto music.  Why can't I see Tiësto under genre?  Is it because of the ë?
Reply #2397
Great, good to know it is working fine now, and you're welcome
Don't see why that should affect it. Checked for any extra spaces etc. in the genre name? Was it working before? If you send another song with ë in it's artist does that show up? Otherwise send me a backup of your iTunes_Control\iTunes folder (I think last person to send a backup used iPhone Explorer) and I can check if anything's wrong in there...
Reply #2398
everything seems to work great with my 3GS/OS3.1/dop/0.6.5.7. thank you so much for your work, musicmusic
i have one question that is not related to 3.1. when i add an album with various artists (compilation) it gets shown under compilation which is ok but all artists who are on this compilation are also under "aritsts". on my nano 4g compilations were <only> under compilations and the artists from this compilation were hidden from the artists list. this makes more sence to me as you have otherwise lots of artists in your list that contain only one track and that makes this list confusing. i guess this is not a foo_dop issue but can that be fixed/changed?
thanks
Reply #2399
sounds like you need to use the Album Artist tag
actually i'm not sure, i just checked my artist list and i have the same problem.....
