Topic: iPod manager (Read 2286072 times) previous topic - next topic
0 Members and 11 Guests are viewing this topic.
[seemingly abandonware] iPod manager
Reply #2125
Version 0.6.4.8 released. See changelog for details.
There have been some updates to the iTunes[C]DB format in preparation for "iPhone OS 3.0" support, please report back if there are any problems.
Reply #2126
Works with my iPod Touch (1st gen) and 3.0 software.
Reply #2127
Now works on Windows 7, however, still need iTunes to "touch" something, I assume to write the cbk file.
Almost there
Reply #2128
Works very well with the 3gs
Thank you !
Reply #2129
lokioki & Rapido, are you using iTunes in any way with the latest version of foo_dop?
Reply #2130
I only have it installed on my pc. Nothing else.
and problem found: it removed nothing from my ipod touch and added nothing when I tried (Tho Foobar showed that music was removed & added) but weird thing is that it added folder.jpg to every album (and every album where it added album art was the wrong album for that album art)
Reply #2131
foo_dop will allow me to copy music to my iPod Touch (2G with OS 3.0), I can load and view the music on my iPod in foobar, but it does not show up on the iPod itself, if I view my iPod in iTunes, edit the info on one of the track, then it all shows up on the iPod
Reply #2132
I can view the music in my iPod and it is there since Foobar can play it, but if I try to play it on my iPod Touch (1st gen + 3.0) it loads selected song for 2 secs and jumps back to the song list and no playback.
Reply #2133
Found a bug with version 0.6.4.8 in my iphone 3GS. MP3 which don't have any gapless info don't show any artwork and won't play. Adding dummy info allows for the artwork to be seen and the track to be played. Everything else working as expected, thanks for the speedy working in getting the iphone 3GS working.
Reply #2134
Hi, that is pretty much what the dummy info option is for (I'm sure it is on by default). iTunes will rescan any items without gapless data (and estimate it) but that will also trigger it into reloading the track's artwork, metadata etc. I don't know why that stopped the item from playing, maybe iTunes didn't like the file or something, doesn't seem worth worrying about at the moment..
Reply #2135
Yes, no big deal. I only have a handful of files without gapless data but they all stuck out. I think that the option to add dummy data is off by default, at least it is on my config and I don't remember changing it.
Thanks again for all the good work.
Reply #2136
You're right it was off by default, sorry.. I've changed that, thanks.
Reply #2137
Hi. I'm able to successfully transfer my folder.jpg artwork files (not embedded) to the iPod, and on the iPod I can view them just fine. Is there a way to make the foobar artwork reader view these images from the iPod, while I've got the iPod library loaded in foobar?
Reply #2138
Sorry, not possible at the moment, though requested a fair bit.
Reply #2139
hi to all,
0.6.4.8 freshly installed, but my iphone 3G under 3.0 OS is not detected at all, is it normal ?? only 3GS working ??
thanx by advance.
EDIT: ok, i figured i t out !!! MobileDevice Option not checked in settings (oops)
thanx musicmusic for the good work
Reply #2140
Thank you very much for replying.
Would it be reasonable to expect this feature at some point in the future? It would be so nice to be able to do it
Reply #2141
I am planning to look into it at some point since it has come up enough times, but I am still working on proper iPhone OS 3.0 support for now which has involved a fair bit of work to at least attempt to do it properly..
Reply #2142
That's great to hear, musicmusic.
The amount of work you have put and are still putting into this super foobar component is quite simply amazing.
Reply #2143
i have try to insert some data to the Library.itdb .
eg: insert into item(pid, media_kind, is_compilation, artwork_status,total_time_ms, relative_volume, title) values (4296214847442,1,0,0,281000,0,'test');
but failed, and the error messageis : no such function: icu_data_for_string
why?.......................
need icu??????
Reply #2144
How is that coming along btw? (3.0 support that is)
Reply #2145
need icu??????
That would relate to some of the triggers in the database. Do you see any trace of "icu_data_for_string" in iTunes?
It is at a state where it partly/mostly works, but some stuff still left to be done..
Reply #2146
need icu??????
Sweet, please say that's without the need to have iTunes installed
Reply #2147
I'm having the icu_data_for_string error as well. It is present on a few triggers of the SQLite databases, and I believe they are somewhat related to how international unicode characters are sorted in the iPod listings (e.g. to make no difference between an U and  Ü or Ú and so on)
I know little about sqlite, but is there a way we could embed our own custom user defined funcion with the same name, to avoid that problem ? It's obvious icu_data_for_string is defined somewhere else, which could be the iPod music player app or just iTunes.
Reply #2148
i have defined custom funcion in sqlite Library. and i can insert the databases now. but the Locations.itdb.cbk file is the trouble .
how to modified the file.  May the most important thing.
who can tell me some Information of Locations.itdb.cb file.
Reply #2149
Version 0.6.4.9 released. This adds iPhone/iPod touch OS 3.0 support.
Note: You must install both the zlib and updated MobileDeviceSign library to your foobar2000 folder for iPhone/iPod touch OS 3.0 support.
Please report any encountered problems in this thread.
