Topic: foo_uie_playlists_dropdown (Read 406622 times) previous topic - next topic
  • mixcherry
  • Developer
Reply #300
Middle click action configuration changed in latest version. Go to Preferences -> Display -> Columns UI extensions -> Playlists Dropdown -> General -> Middle click. Choose File/Remove Playlist.
http://foobar2000.pl/ :: unofficial polish forum
Reply #301
Thank for the quick answer buddy.
  • mixcherry
  • Developer
Reply #302
Version 0.7.5:
  • Added customizable icons for different playlists (see screenshot on [a href='index.php?showtopic=44703']first page[/a]). Built-in icons taken from Fugue Icons set.
Download: www.fb2k.org/show.php?id=142
  • 2E7AH
Reply #303
Lovely, thanks
  • Robertina
  • Banned
Reply #304
Version 0.7.5:
[/li][/list]
mixcherry,
thank you for adding customizable icons support!
Now I can mark some of my playlists as important and so on.
A very handy new feature!
Robertina.
  • 2E7AH
Reply #305
Saving custom icons preview is really nice, it's great
But, deleting custom icon preview would mean removing Playlist Dropdown, then adding the component again, right?
[edit] And overlay icons are unchangeable
Another thing: can custom icons be set dependent on playlist names: i.e. I set CD icon on playlist "Audio CD"; if I delete the playlist and then create again playlist "Audio CD" it's set to default icon
  • Last Edit: 07 September, 2009, 10:49:35 PM by 2E7AH
  • mixcherry
  • Developer
Reply #306
@Robertina, thank you.
"Custom icons preview" is just history of 10 last opened files. Currently there is no "easy" way to remove elements from history. I'll add option to clear history. Thanks for suggestion.
Changeable overlay icons are on my to-do list. Auto-assigned icons dependent on playlist name/lock/size is a great idea. It could be based on title formatting or simple filters (eg. "*CD* -> disc.png"). On the other hand, I'd like to keep this component simple and easy to use, so any suggestions to the way icons should be auto-assigned are welcome.
  • Last Edit: 07 September, 2009, 11:17:54 PM by mixcherry
  • 2E7AH
Reply #307
Maybe drop-down box with your 7 default icons, and up to last 10 custom icons, responding on input box for entering playlist filter like CUI filters it's columns i.e. "*missing" for selected warn.png; "*search*; *result*" for selected search.png...
It won't take much space and it will cover titleformatting if it's easy for implementing. Only that input box maybe isn't so much great suggestion
Or if you could implement something like fields are defined in CUI filter preferences, on the left side icon or image name and on the right titleformatting filter and their precedence as their shown order
  • Last Edit: 07 September, 2009, 11:30:38 PM by 2E7AH
  • SCOOTER_CS
Reply #308
how do you activate it? I am keen to use this plugin but I can't see how to turn on the dropdown list. I have the plugins from the stable package off foosion's site and am using Columns ui on foobar 0.91.
All you need is the latest Columns UI plugin (remember to activate it here: Preferences -> Display -> User interface module /reset/). Then, you can simply add my component to your toolbar (right-mouse-button on toolbar and Toolbars -> Playlists Dropdown) or add it as a panel - using Columns' Layout page (Preferences -> Display -> Columns UI -> Layout).
I can't activate plugin anyway.  I pushed "reset all" and "reset page" buttons everywhere. And here is no "User interface module".  My Screenshot
PLZ help me with screenshots. I use Foobar2000 v0.9.5.6.
  • marc2003
  • Developer
Reply #309
you need to download columns UI.
http://yuo.be/columns.php
  • SCOOTER_CS
Reply #310
  • mixcherry
  • Developer
Reply #311
Version 0.7.5.2:
  • More convenient icon chooser
  • Fixed XP/Classic Theme glitches
  • Added options to reset default icons / clear custom icons history
  • Improved performance
Download: www.fb2k.org/show.php?id=142 / foobar2000.org/components
  • 2E7AH
Reply #312
When option in "preferences > general > other > mouse wheel..." is unchecked, mouse wheel isn't scrolling in playlist dropdown and middle click isn't functioning properly (It may be a problem in CUI itself)
BTW, I think that instead "use middle mouse button to reorder playlist" more convenient behavior would be left click - hold and drag for reordering
  • mixcherry
  • Developer
Reply #313
This is intended. As the option says: if it's unchecked, you have to set focus on UI element to use mouse wheel (ie. click on it at first).
As for middle-click problem: I can't reproduce it. What exactly does not work?
Good idea - added to To-Do list.
