Has anyone tested to see if a WMA 10 Pro (with the 'plus' enhancements) 64k file created/ripped fom a CD with WMP 11 Beta will play on previous versions of WMA supporting apps...accurately? I am anxious to know if files I create will be play, with all the whatever kind of SBR-like enhancements MS may be using, on earlier media player so I know my users can play my audio files encoding with WMP 10 Pro+ at 64K. Older decoders may not be able to play the Plus version --or they do, it plays back as 22khz mono (at 64kbps, not mono, but still 22khz, so no PS-like stuff at 64kbps). I verify this with my PocketPC, which uses a first-gen WMA9pro decoder and plays 32kbps 44khz Stereo WMA10Pro+ files at 22khz mono. The same PocketPC plays WMA10Pro (not plus) correctly at the same bitrate. So basically, to ensure compatibility, only use WMA10Pro (not plus). But don't worry--try encoding something with WME (or any 3rd-party app which used the old WMA9Pro) at VBR Quality = 25, and tell me what you think. Trust me on this one edit:Do you have any evidence that WMA Plus is really using SBR and PS? If yes, please show me where you have that information from. Edit: If a Ferrari car is as fast as a Porsche car it doesn't mean that they use the same engine. "Speculative conclusion" is based on the following: 1. The PocketPC theorem (see above). 2. The name "Plus" as in AAC "Plus" 3. Artifacts, artifacts... 4. They tested this explicitly against HE-AAC, not even comparing it to any other established low-bitrate winner like atrac, tuned vorbis, etc... 5. Naa, that's about it, really. But it's compelling dontcha think? Don't worry--though I'm new to the forum, I'm not necessarily uneducated enough to compare codecs based on ... well, nothing. Nor would I say, for instance, that AAC and MP3 are the exact same thing just because LAME and Nero encode at the same speed on my system (Ferrari vs Porsche speed example)
