Topic: foo_uie_playlists_dropdown (Read 406650 times) previous topic - next topic
  • mixcherry
  • Developer
BTW I recommend a reset button to return to the default settings and code.
Doesn't the Reset page button (on my plugin's preferences page) do exactly what you want? It works here...
http://foobar2000.pl/ :: unofficial polish forum
  • deagle32
Hm,
I am using Columns UI and the dropdown option isn't available on either method ...i'm not sure why.
Here's a screenshot of right clicking.
Any ideas?
moderation: please refrain from inlining images larger than roughly 800x600 and 80KB. please use thumbnails and/or links for large pictures instead.
  • Last Edit: 18 May, 2006, 08:31:10 AM by foosion
  • deagle32
Okay, I fixed it
I had the pre-beta version of Columns UI, it now works with the newest columns ui plugin.
Thanks for having a look.
Cheers!
Hm,
Any ideas?
My apologies~ I won't do it again.
  • Squeller
You're probably right.
Another recommendation: This plugin seems to be the only way to display the currently used playlist. I use it on my notebook with big fonts (36 pt). Would you please allow to change the background color? (I generally use dark backgrounds).
b) Would you implement a way to center text?
  • mixcherry
  • Developer
Update to version 0.5.5:
  • 20060519 (v0.5.5)
    • Added custom-sorting
    • Added customizable colors
    • Added top/right/bottom/left padding
    • Added Rename and Preferences... context-menu items
You'll find download in the first post.
I've added this to my to-do list, though I don't know how hard it would be to implement... (so it can take some time)
[EDIT]Please re-download this version: 1). Fixed problem with removing playlist. 2). Auto-switch to newly created playlist.[/EDIT]
  • Last Edit: 18 May, 2006, 11:55:26 PM by mixcherry
  • 81x
Reply #30
Hi mixcherry
Very nice plugin, thanks
Couple of requests if you don't mind.
1. when creating a new playlist from context menu, focus the new playlist.
2. drag and drop support, create a new playlist and do the whole compare files for identical string thing to
generate playlist name, like with playlist switcher/playlist tabs.
Also with latest build (0.5.5), removing playlists from context menu doesn't work.
Thanks again
  • 81x
Working fine now. And thanks for the auto-switch
  • Last Edit: 19 May, 2006, 01:05:53 AM by 81x
I love this plugin, the only thing I'm missing is the ability to display the length of the playlist.
  • mixcherry
  • Developer
Reply #33
drag and drop support, create a new playlist and do the whole compare files for identical string thing to generate playlist name, like with playlist switcher/playlist tabs.
I'm working on it.
I've just uploaded new version (0.5.5.1) which supports %length% field
  • Squeller
Reply #34
Many thanks, mixcherry, esp. for the %length% field. Centering and background is no more important for me, I like the style I chose now.
I use it only for showing which Playlist is active...
  • NinjaN
Reply #35
Hello mixcherry,
Thank you very much for this plugin!
I just have one suggestion for you:
Could you make a button in the preferences which allows us to use the active (showing) playlist as the source for the next song to play?
As it is now, after I switch playlists, the next song being played always comes from the "playing" playlist.
I would like it so that the next song after playlist switching comes from the active playlist...
Or can this already be done? I didn't find any way to achieve this yet...
Whatever, great plugin!
  • Last Edit: 19 May, 2006, 06:12:16 AM by NinjaN
IDE? This is S-ATA!
  • gfngfgf
Reply #36
Have you tried "Playback -> Playback follows cursor" from the main menu?
  • NinjaN
Reply #37
No, didn't try that yet...
But anyway, I am almost always in "Shuffle-Mode", so that is not exactly what I want.
I'd like foobar to autmatically switch to the active playlist and select one song randomly...
IDE? This is S-ATA!
  • mixcherry
  • Developer
Reply #38
You're welcome!
Unfortunately, I don't think that this feature would be suitable for my plugin, which is designed for displaying some data and is not related to playback/playback order/shuffle in any kind.
I think that this should be rather some kind of 'internal' option, not maintained by any plugin, but by core. So you should nag main foobar2000 developers instead
  • Last Edit: 19 May, 2006, 12:23:46 PM by mixcherry
  • Zimdgre
  • Banned
Reply #39
my screenshot with foo_fullscreen, foo_notaskbar, foo_ui_columns and foo_uie_playlists_dropdown
F : fullscreen/normal
P : play/pause
S : stop
when doubleclick the statusbar : toggle menubar
I've made fb2k a system service running in no other process but svchost.exe. no alt+tab Icon showing, no trayicon showing, no taskbar showing, and the only way to evoke fb2k is to press a certain key on my programmable keyboard.
That's pretty cool to me. Any comments, please let me know.
Reply #40
I'm working on it.
Thanks for adding the %length%
  • 4nt1
Reply #41
Also is it possible to remove the outer frame like most other components, ie so grey, sunken and none..
hopefully this is not too hard too implement
  • Lyx
Reply #42
Ahem - this is just a dropdown-menu plugin! Don't make the preferences look like Columns UI.
  • NinjaN
Reply #43
I take everything back!
The solution by gfngfgf actually works exactly like I wanted!
No need for anything from my side, I'm happy now!
IDE? This is S-ATA!
  • Zimdgre
  • Banned
Reply #44
I like this plugin, but it'll be better if it displays Active as an A, Ready-only as an L(for Locked), and playing as a P.
  • mixcherry
  • Developer
Reply #45
You can change it using formatting strings (on my plugin's preferences page). For example, if you'd like to change the "playing" and "active" indicators, you have to change this line:
$if(%is_active%,' (active'$if(%is_playing%,', playing')')',$if(%is_playing%,' (playing)'))
into something like this:
$if(%is_active%,' (A'$if(%is_playing%,', P')')',$if(%is_playing%,' (P)'))
As for name of locks, you have to change this line:
$tab(3)[ '('%playlist_lock%')']$tab(2)
into:
$tab(3)[ '('$abbr(%playlist_lock%)')']$tab(2)
which simply gives you abbreviation of the name of the lock. If you'd like to display only the letter L whenever the playlist is locked, you can use this code:
$if(%playlist_lock%,L)
You can do *anything* with the format of displayed data. That's what 'formatting strings' are for  Search the forums for formatting strings, title formatting, etc. Look at the file "titleformat_help.html" in your foobar2000 folder.
  • deagle32
Reply #46
hi mixcherry, this plugin is GREAT ...I have many playlists and it just makes changing between them so much easier (especially since panel stack hasn't been ported for 0.9.1)
Fantastic work!
  • mimeryme
Reply #47
Thanks for this plugin mixcherry!
I too was looking for a way to display the active playlist and this fits the bill nicely.
  • Zimdgre
  • Banned
Reply #48
Got it and done, thanks mixcherry.
  • deagle32
Reply #49
would it be possible to display the total filesize of the playlist?  I can't seem to find a tag that does this.
thanks.