________________
New version 0.7.6:
  • Code rewrite/clean-up/optimization (performance significantly improved on large number of playlists)
  • Changed color handling to be compatible with core functions like $blend() or $transition()
  • Replaced color fields (%_text% etc.) with function $color() taking appropriate parameters ($color(text) etc.)
  • Removed $offset_colour() function (using core $blend() now)
  • $calculate_blend_offset() function renamed to $blend_offset()
  • Replaced %incontrol% field with opposite %_list% field
  • Changed default title/style formatting strings
Please note that due to internal changes, title/style formatting strings will be reset after update to 0.7.6.
  • 2E7AH
Reply #314
Thanks for the new version and to-do
When the "mouse wheel" option is unchecked CUI panels don't work as it should (don't have focus but they scroll) but DUI elements do.
I first click on playlist dropdown - it opens (it should have focus) but the panel below playlist dropdown accepts mouse wheel action and scrolls. I can't use wheel when dropping files in playlist dropdown for playlist that aren't visible (max visible items)
I thought that middle click rearrangement also doesn't work in this case, but it works
  • Erich_2
Reply #315
Oh, I hate to loose all my settings!
Old setting (only in "Display"):
$if(%isactive%,$rgb(158,212,255,255,255,255)● %title%,
$if(%isplaying%,$rgb(255,128,64,255,255,255)√ %title%, %title%))
$if(%isactive%,' (visible'$if(%isplaying%,', '$rgb(255,128,64,255,255,255)'playing')')',$rgb(255,128,64,255,255,255)$if(%isplaying%,' (playing)'))
$tab(3)[ '('%lock%')']$tab(2)
$rgb(127,127,127,255,255,255)' ('%length%')')
Left picture: Visible (blue), playing (red); right picture: when visible and playing are the same.
Can sameone help me to get this result (or a similar) in  new version 0.7.6?
Erich
  • Last Edit: 27 September, 2009, 04:37:20 PM by Erich_2
  • mixcherry
  • Developer
Reply #316
Sorry for the inconvenience. If someone updated the component and wants to get the old settings, then (s)he must revert to older version of the component, copy the strings somewhere and then use them in new version (modifying them to match latest changes).
As for your question. Have you actually tried to use your formatting string in 0.7.6? Latest changes in the component shouldn't affect the code like yours and it should work without problems. I checked it and it looks exactly like in your pictures - is that what you wanted?
  • Erich_2
Reply #317
Oh, easy...
I was impressed by your "Replaced color fields (%_text% etc.) with function $color() taking appropriate parameters ($color(text) etc.)"
So I thought there where so much changes to do with my $color declaration.
Thank you, this was what I wanted.
Erich
  • Robertina
  • Banned
Reply #318
mixcherry,
my main CUI layout simply consists of foo_uie_playlists_dropdown, Playlist tabs and Columns Playlist.
If I choose a playlist by clicking on a playlist's tab I am able to see the actually marked track (not playing) in this playlist because it is focused.
Choosing a playlist with Playlists Dropdown the focus remains on your component without the possibility to identify the marked track(s) in this playlist.
Could you please consider to change this behaviour or has it something to do with my configuration?
f2k 0.9.6.9, Columns UI 0.3.8.0, Playlists Dropdown 0.7.6
  • mixcherry
  • Developer
Reply #319
I can see highlighted items even when Playlists Dropdown is focused (you can see it on my [a href='index.php?act=findpost&pid=393106']screenshot[/a] - notice that 'Something' has gray background). Do you use XP/Vista theming or 'classic' windows style? I've tried it with classic style and still highlighted (but not playing) items have grayed background even if my component is focused.
I can't reproduce your problem (or I don't fully understand what do you mean). 'Auto-UNfocus' on playlist select is not an option (it's against UI guidelines). You can try unfocusing Playlists Dropdown by hitting enter or escape key after selecting playlist.
  • Robertina
  • Banned
Reply #320
Something must had been wrong with my PC-/foobar-configuration.
I regained the old behaviour by performing a system restore and cannot reproduce the described situation any more.
Thank you for your investigation, also for your hint to press enter or escape.
  • KeyLogic
Reply #321
Hi.
Question: is there a way to access the dropdown playlist via a button? I want to have it next to my other media buttons to save space.
  • mixcherry
  • Developer
Reply #322
Hi.
No, there is no such option.
  • wojtek
Reply #323
So the question remains - is it possible to add such? ;>
Reply #324
Thanks for the sweet plugin! Would it be possible to add an %album_count% function or whatever you want to call it that would count the number of albums in the playlist?
Also, anyone made some cool custom icons for this or know where I can get some?
  • Last Edit: 04 January, 2010, 03:39:42 AM by shiphtfour
